¼ÒôÅïÉ豸Çåµ¥2
Ó²¼þ²úÆ·
»¶Ó­¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾­ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ­×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶Ó­À´µç×Éѯ£¨Ð¤¾­Àí £© QQ£º3777144798£» µç»°/΢ÐÅ£º 13371743505£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
»ìÒôÅᆱ¹¤ÉùѧÌ×¼þ370.   Éùѧģ¿é£º×ÜÌå²»µÍÓÚ 30 ¸öÉùѧģ¿é£¬ÔÚ½Ì ÊÒÀïÁ½¸ö»òÒ»ÁÐ LENRD ´¹Ö±µþ¼ÓʹÓã¬Ðü¹ÒºóÎüÊÕ µÍÒô£º50hz
371.   Éùѧģ¿é³ß´ç£º¡Ý120x30cm£¬ÎüÒôƵÂÊ£º²»µÍ ÓÚ 100hz
372.   Ç½ÌåÉùѧ´¦Àí£º×¤²¨ºÍ²üÕñ»Ø²¨²»µÍÓÚ 15 ¿é £¨³ß´ç£º30cm*30cm£©373.   ÈýάÉùÀ©É¢Ì壺¡Ý120x30x15cm Ò»×é 4 ¿é£»²¨ ÀËÐÍÀ©É¢ÌåÊÇÈýάµÄ£¬³£ÓÃÀ´²úÉú·Ç³£³öÉ«µÄ»·¾³ Éù³¡¡£ÕâЩÀ©É¢Ìå¿ÉÒÔ¸ü¾«È·µØ¿ØÖÆÉùÒô·´É䣬Èà ·¿¼äÖÐµÄÆµÏì¸üƽ̹»·±£ºÍ×èȼ¡£²ÄÖÊ£º¸ßÃܶȲ£ Á§ÏËά£»¿íƵ´øÈý½ÇʽµÍƵÎüÉù´¦ÀíÏÝÚå¡£
374.   ÅäÌ×ÒôÀÖ¼¶µØÃæ¾²µçµØ°å¼°Ç½ÃæÉý¼¶
375.   ¸ôÒô´°Á±½¨Éè 40 ƽÃ×
376.   µÆ¹â£º¸ù¾Ý½Ìѧ³¡¾°ÅäÖáÝ4 ÖÖĬÈϳ¡¾°Ä£Ê½£¬ Ö§³Ö¿ìËÙÅäÖ㻳¡¾°¿ìËÙÇл»£¬¸ù¾ÝʹÓÃÐèÇóÄܹ» ¿ìËÙÇл»ÕûÌ嵯¹âÕÕÃ÷״̬¡£
ȫƵ¸ôÉùǽÌåרÓÃÉùѧģ¿é377.   ¸´ºÏ¸ôÉù½á¹¹
378.   ¸ôÉùÁ¿ Dntw¡Ý45dB
379.   ¿ÕÇ»ÎüÒôÒ»²ãDntwb¡Ý25 ¹ú¼ÒB1 ¼¶·À»ð±ê×¼£» ¹ú¼Ò E1 ¼¶»·±£±£×¼¡£
380.   ¸÷ÊҵĻìÏìʱ¼ä¼°ÆäƵÂÊÌØÐÔÓ¦·ûºÏÉè¼ÆÉù ѧָ±êÒªÇó¡£
381.   ¸÷ÊÒÎÞ»ØÉù¡¢²ü¶¯»ØÉù¼°ÉùȾɫµÈÒôÖÊȱÏÝ¡£
382.   ÊÒÄÚÉù³¡ÌØÐÔÁ¼ºÃ£¬Éù³¡·Ö²¼¾ùÔÈ£¬Âú×ãÏÖ³¡ ¼Òô¼°ºóÆÚÖÆ×÷µÄÒªÇó¡£
383.    ÊÒÄÚ×ã¹»°²¾²£¬½¨ÖþÍâ»·¾³¼°¿Õµ÷¡¢Í¨·çϵͳ ÎÞÔëÉù¸ÉÈÅ¡£
384.   Éùѧ²ÄÁϵÄÑ¡Óú͹¹ÔìµÄÉè¼Æ¡¢ÅäÖþßÓÐÁ¼ºÃ µÄ×°ÐÞÊÓ¾õЧ¹û£¬ÔÚ´ïµ½ÉùѧҪÇóµÄͬʱ£¬¾ß±¸½Ï ºÃµÄ¼¼Êõ¾­¼ÃÐÔ¡£
385.   Éùѧ²ÄÁϺ͹¹ÔìµÄÑ¡Óá¢Éè¼ÆÓ¦Âú×ãÓйØÏû·À ÒªÇó¡£
386.   Í¨Óñê×¼£¬¸ù¾ÝÒôƵÉ豸ѡÅ䣬°üÀ¨£ºÄ£ÄâÏß¡¢ Êý×ÖÏß¡¢¹âÏËÏßÀ 8 ͨµÀÒôƵÏßÀ¡¢Ï߱ꡢÔúÏß´ø µÈ¡£
ȫƵÎüÉùǽÌåÌ컨µØÃæ×¨ÓÃÉùѧģ¿é387.½á¹¹»ìÏìʱ¼ä
RT60 at 63 Hz 0.3s-0.5s RT60 at 125 Hz 0.3s-0.5s RT60 at 250 Hz 0.3s-0.5s RT60 at 500 Hz 0.35s-0.55s RT60 at 1000 Hz 0.4s-0.6s RT60 at 2000 Hz 0.4s-0.6s RT60 at 4000 Hz 0.4s-0.6s RT60 at 8000 Hz 0.35s-0.5s
RT60 at 8000 Hz up 0.35s-0.5s
388.ȫƵÎüÉùǽÌåרÓÃÉùѧģ¿éÔ¼ 128 ƽ·½
¹ú¼Ò B1 ¼¶·À»ð±ê×¼£»¹ú¼Ò E1 ¼¶»·±£±£×¼
ÒôƵ¹¤×÷Õ¾Èí¼þÊÚȨ390.¶à¹ì¼ÒôÓë»ìÒô£º²ÉÑùÂʵļÒô£¬Äܹ»´¦Àí»·ÈÆÉùϵͳ£¬Êʺϸ´ÔÓµÄÒôƵºóÆÚÖÆ×÷ÐèÇó¡£
ÒôƵ´¦Àí£ºÖ§³Ö VST2.0 Plug-ins¡¢ÐéÄâInstrument ÒÔ¼° ASIO2.0 ¼æÈÝÒôƵӲ¼þ£¬ÌṩÖÇÄÜ»¯µÄ×Ô¶¯ MIX ´¦Àí¹¦ÄÜ 2¡£
392.¸ñʽ֧³Ö£ºÖ§³Ö¶àÖÖÒôƵºÍÊÓÆµ¸ñʽ£¬°üÀ¨NTSC¡¢PAL/SECAM µÈ£¬ÊÊÓÃÓÚ²»Í¬µÄÓ°ÊÓÖÆ×÷ÐèÇó 3¡£
393.×Ô¶¯»¯¿ØÖÆ£ºÌṩÁé»îµÄ×Ô¶¯»¯¿ØÖƹ¦ÄÜ£¬Óû§¿ÉÒÔ½øÐÐÎÞÏÞ¼¶µÄ Undo/Redo ²Ù×÷£¬¼Ç¼²¢ÐÞ¸ÄÈκÎÒôƵ±à¼­²½Öè¡£
394.ϵͳÁ´½Ó¼¼ÊõÔÊÐíͨ¹ý¶ą̀¼ÆËã»úÏ໥Áª½Ó£¬ ÐγÉÅÓ´óµÄϵͳ¹¤³Ì¡£
¼àÌýÄÜÁ¦
Êý×ÖÒôƵ½Ó¿Ú396.×Üг²¨Ê§Õæ ²»Ð¡ÓÚ£¨THD£©+ÔëÉù£º-115 dB @ 22dBu £¨0.00020%£© δ¼ÓȨ
397.¶¯Ì¬·¶Î§£º¡Ý122dB A ¼ÓȨ
398.×î´óÊäÈëµçƽ£º¡Ý+4dB ÉèÖãº+24dBu-10dB ÉèÖãº+6dBV
399. ƵÂÊÏìÓ¦ 44.1 ¨C 20,000 kHz £¨+/- 0.05dB£©
400.ÊäÈë×迹£º¡Ý10K£»
401.ÊýÄ££ºTHD+N£º-119dB @ 21 dBu
402.¶¯Ì¬·¶Î§£º¡Ý126 dB A ¼ÓȨ
403.Êä³ö×迹£º¡Ý50 Å·Ä·
¶ú»úÊä³ö£ºÇ°Ãæ°å²»ÉÙÓÚ 1 ¸öÁ¢ÌåÉù 1/4 Ó¢´ç¶ú»úÊä³ö¡£
¿ØÖÆÌ¨ÍÆ×Ó£º8 x 100mm£¬µç¶¯£¬´¥Ãþ¸ÐÓ¦
±àÂëÆ÷/µãÊý£º8 x Ðýת±àÂëÆ÷£¬Íƶ¥Ê½£¬´¥Ãþ¸ÐÓ¦Èí¼ü£º¶À×࣬¾²Òô£¬Ñ¡Ôñ£¬Â¼Òô£¬Î¢µ÷£¬´æ´¢
¼ÆËã»úÁ¬½Ó£ºÒÔÌ«Íø
USB£º1 x A ÐÍ£¨Æ½°åµçÄÔ³äµç£©
Êý¾Ý I / O£º1 x ÒÔÌ«Íø£¬Wi-Fi ÆäËû I / O£º1 x 1/4 ¡°£¨½Å̤¿ª¹Ø£©
Êý×Öµ÷Òǫ̂406 ¾ß±¸²»ÉÙÓÚ 24 ¸öÎïÀíµç¶¯Âí´ïÍÆ×Ó£¬Ö§³Ö¶à²ã
·­Ò³¡£Ã¿¸öÎïÀíÍÆ×ÓÅ䱸ÓвÎÊýÐýÅ¥¡¢Í¨µÀ״̬´°¿Ú¡¢MUTE/SOLO/SEL °´¼ü¡£407.¾ß±¸ 3 ¿éÆßÓ¢´ç²ÊÉ«´¥¿ØÏÔʾÆÁ¡£¿É¶ÔÓ¦ÍÆ×ÓͨµÀÌõÒ»Ò»¶ÔÓ¦µÄÏÔʾÔöÒæ¡¢¶¯Ì¬¡¢¾ùºâ¡¢Ä¸Ïß·ÖÅä¡¢µçƽ±íµÈ²ÎÊýÖµ£¬¿ÉÇл»ÏÔʾµ¥¸ö/²»Í¬Í¨µÀµÄÏêϸͨµÀ²ÎÊý¡¢Ä¸Ïß·ÖÅäÇé¿öµÈÄÚÈÝ£»¾ß±¸²»ÉÙÓÚ 2 ¸öÀ©Õ¹¿¨²Û룬¿ÉÖ§³Ö Analog¡¢AES¡¢MADI¡¢Dante¡¢SMPTE ST-2110 ¸ñʽµÄÀ©Õ¹¿¨¡£
408.¾ß±¸²»ÉÙÓÚ 32 ·[AUX/GROUP ¿ÉÇл» MIX ×ÜÏß¡£
409.²»ÉÙÓÚ 22 · MAIN L/R ×ÜÏß¡£
410.²»ÉÙÓÚ 1 ·(Stereo), Fx ·¢ËÍ×ÜÏß¡£
411.¾ß±¸²»ÉÙÓÚ 2 ¸öÀ©Õ¹¿¨²Û룬ÖÁÉÙÖ§³Ö Analog¡¢AES¡¢Dante¡¢MADI£¨64ch£©µÈ¸ñʽ½Ó¿ÚµÄÀ©Õ¹¡£
412.µ÷Òǫ֧̂³Ö¶àÀàÐÍͬ²½Ðźţ¬¿ÉÖ§³ÖÄÚͬ²½¡¢Worldclock¡¢Dante µÈͬ²½ÐźÅÔ´¡£
413.µ÷Òǫ̂ÔÚ 48KHz ²ÉÑùÂÊÏ£¬¾ß±¸²»ÉÙÓÚ 40 ·µ¥ÉùµÀ¡¢2 ×éÁ¢ÌåÉùµÄ DSP ÊäÈëͨµÀ¡£Ã¿¸öͨµÀÐè¾ßÓоùºâ¡¢ÉùÏñµ÷Õû¡¢¶¯Ì¬´¦Àí¡¢ÑÓʱµÈ¹¦ÄÜ¡£
414.ÊäÈë¶Ë¿Ú£º×î´ó 160 ¶Ë¿Ú(96khz)£¬×î´ó 256 ¶Ë¿Ú(48khz)£¬ MIC/LINE: 24£¬Á¢ÌåÉù(RCA): 4 (2st)£¬ Dante:32 (96khz)/64 (48khz)£¬ SLOT:32 ³2 (96khz)/64³2 (48khz)£¬USB Audio: 32£¬ÄÚÖò¥·ÅÆ÷:2(1st)£¬OSC:1¡¢TALKBACK: 1¡£
415.ÄÚÖà FX Ч¹û£º4 [REVERB £¨Mono¡¢Stereo¡¢Plate¡¢Gate£©¡¢DELAY £¨Mono¡¢Stereo¡¢Ping-Pong¡¢LCR£©¡¢CHORUS¡¢FLANGER¡¢PHASER¡¢PITCH SHIFTER]¡£
416.¿ØÖƽӿڣºRJ-45 ½Ó¿Ú£¬¹æ¸ñ£º100BASE-TX¡¢1000BASE-T¡£
417.Ö§³Ö¼Òô£ºWAV/BWF ¼Òô : 48kHz/96kHz¡¢24bit¡¢2ch ²¥·Å : 48kHz/96kHz¡¢16/24bit¡¢2ch¡£
418.½Ó¿Ú£ºPrimary/Secondary £¨etherCON® Cat5e ½Ó¿Ú£©, 64ch £¨48kHz£©/ 32ch £¨96kHz£©, Ö§³Ö
32³32 ÒôƵÁ÷¡£
Ö÷¼àÌýÒôÏä419 ÀàÐÍ£ºÈý·ÖƵÉùѧͬÖáÖÇÄÜÓÐÔ´ÒôÏä
420. Éùѹ£º¡Ý110dB
421. ƵÂÊÏìÓ¦£º¡Ý32Hz - 40kHz
422. µ¥Ôª´óС£ºµÍÒô=ÍÖÔ²½Ï´óÖ±¾¶ 8'x2 ÖÐÒô¡Ý5' ¸ßÒô¡Ý3/4' ÖиßÒôͬÖá
423. µ¥Ôª¹¦ÂÊ£ºµÍÒô¡Ý150W ÖÐÒô¡Ý120W ¸ßÒô¡Ý90W
424. ÊäÈë½Ó¿Ú£º¡Ý1 x XLR ¿¨Å©¿ÚÄ£ÄâÊäÈ룬¡Ý1 x XLR AES Êý×ÖÊäÈë / ¡Ý1 x XLR AES Êý×ÖÊä³ö£¬¡Ý2 x RJ45 ¿ØÖÆÍø¿Ú
»·ÈƼàÌý 425 ƵÂÊÏìÓ¦·¶Î§ 38 Hz - 37 kH ƵÂÊÏìÓ¦¾«×¼¶È
¡À 1.5 dB(45 Hz - 20 kHz)
426. ¹¦·Å¹¦ÂÊµÍÆµ 250 W ÖÐÆµ 150 W ¸ßƵ 150 W
427. ÒôƵ½Ó¿ÚÀàÐÍ 1 x XLR Ä£ÄâÊäÈë 1 x XLR AES/EBU Êý×ÖÊäÈë 1 x XLR AES/EBU Êý×ÖÊä³ö
µÍÒôÒôÏä428. µÍÒôµ¥Ôª£º¡Ý12 ´çµÍÒôÅÚ£»½Ï´óÉùѹ£º¡Ý113dB
429. ƵÂÊÏìÓ¦£º¡Ý19Hz - 100Hz £¨-6dB£©/LFE 19Hz
- 150Hz £¨-6dB£©
430. µ¥Ôª¹¦ÂÊ£º¡Ý400W £¨D Àࣩ
431. ÊäÈë½Ó¿Ú£º¡Ý7.1 Ä£Äâ XLR ÊäÈë/Êä³ö£¬1*ÊäÈë/1*Êä³ö XLR Êý×Ö AES/EBU£¬2* RJ45 ¿ØÖÆÍøÂç
À©Éùϵͳ²âÁ¿Ð£×¼Ì×¼þ432. Ö§³ÖÒôÏìϵͳ£ºÖ§³Ö²»ÉÙÓÚ 20 Ö»ÒôÏäУ׼
433. ²ÉÑùÂÊ£ºÖÁÉÙ°üÀ¨ 44.1kHz, 48kHz, 88kHz, 96kHz, 192kHz
434. Çý¶¯£º¶àͨµÀ²âÁ¿ ¨C ASIO¡£Á¢ÌåÉù²âÁ¿ ¨C ASIO, WASAPI
435. ²å¼þÀàÐÍ£ºÖÁÉÙ°üÀ¨ VST 2.4v, VST3, AU, AAX
·µÌý¶ú»ú436. ÀàÐÍ£º·â±Õ¶¯È¦Ê½Â¼ÒôÅï¼àÌý¶ú»ú
437. Çý¶¯µ¥Ôª£º¡Ý50 ºÁÃ×îÏÌúÅð´ÅÌú
438. ƵÂÊÏìÓ¦£º10Hz-32kHz
439. ÁéÃô¶È£º98dB (+/-3dB 1mW @ 1kHz) 440. ×迹£º32¦¸(+/- 15% @1000Hz)
441. ×î´óÊäÈ빦ÂÊ£º1500mW
12 ·¶ú»ú·Å´óÆ÷442.ͨµÀ£º18 ͨµÀ£»
443.¿ØÖÆ£ºË«¹¦ÄÜÅÌ/ÿͨµÀ»ìºÏ¿ØÖÆ
444.½Ó¿Ú£ºÇ°Ãæ°åºÍºóÃæ°åÊä³ö²å¿Ú
445.ƽºâÊäÈ룺XLR ºÍ 1/4 Ó¢´ç TRS ƽºâÊäÈë
446.¹¦ÄÜ£ºÄÜÒÔÁ¢ÌåÉù¡¢µ¥ÉùµÀ£¨ÐźÅÔ´×󣩡¢µ¥ÉùµÀ£¨ÐźÅÔ´ÓÒ£©»ò×ܵ¥ÉùµÀ£¨ÐźÅÔ´×óºÍÓÒ£©Ä£Ê½²Ù×÷¡£
447.Ðźţº¸¨Öú·ÖÀëÐźÅÔ´ÊäÈë
LED µçƽ£ºËùÓÐͨµÀºÍ×ÜÏß´ø 8 ¶Î LED µçƽָʾ
»°Í²·ÖÅäÆ÷449.²»ÉÙÓÚ 16 ͨµÀÎÞÔ´»°Í²·ÖÅäÆ÷
450.²»µÍÓÚÈý··ÖÅäÊä³ö һ·ֱͨ ; ¶þ·ÒôƵ¸ôÀë±äѹÆ÷Êä³ö ; ½ÓµØÑ¡Ôñ¿ª¹Ø
451.ÐèÖ§³ÖÖ§³ÖÈý·Êä³öͬʱ¹©µç
452.Ö§³Ö¹ã²¥¼¶±ê×¼ & Ä£¿é»¯Éè¼Æ
453.ƵÂÊÏìÓ¦£º20Hz - 20kHz ¡À0.2dB
454. ×î´óÊäÈëµãƽ£º +16dBu (0.930% 50Hz) ;
+24dBu (0.008% 1KHz) ; +26dBu (0.006% 1KHz) 455. Ê§Õæ¶È£º0.001% (0dBu% 1KHz)
456. ÐÅÔë±È¡Ý£º101dB
457. ²åÈëËðºÄ-3dB @ 600¦¸
½Ó¿ÚÏä458.ÊäÈëÊä³ö½Ó¿Ú£º²»µÍÓÚ 16 XLR Âó¿Ë·ç/Ïß·ÊäÈ룬²»µÍÓÚ 16 XLR Ïß·Êä³ö¡£
459.²»µÍÓÚ 16 in/16 out Dante ÆôÓÃÈßÓàµÄ½ÓÏߺС£
460.²»µÍÓÚ 16 XLR mic/line ÊäÈë´ø+48 »ÃÏóµçÔ´ºÍ SIG OL LED ÊäÈëÐźÅ/¹ýÔØÖ¸Ê¾µÆ¡£
461.²»µÍÓÚ 16 XLR line Êä³ö´ø SIG OL LED Êä³öÐźÅָʾµÆ¡£
462.²»µÍÓÚ 96 kHz ²ÉÑùºÍ 32bit ¾«¶È
463.Ö§³ÖµØ°å°²×°ºÍ 3U »ú¼Ü°²×°
464.¿Éͨ¹ýÁ¬½ÓÊý×Öµ÷Òǫ̂½øÐÐÍêÈ«¿ØÖÆ¡£
¿ØÖÆÓ¦ÓóÌÐò½øÐÐÔ¶³Ì¿ØÖƺÍÀëÏ߱༭¡£466.Å䱸 DC ÊäÈëºÍÖ§³ÖÈßÓ๩µç
467.Å䱸²»µÍÓÚ 8 in/8 out À©Õ¹ GPIO ¶Ë×Ó£¬Á¬½Óµ½ TASCAM Sonicview µ÷Òǫ̂ʱ¿ÉÀ©Õ¹ÖÁ 16 in/16 out
468.¿ÉÇл»µÄ²Î¿¼µçƽ
469.Å䱸 etherCON ¼æÈÝÁ¬½ÓÆ÷×÷Ϊ Dante Á¬½Ó
470.Ö§³Ö Dante Óò¹ÜÀíÆ÷
471.Ö§³Ö AES67 »¥²Ù×÷ÐÔ
472.SMPTE ST 2110 »¥²Ù×÷ÐÔ
473.ÊäÈë×迹£º5.0k¦¸
474.ͨµÀÊýÁ¿£º²»µÍÓÚ 64 channels (48 kHz), 32 channels (96 kHz)
475.ÒÔÌ«Íø¿Ú£º1000BASE T(IEEE802.3ab)
Ö§³ÖÈßÓàģʽºÍÇл»Ä£Ê½
¶àͨµÀ»°Í²·Å´óÆ÷477.ÀàÐÍ£º°ËͨµÀÊý×ÖÂó¿Ë·çǰÖ÷ŴóÆ÷»°·Å
478.Ä£ÄâÊäÈ룺¡Ý8 ¸ö¿¨Å©/´óÈýо ¸´ºÏÊäÈë½ÓÍ·
479.Ä£ÄâÊä³ö£º¡Ý8 ¸ö¿¨Å©¹« XLR Êä³ö½Ó¿Ú
480.ADDA ת»»²ÉÑùÂÊ£º24Bit-192kHz
481.ÐÅÔë±È(SNR):¡Ý113dB£¬RMS ·Ç¼ÓȨ£¬116dBA
482.»ÃÏëµçÔ´£º¡Ý8 ¸ö»ÃÏëµçÔ´¿ª¹Ø
483.ƵÂÊÏìÓ¦£º¡Ý192kHz ʱ£¬-1dB:5Hz¡«92kHz
484.ÏÔʾ£º¡Ý2 ¶Î OLED ÂÌÉ«ÐźÅ/ºìÉ«ÐźÅÏÔʾ
485.SYNC ʱÖÓ£º¡Ý1 ¸ö±ê×¼²ÉÑùÂÊ: 1³8 ͨµÀ£¬ 24Bit£¬ 48kHz¡£
486.±³Ãæ°åËĸöÇл»¿ª¹Ø£ºÄ£ÄâIN/ADAT/48kHz/44.1kHz
487.Êý×ÖÊäÈëÊä³ö£ºADAT8 ͨµÀÊäÈëÊä³ö½ÓÍ·
488.´®ÐнӿڣºÄÚÖà RS232 ¼ÆËã»ú´®¿ÚÊý¾ÝͨÐŽӿÚ
489.ÊäÈë×迹:¡Ý3.4kOhm
490.Êä³ö×迹:¡Ý30Ohm
·Å´óÔöÒæ·¶Î§:¡Ý65dB
ÒôƵ¸ôÀëÆ÷492. ÒôƵµç·ÀàÐÍ:ÎÞÔ´Ïß·µçƽ¸ôÀ룬»ùÓÚ±äѹÆ÷ͨµÀÊýÁ¿:Á¢ÌåÉù(Ë«µ¥ÉùµÀ)ƵÂÊÏì
Ó¦:10Hz~50KHz(¡À1dB)¶¯Ì¬·¶Î§:135dB
×î´óÊäÈë:+21dBu@1kHz£¬1%THD+N ×Üг²¨Ê§
Õæ:0.001% @ 1kHz,+ 4dBu Êä³öÏàλƫ²î:0.5¡ã@ 100Hz;37¡ã@ 20Hz¡£
´ó»°Í²Ö§¼Ü493.¶à¹¦ÄÜ»°Í²Ö§¼Ü¡Ý1 Ö§
494.ËÜÁϱ£»¤Ä¤¡Ý1 ¸ö
495.¶à¹¦ÄÜ»°Í²¼Üת½Ó¿Ú¡Ý1 ¸ö
496.¿¨Ï߿ۡÝ1 ¸ö
497.²ÄÖÊ£ººÏ½ð½á¹¹¸Ö ¸Ö½á¹¹°ÑÊÖ
498. ½Ç¶È£º¡Ý5 ½Ú 180¡ãµ÷½Ú
499. ¹¦ÄÜ£º¿ÉÒÔÇãб´¹¹ÒÒ²¿ÉÒÔÊúÖ±Ö§ÍÐ
500. ¸ß¶È£º¿ÉËæÒâµ÷ÕûÈ«
501. Ö§³Å¹ÜÖ±¾¶£º²»Ð¡ÓÚ 20-25-30-35-40mm
502. ºá±Û£º²»Ð¡ÓÚ 110-215cm
503. ¸ºÖØ£º²»µÍÓÚ 3-5kg
»°Í²¼Ü504. ÂäµØÊ½»°Í²Ö§¼Ü¼Ó¹ÌÐÍ£¬»Æ½ð±ÈÀýÈý½ÅÖ§³Åµã
505. ²ÉÓüӺñ¸Ö¹Ü£¬ËܽºÂó¿Ë·ç²åÈëÍ·
506. ºá¸Ë²¿Î»²ÉÓÃÌúºÍÂÁºÏ½ð×öÖ§³Åµã,¸ü¼Ó¼á¹Ì
507. »°Í²½Ç¶È¿Éµ÷£»ÊÖŤʽÌú×ùÖ§¼Ü¡£508. ºá¸Ë³¤¶È£º¡Ý700-1300MM
µ×¹Ä¼ªËûÀÖ509. ¸ß¶È: ¡Ü540mm
510. µ××ù£ºÂÁºÏ½ð
¶ú·ÅÖ§¼Ü511. »î¶¯¶ú»ú·Å´óÆ÷Ö§¼Ü£¬¿É·Å±ê×¼£±£¹Ó¢´çÉ豸¡£
512. ǰºó¿ÉÒÔ¶àÖֽṹ×éºÏ£¬ÃŰ壬ä°å¾ù¿ÉÄÚÖÃÍмܣ¬Íаå.°²×°·½±ã¿ì½Ý¡£
513. ½ðÊô²ÄÖÊ
Æ×¼Ü514. ²ÄÖÊ£º¸ÖÆ×̨¡¢¸Ö½Å¼Ü
515. ¸ß¶È·¶Î§£º¡Ý90-150CM
516. ½Å³¤£º¡Ý33CM
517. ÊÊºÏ A4 ³ß´çÇúÆ×Êé
רҵ·ÀÅçÕÖ518. ¼æÈÝÈÎÒ⻰Ͳ
519. ¾±¹Ü£º¡Ý45cm
É豸¸ÉÔïÏä520. ²úƷζÈ×ÔȻζÈ
²ÄÖʺϽð ·À³±¹¤¾ßÀàÐÍ·À³±Ïä
42U »ú¹ñ521. ·À³±Â¼ÒôÅï»ú¹ñ
¼ÒôÅïÖÇÄÜÁ÷³ÌÓÅ»¯ÏµÍ³Ä£¿é522. AI Çý¶¯µõÔØÒýÇæ¿É¿Øµç»ú¹¦ÂÊ 37-90kw
523. תËٱ仯ÂÊ¡Ü2.5%
524. ÎÈËÙ¾«¶È¡Ü1%
525. Ϊ¡¸ºËÐÄÔËËã¿ØÖÆÄ£¿é¡¹Ìṩ¸ºÔØÓÅ»¯·½°¸ÔöÇ¿¡¸¼àÌýÐźŹÜÀíÄ£¿é¡¹µÄ·ÓÉÁé»îÐÔ
¸¨Öú¡¸Éùѧ»·¾³¹¹½¨Ä£¿é¡¹ÊµÏÖ×ÔÊÊӦУ׼
Êý×Öµ÷Òǫ̂556.²»ÉÙÓÚ 48 ¸öÂí´ïÍÆ×Ó(48 ͨµÀ+1 Ö÷¿Ø),
557.²»ÉÙÓÚ48 ÌõÊäÈë»ìÒôͨµÀ(40 µ¥ÉùµÀ+2 Á¢ÌåÉù
+2 ·µËÍͨµÀ)
558.20 ¸öAUX(8 µ¥ÉùµÀ+6 Á¢ÌåÉù)+Á¢ÌåÉù+×ÓĸÏß,
559.8 ¸ö´øÓÐ Roll-out µÄ DCA ±à×é,
560.32 ¸öÄ£Äâ XLR/TRS »ìºÏÂó¿Ë·ç/Ïß·ÊäÈë+2 ¸öÄ£Äâ RCA Á¢ÌåÉùÏß·ģÄâÊäÈë,
561.16 ¸öÄ£Äâ XLR Êä³ö,
562.34x34 Êý×Ö¼Òô/»Ø·ÅͨµÀ(Ðèͨ¹ý USB2.0 »ò2x2USB ´æ´¢É豸ʵÏÖ)¡£
1 ¸öÖ§³Ö NY64-D ÒôƵ½éÃæ¿¨µÄÀ©Õ¹²Û
