KRK V8 S4Á½·ÖƵ8´çµÍÒôÓÐÔ´¼àÌýÒôÏä, I- O& e! X6 }2 A6 G& y
/ H& p% K/ @$ v0 x) c1 n
( Z2 n k! e S) v1 y
( `% j' x6 w/ K( ?
7 E$ I4 B0 P9 ?4 b( P3 p7 i$ zKRK VϵÁÐËùÓÐÐͺŵÄÒôÏä¶¼ÊDzÉÓÃË«¹¦·ÅDÀà·Å´óÆ÷£¬Äܹ»¶ÀÁ¢Çý¶¯×Ô¶¨ÒåKRKÉè¼ÆµÄÒ»Ó¢´çÇò¶¥¸ßÒôµ¥Ôª£¬°´ÕÕÖ÷Çý¶¯Æ÷³ß´çKevlarµÍÒôµ¥Ôª·ÖΪ--V4¡¢V6¡¢V8Èý¸öÐͺš£µçԴͨ¹ý±ê×¼µÄKettleÒýÏßÁ¬½Ó£¬ÒôƵͨ¹ýXLR / 1 / 4¡±×éºÏ²å×ùÊäÈ롣ÿ¸öÐͺŶ¼ÊÇÓÃÖÐÃܶÈÏËά°å/ÂÁ²ÄÁÏÖÆÔìµÄ£¬Ç°Ãæ°åÊÇĿǰÁ÷ÐеĿîʽ£¬´øÁ÷ÏßÐÍ»¡ÐαßÔµ¡£
* I- L+ t4 p3 Y9 v% H9 W' P3 Z1 R7 a( b5 |- G! l4 `
1 Z4 M T) T! Y) T9 `' L0 }* n
; T. A) F! @1 [* t( ]
KRK V8 S4ÌØµã 1 f5 E; s$ X( P7 T: `/ w- F
2 W# u- D4 T% {# u
KRK¶¨ÖÆÉè¼Æ¿·òÀ¸ßÒôµ¥Ôª 8 T, g* i9 J3 D S4 N1 J) Z
+ m4 o8 u' K# r
KRK¶¨ÖÆÉè¼ÆµÄ±àÖ¯¿·òÀµÍÒôÑïÉùÆ÷ & X9 A$ E, I- S6 W- a* p
# U2 [" i. W) K* }9 y, CÓÅ»¯µÄǰ¶ËµÍÒô·´ÉäÍâ¿ÇÉè¼Æ
7 f0 `$ n* q& b
! U7 D3 V/ `' ]9 FË«¼«»¯DÀà·Å´ó
5 n9 `" N7 N& o. q5 f, m
" e8 T( X1 W$ N1 Y* C1 j, b& l0 RÉùѧºÍ×ÀÃæ¼ÓÔØÌõ¼þУÕýµÍƵ¾ùºâÆ÷ : C6 w& [6 ]& v6 d5 |& n
& l; N/ J$ I0 [* W( e8 H
ÖÐ¸ßÆµ¾ùºâÆ÷
: p5 f" ~6 X3 e, P% L% J. t7 s5 ^1 ~- [, v4 Y( U. ~- u, `! a4 I
¾«È·µÄÊäÈëµçƽ˥¼õ¿ª¹Ø
1 p0 l \. f4 V- o& C# g' a* F. m
* u- O- T& n' `´ý»ú£¬µØÃæÉý½µ£¬ÊäÈëÁéÃô¶ÈºÍ±êÖ¾LEDÑ¡ÔñÆ÷ . m2 y& y5 k) d, [# m
7 R2 ^0 n0 h* ?0 J7 W
°üÀ¨Òƶ¯¹ã²¥Ó¦ÓõĿÉÑ¡±£»¤¸ñÕ¤
! P, q, m8 S0 O( q Q: d/ g- |9 A$ {" A5 D. H6 u* X! L
FrictionËø£¬Neutrik×éºÏ£¨XLRºÍTRS£©Á¬½ÓÆ÷ T; S' B+ |+ S) ]0 L( m2 S/ ^
2 q _' H: H" Z1 k* J8 J7 X
¼á¹ÌµÄEVAÅÝĵ棬ÓÃÓÚ·À»¬ºÍ¸ôÒô . R7 I6 t( x: q$ g9 \
$ f' h3 F2 o- [. i2 ]5 V! {, X. h
ͨÓÃÂÝÎÆ°²×°Ö§¼Üµã 9 E P Y0 n' N5 P: j' z
1 S7 v6 d: V! H! B8 m0 g# y0 _- P) U! G# C
/ @) _9 C$ q6 x# d) ^, E
KRK V8 S4¼¼Êõ¹æ¸ñ 7 E N' @) _2 X9 ]3 k% A
0 b z9 n& p0 g& } Y- ]
ÅäÖãºÁ½·ÖƵÓÐÔ´¼àÌýÒôÏä
$ D# x. |0 d; w" I
) s5 q0 k$ x9 C: Q# r) UϵͳÀàÐÍ£ºActive Studio Monitor ! S% t, o9 k; s3 `* G' D# n
$ V: q6 ~! ^; o: t6 L1 o
µÍƵ£ºµÍÒôµ¥Ôª£¬8¡°ÖýÂÁ¿ò£¬¿·òÀ×¶£¬ÌúÑõÌå´ÅÌú 9 E& M0 \/ o: L& o# B( \9 p
" t. u& e, F5 {- X7 _0 h6 x¸ßƵ£º¸ßÒôµ¥Ôª£¬1¡°£¬¿·òÀ¶ûÔ²¶¥£¬ÌúÑõÌå´ÅÌú + e# L3 w$ j- Z. \. T1 M
6 K- s% J* b" {5 v# b# j* Z9 xƵÂÊÏìÓ¦£º35Hz-19kHz
9 C8 c- o4 ?6 F3 a4 _6 B" C+ g+ x( j q4 }2 L r% @2 z
ƵÂÊ·¶Î§£º29Hz-24kHz 1 e0 G' r) j8 Z: p2 R6 G4 ~& i, y
, C) A9 a8 ]0 C3 {7 \! r! n+ N' y. M
·åÖµSPL£º118 dBSPL 2 b) S8 Y8 p' P! A& E
" e ?9 E; y p% \% W
¹¦ÂÊÊä³ö£ºLF£¨200Íߣ©£¬HF£¨30Íߣ©£¬×ܼƣ¨230Íߣ©
' R" z8 D3 o: |3 E
8 r* J6 l I7 Y¸ß¿ØÖÆ£ºH1 (High Shelf -2dB 10kHz, H2 (High Shelf -1dB 10kHz / High Mid Peq -1dB 3.5kHz), H3 (High Mid Peq -1dB 3.5kHz), H4 (Flat), H5 (High Mid Peq +1dB 3.5kHz), H6 (High Shelf +1dB 10kHz / High Mid Peq +1dB 3.5kHz, H7 (High Shelf +2dB 10kHz)
7 D. M) X# r# \6 v& P. a% p; [& z3 @& l. r/ z
µÍ¿ØÖÆ£ºL1 (Low Shelf -3dB 75Hz), L2 (Low Shelf -1.5dB 75Hz), L3 (Low Shelf -2dB 75Hz / Low Mid Peq -2dB 200Hz), L4 (Flat), L5 (Low Mid Peq -2dB 200Hz), L6 (Low Shelf +1.5dB 75Hz), L7 (Low Shelf +3dB 75Hz) % u# v% ~8 t1 ?, d0 P Y
1 D, a' d7 J6 t
Íâ¿Ç½á¹¹£ºMDF /ÂÁ
' e' T- E& Y; E
7 ]( _% E9 w% @$ @1 @9 X³ß´ç£¨¸ßx¿íxÉ£º17.13¡°£¨435mm£©¡Á11.18¡±£¨284mm£©¡Á13.66¡°£¨347mm£©
- f! o, n2 e; ?) t" X' V" H8 h
. r+ p/ k N7 o0 o2 r6 y8 S5 gÌåÖØ£º31.75°õ £¨14.4¹«½ï£©' L$ ^& W7 x% g
4 J1 B, r7 R; A3 q; J1 V: b: i/ M, m$ X1 w- ~
