| AoIP±ê×¼ | Dante |
| ͨµÀÊý | 16¸ö½ÓÊÕ£¬16¸ö·¢ËÍ |
| Á÷ÊýÁ¿ | 16¸ö½ÓÊÕ£¬16¸ö·¢ËÍ |
| ²ÉÑùÂÊ | 48 kHz |
| ¸ñʽ | ÏßÐÔPCM£¬16»ò24λ |
| AES67Ö§³Ö | ÊÇ |
| Á¬½ÓÐÔ | 2¸öRJ45ºÍ2¸öSFP |
| ËÙ¶È | 1GbpsºÍ100Mbps |
| ÍøÂçģʽ | ½»»»»òÈßÓà |
| ¾ß±¸Dante Domain Manager |
| ÊäÈë×迹£¨micģʽ£© | 2.5k¦¸µç×ÓÆ½ºâ |
| ÊäÈë×迹£¨Ïß·ģʽ£© | >10k¦¸µç×ÓÆ½ºâ |
| ǰÖ÷ŴóÆ÷ÔöÒæ£¨micģʽ£© | Óû§¿ÉÒÔ3dBΪµ¥Î»Ñ¡Ôñ0dBÖÁ60dB |
| ǰÖ÷ŴóÆ÷ÔöÒæ£¨micģʽ£© | -58dBu @×î´óǰÖ÷ŴóÆ÷ÔöÒæ£¬+ 2dBu @×îСǰÖ÷ŴóÆ÷ÔöÒæ |
| ǰÖ÷ŴóÆ÷ÔöÒæ£¨Ïß·ģʽ£© | Óû§¿ÉÑ¡+ 15dBu / + 18dBu / + 20dBu / + 22dBu / + 24dBu = 0dBFS |
| ƵÂÊÏìÓ¦£¨micģʽ£© | + 0 / -0.2dB 20HzÖÁ22kHz Ref 40dBÔöÒæ@ 1kHz |
| ƵÂÊÏìÓ¦£¨Ïß·ģʽ£© | + 0 / -0.2dB 20HzÖÁ22kHz |
| ²Î¿¼0dBu @ 1kHz |
| THD + N£¨micģʽ£© | <-90dBFS£¬-64dBFS£¬20Hz ¨C 20kHz£¬40dBÔöÒæ£¬20kHz BW |
| THD + N£¨Ïß·ģʽ£© | <-98dBFS£¬-30dBFS£¬20Hz ¨C 20kHz£¬20kHz BW |
| µÈЧÊäÈëÔëÉù£¨micģʽ£© | 127dB²Î¿¼60dBǰÖ÷ŴóÆ÷ÔöÒæ£¬Rs =200¦¸ |
| ÔëÉù£¨Ïß·ģʽ£© | <-110dBFS£¬20kHz BW£¬Rs =200¦¸ |
| C.M.R.R. > 60·Ö±´ |
| ÊäÈë×迹 | 110¦¸ |
| Ö§³ÖµÄÊäÈëËÙÂÊ | 32kHz£¬44.1kHz£¬48kHz£¬88.2kHz£¬96kHz£¬176.4kHzºÍ192kHz |
| Êä³ö×迹 | 110¦¸ |
| Ö§³ÖµÄÊä³öËÙÂÊ | 48kHz |
| ÊäÈë×迹 | >20k¦¸µç×ÓÆ½ºâ |
| 0dBFSÕóÈÝ | Óû§¿ÉÑ¡+ 15dBu / + 18dBu / + 20dBu / + 22dBu / + 24dBu = 0dBFS |
| ƵÂÊÏìÓ¦ | + 0 / -0.2dB 20HzÖÁ22kHz |
| ²Î¿¼0dBu @ 1kHz |
| THD + N | <-110dBFS£¬-30dBFS£¬20Hz ¨C 20kHz£¬20kHz BW |
| ÔëÉù | <-110dBFS£¬20kHz BW£¬Rs =200¦¸ |
| C.M.R.R | > 60dB |
| Êä³ö×迹 | <50¦¸ |
| 0dBFSÕóÈÝ | Óû§¿ÉÑ¡0dBFS = + 15dBu / + 18dBu / + 20dBu / + 22dBu / + 24dBu |
| ƵÂÊÏìÓ¦ | + 0 / -0.5dB 20HzÖÁ22kHz |
| ²Î¿¼0dBu @ 1kHz |
| ÔëÒô | <-110dBFS£¬20kHz BW |
| ¶ú»úÊä³ö | Çý¶¯ÄÜÁ¦½«150mWÇý¶¯µ½32¦¸ÖÁ600¦¸µÄ¶ú»úÖÐ |
| 0dBFSÕóÈÝ | ¹Ì¶¨0dBFS = + 18dBu |
| THD + N | <-108dBFS£¬-30dBFS£¬20Hz ¨C 20kHz£¬20kHz BW |
| Ö÷Ãæ°å²Ù×÷¿Ø¼þºÍָʾµÆ | ͨµçʱ£¬µçÔ´LED Sonifex»Õ±êµãÁÁ |
| °´Å¥ | 24 x·¢¹â°´Å¥£¬¿É·ÖÅ䏸ÒÔÏÂÈκι¦Äܲ¢½øÐÐÅäÖÃ: |
| ÏÔʾÆÁ | 2 x 480 x 107ÏñËØ²ÊÉ«TFTÏÔʾÆÁ£¬ÏÔʾÉùÏñ״̬£¬µçƽ£¬²â¹â£¬¿ØÖÆÀàÐÍ£¬Ô´/»ìºÏ/Ä¿µÄµØÃû³ÆºÍÖ÷Êä³ö²â¹â |
| ״ָ̬ʾµÆ | ʱÖÓ/ AoIP״̬/ PoE״̬ºÍPSU״ָ̬ʾµÆ£¬ÓÃÓÚ¼àÊÓµçÔ´ºÍÁ¬½ÓÐÔ¡£¿É¸ù¾ÝÐèÒª½ûÓà |
| Ðýת±àÂëÆ÷ | 12 x¼á¹ÌµÄÈí´¥ÃþÐýת±àÂëÆ÷£¬´øÓÐÏàÁڵĿÉÅäÖõÆÌõ£¬ÓÃÓÚ×é/Ô´/×¢ÊÍÆ÷·Ö×éºÍʶ±ð |
| ¶ú»úÊä³ö | 4¸öNeutrik¼¡±£¨6.35mm£©Ëø¶¨²å¿× |
| Âó¿Ë·ç/Ïß·ÊäÈë | 4¸öNeutrik 3ÕëãÅËøXLR²å×ù |
| ÊäÈë | RJ45²å×ù£¨µç×ÓÆ½ºâ£© |
| Á¢ÌåÉùÊý×ÖÊä³ö | RJ45²å×ù£¨µç×ÓÆ½ºâ£© |
| Ä£ÄâÏß·ÊäÈë | 4¸öNeutrikËø¶¨XLR²å×ù |
| Ä£ÄâÏß·Êä³ö | 6¸öNeutrikËø¶¨XLR²åÍ· |
| GPIO¶Ë¿Ú | 15·¡° D¡±ÐͲå×ù |
| ÍøÂç | 2 x 1Gbps Neutrik EtherCON²å×ù£¬´øPoE£¬×î´ó12W |
| 2¸öSFP²å²ÛÓÃÓÚ±¸ÓÃ½Ó¿Ú |
| Ö±Á÷ÊäÈë | Neutrik 4ÕëXLR²åÍ·£¬12VDC£¬×î´ó12W |
| µçÔ´ÊäÈë | Â˲¨IEC£¬85 ¨C 264VAC£¬47-63 Hz£¬×î´ó60W |
| ±£ÏÕË¿¶î¶¨Öµ | ·ÀÀËÓ¿±£ÏÕË¿2A 20 x 5mm |
| É豸ÀàÐÍ | AVN-CU4-DANTE AVN Dante½â˵Æ÷µ¥Ôª£¬4¸ö½â˵Æ÷ |
| ³ß´ç£¨Ôʼ£© | 25.7ÀåÃ×£¨¿í£©x 22.9ÀåÃ×£¨Éx 9.2ÀåÃ×£¨¸ß-×î´ó£©£¬6.5ÀåÃ×£¨¸ß-ǰ£©£¬8.9ÀåÃ×£¨¸ß-ºó£© |
| 10.1Ó¢´ç£¨W£©x 9Ó¢´ç£¨D£©x 3.6Ó¢´ç£¨H-×î´ó£©£¬2.6Ó¢´ç£¨H-ǰ£©£¬3.5Ó¢´ç£¨H-ºó£© |
| ³ß´ç£¨ºÐ×°£© | 37ÀåÃ×£¨À«£©x 35.5ÀåÃ×£¨Éx 19ÀåÃ×£¨¸ß£© |
| 14.6Ó¢´ç£¨¿í£©x 14Ó¢´ç£¨Éx 7.5Ó¢´ç£¨¸ß£© |
| ÅäÊÎ | AVN-DCX60ÓÃÓÚAVN·¶Î§µÄÖ±Á÷µçÔ´£¬4ÕëXLR²å×ù£¬60W |
| AVN-TC1£¨½öÏ䣩ÔËÊäÏ䣬AVN-CU2-DANTEºÍµçÔ´¿ª¹Ø |
| ³ß´ç£¨Ôʼ£© | 46.5ÀåÃ×£¨¿í£©x 36ÀåÃ×£¨Éx 17.6ÀåÃ×£¨¸ß£© |
| 18.3Ó¢´ç£¨¿í£©x 14.2Ó¢´ç£¨Éx 6.9Ó¢´ç£¨¸ß£© |
| ³ß´ç£¨ºÐ×°£© | 52ÀåÃ×£¨¿í£©x 21.5ÀåÃ×£¨Éx 43ÀåÃ×£¨¸ß£© |
| 20.5Ó¢´ç£¨¿í£©x 8.5Ó¢´ç£¨Éx 16.9Ó¢´ç£¨¸ß£© |
| ÖØÁ¿ | ¾»ÖØ:3.0kgÃ«ÖØ:3.5kg |
| ¾»ÖØ | 6.6°õÃ«ÖØ:7.7°õ |
| CM-GM1 | רҵ¶ì¾±µçÈÝ»°Í² |
