»¶Ó¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶ÓÀ´µç×Éѯ£¨Ð¤¾Àí £© QQ£º3777144798£» µç»°/΢ÐÅ£º 13371743505£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
²úÆ·ÏêÇ飺 Á½¸öƽºâµÄ7.1ÊäÈëºÍÁ½¸öƽºâµÄÁ¢ÌåÉùÊäÈëµÄÿһ¸ö¾ù¿É·Óɵ½Æ½ºâµÄ7.1Êä³ö¡£Ö÷¶¯ÊäÈëµÄ×óÓÒÐźſÉÒÔ¶îÍⱻ·ÓÉÖÁÈÎÒâÒ»¸öÁ¢ÌåÉùÊä³ö¡£´øÓиßÖÊÁ¿¶ú»ú·Å´óÆ÷£¬¿ÉÒÔÈÃÄãñöÌýÖ÷¶¯ÊäÈëµÄ×óÓÒÐźźÍ·ÓÉÖÁ 7.1 ÊäÈëµÄµ¥ÉùµÀÐźš£ °Ë½ÚµçλÆ÷Ö±½Ó¿ØÖÆËùÓÐͨµÀµÄÒôÁ¿£¬²»Ê¹ÓÃVCAsÕâÑùµÄ¿ØÖƵç·¡£ SMC 7.1 ²ÉÓøßÖÊÁ¿µÄÄ£Äâ¼¼Êõ£¬È·±£ÏßÐÔÆµÂÊÏìÓ¦¸ß´ï100 kHz£¬²¢¾ßÓгöÉ«µÄ¶¯Ì¬·¶Î§¡£ Á½Â·Æ½ºâ7.1ÊäÈë Á½Â·Æ½ºâÁ¢ÌåÉùÊäÈë Æ½ºâ7.1Êä³ö ƽºâÁ¢ÌåÉùÊä³ö£¨´øÓб¸ÓÃÊä³ö£© À©Õ¹µÄ·ÓÉÑ¡Ïî Ö¸¶¨Î»ÖõÄSolo/ÖÐÐÄλÖõÄSolo ¸ßÆ·ÖʵĶú»ú·Å´óÆ÷ רÓÃÄ£ÄâÁ¿±íÊä³ö ÄÚ²¿¹©µç µÂ¹úÖÆÔì ¼¼ÊõÖ¸±ê£º ÊäÈë Sub-D-25-ÊäÈë Sub-D-25 (TASCAM-±ê×¼) ¿¹×è: 20 kOhms CMR: -82 dB ×î´óÊäÈëµçƽ: +22 dB XLR-ÊäÈë Neutrik XLR, symmetrisch, Pin 2 = (+) ¿¹×è: 20 kOhms CMR: -82 dB ×î´óÊäÈëµçƽ: +22 dB Êä³ö Sub-D-25-Êä³ö Sub-D-25 (TASCAM-±ê×¼) ƵÂÊ·¶Î§: 10 Hz to 150 kHz ( -3 dB) ´®ÈÅ at 1 kHz: -92 dB THD & N: 0,001% (0 dBu, 1 kHz, 100 kOhms load) ÔëÉù (A-weighted): -93 dB ¶¯Ì¬·¶Î§: 115 dB XLR-Êä³ö Neutrik XLR, balanced, Pin 2 = (+) ƵÂÊ·¶Î§: 10 Hz to 150 kHz ( -3 dB) ´®ÈÅ at 1 kHz: -92 dB THD & N: 0,001% (0 dBu, 1 kHz, 100 kOhms load) ÔëÉù (A-weighted): -93 dB ¶¯Ì¬·¶Î§: 115 dB ¶ú»úÊä³ö 6.35 mm TRS Á¬½ÓÆ÷ Pin wiring: Tip = Left, ring = right, sleeve = GND ¿¹×è: 22 kOhms ƵÂÊ·¶Î§: 10 Hz to 80 kHz ( -3 dB) ´®ÈÅ at 1 kHz: -70 dB THD & N: 0,001% (0 dBu, 1 kHz, 40 kOhms load) ÔëÉù (A-weighted): -93 dB ¶¯Ì¬·¶Î§: 113 dB ÄÚ²¿²Ù×÷µçѹ Ä£Äâ: +/- 18 V µçÔ´¹©Ó¦ Ö÷µçѹ (¿ÉÇл»): 230 V AC / 50Hz or 115 V AC / 60Hz ±£ÏÕË¿: 230 V = T 500 mA; 115 V = T 1 A ÄÜÁ¿¹¦ºÄ: ×î´ó 25 VA Ìå»ýºÍÖØÁ¿ (WxHxD) 10.95 x 4.6 x 13.1 in (278 x 103 x 333 mm) 9.04 lbs (4.1 kg), Éè±¸ÖØÁ¿
