¼ÒôÅïÊýÂëÒôÀÖ¡¢ÉÙÄ깬¼ÒôÅȺÒչݼÒôÖÆ×÷
¹¤×÷Õ¾ "3.2GHz ÁùºËµÚ°Ë´ú Intel Core i7 ´¦ÀíÆ÷ (Turbo Boost ¸ß¿É´ï 4.6GHz)
16GB 2666MHz DDR4
Intel UHD Graphics 630 ͼÐδ¦ÀíÆ÷
1TB ¹Ì̬ӲÅÌ
ǧÕ×ÒÔÌ«Íø (10/100/1000BASE-T ǧÕ×ÒÔÌ«Íø£¬²ÉÓà RJ-45 ½Ó¿Ú)"
ÏÔʾÆ÷ "¼Ñ·Ö±æÂÊ 3840x2160
ÆÁÄ»±ÈÀý 16:9£¨¿íÆÁ£©
¸ßÇå±ê×¼ 4K
Ãæ°åÀàÐÍ IPS
±³¹âÀàÐÍ LED±³¹â
¾²Ì¬¶Ô±È¶È 1300:1
ÏìӦʱ¼ä 5ms
µã¾à 0.1554mm
ÁÁ¶È 350cd/©O
¿ÉÊÓÃæ»ý 596.74¡Á335.66mm
¿ÉÊÓ½Ç¶È 178/178¡ã
ÏÔʾÑÕÉ« 10.7ÒÚ
É«Óò sRGB£º99.9£¥
Ë¢ÐÂÂÊ 60Hz
ÊÓÆµ½Ó¿Ú HDMI£¬Displayport£¬Mini Displayport
ÆäËü½Ó¿Ú USB3.0¡Á4£¬ÒôƵÊä³ö
²úÆ·³ß´ç 611.3¡Á356.2¡Á49.1mm£¨²»º¬µ××ù£©
611.3¡Á410.2¡Á200.3mm£¨°üº¬µ××ù£©
²úÆ·ÖØÁ¿ 6.55kg£¨¾»ÖØ£©
9.4kg£¨Ã«ÖØ£©
µ××ù¹¦ÄÜ ²àת£º45¡ã£¬Çãб£º-5-21¡ã£¬Ðýת£º90¡ã£¬Éý½µ£º130mm
±Ú¹Ò Ö§³Ö£¨100¡Á100mm£©"
ÒÆ¶¯¹¤×÷Õ¾ "2.4GHz 8 ºËµÚ¾Å´ú Intel Core i9 ´¦ÀíÆ÷£¬Turbo Boost ¸ß¿É´ï 5.0GHz
32GB 2666MHz DDR4 ÄÚ´æ
AMD Radeon Pro 5500M ͼÐδ¦ÀíÆ÷£¬Å䱸 8GB GDDR6 ÏÔ´æ
4TB ¹Ì̬ӲÅÌ
²ÉÓÃÔ­²ÊÏÔʾ¼¼ÊõµÄ 16 Ó¢´çÊÓÍøÄ¤ÏÔʾÆÁ
ËĸöÀ×ö¨ 3 ¶Ë¿Ú
´¥¿ØÀ¸ºÍ´¥¿Ø ID
±³¹âÃî¿Ø¼üÅÌ - ÖÐÎÄ (Æ´Òô)"
µ÷Òǫ̂ "*16¸ö´¥Ãþ¸ÐÓ¦µç¶¯ÍÆ×ÓÒÔ¼° 10 ¶ÎÐÅºÅµçÆ½±í£¨Ö§³Ö¶à 6 ¸öÍÆ×ӿ⣩£»
32 ¸öÓÃÓÚÉùÏñ¡¢ÔöÒæ¿ØÖÆ¡¢²å¼þ²ÎÊýµ÷ÕûµÈµÄ´¥Ãþ¸ÐÓ¦°´Å¥ÐýÅ¥±àÂëÆ÷£¨16 ¸öͨµÀ¿ØÖÆ£¬16 ¸ö¿É·ÖÅ䣩£¬Ã¿¸ö¶¼´øÓÐÈýÉ« LED ¹¦ÄÜָʾ£»
32¸ö¸ß·Ö±æÂÊ OLED ÏÔʾÆÁ£¬ÓÃÓڲ鿴Òô¹ìÃû³Æ/Òô¹ìºÅ¡¢²âÁ¿Êý¾Ýϸ½Ú£¨´Óµ¥ÉùµÀµ½»·ÈÆÉù£©¡¢²ÎÊýÃû³Æ/²ÎÊýÖµ¡¢µ±Ç°×Ô¶¯¿ØÖÆÄ£Ê½µÈµÈ£»
*Ö§³ÖEUCONЭÒ飻
ÖÁÉÙ4¸öÄ£ÄâÊäÈ룬4¸öÄ£ÄâÊä³ö£¬Áí¸½´øÒôÁ¿¿ØÖƵĶú»úÊä³ö"
ÓÐÔ´ÒôÏä "´óÉùѹ¼¶ 114 dB
*ƵÂÊÏìÓ¦·¶Î§ 33 Hz ¨C 23 kHz (-6 dB)
*ƵÂÊÏìÓ¦¶È ¡À 2.5 dB (40 Hz ¨C 20 kHz)
*²úÆ·³ß´ç ¸ß 495 x ¿í 320 x Éî 290 mm
*µ¥Ôª³ß´ç µÍƵ 10 ´ç ¸ßƵ 1 ´ç
*¹¦·Å¹¦ÂÊ µÍƵ 200 W ¸ßƵ 150 W
*ÒôƵ½Ó¿ÚÀàÐÍ 1 x XLR Ä£ÄâÊäÈë 1 x XLR AES/EBUÊý×ÖÊäÈë 1 x XLR AES/EBUÊý×ÖÊä³ö
²úÆ·ÖØÁ¿ 17 kg"
Ч¹û²å¼þ "½áºÏ×ÛºÏÐÔÒôЧ´¦Àí¹¤¾ßÓÚÒ»ÉíµÄDiamondÈí¼þ£»
Ϊ¹¤×÷ÊÒÌṩÎÞ¿ÉÆ¥µÐµÄÐźŴ¦ÀíÁ¦Á¿£»
°üÀ¨Â¼Òô»ìÒô¡¢Ä¸´øºóÖÆ¡¢´´ÒâÒôЧÉè¼Æ¡¢ÒÔ¼°ÒôЧ»¹Ô­£»
ÄÚº¬MaxxVolume, Q-Clone, Waves Tune LT, L3 Multimaximizer, L3-LL Multimaximizer, IR-L Convolution Reverb ÒÔ¼°ÔÚWave Platinum¡¢Restoration¡¢TransformÌ×¼þÖеÄËùÓвå¼þ£»
¸»º¬¶¯Ì¬´¦Àí¡¢µÈ»¯¡¢²ÐÏì´¦Àí£¬»òÊÇÒô×¼µ÷Õû¡¢¿Õ¼ä¸Ð¼ÓÈëµÈµÈ"
ÒôƵ½Ó¿Ú "1¡¢»°·ÅÊýÁ¿£º4·/65dB
2¡¢»°·Å¹¦ÄÜ£ºUnisonTM / ¶Ô½²»°Í² / ·´Ïà / µÍÇÐ / PAD
3¡¢Êä³öµçƽ£º¿ÉÑ¡ +12 / +24dBu
4¡¢Ä£ÄâÊäÈ룺8·/123dB¶¯Ì¬·¶Î§
5¡¢ÏßÐÔÊä³ö£º8·/127dB¶¯Ì¬·¶Î§
6¡¢ÐéÄâͨµÀ£º8x8ÐéÄâÄÚ¼ͨµÀ¡¢4×éCue×Ó»ìÒôͨµÀ
7¡¢¶ú»ú½Ó¿Ú£ºË«¶ú»úÊä³ö/125dB¶¯Ì¬
8¡¢¶ú·ÅÍÆÁ¦£º150mW@300¦¸ (+19dBu)
9¡¢Êý¾Ý½Ó¿Ú£ºË«À×µç3½Ó¿Ú ( Ö§³Ö¶ą̀Apollo X´®Áª )"
¼ÒôÈí¼þ "ȫеÄVariAudio 3
5GB¸ßÆ·ÖʵÄÉùÒôºÍÑ­»·
AAFÖ§¼Ü
ÈËÉùÒô¸ßÐÞÕý¹¦ÄÜÉý¼¶
20¸öеÄÂö³åÏìÓ¦
µ÷Òǫ̂¿ìÕÕ¹¦ÄÜ
ÑÓʱ¼àÊÓÆ÷
¿ìËٶԹ칦ÄÜ
Ö§³Ö¸ß·Ö±æÂÊÏÔʾÆ÷£¬ÊÓÍøÄ¤ÆÁÄ»
ÐÂͨµÀÌõ
ýÌå»ú¼ÜЧӦ
Ö§³Ö32bitÉî¶ÈµÄ¶¯Ì¬
MPEÖ§³Ö
Ôö¼ÓÁ˶Ô64bitÉî¶ÈµÄ¸¡µãÔËËãÄÜÁ¦
¸Ä½øµÄͼƬ±à¼­
еIJàÁ´¹¦ÄÜ
˹̹²®¸ñÐéÄâÏÖʵ
еÄÓû§½çÃæ
ARAÔØÌå"
ËÞÖ÷Èí¼þ "DAWÈí¼þ
¿ÉÖ§³ÖAAX²å¼þ
¿Éͬʱ֧³Ö32ͨµÀÒôƵÊäÈë
´óÊýÁ¿Í¬²½ÒôƵ¹ìµÀ£¨48/96/192 kHz£©£º128/64/32(µ¥ÉùµÀ»òÁ¢ÌåÉù)
MIDIͨµÀ£º512¹ì
¸¨ÖúͨµÀ£º128¹ì
Ö§³ÖÒ»Äê¸üÐÂ
º¬¼ÓÃܹ·1¸ö"
ÒÆ¶¯¹Ì̬ӲÅÌ 2TÒÆ¶¯¹Ì̬ӲÅÌ£¬¸ßËÙUSB3.2´«Êä
¶àͨµÀ»°·Å "8·Audient Console»°·Å
ȫеÄBurr BrownµÄADת»»¼¼Êõ
¿É±äÊäÈë×迹
¿Éµ÷½ÚƵµã¸ßͨÂ˲¨Æ÷
ÿͨµÀ¾ùÓз´Ïò°´Å¥
48V»ÃÏóµçÔ´
ADת»»¿ª¹Ø
ÐźÅָʾ
»°Í²Ç°Ö÷ŴóÆ÷ºÍADת»»Æ÷Ö®¼äÓÐ8²åÈëµã
Á½Í¨µÀA¼¶ÀëÉ¢JFET DIÀÖÆ÷ÊäÈë
8ͨµÀÊý×ÖÊä³ö - ADAT£¬AES£¬Á¢ÌåÉùS / PDIF
²ÉÑùƵÂʿɵ÷
¿É½ÓÊÕWorld Clock ʱÖÓ"
´óÕðĤµçÈÝ»°Í² "ÉùÒô¹¤×÷Ô­Àí:ѹÁ¦Ìݶȴ«¸ÐÆ÷
Ö¸ÏòÐÔ:È«ÏòÐÔ£¬ÐÄÐÍ£¬8×ÖÐÍ
ƵÏì:20Hz-20KHz
ÁéÃô¶È£¨1KHz-1KOHM£©:20/28/22mVPa
Êä³ö×迹:200ohms
¸ºÔØ×迹:1000ohms
ÁéÃô¶È£¨CCIR486-3£©:26/23/25dB-A
ÁéÃô¶È£¨DIN/IEC 651£©:15/12/14dB-A
S/N±È£¨CCIR 486-3£©:68/71/69dB
S/N±È£¨DIN/IEC 651£©:79/82/80dB
½Ï´óÉùѹ¼¶£¨THDСÓÚ0.5%£©:117dB(ÐÄÐÍ)
½Ï´óÉùѹ¼¶£¨THD СÓÚ0.5%,Ԥ˥¼õ£©:127dB
½Ï´óÊä³öµçѹ:390Mv
Âó¿Ë·ç´«¸ÐÆ÷£¨DIN/IEC651£©¶¯Ì¬·¶Î§ :105dB"
ÐÄÐÎÖ¸ÏòµçÈÝ»°Í² "´óÕðĤµçÈÝ»°Í²
ÕðĤ³ß´ç: 32mm (@ 3um)
Ö¸Ïò: ÐÄÐÍ
ƵÂÊÏìÓ¦·¶Î§: 16Hz-20kHz
ÁéÃô¶È@1KHz: -33dBV¡À1dB (-54dB @ 180¡ã)
´óÉùѹ¼¶: 128dB
