»¶Ó¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶ÓÀ´µç×Éѯ£¨Ð¤¾Àí £© QQ£º3777144798£» µç»°/΢ÐÅ£º 13371743505£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
²úÆ·¼ò½é£º ¶ÔÓÚÄÇЩ׷ÇóÍêÃÀÓÖ²»Ïë×ö³öÈκÎÍ×еĿñÈȶú»ú°®ºÃÕßÀ´Ëµ£¬Phonitor xe ÊÇһ̨ÖÕ¼«µÄ¶ÀÁ¢É豸¡£Ïà±ÈÆðµÚÒ»´úµÄ Phonitor ¶ú·Å£¬Phonitor xe ×°±¸ÁËÈ«Ð嵀 DAC768¡£ÕâÖÖÄÚ²¿Uber ¨C DAC ¸³ÓèÁË Phonitor xe׿Խת»»ÉùÒôµÄÐÔÄÜ¡£ºÍDSDÒ»Ñù¿ÉÖ§³Ö 32bits PCM ²ÉÑùÂÊ´ïµ½768kHz ¨C ÔÙµ½DSD256 ¨C ÕâЩÊý¾Ý¶¼·Ç³£³öÉ«¡£Í¬Ê±Õą̂ת»»Æ÷µÄÄ£Äâ¶ËÒ²ºÜ³öÉ«£º±ÈÈçÔÚDirector DAC & ǰÖ÷ŴóÆ÷ÖУ¬Ö÷¶¯µÍͨÂ˲¨Æ÷ÊÇÔÚÒ»ÖÖ120V - Voltair - ¼¼ÊõÏÂËùÉè¼ÆµÄ¡£ ¼¼ÊõÖ¸±ê£º XLR ÊäÈë Neutrik XLR£¬Æ½ºâ£¬2Õë = (+) ×迹£ºca. 20 kohms CMR£º-82 dBu (1 kHz) ×î´óÊäÈëµçƽ£º+32.5 dBu RCA ÊäÈë RCA£¬·Çƽºâ£¨µ¥¶Ë£© ×迹£ºca. 10 kohms ×î´óÊäÈëµçƽ£º+32.5 dBu Digital Inputs (¿ÉÑ¡) ͬÖá SPDIF (RCA) ¨C ²ÉÑùÂÊ PCM (kHz): 44.1, 48, 88.2, 96, 176.4, 192 ¹âÏË TOSLINK (F06) ¨C ²ÉÑùÂÊ PCM (kHz): 44.1, 48, 88.2, 96 USB (B) ¨C PCM ²ÉÑùÂÊ (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384, 705.6, 768 USB (B) ¨C DSD 1, 2 ºÍ4 (DoP) AES ¨C ²ÉÑùÂÊPCM (kHz): 44.1, 48, 88.2, 96, 176.4, 192 ƽºâ¶ú»úÊä³ö Neutrik 4-ÕëXLR Á¬½ÓÍ· Pin wiring£º1= ×ó (+), 2= ×ó (-), 3= ÓÒ (+), 4= ÓÒ (-) ×迹£º0.36 ohms ×èÄáÒòÊý£º180 @ 40 ohms ƵÏ췶Χ£º10 Hz - 300 kHz ( -3 dB) 1kHz ´®ÈÅ£º-90 dB THD & N: 0.00082 % (0 dBu, 1kHz, 100 kohms ÔØºÉ) ÔëÒô£¨A-¼ÓȨ£©£º-98 dBu ¶¯Ì¬·¶Î§£º130.5 dB ·Çƽºâ¶ú»úÊä³ö 6.35 ºÁÃ×TRS Á¬½ÓÍ· Pin wiring£ºTip = ×ó£¬Ring = ÓÒ£¬Sleeve = ½ÓµØ ×迹£º0.18 ohm Ë¥¼õϵÊý£º180 @ 40 ohms ƵÏ췶Χ£º10 Hz - 300 kHz ( -3 dB) 1kHz´®ÈÅ£º-90 dB THD & N: 0.00082% (0 dBu, 1 kHz, 100 kohms ÔØºÉ) ÔëÒô(A-¼ÓȨ)£º-103 dB ¶¯Ì¬·¶Î§£º135.5 dB ×î´óÊä³ö¹¦ÂÊ (+30 dBu @ 1 kHz) 2 x 1 W£¬600 Ohm ×迹 2 x 2 W£¬300 Ohm ×迹 2 x 3.7 W£¬120 Ohm ×迹 2 x 2.9 W£¬47 Ohm ×迹 2 x 2.7 W£¬32 Ohm ×迹 ÄÚ²¿²Ù×÷µçѹ Ä£Ä⣺+/- 60 V Êý×Ö£º+ 5 V ºÍ + 3,3 V (¹âÏËDAC768) ¹©µç Ö÷µçѹ (¿ÉÇл»)£º230 V AC / 50 Hz »ò115 V AC / 60 Hz ±£ÏÕ£º230 V: T 500 mA; 115 V: T 1 A ¹¦ºÄ£º×î´ó40 VA ´ý»ú¹¦ºÄ£º0.7 W Ìå»ý 278 ºÁÃ× ¿í x 100 ºÁÃ× ¸ß x 330 ºÁÃ× Éî 10.95 Ó¢´ç ¿í x 3.94 Ó¢´ç ¸ß x 12.99 Ó¢´ç Éî ÖØÁ¿ 11.24 °õ (5,1 ǧ¿Ë), ¾»ÖØ 13.78 °õ (6,25 ǧ¿Ë), Ã«ÖØ
