| | [size=11.0000pt]1.²ÎÊýÓëÒôƵ½Ó¿ÚÏàÆ¥Åä[size=11.0000pt]
[size=11.0000pt]2.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1.ͨµÀÍÆ×ÓÊýÁ¿£º¡Ý16¸ö[size=11.0000pt]
[size=11.0000pt]2.±àÂëÆ÷ÊýÁ¿£º¡Ý32¸ö[size=11.0000pt]
[size=11.0000pt]3.µçƽ±íÏÔʾ£º¡Ý16¸öµçƽ±í[size=11.0000pt]
[size=11.0000pt]4.Ä£ÄâÊäÈë½Ó¿Ú£º¡Ý4¸öXLR»°Í²/Ïß·ÊäÈë½Ó¿Ú£¬¡Ý2¸öTRSÏß·ÊäÈë½Ó¿Ú[size=11.0000pt]
[size=11.0000pt]5.Ä£ÄâÊä³ö½Ó¿Ú£º¡Ý4¸öXLRÏß·Êä³ö½Ó¿Ú£¬¡Ý2¸öTRSÏß·Êä³ö½Ó¿Ú[size=11.0000pt]
[size=11.0000pt]6.¶ú»úÊä³ö½Ó¿Ú£º¡Ý1¸ö6.35mm TRS¶ú»úÊä³ö£¬´ø¶ÀÁ¢µçƽµ÷½Ú[size=11.0000pt]
[size=11.0000pt]7.¶à¹¦ÄܱàÂëÆ÷:ÿ¸öͨµÀÅ䱸¶ÀÁ¢µÄÎïÀíÔöÒæµ÷½ÚÐýÅ¥£¬¾ß±¸¶À×ࣨSolo£©ºÍ¾²Òô£¨Mute£©°´¼üº¬Èí¼þ[size=11.0000pt]
[size=11.0000pt]8.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1.Ä£ÄâÓëÊý×Ö½Ó¿ÚÀàÐÍ£ºÖ§³ÖÄ£ÄâÓëÊý×ÖÊäÈë/Êä³ö[size=11.0000pt]
[size=11.0000pt]2.¼àÌýÓëÐźÅ·Óɹ¦ÄÜ£ºÖ§³Ö¶àͨµÀ¼àÌýºÍÁé»î·ÓÉÉèÖÃ[size=11.0000pt]
[size=11.0000pt]3.Âó¿Ë·ç/ÀÖÆ÷ÊäÈë½Ó¿Ú£º¡Ý2¸öÊäÈë½Ó¿Ú[size=11.0000pt]
[size=11.0000pt]4.Ä£ÄâÏß·ÊäÈë/Êä³ö£º¡Ý16½ø16³ö[size=11.0000pt]
[size=11.0000pt]5.ADAT¹âÏ˽ӿڣº¡Ý16½ø16³ö[size=11.0000pt]
[size=11.0000pt]6.DanteÍøÂçÒôƵ½Ó¿Ú£º¡Ý64½ø64³ö[size=11.0000pt]
[size=11.0000pt]7.DigiLink½Ó¿Ú£º¡Ý1¸ö32ͨµÀDigiLink Mini½Ó¿Ú[size=11.0000pt]
[size=11.0000pt]8.רÓüàÌýÊä³ö½Ó¿Ú£º¡Ý2¸öÊä³ö½Ó¿Ú[size=11.0000pt]
[size=11.0000pt]9.¶ú»úÊä³ö½Ó¿Ú£º¡Ý2¸öÊä³ö½Ó¿Ú[size=11.0000pt]
[size=11.0000pt]10.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| [size=11.0000pt]ʰÒôϵͳ²¿·Ö |
| | [size=11.0000pt]1.ÀàÐÍ£º µç×Ó¹ÜÂó¿Ë[size=11.0000pt]
[size=11.0000pt]2.Ö¸ÏòÐÔ£º9ÖÖÖ¸Ïò[size=11.0000pt]
[size=11.0000pt]3.ƵÂÊ·¶Î§£º 20 Hz - 20 kHz£¬¡À3 dB[size=11.0000pt]
[size=11.0000pt]4.µçÔ´£º ÍⲿµçÔ´[size=11.0000pt]
[size=11.0000pt]5.Êä³ö±äѹÆ÷£º BV8[size=11.0000pt]
[size=11.0000pt]6.ÁéÃô¶È£º 24.5 mV/Pa£¬¡À1 dB[size=11.0000pt]
[size=11.0000pt]7.Êä³ö×迹£º 200¦¸[size=11.0000pt]
[size=11.0000pt]8.×î´ó SPL£¨¶ÔÓÚ 1% THD£©£º 127 dB[size=11.0000pt]
[size=11.0000pt]9.ÐÅÔë±È£º 85 dB[size=11.0000pt]
[size=11.0000pt]10µçÔ´ÐèÇó£º×¨ÓõçÔ´¼°Ïß²Ä[size=11.0000pt]
[size=11.0000pt]11.²ÉÓÃDale¸ß¾«¶Èµç×è[size=11.0000pt]
[size=11.0000pt]12.MIAL¾Û±½ÒÒÏ©µçÈÝ[size=11.0000pt]
[size=11.0000pt]13.ERO±¡Ä¤µçÈݵȸ߾«¶ÈÔª¼þ[size=11.0000pt]
[size=11.0000pt]14.³Á½ðµç·»ù°å[size=11.0000pt]
[size=11.0000pt]15.¸ßѹ¹©µç²ÉÓúãÁ÷Ô´£«RCÂ˲¨[size=11.0000pt]
[size=11.0000pt]16.ÄÚÖÃEMIÂ˲¨Æ÷[size=11.0000pt]
[size=11.0000pt]17.ʹÓöÀÁ¢µÆË¿¹©µç£¨ÏßÐÔÎÈѹ£©[size=11.0000pt]
[size=11.0000pt]18.PAD£º-10DB[size=11.0000pt]
[size=11.0000pt]19.Low Cut£º150Hz[size=11.0000pt]
[size=11.0000pt]20.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1.ÉùÒôʰȡ·½Ê½£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷[size=11.0000pt]
[size=11.0000pt]2.Ö¸ÏòÐÔģʽ£º¡Ý3ÖÖÖ¸Ïò£¨¿ÉÇл»£©[size=11.0000pt]
[size=11.0000pt]3.ƵÂÊÏìÓ¦·¶Î§£º20Hz¨C20kHz[size=11.0000pt]
[size=11.0000pt]4.Êä³ö×迹£º¡Ý200¦¸[size=11.0000pt]
[size=11.0000pt]5.½¨Òé¸ºÔØ×迹£º¡Ý1000¦¸[size=11.0000pt]
[size=11.0000pt]6.×î´óÉùѹ¼¶£¨THD£¼0.5%£¬ÆôÓÃԤ˥¼õ£©£º¡Ý120dB SPL[size=11.0000pt]
[size=11.0000pt]7.¶¯Ì¬·¶Î§£¨ÒÀ¾ÝDIN/IEC 651±ê×¼£©£º¡Ý90dB[size=11.0000pt]
[size=11.0000pt]8.¸½¼þ£º°üº¬×¨Ó÷ÀÕðÖ§¼ÜºÍ·À³±ÊÕÄɺÐ[size=11.0000pt]
[size=11.0000pt]9.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1.Ö¸ÏòÐÔ£ºÐÄÐÍ¡¢³¬ÐÄÐÍ¡°A¡±ÀೡЧӦ¹Üµç·£¬ÎÞ±äѹÆ÷µç·Éè¼Æ£¬22ºÁÃ×ÐÄÐͺͳ¬ÐÄÐÍÖ¸ÏòʰÒôÍ·£¬6΢Ã׶ƽðµÄ¾Ûõ¥±¡Ä¤¸²¸ÇʰÒôÍ·[size=11.0000pt]
[size=11.0000pt]2.²ÉÓÃWimaµçÈÝ ¾§Ìå¹Ü2SK170[size=11.0000pt]
[size=11.0000pt]3.µÍƵÂ˲¨Æ÷Çл»75Hz & 100Hz [size=11.0000pt]
[size=11.0000pt]4.ÁéÃô¶ÈË¥¼õÇл»-10dB/-20dB[size=11.0000pt]
[size=11.0000pt]5.ƵÂÊÏìÓ¦£º50HzÖÁ20kHz +/-3dB[size=11.0000pt]
[size=11.0000pt]6.ÁéÃô¶È£º-40dB @ 1kHz[size=11.0000pt]
[size=11.0000pt]7.×迹£º<200 ohms [size=11.0000pt]
[size=11.0000pt]8.µÈЧÔëÉù£º<15dB£¨A¼ÓȨ£©[size=11.0000pt]
[size=11.0000pt]9.×î´óÉùѹ¼¶£º127dB£¬137db / -10db pad£¬-147db / -20db pad @1kHz£¬ ÓÃÓÚ0.5%×Üг²¨Ê§Õæ[size=11.0000pt]
[size=11.0000pt]10.Ðè48V»ÃÏóµçÔ´£¬Ò»¶ÔרÓû°Í²Æ¤Ì×£¬×¨ÓÃÔ×°Á¢ÌåÉùÖ§¼Ü£¬½ðÊô¼õÕðÆ÷[size=11.0000pt]
[size=11.0000pt]11.½Ó¿Ú£ºXLR 3[size=11.0000pt]
[size=11.0000pt]12.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1 x ÐÄÐζ¯È¦µ×¹Ä»°Í²[size=11.0000pt]
[size=11.0000pt]3 x ÐÄÐζ¯È¦¾ü¹Ä/ͨ¹Ä»°Í²[size=11.0000pt]
[size=11.0000pt]1 x ÐÄÐζ¯È¦ÀÖÆ÷»°Í²[size=11.0000pt]
[size=11.0000pt]2 x ÐÄÐεçÈÝÀÖÆ÷»°Í²[size=11.0000pt]
[size=11.0000pt]3 x »°Í²¼Ð[size=11.0000pt]
[size=11.0000pt]3 x ¹Ä±ß¿òÖ§¼Ü[size=11.0000pt]
[size=11.0000pt]½Ó¿Ú£ºXLR 3[size=11.0000pt]
[size=11.0000pt]°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1.ƵÂÊÏìÓ¦·¶Î§£º20HzÖÁ22kHz¡£[size=11.0000pt]
[size=11.0000pt]2.ÊäÈë×迹£º600ŷķƽºâ¡£[size=11.0000pt]
[size=11.0000pt]3.Êä³ö×迹£º600ŷķƽºâ¡£[size=11.0000pt]
[size=11.0000pt]4.г²¨Ê§Õ棺ÔÚ+20dBmÊä³öʱ£¬20dBÔöÒæËõÐ¡Ê±Ê§ÕæÐ¡ÓÚ1%¡£[size=11.0000pt]
[size=11.0000pt]5.×î´óÊä³ö£º+22 dBm¡£[size=11.0000pt]
[size=11.0000pt]6.ÐÅÔë±È£º²Î¿¼µçƽΪ+10dBm£¬-80dB¡£[size=11.0000pt]
[size=11.0000pt]7.Æô¶¯Ê±¼ä£º´Ó100΢Ãë(¿ØÖÆÐýÅ¥ÉϵÄÁã)µ½5ºÁÃë¡£[size=11.0000pt]
[size=11.0000pt]8.±£³Öʱ¼ä£ºÐ¡ÓÚ2ºÁÃ룬ÌṩÈíÏ÷²¨£¨3dBÏ÷²¨Ê±Ê§ÕæÐ¡ÓÚ3%£©¡£[size=11.0000pt]
[size=11.0000pt]9.ÊÍ·Åʱ¼ä£º¿Éµ÷½Ú´Ó20ºÁÃëµ½2Ãë,Ïà¹ØµÄÊÍ·ÅÇúÏߣ¬¿É´Ó¶ÌÔÝµÄ¸ßµçÆ½Ë²±äÖиü¿ìµØ»Ö¸´£¬Í¬Ê±±£³Ö½ÏÂýµÄ³¤ÆÚƽ¾ùµçƽ¿ØÖÆ£¬ÒÔʵÏÖ¸üκ͵Ķ¯Ì¬±ä»¯[size=11.0000pt]
[size=11.0000pt]10.ͨµÀ´®ÈÅ£º-90dB¡£[size=11.0000pt]
[size=11.0000pt]11.¾²Ì¬Ô¤ÖµºÍ¶¯Ì¬Ô¤Öµ¿Éµ÷½Ú¡£[size=11.0000pt]
[size=11.0000pt]12.ѹËõ±È´Ó1:1µ÷Õûµ½20:1£¬¿Éµ¥¶À×÷ΪLimiter¹¤×÷[size=11.0000pt]
[size=11.0000pt]13.Çл»Ä£Ê½£º¿ÉÔÚÁ½¸ö¶ÀÁ¢Ñ¹ËõÆ÷ÓëÒ»¸öÁ¢ÌåÉùѹËõÆ÷Ö®¼äÇл»¹¤×÷ģʽ¡£[size=11.0000pt]
[size=11.0000pt]14.UV±í¿ÉÇл»ÏÔʾÁ½Í¨µÀѹËõ״̬[size=11.0000pt]
[size=11.0000pt]15.Bypass¹¦ÄÜ£ºÍ¨¹ý¼ÌµçÆ÷À´ÊµÏÖÓ²¼þÌøÏß¡£[size=11.0000pt]
[size=11.0000pt]16.ͬ²½¸ú×Ù£º¿ØÖƵç·ÔÚÕû¸öÔöÒæËõ¼õ·¶Î§ÄÚÆ¥Åä¶ÈСÓÚ0.25dB¡£[size=11.0000pt]
[size=11.0000pt]17.µçÔ´ÒªÇó£º117VAC»ò230VAC¡£[size=11.0000pt]
[size=11.0000pt]18.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
| | [size=11.0000pt]1.Îå¶ÎÍêÈ«²ÎÊýµÄ¸ßµÍƵÂ˲¨Æ÷[size=11.0000pt]
[size=11.0000pt]2.ÊÖ¹¤ÖÆÔì*¾«ÃܵÄÎÞ±äѹÆ÷µç×Ó»º³åƽºâÊäÈëµç·[size=11.0000pt]
[size=11.0000pt]3.DCservoÎȶ¨Ö±½ÓñîºÏÊä³ö[size=11.0000pt]
[size=11.0000pt]4.µÍƵ\¸ßƵ¶Î¿ÉÑ¡BELL\SHELF[size=11.0000pt]
[size=11.0000pt]5.µÍÔëÉù£¬µÍÊ§Õæ£¬¿í¶¯Ì¬·¶Î§£¬¸ßÖÊÁ¿¶Æ½ðXLR»¥Á¬[size=11.0000pt]
[size=11.0000pt]6.ÿ¸öƵ¶Î¶¼Ö§³ÖEQ In\outµÄµ¥¶À¿ØÖÆ [size=11.0000pt]
[size=11.0000pt]7.ÄÚÖÃTrm΢µ÷£¨+/- 2 dB£©[size=11.0000pt]
[size=11.0000pt]8.¡° EQ In\out¡±LED°´Å¥¿ª¹Ø[size=11.0000pt]
[size=11.0000pt]9.ͨ¹ý44¶Î²½½øµçλÆ÷¿ÉÒÔ¾«×¼µÄ¿ØÖÆÐźŲÎÊý[size=11.0000pt]
[size=11.0000pt]10.¾«Ãܵĵç×ÓÆ½ºâµÄXLRÄ£ÄâÊäÈëÊä³ö[size=11.0000pt]
[size=11.0000pt]11.´Ó8Hzµ½50kHzµÄÈý¶ÎÍêÈ«µÄ²ÎÊý¶Î[size=11.0000pt]
[size=11.0000pt]12.ÔöÒæ£¨ÎÞeq.£©0 +/- 2 dB£¨¿Éµ÷½Ú£©[size=11.0000pt]
[size=11.0000pt]13.×ÔÔëÉù£¾-90dBu[size=11.0000pt]
[size=11.0000pt]14.ת»»ËÙÂÊ´óÓÚ200V/us[size=11.0000pt]
[size=11.0000pt]15.THD+N£º£¼-0.01%£¨ÈÎºÎÆµÂÊ¡£´Ó20-20000ºÕ×È¡£[size=11.0000pt]
[size=11.0000pt]16.Êä³ö£º×î´óµçƽ+26 dBu[size=11.0000pt]
[size=11.0000pt]17.3U»ú¼ÜÉè¼Æ[size=11.0000pt]
| | [size=11.0000pt]1.ÄÚÖÃÁ½¸ö»°·Å[size=11.0000pt]
[size=11.0000pt]ÀÖÆ÷DIÊäÈ룬´ø¸ßµÍEQ[size=11.0000pt]
[size=11.0000pt]±ê×¼¿Ø¼þ£ºãÐÖµ£¬Ñ¹Ëõ±È£¬Æô¶¯Ê±¼äºÍÊÍ·Åʱ¼ä[size=11.0000pt]
[size=11.0000pt]ºóÃæ°åÅÔÁ´²åÈëµã£¬¿ÉÌṩÅÔÁ´Ñ¹ËõµÈÀ©Õ¹¹¦ÄÜ¡£[size=11.0000pt]
[size=11.0000pt]¡° Big¡±ºÍ¡° Air¡±Ä£Ê½¿É±£»¤³¬Ô¤ÆÚ£¬ÔöÇ¿³¬¸ßƵ[size=11.0000pt]
[size=11.0000pt]ÊäÈë×迹£º20kÅ·Ä·ÒÔÉÏ[size=11.0000pt]
[size=11.0000pt]2.´óÊäÈëÓÅÊÆ£º+ 21dBu[size=11.0000pt]
[size=11.0000pt]3.Êä³ö½Ó¿Ú£ºXLR¿¨Å©¿Ú£¨x2£©[size=11.0000pt]
[size=11.0000pt]4.Êä³ö×迹£º100Å·Ä·[size=11.0000pt]
[size=11.0000pt]5.´óÊä³ö¹¦ÂÊ£º+ 21dBu£¬10kÅ·Ä·¸ºÔØ[size=11.0000pt]
[size=11.0000pt]6.ÅÔÁ´ÊäÈ룺1/4¡±£¨x2£©£¬Ring =·¢ËÍ£¬Tip =·µ»Ø[size=11.0000pt]
[size=11.0000pt]7.ƵÂÊÏìÓ¦£º20HzÖÁ20kHz£¨+/- 0.5dB£©[size=11.0000pt]
[size=11.0000pt]8.´®ÈÅ£º<-75dB @ 1kHz[size=11.0000pt]
[size=11.0000pt]9.µ¥Î»ÔöÒæÔëÉù£º20Hz-20kHz> 93dB[size=11.0000pt]
| | [size=11.0000pt]1.ÐÅÔë±È(SNR) : 113dB RMS·Ç¼ÓȨ,116 dBA[size=11.0000pt]
[size=11.0000pt]2.ƵÂÊÏìÓ¦ @ 44.1 kHz, -0.1 dB: 5 Hz - 20.8 kHz[size=11.0000pt]
[size=11.0000pt]3.ƵÂÊÏìÓ¦ @ 96 kHz, -0.5 dB: 5 Hz - 45.8 kHz[size=11.0000pt]
[size=11.0000pt]4.ƵÂÊÏìÓ¦ @ 192 kHz, -1 dB: 5 Hz - 92 kHz[size=11.0000pt]
[size=11.0000pt]5.THD: < -110 dB, < 0.00032%[size=11.0000pt]
[size=11.0000pt]6.THD+N: < -104 dB, < 0.00063%[size=11.0000pt]
[size=11.0000pt]7.ƵµÀ·Ö¸ô : > 110dB[size=11.0000pt]
[size=11.0000pt]8.ÊäÈë:6.3mm TRS²å¿Ú,µç×ÓÆ½ºâ[size=11.0000pt]
[size=11.0000pt]9.ÊäÈëÁéÃô¶È£º8 kOhm·Çƽºâ, 12 kOhmƽºâ[size=11.0000pt]
[size=11.0000pt]10.ÊäÈëÁéÃô¶ÈÇл»ÖÁLo Gain,+4dBu,-10dBV[size=11.0000pt]
[size=11.0000pt]11.ÊäÈëµçƽ0 dBFS@ Lo Gain:+19dBu[size=11.0000pt]
[size=11.0000pt]12.ÊäÈëµçƽ0 dBFS@ Lo Gain:+4dBu:+1 DBu[size=11.0000pt]
[size=11.0000pt]13.ÊäÈë:XLR,µç×ÓÆ½ºâ[size=11.0000pt]
[size=11.0000pt]14.ÊäÈë×迹£º3.4 kOhm[size=11.0000pt]
[size=11.0000pt]15.ÐÅÔë±È(SNR):112 dB RMS·Ç¼ÓȨ,116dBA[size=11.0000pt]
[size=11.0000pt]16.ÔöÒæ·¶Î§:54 dB[size=11.0000pt]
[size=11.0000pt]17.×î´óÊä³öµçƽ0 dBFS,¸ß:+16.8dBu[size=11.0000pt]
[size=11.0000pt]18.×î´óÊä³öµçƽ0 dBFS,µÍ:+2dBV[size=11.0000pt]
[size=11.0000pt]19.Êä³ö×迹:30 Ohm[size=11.0000pt]
[size=11.0000pt]20.ADAT ¹âÏË[size=11.0000pt]
[size=11.0000pt]21.2 x TOSLINKÊäÈë/Êä³ö£¬¸ù¾ÝAlesis¸ñʽ[size=11.0000pt]
[size=11.0000pt]22.×ÖʱÖÓ[size=11.0000pt]
[size=11.0000pt]23.BNC, ¿ÉÇл»ÖÕ¶Ë[size=11.0000pt]
[size=11.0000pt]24.°üº¬ÅäÌ×¹ÜÏßÁ¬½Ó¼þµÈ¸¨Öú²ÄÁÏ£¬Âú×ãʹÓÃÒªÇó |
