Vintech Audio X73 µ¥Í¨µÀ»°Í²·Å´óÆ÷ÊÛ¼Û£º£¤22950Ôª8 N8 m5 Y8 i+ R, L7 U3 t0 B
( P4 U% A: R$ m
×Ô 1997 ÄêÒÔÀ´£¬ Vintech Ò»Ö±¶¼ÔÚÒÔǰµÄ¾µäÉè¼Æ»ù´¡ÉÏÉú²úÓÅÖʵÄÒôƵÉ豸£¬²¢³ÉΪÐÐÒµÄڵĵ䷶¡¢±ê×¼¡£ X73 ÊÇÔڹŵäµÄ Neve 1073 »ù´¡ÉÏÉè¼ÆµÄÒ»¿îµ¥ÉùµÀÂó¿Ë·çǰÖ÷ŴóÆ÷£¯¾ùºâÆ÷£¬ÓÐ×ÅÏàͬµÄµç·Éè¼Æ¡¢µçÈÝÆ÷ºÍ±äѹÆ÷£¬±£Ö¤ÁË X73 µÄÒôЧºÍ 1073 Ò»ÑùÓÅÖÊ¡£ X73 ÐèÒªµçÔ´¹©µçʹÓá£& ?! {5 y" X7 j F/ ?+ P
. @ q4 I2 E6 S' F" D
$ l8 c: U% O7 v- P p. |! ]0 Z
5 y6 t/ C0 f1 S" C% s4 g7 w9 f¡¡¡¡ÌØÕ÷£º ' c- U3 L7 u/ M, i
¡¡¡¡A ¼¶Êä³ö·Å´óÆ÷£¬²ÉÓÃÒ»¸ö 2N3055 NPN ¾§Ìå¹Ü¡£
\8 l# N& Y0 u0 \+ o¡¡¡¡1 ¸ö»ú¼Ü¿Õ¼ä£¬ 16 ¹æ¸ñ£¬È«¸ÖÖÆµ×ÅÌ¡£ 3 I7 v/ i: Y# W7 i H5 H! z
¡¡¡¡St. Ives Êä³ö±äѹÆ÷¡£
$ W) l4 l" y$ k¡¡¡¡Elma ÊäÈëÔöÒæÐýÅ¥¿ª¹Ø¡£ - v8 a. U G T' x% @8 v+ [0 L
¡¡¡¡Clarostat Êä³öµçƽ¿ØÖÆ¡£
5 `1 p* ~8 t2 F, v¡¡¡¡Electroswitch ¾ùºâÆ÷¿ª¹Ø¡£
; `7 B1 y' G& ~/ H) Z¡¡¡¡¶Æ½ð½Ó¿Ú¡£ 1,200 »ò 300 Å·Ä·ÊäÈë×迹¡£ 3 c- _/ Q7 K) l! v. X
¡¡¡¡ºó²¿ÓÐ Neutrik XLR ÊäÈ룯Êä³ö½Ó¿Ú£¬ TRS Êä³ö½Ó¿Ú¡£ ( @- u6 o# R7 a# E# b' v/ f! X
¡¡¡¡ºó²¿´ø 1/4" TRS ƽºâÐźÅÏß·ÊäÈë½Ó¿Ú¡£ # R2 N1 q. U0 A; Y( @
¡¡¡¡1/4" É豸ֱÁ¬ÊäÈë½Ó¿Ú£¬ÔÚǰ²¿Ãæ°å¡£ , x0 L4 t7 I; s2 e" a4 Y
¡¡¡¡¸ß£¯µÍÂ˲¨´¦Àí¡£
6 g* W, Z/ K6 c6 f R7 H% Q, H¡¡¡¡¿É±ä¾ùºâÆ÷ƵÂÊ¡£ ÊäÈëÔöÒæ¿ØÖÆ¡£ 7 ^+ ` A/ u1 |8 m6 f1 @/ @
¡¡¡¡Êä³öµçƽ¿ØÖÆ¡£
+ R( k! `+ E: ]+ G1 I2 ~( d5 ]¡¡¡¡ÏàÎ»Äæ×ª¿ª¹Ø¡£ 9 c% \' y& z; O' u' C% E' R
¡¡¡¡+48-Volt »ÃÏóµçÔ´¿ª¹Ø¡£ & S1 X$ U6 N7 ^0 x6 u
¡¡¡¡¾ùºâÊäÈ룯Êä³ö¿ª¹Ø¡£
( O8 q5 p2 x) c2 N" D0 B¡¡¡¡LED Êä³öÔöÒæÏÔʾ£º -6 dB ÖÁ +18 dB ¡£
- f. Y4 D {4 s; o) j- j¡¡¡¡LED ¹¦ÂÊָʾÆ÷¡£8 z, F+ d" M" R% g& M9 }; A
7 R/ A! Y" b1 [2 D, p1 H; E
/ i9 A; P8 A0 `4 _
L; K% P2 {! _# s$ U) [Vintech Audio X73--¼¼Êõ²ÎÊý4 L' l6 i6 p) R. l4 T
• Class-A output amplifier that uses a 2N3055 NPN power transistor6 J5 E& |$ T+ p0 L4 t
• 1 rack space 16-gauge, all-steel Chassis
/ y9 H. c9 {' a6 ?• St. Ives output transformer1 n% K9 R V6 {8 p$ H) N+ Q1 V
• Hand wired Elma rotary input gain switch $ @) N- C7 p! n5 c: j
• Output Level control by Clarostat
0 h, X) K9 k! E8 w8 s3 X s0 A; A• EQ switches by Electroswitch : K4 H, n2 W) w+ w! V. S) Q; Q4 K
• Gold contacts& }% b: T2 W" |0 }3 c
• 1,200 OR 300 ohm input impedance 5 X" V' E' r6 u ?; A6 ^, F
• Rear Neutrik XLR in/out, TRS out
+ U0 H9 \% R. B* C9 W+ t6 g* V• Rear 1/4" TRS balanced line input4 g7 P: [9 x3 l# m* Y
• 1/4" direct instrument input on the front panel) C `- C5 `% T! L9 g
• Hi/Low shelving2 @) d/ |% }3 Q3 S
• Variable EQ frequencies
3 T( U% u$ Q- A7 Q2 V6 J0 X• Input gain control$ f7 p0 X0 Y' V: U( u9 c1 d. m7 h" e
• Output level control
" z; N$ ^# @& w$ G `; A8 A2 G4 p+ ~• Phase reverse switch* k3 d2 S5 t7 g+ H
• +48-Volt phantom power switch
' G, [) u. s; G• EQ in/out switch- P J7 B, N- P/ r7 J P
• LED output gain display ranging from -6 dB to +18 dB 2 A9 O( {" d* a2 M% Q$ M
• Power indicator LED |
