»¶Ó¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶ÓÀ´µç×Éѯ£¨Ð¤¾Àí £© QQ£º3777144798£» µç»°/΢ÐÅ£º 13371743505£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
²úÆ·½éÉÜ£º ¼ÒôÅï»ìÏìÐÂÌíÃͽ«£¬½üÆÚµ½»õȫУ¬PHONIC i7300 REVERB MASTER ÊÇרΪ¼ÒôÅï¡¢Êý×ÖÒôÀÖÖÆ×÷ºÍÏÖ³¡À©Òô¶øÉè¼ÆµÄÊý×Ö»ìÏì´¦ÀíÆ÷. ÄÚÖÃ100×é¶À¼ÒµÄÔ¤ÉèЧ¹û¡¢ÐÂÒ»´úµÄÁ¢Ìå»ìÏìÆ÷ʹÓà ÄÚÖÃADDA ÈËÉùת»»£¬²ÉÑùÂÊÖ§³Ö£º24-bit/48 kHz A/D ºÍD/A ת»¯Æ÷,ÄܲúÉú´ø¿í´øÏìÓ¦µÄÓÅÖÊÉùÒô.REVERBMASTERÉèÓÐ4ÖÖ»ØÐ§¹û:´óÌü,½ðÊô,ÊÒÄÚ,ÌØÊâ.Óû§¿É×Ô¶¨,´æ´¢25ÖÖ³ÌÐò.ͨ¹ý3¸ö¿ØÖÆÐýÅ¥,6¸öÁÁµÆ°´Å¥ºÍÈí¼þ¾ÍÄÜÉ趨²ÎÊý.ÿһÊäÈëºÍÊä³öµç·¶¼ÓжÀÁ¢µÄµçƽ¿ØÖÆ¿ª¹Ø,ÕâÑùÓû§¿ÉÈàºÏרҵ(+4 dBu)ºÍ·Çרҵ(-10 dBV)µÄ²úÆ·.MIDI½Ó¿ÚºÍ½Å̤¿ª¹ØÔö¼ÓÁËREVERBMASTERµÄÁé»îÐÔ,ʵÏÖÁËÔ¶³ÌÊý¾Ý´æ´¢ºÍʵʱ²ÎÊý¿ØÖÆ.
- ²úÆ·ÌØÉ«£º
- Ö§³Ö£º24-bit A/D ºÍ D/A ת»»Æ÷, È¡ÑùÂÊ256/512´Î
- ÄÚ½¨32-bit/44.1 kHz´¦ÀíÆ÷
- ±ÆÕæµÄÈýάЧ¹ûºÍ¿É±äÈýάЧ¹û²ÎÊý
- Ч¹û£º100 ÖÖ³§¼ÒÔ¤Éè³ÌÐòºÍ100ÖÖÓû§×Ô¶¨³ÌÐò
- ½Ó¿Ú£ºMIDI µÄʵʱ³ÌÐòÑ¡ÔñºÍÏÂÔØ¹¦ÄÜ
- ƽºâʽXLR ºÍ1/4" TRS ÊäÈëºÍÊä³ö
- Ãæ°åÁ½ÁÐ10¶Îµçƽ±í£»
- ¹¦ÄÜ£º¶ÀÁ¢Ñ¡ÔñÊäÈëºÍÊä³öµçƽ+4 dBu ºÍ-10 dBV
- Ö§³Ö½Å̤¿ª¹Ø²å×ù
- ÐýÅ¥¸Ë¿ØÖƺÍÕÕÃ÷ָʾµÆ°´Å¥
- Ãæ°å£ºÒº¾§ÆÁÏÔʾ£»
- ¼¼Êõ²ÎÊý£º
- 1.Á¬½ÓÆ÷£ºÆ½ºâʽ×éºÏ²å×ù(XLR and 1/4¡± TRS)£»
2.¶î¶¨µçƽ £º+4 dB »ò -10 dB (ÓɺóÃæ°å¿ª¹ØÑ¡Ôñ)£»
3.×迹 £º50 K Ohms £»
4.×î´óÊä³öµçƽ£º +16 dBu£»
5.Á¬½ÓÆ÷ £ºÆ½ºâʽXLR ºÍ1/4¡± TRS£»
6.¶î¶¨µçƽ £º+4 dB »ò -10 dB (ÓɺóÃæ°å¿ª¹ØÑ¡Ôñ)£»
7.×迹£º500 Ohms £»
8.×î´óÊä³öµçƽ £º+16 dBu£»
9.ƵÂÊÏìÓ¦:£º20 Hz to 20 KHz +/-0.5 dB £»
10.ÖÆ¶¯·¶Î§£º 96 dB typical £»
11.THD £º0.003% typ. @ +4 dBu, 1 KHz£»
12.ÔëÒô £º< -80 dB£»
13.´®Òô £º< -80 dB£»
14.ת»»Æ÷£º 24λģÄâתÊý×Ö/Êý×ÖתģÄâ ¼°32/40λSigma-DeltaÊý×ÖÐźŴ¦ÀíÆ÷, ³¬È¡Ñù256/512´Î £»
15.²ÉÑùƵÂÊ£º 44.1 KHz£»
16.´æ´¢£ºÒôÀÖ (Ö»¶Á) , Óû§(¶Á£¯Ð´)£»
17.´æ´¢Ïß·²¼¾Ö£º 4ÖÖÒôÀÖÀàÐÍ(HALL, ROOM, PLATE, SPECIAL)£¬Ã¿ÖÖÀàÐ;ùÓÐ25¸öÔ¤ÉèÒôÀÖºÍ25¸öÓû§É趨ÒôÀÖ
18.¿ª¹Ø £ºPreset/User, Type, Bypass/Compare, Store, Setup, Edit£»
19.Ðýת¿ØÖÆÆ÷£º Input Level, Adjust, Mix Level / EFX Level£»
20.ÏÔʾ£º Digital-LCD Display, Stereo-LED, User-LED, MIDI IN-LED£»
21.Á¬½ÓÆ÷£º ÊäÈë L/R (COMBO), Êä³ö L/R (XLR) (1/4¡± ¶ú»ú²å×ù), ½Å̤¿ª¹Ø(1/4¡± ¶ú»ú²å×ù), MIDI½Ó¿Ú5-Pin-DINSocket IN / OUT / THRU£»
22.±£ÏÕË¿£º 100-120 V AC: 1 A, 200-240 V AC: 500 mA£»
23.¹¦ÂÊÏûºÄ£º 20 Watts£»
24.µçÔ´Á¬½Ó £º±ê×¼IEC ²å×ù£»
25.³ß´ç£º 483 x 44 x 207.6 mm (19.02" x 1.73" x 8.17")£»
26.ÖØÁ¿ £º2.17 kg (4.8 lbs)£»
