¼¸¿îÖ÷ÒªµÄCelestionÀ®°È½éÉÜ
mmzchoa8rh
2006-5-11 11:01:00
1¡¢Vintage 30£º
Vintage 30ÊDzÉÓÃÁËÏÖ´úµÄ¿Æ¼¼ÊÖ¶ÎÖÆ×÷µÄ¾ßÓÐÔçÆÚCelestionÀ®°ÈÒôÉ«ÌØµãµÄÐͺš£70Äê´ú¿ªÊ¼£¬¼ªËûÊÖÏ£Íû¼ªËûÒôÏäÄܹ»·¢³ö¸ü¼ÓÓÐÁ¦µÄÒôÉ«£¬ËûÃÇÏ£ÍûCelestion BlueÐͺŵÄÀ®°ÈÄܹ»¸ü¼ÓÓÐÁ¦¡£ÓÚÊÇÔÚ80Äê´úÔçÆÚ£¬Celestion²ÉÓÃÁ˼¤¹â¶àÆÕÀÕ¸ÉÉæ²âÁ¿·¨¶ÔCelestion BlueÐͺŽøÐÐÁË·ÖÎö£¬È»ºó²ÉÓÃÁ˸üÏȽøµÄ¼¼ÊõÀ´¸´ÖÆ£¬²¢ÇÒʹµÃËü¸ü¾ßÓÐÁ¦Á¿¡£ÕâÑùµÄ½á¹û¾ÍÊǵ®ÉúÁ˾­µäµÄVintage 30À®°È£¬Ëü±Èͬ¹¦ÂÊµÄÆäËûÀ®°È¾ßÓм¸ºõÁ½±¶µÄÄÜÁ¿¡£Äܹ»ÇáÒ׵IJúÉú¹ýÔØÒôÉ«¡£½ôÅòµÄµÍƵ¡¢·ÊºñµÄÖÐÆµÒÔ¼°¹â»ª¡¢³äÂú·ºÒôµÄ¸ßƵÊÇVintage 30³ÉΪÁË׿ԽµÄ4X12ÏäÌåÉè¼ÆµÄÀ®°È¡£µ±È»ËüÒ²ÊÊºÏÆäËüÏäÌåµÄÅäÖá£
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
General specifications
Nominal diameter 12", 305mm
Power Rating 60W
Nominal impedance 8¦¸ and 16¦¸
Sensitivity 100dB
Chassis type Pressed steel
Voice coil diameter 1.75", 44.5mm
Voice coil material Round copper
Magnet type Ceramic Magnet weight 50oz, 1.42kg
Frequency range 70-5000Hz
Resonance frequency, Fs 75Hz
DC resistance, Re 7.3¦¸ & 12.9¦¸
Mounting Information
Diameter 12.2", 309mm
Overall depth 5.3", 135mm
Magnet structure diameter 6.1", 156mm
Cut-out diameter 11.1", 283mm
Mounting slot dimensions 0.31", 7.9mm Ø
Number of mounting slots 4
Mounting slot PCD 11.7", 297mm
Unit weight 10.4lb, 4.7kg
2¡¢G12M ¡®Greenback¡¯
ÕâÊÇCelestionµÚÒ»¸ö²ÉÓÃÁËÌÕ´É´ÅÌå½á¹¹µÄÀ®°ÈÐͺš£ºÍÆÕͨµÄÂÁÄøîܺϽðÐͺÅÏà±È£¬Ëü¿ÉÒÔÓøüСµÄÏßȦÀ´ÊµÏÖ¸ü´óµÄ´ÅͨÁ¿¡£ÕâÑù¾Í¿ÉÒÔ°´×é¸ü´ó¹¦ÂÊÒôÏäµÄÐèÇó¡£µ±È»ÌÕ´É´ÅÌå½á¹¹µÄÀ®°È»áÓÐËü×Ô¼º¶ÀÌØµÄÒôÉ«ÌØµã¡£Greenback¾ßÓеĴó¹¦ÂʺÍÒôÉ«ÌØµãÊǷdz£Êʺϵç×Ó¹ÜÒôÏä¹ýÔØµÄÐèÇóµÄ¡£
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
Power Rating 25W
Sensitivity 98dB
Magnet type Ceramic
Magnet weight 35oz, 0.99kg
Frequency range 75-5000Hz
DC resistance, Re 6.7¦¸ & 13.1¦¸
Overall depth 5.1", 130mm
Magnet structure diameter 5.9", 150mm
Unit weight 7.9lb, 3.6kg
3¡¢G12T-75£º
·¢ÐÐÓÚ70Äê´úÄ©µÄG12T-75ÊÇеĴó¹¦ÂÊÀ®°ÈµÄÏÈÇý¡£ËüÊÇԭʼµÄCelestion G12MÑÝ»¯µÄÖÕ¼«²úÎËü¾ßÓй¥»÷ÐԺͼâÈñµÄÒôÉ«ÌØµã£¬±»¹ã·ºÔËÓÃÔÚ¸÷ÖÖÏäÌåÉè¼ÆÖУ¬±ÈÈç¾­µäµÄMarshall 1960¡£ËüÊÇÏúÁ¿×î¸ßµÄ¼ªËûÀ®°È£¬ÒòΪËü¾ßÓкܺõÄͨÓÃÐÔ£¬Äܹ»ÔÚ´óÒôÁ¿ÏÂÒ²±£³ÖºÜºÃµÄÇ峺ÒôÉ«£¬µ«ÊÇÔÚÒ¡¹öºÍ½ðÊôÀÖÖÐҲͬÑùÄܹ»ÏÔʾÆäÍþÁ¦£¬Ëü¾ßÓÐÇ¿´óµÄµÍƵ¡¢¿íËɵÄÖÐÆµºÍÃ÷ÁÁµÄ¸ßƵ¡£
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
4¡¢Classic Lead 80£º
Classic LeadÊÇÒ»¿î²ÉÓÃпƼ¼ËùÄÜ×÷µ½µÄÒôÉ«ÌØµãµÄµäÐÍ´ú±í¡£70Äê´úÄ©ÆÚ£¬Ò»ÖÖеIJ£Á§ÏËάÏßȦ³öÏÖÁË£¬Äܹ»³ÐÊܸܺߵÄζȡ£Ëü±»ÔËÓÃÔÚClassic Lead 80ÍßÀ®°ÈÉÏ¡£Ëü¿ÉÒÔ¸Äɯ׶ÌåµÄÕð¶¯ÒÔ¼°Ó°Ïì×¶ÌåµÄË¥ÍÇ¡£Í¨¹ý¼«¶ËµÄ²âÊԺͳÖÐøÌý¾õ²âÊÔ£¬ÎÒÃÇÌôÑ¡³öÁË×îÊʺϵIJ£Á§ÏËάÏßȦ£¬ÒÔ»ñµÃ×î¼ÑµÄÒôÉ«ÌØµã¡£½ñÌ죬Classic LeadÀ®°È·Ç³£Êܵ½ÄÇЩϲ»¶ÑÝ×à¿ìËÙ¡¢ÓÐÁ¦¡¢ÇåÎúµÄ¶À×༪ËûÊÖµÄϲ°®£¬ÒòΪ¼´Ê¹ÔÚ´óÊ§Õæ×´Ì¬£¬Ã¿Ò»¸öÒô·û»¹ÊÇ¿ÉÒÔ±»ÇåÎúµÄ±íÏÖ³öÀ´¡£Classic LeadÀ®°ÈµÄÒôɫҲÊDZȽÏCleanµÄ£¬ÒôÉ«·Ç³£ÇåÎúºÍ´¿¾»£¬·Ç³£ÊʺÏÁ÷³©¶ø¶¯¸ÐµÄÑÝ×à¡£
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
Power Rating 80W
Sensitivity 99dB
Voice coil material Rounded copper
Magnet type Ceramic
Frequency range 80-5000Hz
Resonance frequency, Fs 85Hz
DC resistance, Re 6.9¦¸ & 11.8¦¸
5¡¢G12H 30£º
ÕâÊÇ10ÄêÒÔÇ°ÖØÐ·¢ÐеÄ70ÖÜÄê¼ÍÄî°æÐͺţ¬ËüÔÙÏÖÁË60-70Äê´úµÄ¾­µäÒ¡¹öÀÖ¶ÓµÄÒôÉ«¡£Ëü¾ßÓгÁÖØµÄ´ÅÌå¹¹Ô죬ËüÈÚºÏÁËVintage 30ºÍGreenbackµÄһЩÒôÉ«ÌØµã£¬Äܹ»²úÉúºñʵ¡¢ÎÂů¡¢Å¨³íµÄÒôÉ«£¬Í¬Ê±»¹±£³Ö½ô±ÁÓÐÁ¦µÄµÍƵ¡£µ±ÑÝ×àCleanÒôÉ«µÄʱºò£¬Äܹ»±£³ÖºÜºÃµÄ¸É¾»ÒôÉ«ºÍÒôÀÖÐÔ£¬¶øÇÒ²»´Ì¶ú¡£¶ÔÓÚ´¥ÏҵĶ¯Ì¬Äܹ»ºÜºÃµÄ·´Ó³£¬²¢ÇÒ¶ÔÓÚÒô·û³ÖÐø²¿·ÖµÄ·ºÒôÓÐÁ¼ºÃµÄ±íÏÖ¡£
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
°´´ËÔÚд°¿Úä¯ÀÀͼƬ
Power Rating 30W
Sensitivity 100dB
Magnet type Ceramic
