| Directional pattern | Omnidirectional |
| Principle of operation | Pressure |
| Cartridge type | Pre-polarized condenser |
| Frequency range | 20 Hz - 20 kHz |
| Frequency range, ¡À2 dB | Soft boost grid |
| Sensitivity, nominal, ¡À3 dB at 1 kHz | 6 mV/Pa; -44 dB re. 1 V/Pa |
| Equivalent noise level, A-weighted | Typ. 26 dB(A) re. 20 ¦ÌPa (max. 28 dB(A)) |
| Equivalent noise level, ITU-R BS.468-4 | Typ. 38 dB (max. 40 dB) |
| S/N ratio (A-weighted), re. 1 kHz at 1 Pa (94 dB SPL) | Typ. 68 dB(A) |
| Total harmonic distortion (THD) ¨C Legacy | < 1% THD up to 123 dB SPL peak; < 1% THD up to 120 dB SPL RMS sine |
| Total harmonic distortion (THD) ¨C CORE | < 1% THD up to 137 dB SPL peak |
| Dynamic range ¨C Legacy | Typ. 97 dB |
| Dynamic range ¨C CORE | Typ. 111 dB |
| Max. SPL, peak before clipping | 144 dB |
| Output impedance | 30 - 40 ¦¸ |
| Cable drive capability | Up to 300 m (984 ft) |
| Power supply (for full performance) | For wireless systems |
| Current consumption | Typ. 1.5 mA (microphone). 3.5 mA with DAD6001-BC XLR Adapter |
| Connector | MicroDot |
| Color | Black, beige, brown or white |
| Weight | 7.5 g (0.26 oz) incl. Cable and MicroDot connector |
| Microphone diameter | 5.4 mm (0.21 in) |
| Microphone length | 12.7 mm (0.5 in) |
| Cable length | 1.8 m (5.9 ft) |
| Polarity | Positively increasing sound pressure produces positive going voltage on MicroDot pin |
| Temperature range | -40¡ãC to 45¡ãC (-40¡ãF to 113¡ãF) |
| Relative humidity (RH) | Up to 90% |
