¹¦ÄÜÌØµã 24¸öÊäÈë 32¸öÊä³ö£¨Í¨¹ýUSBÖ§³Ö24¸öͬʱÊä³ö£© 8¸öClass-A Audientµ÷Òǫ̂Âó¿Ë·çǰÖ÷ŴóÆ÷ ÁìÏȵÄAD/DAת»»Æ÷ Ö÷ÑïÉùÆ÷ºÍ±¸ÓÃÑïÉùÆ÷Êä³ö 2¸ö¶ÀÁ¢µÄ¶ú»úÊä³ö 2¸öADATÊäÈëºÍÊä³ö 8¸ö¿ÉÇл»µÄƽºâ²åÈë½Ó¿Ú ³¬µÍÑÓ³ÙÈí¼þ»ìÒôÆ÷ ÒôƵ»Ø´«¹¦ÄÜ ¹ö¶¯¿ØÖÆ£¨ScrollControl£© רÓõı¸ÓÃÑïÉùÆ÷ºÍ¶Ô½²¿ØÖÆ 2¸öÓû§×Ô¶¨Ò幦Äܰ´¼ü +48V»ÃÏóµçÔ´¡¢Ë¥¼õ£¨Pad£©¡¢+10dBÔöÒæ¡¢Ïàλ·´×ªºÍ¸ßͨÂ˲¨¿ØÖÆ Word ClockʱÖÓÊäÈëºÍÊä³ö ¶ÀÁ¢Ä£Ê½£¨Standalone Mode£© µçÔ´¿ª/¹Ø¹¦ÄÜ ·ûºÏUSB 2.0±ê×¼£¨24ÊäÈë/24Êä³ö£© 24bit/96kHz²ÉÑùÂÊ ¿É²ðж»ú¼Ü¶ú È«½ðÊôÉè¼Æ Ãâ·ÑÈí¼þºÍ²å¼þ ¼¼Êõ¹æ¸ñ Âó¿Ë·çǰÖ÷ŴóÆ÷ Âó¿Ë·çÔöÒæ (MIC GAIN): 0 µ½ +68dB£¨º¬10dBÔöÒæÌáÉý£© Ïß·ÔöÒæ (LINE GAIN): -10 µ½ +58dB£¨º¬10dBÔöÒæÌáÉý£© »ÃÏóµçÔ´ (PHANTOM POWER): 48v +/-4v @ 10mA/ͨµÀ Âó¿Ë·çµÈЧÊäÈëÔëÉù (MIC EIN): -127dBu ¹²Ä£ÒÖÖÆ±È (CMRR): >80dB @ 1kHz ×î´óÊäÈëµçƽ (MAXIMUM INPUT LEVEL): +18dBu ÊäÈë×迹 (Âó¿Ë·ç) (INPUT IMPEDANCE ¨C Mic): 3k¦¸ ƽºâ ÊäÈë×迹 (Ïß·) (INPUT IMPEDANCE ¨C Line): 10k¦¸ ƽºâ ƵÂÊÏìÓ¦ (FREQUENCY RESPONSE): ¡À0.5dB 10Hz µ½ 65kHz ´®ÈÅ (CROSSTALK): <-115dB @ 1kHz & 10kHz ×Üг²¨Ê§Õæ¼ÓÔëÉù (THD+N @ 0dBu, 1kHz): 0.0016% (-96dB) ÐÅÔë±È (SNR): 99dB A¼ÓȨ XLR: µÚ2Õë (ÈȶË)¡¢µÚ3Õë (Àä¶Ë) & µÚ1Õë (ÆÁ±Î) 1/4Ó¢´çTRS²å¿× (1/4¡± TRS JACK): ²åÍ· (ÈȶË)¡¢»· (Àä¶Ë) & Ì×Ͳ (ÆÁ±Î) Ë¥¼õ (PAD): -10dB ¸ßͨÂ˲¨ (HPF): -3dB @ 100Hz£¬2½× (12dB/±¶Æµ³Ì) Ïß·ÊäÈ룺 LINE GAINÏß·ÔöÒæ:-10 to +48dB MAXIMUM×î´óÊäÈëµçƽ:+22dBu THD+N @0dBu 1kHz:0.0013%, -97dB D.I / ÀÖÆ÷ÊäÈ루ͨµÀ1ºÍͨµÀ2£© D.IÔöÒæ (D.I GAIN): 0 µ½ +68dB£¨º¬10dBÔöÒæÌáÉý£© ×î´óÊäÈëµçƽ (MAXIMUM INPUT LEVEL): +15dBu ÊäÈë×迹 (INPUT IMPEDANCE): 500k¦¸ ·Çƽºâ ƵÂÊÏìÓ¦ (FREQUENCY RESPONSE): ¡À0.5dB 10Hz ÖÁ 40kHz ×Üг²¨Ê§Õæ¼ÓÔëÉù (THD+N @ 0dBu, 1kHz): <0.06% ÐÅÔë±È (SNR): 96dB A¼ÓȨ 1/4Ó¢´ç²å¿× (1/4¡± JACK): ²åÍ· (ÈȶË) & Ì×Ͳ (ÆÁ±Î) Ä£Äâµ½Êý×Öת»»Æ÷ ×î´óÊäÈëµçƽ (MAXIMUM INPUT LEVEL): +18dBu£¨0dBFS Êý×Ö×î´óÖµ£© Êý×ֲο¼µçƽ (DIGITAL REFERENCE LEVEL): +18dBu = 0dBFS ÊäÈë×迹 (INPUT IMPEDANCE): >10k ¦¸ ƽºâ ´®ÈÅ (CROSSTALK): <-118dB @ 1kHz£¬<-115dB @ 10kHz ƵÂÊÏìÓ¦ (FREQUENCY RESPONSE): ¡À0.5dB 10Hz ÖÁ Fs/2£¨ÄοüË¹ÌØÆµÂÊ£© ×Üг²¨Ê§Õæ¼ÓÔëÉù (THD+N @ -1dBFS, 1kHz): <0.0003% (-110dB) ¶¯Ì¬·¶Î§ (DYNAMIC RANGE): 120dB A¼ÓȨ 1/4Ó¢´çTRS²å¿× (1/4¡± TRS JACK): ²åÍ· (ÈȶË)¡¢»· (Àä¶Ë) & Ì×Ͳ (ÆÁ±Î) Êý×Öµ½Ä£Äâת»»Æ÷£¨¼àÌýºÍÏß·Êä³ö£© ×î´óÊä³öµçƽ (MAXIMUM OUTPUT LEVEL): +18dBu£¨0dBFS Êý×Ö×î´óÖµ£© Êä³ö×迹 (OUTPUT IMPEDANCE): <100 ¦¸ ´®ÈÅ (CROSSTALK): <-120dB @ 1kHz£¬<-115dB @ 10kHz ƵÂÊÏìÓ¦ (FREQUENCY RESPONSE): ¡À0.5dB 10Hz ÖÁ Fs/2£¨ÄοüË¹ÌØÆµÂÊ£© ×Üг²¨Ê§Õæ¼ÓÔëÉù (THD+N @ -1dBFS, 1kHz): <0.00026% (-111.5dB) ¶¯Ì¬·¶Î§ (DYNAMIC RANGE): 124dB δ¼ÓȨ£¬126.5dB A¼Ó 1/4Ó¢´çTRS²å¿× (1/4¡± TRS JACK): ²åÍ· (ÈȶË)¡¢»· (Àä¶Ë) & Ì×Ͳ (ÆÁ±Î Word Clock×ÖʱÖÓÊäÈë/Êä³ö£º ×ÖʱÖÓ£º44.1kHzÖÁ96kHz ×ÖʱÖÓÊäÈëÖÕÖ¹£º75R ¶ú»úÊä³ö ×î´óÊä³öµçƽ (MAXIMUM OUTPUT LEVEL): +18dBu£¨0dBFS Êý×Ö×î´óÖµ£© Êä³ö×迹 (OUTPUT IMPEDANCE): <50 ¦¸ ·Çƽºâ ´®ÈÅ (CROSSTALK): <-117dB @ 1kHz£¬-112dB @ 10kHz ƵÂÊÏìÓ¦ (FREQUENCY RESPONSE): ¡À0.5dB 10Hz ÖÁ Fs/2 ×Üг²¨Ê§Õæ¼ÓÔëÉù (THD+N @ -1dBFS, 1kHz): <0.00023% (-112dB) ¶¯Ì¬·¶Î§ (DYNAMIC RANGE): 121dB δ¼ÓȨ£¬124dB A¼ÓȨ ×î´óµçƽ (30Å·Ä·¸ºÔØ) (MAX LEVEL INTO 30ohms): 4V ·åÖµ£¬2.85V RMS£¬530mW ×î´óµçƽ (60Å·Ä·¸ºÔØ) (MAX LEVEL INTO 60ohms): 5.82V ·åÖµ£¬4.12V RMS£¬565mW ×î´óµçƽ (600Å·Ä·¸ºÔØ) (MAX LEVEL INTO 600ohms): 8.71V ·åÖµ£¬6.16V RMS£¬126mW 1/4Ó¢´ç²å¿× (1/4¡± JACK): ²åÍ· (ÈȶË)¡¢»· (Àä¶Ë) & Ì×Ͳ (ÆÁ±Î) USB 2.0¸ßËÙ£º ÊäÈëͨµÀÊýÁ¿£º24£¨8¸öÄ£ÄâͨµÀ£¬16¸öÊý×ÖͨµÀ£© Êä³öͨµÀÊýÁ¿£º32£¨16¸öÄ£Ä⣬16¸öÊý×Ö£©* Á¬½Ó:USB Type-C °üÀ¨ÏßÀ£º1m USB 2.0 Type-Cµ½Type-C *ÔÚͬһʱ¼ä×î¶à24¸öΨһµÄͨµÀ¡£Óйظü¶àÐÅÏ¢£¬Çë²ÎÔı¾ÊÖ²áµÚ36Ò³¡£ Êý×ÖÊäÈë: 2 ¡Á 8ͨµÀADAT: 44.1kHzÖÁ48kHz 2 ¡Á 4ͨµÀADAT:88.2kHzÖÁ96kHz £¨SMUX£© Á¢ÌåÉùS/PDIF:44.1kHzÖÁ96kHz£¨Á¢ÌåÉù£© Êý×ÖÊä³ö: 2 ¡Á 8ͨµÀADAT:44.1kHzÖÁ48kHz 2 ¡Á 4ͨµÀADAT:88.2kHzÖÁ96kHz £¨SMUX£© Á¢ÌåÉùS/PDIF:44.1kHzÖÁ96kHz£¨Á¢ÌåÉù£© DSP»ìÒôÆ÷ÑÓ³Ù£¬Íù·µ£¨ÊäÈëµ½Êä³ö£© 44.1kHz£º0.344ms 48kHz£º0.312ms 88.2kHz£º0.188ms 96kHz£º0.177ms ³ß´ç£¨²»°üº¬»ú¼Ü¶ú£© ¿í¶È£º437mm ¸ß¶È£º50mm Éî¶È£º327mm
