| [size=10.5000pt]1¡¢»»ÄÜ·½Ê½£º¶¯È¦Ê½[size=10.5000pt]
[size=10.5000pt]2¡¢[size=10.5000pt]ÀàÐÍ[size=10.5000pt]£º·â±Õʽ[size=10.5000pt]
[size=10.5000pt]3¡¢ÆµÂÊÏìÓ¦£º5Hz-35,000Hz[size=10.5000pt]
[size=10.5000pt]4¡¢¶î¶¨×迹£º32 ¦¸[size=10.5000pt]
[size=10.5000pt]5¡¢[size=10.5000pt]ÁéÃô¶È[size=10.5000pt]£º96 dB |
| 1¡¢ CPU:M4 10+10ºË 2¡¢ Äڴ棺16GB 3¡¢ Ó²ÅÌ£º256G£¨ÏµÍ³£©+2T£¨´æ´¢£© 4¡¢ ÍøÂ磺ǧÕ× 5¡¢ USB Type C*2 6¡¢ À×ö¨½Ó¿Ú*3 7¡¢ ÒÔÌ«Íø¶Ë¿Ú*1 8¡¢ HDMI½Ó¿Ú*1 9¡¢ ¶ú»ú½Ó¿Ú*1 |
| [size=10.5000pt]1¡¢³ß´ç£º34Ó¢´ç[size=10.5000pt]
[size=10.5000pt]2¡¢ÆÁÄ»±ÈÀý£º21:9[size=10.5000pt]
[size=10.5000pt]3¡¢½Ó¿ÚÀàÐÍ£ºHDMI¡Á2,DisPlay port,ÒôƵÊä³ö(¶ú»ú½Ó¿Ú)[size=10.5000pt]
[size=10.5000pt]4¡¢ÁÁ¶È£º350cd/m2[size=10.5000pt]
[size=10.5000pt]5¡¢µäÐͶԱȶȣº4000:1[size=10.5000pt]
[size=10.5000pt]6¡¢·Ö±æÂÊ£º3440¡Á1440[size=10.5000pt]
[size=10.5000pt]7¡¢ÏìӦʱ¼ä£º1ms[size=10.5000pt]
[size=10.5000pt]8¡¢Ë¢ÐÂÂÊ£º180Hz[size=10.5000pt]
[size=10.5000pt]9¡¢Ë®Æ½¿ÉÊӽǶȣº178¶È[size=10.5000pt]
[size=10.5000pt]10¡¢´¹Ö±¿ÉÊӽǶȣº178¶È[size=10.5000pt]
[size=10.5000pt]11¡¢±³¹âÀàÐÍ£ºWLED[size=10.5000pt]
[size=10.5000pt]12¡¢ÇúÂÊ£º1500R[size=10.5000pt]
[size=10.5000pt]13¡¢ºÄµç¹¦ÂÊ£º65W[size=10.5000pt]
[size=10.5000pt]14¡¢Íâ¹Û³ß´ç£º811.3¡Á210¡Á510.1mm[size=10.5000pt]
[size=10.5000pt]15¡¢ÖØÁ¿£º6.9kg[size=10.5000pt]
[size=10.5000pt]16¡¢Ç°ÇãºóÑö£ºÇ°5¡ã¡À2ºó21¡ã¡À2 |
| [size=10.5000pt]1¡¢ÔÀí£ºÑ¹²îʽ´«ÉùÆ÷[size=10.5000pt]
[size=10.5000pt]2¡¢Ö¸ÏòÐÔ£ºÐÄÐÎÆµÂÊÏìÓ¦£º20Hz~20kHz[size=10.5000pt]
[size=10.5000pt]3¡¢ÁéÃô¶È£º-35dBÊ¿2dB(OdB=1V/PatE1kHz)[size=10.5000pt]
[size=10.5000pt]4¡¢Êä³ö×迹£º1500Ê¿20%£¨ÔÚ1kHz£©[size=10.5000pt]
[size=10.5000pt]5¡¢¸ºÔØ×迹£º¡Ý10000[size=10.5000pt]
[size=10.5000pt]6¡¢±¾µ×ÔëÉù£º10dBA[size=10.5000pt]
[size=10.5000pt]7¡¢×î´óÊäÈëÉùѹ¼¶£º140dB(TE1kHz=1%T.H.D)[size=10.5000pt]
[size=10.5000pt]8¡¢ÐÅÔë±È£º84dB[size=10.5000pt]
[size=10.5000pt]9¡¢¹©µçÒªÇó£º48V»ÃÏ󹩵ç[size=10.5000pt]
[size=10.5000pt]10¡¢ºÄµçÁ¿£º3mA |
| [size=10.5000pt]1¡¢¸öÈËÒôÀÖÖÆ×÷ϵͳ£¬ÌṩÁËһϵÁиßЧµÄÒôƵ/MIDI¼Òô¡¢±à¼¡¢ÖÆÆ×ºÍ»ìÒô¹¤¾ß[size=10.5000pt]
[size=10.5000pt]2¡¢»ùÓÚÒѱ»È«ÊÀ½çרҵÈËʿ֤Ã÷µÄSteinberg ASIO 2.0¼¼Êõ[size=10.5000pt]
[size=10.5000pt]3¡¢Ö§³Öͬʱ¡Ý64 MIDIºÍ48ÒôƵ¹ì£¬×î´ó24-bit/192kHz[size=10.5000pt]
[size=10.5000pt]4¡¢¡Ý32-bit¸¡µãSteinbergÒôƵÒýÇæ£¬Áé»îµÄ·ÓÉÒÔ¼°È«Ãæ×Ô¶¯µÄÑÓ³Ù²¹³¥[size=10.5000pt]
[size=10.5000pt]5¡¢°üº¬½Ü³öµÄÐéÄâÀÖÆ÷£ºHALion Sonic SE¹¤×÷Õ¾£¬MPC·ç¸ñGroove Agent SE¹Ä»ú£¬PrologueºÏ³ÉÆ÷[size=10.5000pt]
[size=10.5000pt]6¡¢´øÓСÝ44¸öÒôƵЧ¹û´¦ÀíÆ÷£¬°üÀ¨ÓÃÓÚ¸èÉù½ÃÕýµÄPitch Correct£¬MorphFilterºÍרÃÅÕë¶Ô¼ªËûÒôÉ«µÄVST Amp Rack£¨VST·Å´óÆ÷»ú¼Ü£©Ì×¼þ7¡¢ºÍÏÒµæ¿ÉÇáËɱàÅź͹ÜÀíºÍÏÒ[size=10.5000pt]
[size=10.5000pt]8¡¢°üº¬ÊýÒÔǧ¼ÆµÄMIDI¹¹½¨Loop[size=10.5000pt]
[size=10.5000pt]9¡¢¸ßЧµÄÀÖÆ×±à¼¹¦Äܼ¯ |
| 1¡¢ ¾ßÓÐ 120 dB(A) Ä£ÄâÊäÈ뵽ģÄâÊä³ö¶¯Ì¬·¶Î§¡¢0.5 Hz ÖÁ 40 kHz ƵÂÊÏìÓ¦¡£ 2¡¢ ¶àÖÖ²âÁ¿Ä£Ê½£ºÅ䱸¸ß¾«¶È²âÁ¿Âó¿Ë·ç£¬Ö§³Ö¶àµã³¬¾«È·²âÁ¿ºÍ¾«¼ò¿ìËÙ²âÁ¿£¬ÊÊÓ¦²»Í¬ÐèÇó¡£ 3¡¢ Ô¤ÖÆ¶àÌõÊÊÓÃÓÚ´ó¶àÊýÇé¿öµÄ³ö³§Ä¿±êÇúÏߣ¬Ö§³Ö×Ô¶¨Òå¶àÌõÑïÉùÆ÷ÇúÏßÒÔ¼°¿Éµ÷УÕý·¶Î§¡£ 4¡¢ ¸ÄÉÆÏàλÏàÓ¦£¬È·±£¾«È·µÄÁ¢ÌåÉù³ÉÏñ¡£¿É±ä·Ö±æÂÊºÍÆ½»¬¶È 5¡¢ ×Üг²¨Ê§Õ棨THD£©£º0.00035% 6¡¢ Ïàλƫ²î£º×î´ó+7¡ã£¨20Hz£©£¬+16¡ã£¨22kHz£© |
| [size=10.5000pt]1¡¢ÓÃÓÚÒôÀÖÖÆ×÷¡¢»ìÒô¡¢Ä¸´øµÄÇ¿´óÌ××°[size=10.5000pt]
[size=10.5000pt]2¡¢°üº¬93¸ö²å¼þ[size=10.5000pt]
[size=10.5000pt]3¡¢°üº¬Ñ¹Ëõ¡¢EQ¡¢»ìÏì¡¢ÑÓʱ¡¢Ä¸´ø²å¼þµÈµÈ[size=10.5000pt]
[size=10.5000pt]4¡¢Ä£Ä⽨ģ²å¼þ£¬°üÀ¨ËùÓÐCLAϵÁÐѹËõÆ÷¡¢Kramer TapeµÈ[size=10.5000pt]
[size=10.5000pt]5¡¢°üº¬Vocal Rider£¬¿É½øÐÐ×Ô¶¯ÈËÉùÔöÒæ¿ØÖÆ[size=10.5000pt]
[size=10.5000pt]6¡¢°üº¬ÓÃÓÚĸ´ø´¦ÀíµÄϵÁвå¼þ[size=10.5000pt]
[size=10.5000pt]7¡¢Âú×ãËùÓÐĸ´øÖÆ×÷ÐèÇóµÄרҵ²âÁ¿±í 8¡¢ÌṩÕý°æÊÚȨ£¬ÕË»§½»ÓèѧУ¹ÜÀí¡ø |
| [size=10.5000pt]1¡¢´øºá¸Ë±ê×¼»°Í²¼Ü[size=10.5000pt]
[size=10.5000pt]2¡¢¼ÓÅäÖØµ××ù |
| [size=10.5000pt]1¡¢¸ß¶È£º160cm[size=10.5000pt]
[size=10.5000pt]2¡¢ÑÕÉ«£ººÚÉ«[size=10.5000pt]
[size=10.5000pt]3¡¢²ÄÖÊ£ºÌú |
| [size=10.5000pt]1¡¢¶©ÖÆÒôƵ¿ØÖÆÌ¨[size=10.5000pt]
[size=10.5000pt]2¡¢×ÀÃæ16U»ú¼Ü[size=10.5000pt]
[size=10.5000pt]3¡¢×Àµ×20U»ú¼Ü[size=10.5000pt]
[size=10.5000pt]4¡¢³¤¶È£º2Ã× |
| [size=10.5000pt]¶¨ÖÆÂ¼ÒôÊÒ½Ó¿ÚÏ䣬Å䱸Óп¨Å©¡¢HDMI¡¢ÊÓÆµµÈ½Ó¿Ú£¬ÒôÆµÌøÏߺ¬¿¨Å©¡¢´ó¶þо¡¢´óÈýоµÈÂú×ã±¾ÏîÄ¿ÐèÇó |
| [size=10.5000pt]Âú×ã±¾ÏîÄ¿ÐèÇó[size=10.5000pt]£¬[size=10.5000pt]ÏîÄ¿ÅäÌ× |
| [size=10.5000pt]Ê×´ÎÉ豸°²×°µ÷ÊÔ¼°ºóÆÚʹÓÃÅàѵ£¨×¢£ºÊýÁ¿ÎªºóÆÚÅàѵ´ÎÊý£© |
