»¶Ó¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶ÓÀ´µç×Éѯ£¨Ð¤¾Àí £© QQ£º3777144798£» µç»°/΢ÐÅ£º 13371743505£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
Í»³öÌØµã£º 120V rail ¶ú»ú·Å´óÆ÷¼°Ç°Ö÷ŴóÆ÷ ¶ÀÁ¢Á¬½ÓºÍ¹¦ÂÊ·Å´óÆ÷£¨¶ú»úƽºâ»ò·Çƽºâ£© ÊÊÓÃÓÚËùÓÐ×迹´óÓÚ10 ohmsµÄ¶ú»ú ƽºâºÍ·ÇƽºâÄ£ÄâÊäÈë (XLRºÍ RCA) ¿ÉÑ¡Êý×ÖÊäÈë: USB, ͬÖáºÍ¹âÏË ¿ÉÑ¡ DAC: 192kHz ºÍ 24 Bit, WinÇý¶¯¹©Ó¦, Apple¼æÈÝ Æ½ºâºÍ·ÇƽºâÄ£ÄâÊä³ö (XLRºÍ RCA) ¸ïÃüÐÔµÄPhonitor Matrix:ÊÊÓöú»úÊÔÌýµÈЧ¼àÌýÒôÏä µ¥²àÐÔ¿ØÖÆ: ³¬¼¶Æ½ºâ¿ØÖÆ µ¥ÉùµÀת»»¹¦ÄÜ Ò£¿ØÒôÁ¿µ÷½Ú (²ÎÕÕÈκκìÍâÏß¿ØÖÆ) ×î´óÊä³ö¹¦ÂÊ: 2 x 3.7W (120 ohms) ƵÂÊÏìÓ¦: 10 Hz - 300kHz (-3 dB) THD+N: 0.00091 % (HP), 0.00085 % (Ïß·) ¶¯Ì¬·¶Î§: 135.5 dB(HP), 136.3 dB (Ïß·) AMP CTRÁ¬½Ó£¬ÐÔÄܹ¦ÂÊ·Å´óÆ÷ÒÔÖ§³ÖÅä¶ÔÇл» µÂ¹úÖÆÔì ¼¼Êõ²ÎÊý£º XLR ÊäÈë Neutrik XLR, ƽºâ, Õë 2 = (+) ×迹: ca. 20 kohms CMR: -82 dBu (1 kHz) ×î´óÊäÈëµçƽ: +32.5 dBu RCA ÊäÈë RCA, ·Çƽºâ(µ¥¶Ë) ×迹: ca. 10 kohms ×î´óÊäÈëµçƽ: +32.5 dBu Êý×ÖÊäÈë (¿ÉÑ¡) ͬÖá SPDIF (RCA) ¹âѧ TOSLINK (F06) USB (B) ²ÉÑùÂÊ (kHz):44.1, 48 , 88.2, 96, 176.4, 192 ƽºâ¶ú»úÊä³ö Neutrik 4-ÕëXLR ½Ó¿Ú Õë»·Ïß: 1= L (+),2= L (-), 3= R (+), 4= R (-) ×迹: 0.36 ohms ×èÄáÒòËØ: 180 @ 40ohms ƵÂÊ·¶Î§: 10 Hz to300 kHz ( -3 dB) 1kHzʱ´®ÈÅ: -90 dB THD & N: 0.00091 % ( 0 dBu, 1kHz, 100 kohmsÔØºÉ) ÔëÒô (A¼ÓȨ): -98 dBu ¶¯Ì¬·¶Î§: 130.5 dB ·Çƽºâ¶ú»úÊä³ö 6.35 ºÁÃ×TRS ½Ó¿Ú Õë»·Ïß: Tip = ×ó, Ring = ÓÒ, Sleeve = ½ÓµØ ½ÓµØ: 0.18 ohm Ë¥¼õÒòÊý: 180 @ 40ohms ƵÂÊ·¶Î§: 10 Hz ÖÁ 300 kHz ( -3 dB) 1kHzʱ´®ÈÅ: -90 dB THD & N: 0.00091% (0 dBu, 1 kHz, 100 kohmsÔØºÉ) ÔëÒô (A¼ÓȨ): -103 dB ¶¯Ì¬·¶Î§: 135.5 dB ×î´óÊä³ö¹¦ÂÊ (+30dBu @ 1 kHz) 2 x 1 W£¬£¨600 Ohm ×迹£© 2 x 2 W£¬£¨300 Ohm ×迹£© 2 x 3.7 W£¬£¨120 Ohm ×迹£© 2 x 2.9 W£¬£¨47 Ohm ×迹£© 2 x 2.7 W£¬£¨32 Ohm ×迹£© ÑïÉùÆ÷/Ïß· Êä³ö Neutrik XLR, ƽºâ, Õë 2 = (+) RCA, ·Çƽºâ(µ¥¶Ë) ƵÂÊ·¶Î§: 4 Hz ÖÁ 300 kHz (-3 dB) 1 kHzʱµÄ´®ÈÅ: -106 dB THD & N: 0.00085 % ( 0 dBu, 1 kHz, 100 kohmsÔØºÉ) ÔëÒô (A-¼ÓȨ): -103.8 dB ¶¯Ì¬·¶Î§: 136.3 dB ÄÚ²¿²Ù×÷µçѹ Ä£Äâ: +/- 60 V Êý×Ö: + 5 V ºÍ + 3,3 V (¿ÉÑ¡) ¹©µç µçÔ´µçѹ (¿ÉÇл»): 230 V AC / 50 Hz »ò 115 V AC / 60 Hz ±£ÏÕ: 230 V: T 500mA; 115 V: T 1 A ÄÜÁ¿¹¦ºÄ: max 40 VA ´ý»úʱµÄÄÜÁ¿¹¦ºÄ: 0.7 W Ìå»ý 278 ºÁÃ׿í x 100 ºÁÃ× ¸ß x ºÁÃ× Éî 10.95 Ó¢´ç¿í x 3.94 Ó¢´ç ¸ß x 11.19 Ó¢´ç Éî ÖØÁ¿ 4.3 ǧ¿Ë; 9.5 °õ (Ö»°üÀ¨Phonitor x) 5.4 ǧ¿Ë; 11.9 °õ (ÕûÌå°ü×°ÖØÁ¿)
