STAX srm-007t/tII/ta ƫѹµ÷Õû·½·¨
תµ½STAXÇø£¬ÔÙ·¢Ò»´Î£¬¸øÓÐÐèÒªµÄÈË¡£
¹¤¾ß(Tools)£º
ÍòÓõç±í(voltmeter)£¬Æ½Í·Æð×Ó£¨flathead screwdriver£©£¬¾øÔµÊÖÌ×£¨insulating gloves£©¡£
²½Öè(Steps)£º
¾ßÌåµÄµ÷Õû·½Ê½£¬ÊǰÑÒÔÏÂËùÓвâÁ¿Öµ¶¼µ÷Õûµ½¡À0V¡£
( All adjustments are to ¡À0 volts. )
ͼÖкìȦ¼´Îª²âÁ¿µã¡£
( Little red circles are testpoints in the picture. )
1.½«ÍòÓõç±í½ÓÏßÖù½Óµ½TP1µÄÁ½¸ö²âÁ¿µã£¬µ÷ÕûTVR3Ö±ÖÁÍòÓõç±íÏÔʾΪ¡À0V¡£
( Put voltmeter leads between testpoints of TP1 and adjust TVR3 pot to ¡À0 volts. )
2.½«ÍòÓõç±í½ÓÏßÖù½Óµ½TP2µÄÁ½¸ö²âÁ¿µã£¬µ÷ÕûTVR4Ö±ÖÁÍòÓõç±íÏÔʾΪ¡À0V¡£
( Put voltmeter leads between testpoints of TP2 and adjust TVR4 pot to ¡À0 volts. )
3.½«ÍòÓõç±í½ÓÏßÖùÒ»Ö»½Óµ½TP1µÄÒ»¸ö²âÁ¿µã£¬ÁíÒ»Ö»½Óµ½TP2µÄ²âÁ¿µã£¬µ÷ÕûTVR1Ö±ÖÁÍòÓõç±íÏÔʾΪ¡À0V¡£
( Put one voltmeter lead to TP1 the other to TP2 and adjust TVR1 to ¡À0 volts. )
4.½«ÍòÓõç±í½ÓÏßÖùÒ»Ö»½Óµ½TP1µÄÒ»¸ö²âÁ¿µã£¬ÁíÒ»Ö»½ÓµØ£¬µ÷ÕûTVR2Ö±ÖÁÍòÓõç±íÏÔʾΪ¡À0V¡£
( Put one voltmeter lead to TP1 the other to ground and adjust TVR2 to ¡À0 volts. )
ÖØ¸´ÒÔÉϲ½ÖèÓÚÁíÒ»ÉùµÀ¡£
( Repeat procedure for other channel. )
×¢Ò⣨Caution£©£º
1.ËùÓÐstax¶ú·Å¾ùΪ¸ßѹÄÚ²ØÊ½£¬Çë×¢Òⰲȫ£¬×žøÔµÊÖÌ×Íê³ÉÒÔÉϲÙ×÷¡£
( All Stax amp are high voltage inside , please caution , wear insulating gloves.£©
2.°²È«Æð¼û£¬¿ªÊ¼²âÁ¿Ê±£¬Çë°ÑÍòÓõç±íµµÎ»´òµ½×î´óÁ¿³Ì£¬stax¶ú·ÅÄÚ²¿·åÖµµçѹ¿É´ïµ½630V¡£
( Safety first , start the measurement , please put the voltmeter to the maximum range . Stax amp internal peak voltage can reach 630V . )
3.ÇëʹÓøߵµµç±í¡£
( Please use high-quality voltmeter . )
