»ìÏì֪ʶ »ìÏì²ÎÊý »ìÏìÀàÐÍ
Reverb Hall 1 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time2.8s0.3-30.0s»ìÏìʱ¼ä High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ Diffusion60-10»ìÏìÀ©É¢ Ini.Dly40.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF7.0kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz-8KHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Reverb Hall 2 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏìµÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷ Rev.Time3.2s0.3-30.0s»ìÏìʱ¼ä High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ Diffusion80-10»ìÏìÀ©É¢ Ini.Dly38ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF6.3kHz1.0kHz-16.0kHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Reverb Room 1 Ä£ÄâË®Äàǽ±Ú·¿¼ä²úÉú´óÁ¿»ØÉùµÄ»ìÏì *Ϊ¹ÄÒôÉ«Ôö¼ÓÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷ Rev.Time1.4s0.3-30s»ìÏìʱ¼ä High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ Diffusion70-10»ìÏìÀ©É¢ Ini.Dly5.0ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Reverb Room 2 Room1µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷ Rev.Time1.8s0.3-30s»ìÏìʱ¼ä High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ Diffusion60-10»ìÏìÀ©É¢ Ini.Dly17ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPF80HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Reverb STAGE ÀàËÆ³ÌÐò1£¬µ«¸üÃ÷ÁÁ£¬¸üÓÐÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time3.4s0.3-30s»ìÏìʱ¼ä High Ratio0.90.1-1.0¸ßƵ˥¼õÂÊ Diffusion80-10»ìÏìÀ©É¢ Ini.Dly45ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPF70HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Reverb Plate Ä£Äâ¸ÖÅÌÀà»ìÏìϵͳ£¬ÊÊÓ¦ÐÔºÜ¹ã£¬ÌØ±ðÊÇÈËÉù£¬¹ÄºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time2.4s0.3-30s»ìÏìʱ¼ä High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ Diffusion80-10»ìÏìÀ©É¢ Ini.Dly16ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF8kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Rev Ambience 1 Ä£ÄâÀÖÆ÷ÖÜΧµÄ»ìÏ죬ÓÃÓÚÈËÉù£¬ºÏ³ªºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time1.2s0.3-30s»ìÏìʱ¼ä High Ratio10.1-1.0¸ßƵ˥¼õÂÊ Diffusion80-10»ìÏìÀ©É¢ Ini.Dly19ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPF45HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Rev Ambience 2 ³ÌÐò7µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time0.8s0.3-30s»ìÏìʱ¼ä High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ Diffusion80-10»ìÏìÀ©É¢ Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPF56HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Rev Live Room 1 Ä£ÄâÏÖ³¡·¿¼äµÄ»ìÏì,»ìÏì·´Éä±ÈRecerm RoomÇ¿
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time2.4s0.3-30s»ìÏìʱ¼ä High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ Diffusion70-10»ìÏìÀ©É¢ Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF7kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Rev Live Room 2 ³ÌÐò9µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time2.2s0.3-30.0s»ìÏìʱ¼ä High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ Diffusion60-10»ìÏìÀ©É¢ Ini.Dly12.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF4.0kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Reverb Vocal ÓÃÓÚÈËÉù,ºÏ³ªµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Rev.Time1.9s0.3-30.0s»ìÏìʱ¼ä High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ Diffusion60-10»ìÏìÀ©É¢ Ini.Dly16ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF12kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPF100HzTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Chorus Reverb Á¢ÌåÉùºÏ³ªºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È Mod.Depth40%0-100%µ÷ÖÆÉî¶È Mod.Dly1.3ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä Rev.Time2.4s0.3-30s»ìÏìʱ¼ä High Ratio0.70.1-1¸ßƵ˥¼õÂÊ Diffusion70-10»ìÏìÀ©É¢ Ini.Dly30ms0.1-139msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF6.3kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPFTHRUTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Rev.Depth24%0-100%»ìÏìÉî¶È Flange Reverb Á¢ÌåÉùÆ®ºöºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷ Mod.Freq1.4Hz0.1-20Hzµ÷ÖÆËÙ¶È Mod.Depth22%0-100%µ÷ÖÆÉî¶È FB Gain+45%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÆ®ºöµÄÔöÒæ Mod.Dly13ms0-15.5msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä Rev.Time2.4s0.3-30s»ìÏìʱ¼ä Diffusion80-10»ìÏìÀ©É¢ Ini.Dly26ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä LPF4.5kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ HPF45HzTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ Rev.Depth30%0-100%»ìÏìÉî¶È Delay L-C-R ×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷ Dly L250ms0.1-661ms×óÉùµÀÑÓ³Ùʱ¼ä Dly R500ms0.1-661msÓÒÉùµÀÑÓ³Ùʱ¼ä Dly C125ms0.1-661msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä Level C700-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿ FB.Dly500ms0.1-661msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä FB.Gain+40%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ Monodly-Chorus µ¥ÉùµÀÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Delay400ms0.1-618msÑÓ³Ùʱ¼ä FB.Gain+32%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ Mod.Freq0.4Hz0.1-20HzºÏ³ªµ÷ÖÆËÙ¶È Mod.Depth10%0-100%ºÏ³ªµ÷ÖÆÉî¶È Mod.Dly0.1Ms0-24msºÏ³ª¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä Chrous-Dly L C R Á¢ÌåÉùºÏ³ªºó½Ó×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È Mod.Depth24%0-100%µ÷ÖÆÉî¶È Mod.Dly5.9ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä Dly L26.4ms0.1-618ms×óÉùµÀÑÓ³Ùʱ¼ä Dly R33.2ms0.1-618msÓÒÉùµÀÑÓ³Ùʱ¼ä Dly C13.1ms0.1-618msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä Level C600-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿ FB.Dly40.5ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä FB.Gain-48%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ High Ratio0.10.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ Delay-Chrous Á½¼¶ÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Dly 1250ms0.1-618ms1 ÑÓ³Ùʱ¼ä Dly 2500ms0.1-618ms2 ÑÓ³Ùʱ¼ä FB.Dly500ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä FB.Gain+33%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ High Ratio0.70.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ Mod.Freq1.2Hz0.1-20Hzµ÷ÖÆËÙ¶È Mod.Depth25%0-100%µ÷ÖÆÉî¶È Mod.Dly10ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä Karaoke Echo 1 ¿¨ÀOKЧ¹û
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Dly L220ms0.1-332ms×óÉùµÀÑÓ³Ùʱ¼ä FB.Gain L+40%-99--+99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ Dly R223ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä FB.Gain R+40%-99--+99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ High Ratio0.40.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ Karaoke Echo 2 ¿¨ÀOKЧ¹û
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Dly L220ms0.1-332ms×óÉùµÀÑÓ³Ùʱ¼ä FB.Gain L+44%-99--+99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ Dly R180ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä FB.Gain R-55%-99--+99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ High Ratio0.20.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ ST.Pitch Change Á½²¿·ÖµÄÁ¢ÌåÉùÒô¸ß±ä»¯Æ÷£¬ÓжÀÁ¢µÄÉùÏñ²ÎÊý
²ÎÊýÊýÖµ·¶Î§ËµÃ÷Pitch0-12--+12Òô¸ß´Öµ÷ Fine 1+10-50--+50±ä»¯Æ÷1µÄÒô¸ß΢µ÷ Fine 2-10-50--+50±ä»¯Æ÷2µÄÒô¸ß΢µ÷ Out.Lvl 1+100-100--+100±ä»¯Æ÷1µÄÊä³öÒôÁ¿ Out.Lvl 2+100-100--+100±ä»¯Æ÷2µÄÊä³öÒôÁ¿ Pan 1L100L100--R100±ä»¯Æ÷1µÄÉùÏñ Pan 2R100L100--R100±ä»¯Æ÷2µÄÉùÏñ FB.Gain 1+28%-99--+99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷1µÄÔöÒæ FB.Gain 2-28%-99--+99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷2µÄÔöÒæ FB.Dly25ms0.1-223msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
"MALE VOCAL"ÄÐÐÔÉùÒô,Ç¿µ÷ÖеÍÒôG+3db+1db+2db F280Hz1.8KHz5KHz Q3oct3/4octÆÂ×´
"FEMALEVOCAL"Å®ÐÔÉùÒô,Ç¿µ÷¸ßÖÐÒôG-1db+1db+2db F220Hz2KHz7KHz QÆÂ×´3oct3oct CHROUSÈËÉùºÏ³ªG+1db+2db+5db F280Hz1.4KHz5.6KHz Q3oct3/2octÆÂ×´
"MALE ANNOUCER"ÄÐÐÔ½²»°,Ôö¼ÓÇåÎú¶ÈG-3db+2db-4db F100Hz4.5KHz7KHz Q1oct3octÆÂ×´
"FEMALEANNOUCER"Å®ÐÔ½²»°,Ç¿µ÷ÖÐÒôG-3db+3db-1db F200Hz2KHz8KHz QÆÂ×´1octÆÂ×´
"TELEPHONEVOICE"Ä£Äâµç»°Éù,¼õÉٸߵÍÒôG-15db+12db-10db F500Hz1.1KHz9KHz QÆÂ×´2oct3/4oct
"NOTCH 4KHz"ÔÚ4Hz´¦Â˲¨ÒÔ¼õÉÙ·´À¡Ð¥½ÐG0db0db-10db F80Hz2KHz4KHz QÆÂ×´3/2oct1/6oct
"HUM REDUCE 50Hz"ÔÚ50Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db F50Hz160Hz10KHz Q1/6oct1/6octÆÂ×´
"HUMREDUCE 60Hz"ÔÚ60Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db F60Hz180Hz10KHz Q1/6oct1/6octÆÂ×´
"W.NOISE REDUCE"Ϊ´Å´ø·ÅÒô¼õÉÙ¸ßÆµÔëÒôG0db0db-13db F80Hz2KHz16KHz QÆÂ×´3/2octÆÂ×´ |
