| ¼Òô¹¤×÷Õ¾ | 1.רҵ¼ÒôÅïÒôƵ¹¤×÷Õ¾¡£ÐÔÄÜÎȶ¨¡¢×¨Òµ¾²Òô´¦Àí¡£
2.DAWÈí¼þ£º¼æÈݺó£¬Í¬²½·¢Òô/¹ìµÀ(48 kHz/96 kHz/192 kHz)£º¡Ý128/64/32¹ìµÀ¡£
3.DAWÈí¼þ£ºÍ¬²½·¢Òô/¹ìµÀ(48 kHz/96 kHz/192 kHz)£º¡Ý128/64/32¹ìµÀ¡£
4.DAWÈí¼þ£º¼æÈݺó£¬ÒôƵÒýÇæ¾ßÓÐ64bitÉî¶ÈµÄ¸¡µãÔËËãÄÜÁ¦£¬ÒôƵ¹ìµÀ¡Ý1024¹ìµÀ£¬ÒôƵ²ÉÑùÂÊ¡Ý192khz£¬Ö§³Ö»·ÈÆÉùºÍÕæÕýµÄ¶àÉùµÀ²¥·Å£¬°üº¬¡Ý8ÖÖ³öÉ«ÀÖÆ÷µÄ×ÛºÏÌ××°£¬°üº¬¡Ý3000ÖÖÉùÒô¡£
5.´¦ÀíºËо£º¡Ý24ºËÐÄ32Ị̈߳¬×î¸ßî£Æµ£º¡Ý5.4GHz
6.Äڴ棺¡Ý64GB£¬DDR4Äڴ棬ºËÐÄ×î¸ß¿É´ï128G¡£
7.´æ´¢£º¡Ý512G M.2 NVme ¹Ì̬ӲÅÌ £¬Êý¾ÝÓ²ÅÌ£º¡Ý1TB7200RPM¡£
8.ͼÐδ¦ÀíÆ÷£º¼æÈÝNVIDIA/AMDºËÐļ¼ÊõÏÔ¿¨¡¢×î´ó·Ö±æÂÊ 1080P/2K/4K£¬Ö§³ÖÇåÎúÊÓÆµÊä³ö£¬Ö§³ÖHDMI,DP, DVI-D, D-Sub£¬¡Ý4GÏÔ´æ¡¢Ö§³ÖË«ÏÔ¡£ |
| Ö÷ÒôƵ½Ó¿Ú | 1.ADÄ£Êýת»»£¬ÆµÏì 10 Hz -20Khz: > +/-0.2dB (@44.1Khz)
2.ÊäÈë×迹£º¡Ý4KOhm
3.×î´óÊäÈëµçƽ£º¡Ý+20dBu
4.THD + N:¡Ý -113dB
5.¶ú»ú¶¯Ì¬·¶Î§:¡Ý128dB (A¼ÓȨ) |
| Ö÷»ìÒôÈí¼þ | 1.¾ßÓж԰×¼Òô¹¤¾ß¡¢MPEG-H ÒôƵ´´×÷¡¢¶Å±ÈÈ«¾°Éù¹¦ÄÜ
2.¾ßÓÐTonalMatch¹¦ÄÜ£¬¿É¶ÔÒôƵÎļþµÄÌØÐÔ½øÐÐÆÊÎö
3.¾ßÓÐÈ¥³ýµô±³¾°ÉùÒôºÍÆäËûÔÓÒôµÄ¹¦ÄÜ
4.¾ßÓÐеijÁ½þʽÒôƵ¹¦ÄÜ£¬Èç MPEG-H ÒôƵ֧³Ö¡¢Èý²ãZ-Æ½ÒÆ¡¢¸Ä½øµÄ ADM ´´×÷´°¿ÚºÍеĶűÈAtmosäÖȾÆ÷µÈ¡£
5.¾ßÓÐÉùÒôѹËõ¹¦ÄÜ |
| Ö÷ÈËÉù»°Í² | 1.ʰÒôÖ¸ÏòÐÔ£ºÈ«ÏòÐΣ¬ÐÄÐÎÖ¸Ïò8×ÖÐÎ
2.ƵÏ췶Χ£º20 Hz~20 kHz£¬È«ÏòÐÎÁéÃô¶È1kHz-1k¦¸£º20 mV/Pa 28 mV/Pa22 mV/Pa
3.Êä³ö×迹¡Ý200¦¸£¬¸ºÔØ×迹¡Ý1k¦¸
4.×î´óÉùѹ¼¶¡ÝTHD 0.5% 117 dB£¬×î´óÊä³öµçƽ¡Ý-6 dBu
5.ȫָÏòÐÅÔë±ÈCCIR¡Ý68 dB£¬È«Ö¸ÏòÐÅÔë±ÈA¼ÓȨ¡Ý79 dB |
| °é×àÈí¼þ | 1.Ö§³Öµ¼ÈëÎļþ¸ñʽAAC, AC3, AIFF, ALAC, AU, CAF, FLAC, MP3, OGG, Opus, RAW, WAV, WMAµÈ
2.Ö§³Öµ¼³öÎļþ¸ñʽAAC, AC3, AIFF, CAF, FLAC, MP3, OGG, Opus, RAW, WAVµÈ
3.×î¸ß²ÉÑùÂÊ¡Ý384 kHz£¬Ö§³Ö²å¼þ¸ñʽARA2,AAXµÈ
4.ͨµÀÊýÁ¿¡Ý8¸ö |
| »°Í²·Å´óÆ÷ | 1.TrimÐýÅ¥µ÷½ÚÊä³öÒôÁ¿¡Ü¡À6dB
2.ÊäÈë×迹¡Ý3900¦¸£¬ÆµÂÊÏìÓ¦£º¡Ý10Hzµ½100kHz
3.ÔöÒæ£º¡Ý0-72dB£¬µÈЧÊäÈëÔëÉù£¨EIN£©£º¡Ý-128dBV
4.×î´ó¶¯Ì¬·¶Î§¡Ý135dB£¬×î´óÊä³öµçƽ¡Ý+26dBu |
| »ìÏìÈí¼þ | 1.¿ÉÒÔÖ±½Ó¶ÁÈ¡ÒôÉ«£¬¾ß±¸Ë«ÒýÇæ»ìÏ죬¿ÉÒÔÒ»´Î¼ÓÔØÁ½¸ö»ìÏìÔ¤ÖûòIR²ÉÑù£¬ÔÙ»ìºÏ±ÈÀýºóÒ»ÆðÊä³ö
2.¾ß±¸7ÖÖ²»Í¬²ÄÖʵĽðÊô°åÄ£ÐÍ£¬ÊǸõÖÊ£¨ºñʵ±¥Âú£©¡¢ÒøÖÊ£¨ÇáÇÉÇåÎú£©¡¢¸ÖÖÊ£¨½áʵ±¥Âú£©¡¢îîÖÊ£¨Ã÷ÁÁÖÐÐÔ£©¡¢îëÖÊ£¨Ã÷ÁÁ¹âÔ󣩡¢îÜÖÊ£¨½ôÃܳÁÖØ£©ºÍÒ¿ÖÊ£¨½ôÖ°ü¹ü
3.¿É½«ÏÖÓеĵ¥ÉùµÀÒôƵ¹ì£¬»òÕßÁ¢ÌåÉùÒôƵ¹ì£¬Ö±½Ó±ä³ÉµÄ5.1»òÕß7.1.6¿Õ¼ä½øÐÐÊä³ö¡£ |
| Ч¹ûÆ÷Èí¼þ | 1.Ö§³ÖÍêÈ«³Á½þʽÒôƵ£¬Ö§³Ö¸ß´ï9.1.6¶Å±ÈÈ«¾°Éù£¨Dolby Atmos£©µÄ³Á½þʽÉùµÀ
2.µ¼ÈëÂö³åÏìÓ¦¹¦ÄÜ£¬²¢½«ËüÃÇ×Ô¶¯ÖØÐ´´½¨ÎªËã·¨ÉèÖ㬰üÀ¨Ë¥¼õÂʺͺóÖÃEQÕûÐÎ
3.½«ÊªÐÅºÅµçÆ½ÉèÖÃΪÿµ±´æÔÚ¸ÉÐźÅʱ£¬ÉÁ±Ü¿Ø¼þ¾Í»áË¥¼õ£¬Ê¹Óúñ¶ÈÐýÅ¥µ÷ÕûÃܶȺͱ¥ºÍ¶È£¬Ê¹ÓÿÉͬ²½½Ú×àµÄ×Ô¶¯Ãſأ¬²¢Í¨¹ýµ¥»÷¡°¶³½á¡±°´Å¥ÎÞÏÞÆÚµØ²¶»ñ²¢±£ÁôÒôβ¡£ |
| ¼àÌýÒôÏä | 1.ƵÂÊÏìÓ¦£º42Hz¡ª50kHz£¨¡À3dB£©
2.µÍƵÏì¶ÈË¥¼õ£º¡Ý-1dB@60Hz£¬¸ßƵÏì¶ÈË¥¼õ¡Ý-1dB@22KHz
3.µÍÒôµ¥Ôª¡Ý1¸ö/£¨10in£©203mm£¬¸ßÒôµ¥Ôª¡Ý1¸ö/£¨1in£©25mm
4.µÍƵÀàÐÍ£ºDiscrete bipolar Class AB£¬ÀàÐÍ¡Ý24dB/±¶Æµ³Ì
5.·ÖƵµã¡Ý3kHz£¬ÁéÃô¶È¡Ý+4dBU at 300Hz for full output |
| ¼Òôʦ¶ú»ú | 1.ÁéÃô¶È¡Ý96 dB£¬×迹¡Ý65¦¸
2..×î´óÊäÈ빦ÂÊ,¡Ý1000mW
3.ƵÂÊ·¶Î§£º10Hz-30 kHz¦¸
4.Ïß³¤¡Ý2.1m£¬ÏßÀÂÀàÐÍ£ºË«²åÍ·,¿É²ðжÎÞÑõÍÏßÀ |
| ¸èÊÖ¶ú»ú | 1.Á¬½Ó·½Ê½3.5mm¶Æ½ð²åÍ·
2.µ¥ÔªÖ±¾¶¡Ý30mm£¬ÆµÏ췶Χ¡Ý16-28000Hz
3.²úÆ·×迹¡Ý55¦¸£¬ÁéÃô¶È¡Ý91dB |
| ¶ú»ú·ÖÅäÆ÷ | 1.¡Ý18¸ö¸ß¹¦Âʶú»ú·Å´óÆ÷ͨµÀ£¬Ë«¹¦ÄÜÆ½ºâ/»ìºÏ¿ØÖÆ
2.Ç°Ãæ°åÁ¢Ì帨ÖúÊäÈëÁ¬½Ó¶àÑù¼àÌýÉèÖ㬵¥¶ÀÊä³öµçƽ¿ØÖÆ
3.¡Ý4¶Î¾«ÃÜLEDÒDZí¼ì²âÊä³ö
4.¡Ý8¶Î¾«ÃÜLEDÒDZí¼ì²âÖ÷ÒôÁ¿¿ØÖÆ |
| ÖÇÄܵçÔ´¹ÜÀíÖÐÐÄ | ¡ø1.É豸½Ó¿Ú£º¡Ý1·ÊäÈëµçÔ´ÈýÏàÎåÏßÖÆ½Ó¿Ú£¬AC380V¡À10£¥£¬50/60Hz£»¡Ý1·LANÍøÂç½Ó¿Ú£»¡Ý1··ï»Ë¶Ë×ÓRS485½Ó¿Ú£»¡Ý12·µçÔ´Êä³ö£»²ÎÊý¼à²â£ºÃ¿Â·Êä³öͨµÀ¶¼¾ßÓеçÁ÷£¬µçѹ£¬¹¦ÂÊ£¬Î¶ȣ¬¿ª¹Ø×´Ì¬£¬ÔËÐÐʱ³¤ÓëÈýÏàÆ½ºâ¼à²â¶àÖÖÒì³£Çé¿ö±¨¾¯£»£¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
2.µçÔ´Êä³ö£º¡Ý12·¶ÀÁ¢Êä³ö£¬Ã¿Â·ÏàµçѹAC 220V¡À10£¥£¬Ã¿Â·´øÔØ¡Ý4kW£¬¡Ý12·Êä³ö×î´ó¿É´øÔØ¡Ý48kW£»¶Ì·±£»¤£ºÃ¿Â·Êä³öÅäÓÐҺѹµç´Åʽ20A¶Ï·Æ÷£¬¶Ï·Æ÷¿ÉÌṩ¹ýÔØ£¬¶Ì·±£»¤£»Ò»¼ü¿ª¹Ø£ºµ¥Ì¨É豸¡Ý12·Êä³öÒ»¼üʽ˳Ðò¡¢ÄæÐò¿ª¹Ø£¬Ò²¿ÉÒÔÿ·¶ÀÁ¢¿ª¹Ø£»¶¨Ê±¿ØÖÆ£º¿ÉÒÔ×Ô¶¨ÒåÑ¡ÔñÊä³öͨµÀ¶¨Ê±¿ªÆô»ò¹Ø±Õ£¬¿Éµ¥´ÎÔËÐУ¬Ò²¿ÉÒÔÑ»·ÔËÐУ»
¡ø3.µçÆøÉèÖ㺿ÉÒÔÉèÖÃÊäÈëµçѹ¹ýѹºÍǷѹãÐÖµ£¬¿ÉÒÔΪÿ·Êä³öµ¥¶ÀÉèÖõçÁ÷¡¢¹¦ÂÊ¡¢Î¶ȶϵçãÐÖµ£¬³¬³ö·¶Î§±¨¾¯£¬Äܹ»Ê¶±ð³öûÓÐÕý³£¹¤×÷µÄÉ豸£¬Ò²¿ÉÒÔÑ¡ÔñÊÇ·ñ¶Ï¿ªÊä³öµçÔ´£»Ö§³ÖÎïÁªÍøÆ½Ì¨¼¯Öйܿأ¬Í¨¹ýÎïÁªÍøÆ½Ì¨ÊµÊ±²é¿´É豸ÔÚÏß/ÀëÏß״̬¡¢µçÁ÷¡¢µçѹ¡¢¹¦ÂÊ¡¢Î¶ȡ¢ÓõçÁ¿¡¢ÔËÐÐʱ³¤Ó뱨¾¯Çé¿ö£»£¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
4.¿ÉÒÔÏÔʾÉ豸״̬£¬ÈÕÆÚʱ¼ä£¬Í¨µÀ¿ªÆô״̬£¬Ã¿Ò»Â·Â©µç¡¢¹ýѹ£¬¹ýÔØµÈ¸æ¾¯×´Ì¬£¬¿ÉÒÔ²Ù¿ØÉ豸¡£×Ô´øÆÁÄ»Ëø£¬·ÀÖ¹Îó´¥£¬¿Éµ÷½ÚÆÁÄ»ÁÁ¶È£¬ÊÊÓ¦¶àÖÖ¹âÕÕÌõ¼þ£»ÁªÍø¿ØÖÆ£ºÉ豸¾ßÓÐRJ45½Ó¿Ú£¬½ÓÈëÍâÍø¿É×Ô¶¯·ÖÅäIP½ÓÈëÔÆÆ½Ì¨£¬
5.ÁªÍøºó£¬¿ÉÓÉÊÖ»úºÍƽ°åAPP¿ØÖÆ£¬²Ù×÷¼ò±ã£¬É豸֧³ÖÍøÂçÉý¼¶·þÎñ£»¿ÉÒÔͨ¹ý¾ÖÓòÍø¹¦ÄÜʵÏÖÔ¶³Ì¿ØÖÆÉ豸ͨµÀ¿ª¹Ø¡¢ÐÞ¸ÄµçÆøÉèÖᢲ鿴É豸״̬¡¢ÕýÄæÐòÈ«¿ª¹ØµÈ¹¦ÄÜ¡£ |
| Ö÷»°Í²¼Ü | 1.²ÄÖÊ£º¸Ö£¬ÎƽÓÍ·£º3/8
2.´øÖâ½Ú¼Ð¾ßµÄ¿ÉÉìËõÐü±ÛÌṩ870mmÖÁ1550mmµÄ¿Éµ÷³¤¶È¡£ |
| ÏÔʾÖÕ¶Ë | 1.·Ö±æÂÊ¡Ý2560*1440
2.Ö±ÃæÆÁÏìӦʱ¼ä¡Ü5ms
3.ÆÁĻˢÐÂÂÊ¡Ý100Hz
4.½Ó¿Ú£ºDP£¬HDMI
5ÆÁÄ»¡Ý27Ó¢´çÏÔʾÆÁ |
| ¸ÉÔïÏä | 1.Êý¿Ø¾«×¼³ýʪ£¬¿ÉÉ趨ʪ¶ÈÖµ
2.ÏÔʾ±í³£ÁÁ²»Ï¢ÆÁ¸ô°åÊýÁ¿:¿Éµ÷½Ú¸ô°å¡Ý3¿é
3.ʪ¶È·¶Î§£º35%RH-75%RH
4.ÈÝ»ý¡Ý100L |
| ÒôƵ¹ýǽºÐ | 1.Âú×ã¼ÒôÅïÐèÇóµÄÒôƵºÐ×Ó£¬Ö§³Ö¡Ý1¸ö´óÈýо½Ó¿Ú£¬1¸ö¿¨Ù¯½Ó¿Ú |
| ·ÇÏßÐÔ±à¼ÏµÍ³ | ¡ø1.ϵͳ²ÉÓá°¿Í»§¶Ë¹¤¾ß+ÊÓÆµÔÆ¡±µÄÐÎʽ£¬Ö§³Ö¶à³¡¾°¡¢¿çµØÓòµÄÊÓÆµÖÆ×÷¹¦ÄÜ£»ÊÓÆµÔÆÉϾ߱¸ËزİáÔË¡¢ÐéÄâÖ÷²¥¡¢Êý¾ÝÊÓÆµ¡¢¼«¼òÖÆ×÷µÈ³¡¾°»¯¹¤¾ß£¬Ö§³ÖÊôÐÔÒ³×Ô¶¯Çл»£¬ÔÚ¹ìµÀÉÏÑ¡ÖÐÊÓÒôƵ¡¢ÊÓÆµ¡¢ÒôƵ»ò×ÖÄ»µÈ²»Í¬¶ÔÏóʱ£¬ÊôÐÔÒ³¿É×Ô¶¯Çл»ÖÁ¿Éµ÷ÕûµÄÒ³ÃæÄÚÈÝ£»Ö§³ÖÔÚËØ²Äͼ±êÉÏÖ±½ÓÏÔÊ¾ËØ²Ä±»¹ÊʰåÒýÓõĴÎÊý£»Ö§³Ö°´ÕÕËØ²ÄÃû³Æ£¬Ê±³¤µÈÌõ¼þ½øÐÐ×ÊԴɸѡ£¬²¢½«É¸Ñ¡½á¹û¹é¼¯µ½ÖÇÄÜÎļþ¼Ð£»Ö§³ÖÔÚËØ²Äͼ±êÉϽ«ËزĿìËÙÌí¼Óµ½Ê±¼äÏߣ¬Ö§³Ö¸½¼Ó·½Ê½ºÍµþ¼Ó·½Ê½£¬¼´£ºÔÚʱ¼äÏßβ²¿»òµ±Ç°Î»ÖÃÌí¼ÓËØ²Ä£»£¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
2.Ö§³Ö3840¡Á2160@50p/59.94p¸ñʽ4K³¬¸ßÇåÊÓÆµÐźÅÊä³ö£¬Ö§³ÖË«´°¿Ú²¥·ÅÆ÷¡¢Ð§¹û´°¿Ú¡¢ËùÓд°¿ÚµÈ²»Í¬µÄ½çÃæ²¼¾ÖÔ¤É裻²¢ÇÒÖ§³ÖЧ¹û´°¿ÚÕ¹¿ªÖÁÈ«ÆÁ¸ß¶ÈÏÔʾģʽ£»Ö§³Ö¶ÔËØ²ÄÌí¼ÓÑÕÉ«±êÇ©£¬²¢¿ÉÔÚ¹Êʰå¹ìµÀÉÏÒÔÑÕÉ«±êÇ©µÄÑÕÉ«½øÐУ»
¡ø3.ϵͳ֧³ÖµÄÊÓÒôƵ¸ñʽ°üÀ¨XAVC¡¢AVC-Intra¡¢H.264£¨AVC£©¡¢H.265£¨HEVC£©¡¢ProRes¡¢DNxHR/DNxHD¡¢MPEG-2 I¡¢MPEG-2 IBP¡¢XDCAM/XDCAM HD¡¢DV/DVCPRO/DVCPRO 50¡¢DVCPROHD¡¢WebMµÈ¸ñʽ£»Ö§³ÖËØ²ÄµÄRe-LinkÖØÁ´½Ó¹¦ÄÜ£»Ã½ÌåÎļþµÄ±£´æÂ·¾¶±ä»¯ºó£¬¿Éͨ¹ýÖØÁ´½Ó¹¦ÄÜÖØÐ¶¨Î»ÐµÄÎļþ±£´æÂ·¾¶£»Ö§³Ö¶Ô¹Êʰå¹ìµÀËØ²ÄµÄÒ»¼üÊͷźÍÄÚÈÝÌæ»»£»Ö§³ÖËØ²Ä±³¾°Ä£ºý£¬Ö§³Ö¶ÔÊÓÆµ¹ìËØ²ÄµÄ±³¾°£¨Ìî³äÇø£©½øÐÐÄ£ºý´¦Àí£¬Í¨¹ýÄ£ºý¹¦ÄÜʵÏÖºáÊúÆÁµÄת»»£»Ö§³ÖħÊõÌùÄ£°å£¬ÊµÏÖËØ²Ä°ü×°£¬Ö§³Ö¶Ô¹ÊʰåµÄÿһ²½²Ù×÷½øÐб¸·Ý£»Ö§³Ö¶¨Ê±±¸·Ý£¬¿É¶Ô¶¨Ê±±¸·ÝµÄ´ÎÊýºÍ¼ä¸ôʱ¼ä½øÐÐÉèÖã»Ö§³Ö¶ÔÊÓÆµ½øÐÐÖÇÄÜ¿ÙÏñ´¦Àí£¬¿É½«ÊÓÆµÖеÄÖ÷ÌåÈËÎï´Ó×ÔÈ»±³¾°Öп۳öÀ´£¬²¢µþ¼ÓÖÁÆäËû±³¾°ÖС££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
¡ø4.Ö§³ÖÕþÎñÃÀÑÕÌØ¼¼£¬¿É¶ÔÊÓÆµÖеÄÈËÎïÁ³²¿½øÐÐÕþÎñÃÀÑÕ´¦Àí£»²¢¿É¸ù¾ÝÐèÒª¶ÔĥƤ³Ì¶È¡¢×÷Ó÷¶Î§¡¢ÁÁ¶È¡¢ÊÝÁ³¡¢´óÑÛµÈЧ¹ûµÈ½øÐе÷Õû£»Ö§³Ö¶Ô°üº¬¶à¸öÈËÎïµÄÊÓÆµÖеÄÖ¸¶¨ÈËÎï½øÐе¥¶ÀÃÀÑÕ£»Ö§³ÖÖÇÄÜÊÓÆµÎȶ¨´¦Àí£¬¿É¶ÔÊÓÆµ»Ãæ½øÐÐÒ»¼üÈ¥¶¶¶¯£»Ö§³Öͨ¹ýµ÷ÕûÎȶ¨Ç¿¶È¡¢Ëõ·ÅÉÏÏÞ¶ÔÈ¥¶¶¶¯Ð§¹û½øÐе÷Õû£»Ö§³Ö¶ÔÊÓÆµ»Ãæ½øÐÐÒ»¼üÖÇÄܵ÷É«£»Ö§³ÖÖÇÄÜÕÚµ²£¬¿É×Ô¶¯¶ÔÊÓÆµÖÐÖ¸¶¨ÈËÎïµÄÁ³²¿½øÐиú×ÙÕÚµ²´¦Àí£»ÕÚµ²ÇøÓòÖ§³Ö¾ØÐλòÍÖÔ²£¬ÕÚµ²·½Ê½Ö§³ÖÂíÈü¿Ë»òÄ£ºý£¨Èữ£©£¬²¢¿É¶ÔÕÚµ²³Ì¶È¡¢ÕÚµ²¿¹¶¶¶¯²ÎÊýµÈ½øÐÐ×Ô¶¨ÒåÉèÖã»Ö§³Ö¶ÔÊÓÆµÖеÄLogo¡¢ÎÄ×ÖµÈÄÚÈݽøÐвÁ³ý´¦Àí£¬²¢Ê¹ÓÃÏàÁÚÄÚÈݽøÐÐÌî³ä¡££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ© |
| ¹¤×÷̨ | 1.רҵ¼ÒôÅï¡Ý12U»ú¹ñ¿Éµ÷½Ú
2.¸Ö½á¹¹£¬¿É·Å±ê×¼19Ó¢´çÉ豸£¬²Ù×÷̨Á½²àÉÏÏÂǰºó¿ÉÒÔ¶àÖֽṹ×éºÏ
3.¾ù¿ÉÄÚÖÃÍмܡ¢Íа塣°²×°·½±ã¿ì½Ý£¬ÅäÓбê×¼µÄ»ú¼ÜÉ豸Ïä¡£
4.²ÉÓÃÀäÔþA3¸Ö°å£»Ö÷¿ò¼ÜΪ¡Ý2.0mmÀäÔþ¸Ö°å£¬³ß´ç¡Ý1.8m*2.0m |
| µç×Ó°àÅÆ | ¡ø1.°àÅÆÕû»ú±³°å²ÉÓýðÊô²ÄÖÊ£¬¿¹×²¿¹»®¿¹¸¯Ê´¡£±íÃæÎÞ¼âÈñ±ßÔµ»ò͹Æð¡£´ø·ÀµÁÂݿף»ÑïÉùÆ÷²ÉÓòà±ß¿ª¿×Éè¼Æ£¬Ö§³ÖË«ÉùµÀÊä³ö, ÄÚÖÃ˫ͨµÀ¡Ý4¦¸*3W*2ÑïÉùÆ÷£»É豸²ÉÓÃÒþ²ØÊ½²¦ÂëÉ豸¿ª¹Ø¼°¸´Î»°´Å¥¡£·ÀֹѧÉúÎ󴥡£Ö§³Öͨ¹ýƽ̨ÐÞ¸ÄÖն˹ÜÀíÃÜÂë¡£Ö§³Ö¡Ý10Ö¸´¥¿Ø£¬´¥¿Ø×îÐ¡Ãæ»ýÖ±¾¶¡Ý3mm£¬´¥¿ØÏìӦʱ¼ä¡Ü20ms£»ÆÁÄ»±íÃæ²ÉÓáÝ3mmºñ¶È¸Ö»¯²£Á§£¬·À»®·Àײ£»¸Ö»¯²£Á§¿É¼û¹â͸Éä±È¡Ý85%£»ÆÁĻӲ¶È¡Ý7H¡££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
2.Õû»úÆÁÄ»¡Ý21.5Ó¢´ç£»²ÉÓÃÖ±ÏÂʽ±³¹â£¬ÆÁÄ»ÏÔʾ·Ö±æÂÊ¡Ý1920*1080 pixel£¬²¢Ö§³Ö4kÊÓÆµ²¥·Å¡£²ÉÓÃAndroid 11.0¼°ÒÔÉϲÙ×÷ϵͳ£¬CPUÐÔÄÜ¡ÝËĺË64룬GPUÖ÷Ƶ¡Ý2.0GHz£¬ÄÚ´æÐÔÄÜ¡ÝDDR3 1600£¬ÄÚ´æÈÝÁ¿£¨RAM£©¡Ý2G£¬ÄÚÖô洢(ROM)¡Ý16G¡£
¡ø3.É«²ÊÏñËØ¡Ý0.2493*0.241mm¡£ÆÁĻ֡ÂÊ¡Ý60HZ£»¿ÉÊӽǶȡÝ178¶È(H)/ 178¶È(V)£»ÆÁÌå¶Ô±È¶È¡Ý3000:1£¬³¬¸ßÁÁ¶È(typ)/(min)¡Ý500cd/©O(typ.)£»ÁÁ¶È¿É×Ô¶¯µ÷£»ÉãÏñÍ·ÈËÁ³Ê¶±ð×î¿ìÏàӦʱ¼ä£¼300ms£»É«²Ê¶È¡Ý8bit£»Ö§³Ö·ÀÀ¶¹â¡¢·ÀìŹ⣻£¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
4.ÆÁÄ»²ÉÓ÷ÀºÚ»¯Éè¼Æ£¬°àÅÆÖ§³ÖusbÉý¼¶¡¢otaÉý¼¶Á½ÖÖ·½Ê½¡£ |
| ÐÅÏ¢·¢²¼ÏµÍ³ | Ò»¡¢ÏµÍ³¼Ü¹¹
¡ø1.ϵͳ²ÉÓÃB/S¼Ü¹¹£¬Ö§³Ö¹«ÓÐÔÆ¡¢Ë½ÓÐÔÆ£¨³ÇÓòÍø£©¼°±¾µØ»¯²¿ÊðÈýÖÖ²¿Êð·½Ê½£»ÏµÍ³Ö÷Òª¹¦ÄܰüÀ¨£ºÄÚÈݹÜÀí¡¢ÄÚÈÝÉóºË¡¢Ð£Îñ¹ÜÀí¡¢°à¼¶¹ÜÀí¡¢½ÚÄ¿¹ÜÀí¡¢É豸¹ÜÀí¡¢»ù´¡ÉèÖá¢ÏµÍ³ÉèÖõÈÄ£¿é¡££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
2.Ö§³ÖÔÚÎÞÍøÂçÇé¿öϰàÅÆÄܰ´ÕÕ×îºóÒ»´ÎÖÆ¶¨µÄ½ÚÄ¿²ßÂÔÀëÏß²¥·Å¡£
¶þ¡¢×ÊÔ´¹ÜÀí
3.Ö§³Ö¶àÖÖËØ²Ä×ÊÔ´¹ÜÀí£¬°üÀ¨Í¼Æ¬¡¢ÊÓÆµ¡¢ÐÂÎÅ¡¢URLÁ´½ÓµÈ¶àÖÖ¸ñʽµÄËØ²ÄÉÏ´«¡£Ö§³ÖͼƬ¡¢ÊÓÆµËزÄÅúÁ¿ÉÏ´«ºÍɾ³ý£¬Ö§³ÖÒÑÉÏ´«ËزĵÄËõÂÔͼչʾ»òÈ«ÆÁ²¥·Å¡£
Èý¡¢ÄÚÈÝÉóºË
4.Ö§³Ö֪ͨ¡¢ÐÂÎÅ¡¢Ïà²á¡¢ÊÓÆµµÈ·¢²¼ËزĽøÐÐÉóºË£¬¹ÜÀíÔ±¿É½øÐÐÖðÌõÉóºË»òÅúÁ¿ÉóºË¡£¹ÜÀíÔ±Ö±¹Û²é¿´ÐèÉóºËËØ²ÄµÄÀàÐÍ¡¢·¢²¼ÈË¡¢·¢²¼Ê±¼ä¡¢·¢²¼·¶Î§µÈÐÅÏ¢¡£Ö§³ÖËÑË÷¹Ø¼ü×Ö»ò·¢²¼ÈËÐÅÏ¢£¬¿ìËÙ±ã½ÝµÄ²éѯµ½Ïà¹ØÄÚÈÝ¡£Ö§³Ö²éѯÒÑͨ¹ýÉóºËÓëδͨ¹ýÉóºËµÄÀúÊ·¼Ç¼¡£
ËÄ¡¢Ð£Îñ¡¢°àÎñ¹ÜÀí
5.Ö§³ÖѧУ×Ô¶¨ÒåLOGO£¬×Ô¶¨ÒåѧУÃû³Æ¡£Ö§³ÖÉèÖð༶ͷÏñ¡¢°àÖ÷ÈÎÐÅϢѧÉúÊýÁ¿ºÍ°à¼¶¿ÚºÅ¡£
¡ø6.¿¼ÊÔģʽ£ºÖ§³ÖÓû§ÔÚºǫ́ÉèÖöÔÓ¦½ÌÊҵĿ¼ÊÔʱ¼ä£¬¼´¿ÉʵÏÖ¿¼ÊÔʱ¼ä¶ÎÄÚ£¬ÔÚ°àÅÆÉÏÏÔʾ¿¼ÊÔÃû³Æ¡¢¿¼³¡ºÅ¡¢¿¼ÊÔ¿ÆÄ¿¡¢¿¼ÊÔʱ¼ä¡¢¿¼ÊԺŵÈÐÅÏ¢£¬ÏµÍ³Ö§³Ö¡Ý4ÖÖ¿¼³¡Ä£Ê½µÄ±³¾°ÉèÖá£Óû§¿É×Ô¶¨ÒåÑ¡Ôñ£¬ÊÇ·ñÔÚ¿¼³¡Ä£Ê½ÏÂÍ˳ö°ÔÆÁģʽ£»Ö§³Ö·¢²¼°à¼¶ÈÙÓþ£¬ÄÚÖáÝ3Ì×ÈÙÓþÄ£°å£¬Óû§¿É×Ô¶¨ÒåÈÙÓþÃû³Æ£¬Ö§³ÖÖ¸¶¨°à¼¶»òȫУ·¢²¼£¬Ö§³Ö×Ô¶¨Òåչʾʱ¼ä£»¿Î±íÉèÖÃ:Ö§³Öͨ¹ý¿Î±íÄ£°åµ¼Èë°à¼¶¿Î±í¡£¿Î±í¸ßÁÁÏÔʾµ±Ìì¿Î±í¼°µ±Ç°½øÐеĿγ̣¬±ãÓÚѧÉú½Ìʦ²é¿´¡£¿Éͨ¹ý½ÚÄ¿±à¼¿Î±íÄ£¿é£¬ÉèÖÃÏÔʾ½ñÈտαí»ò±¾ÖÜ¿Î±í¡££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
Áù¡¢½ÚÄ¿¹ÜÀí
7.Ö§³Ö´´½¨ºá°å½ÚÄ¿ÓëÊú°æ½ÚÄ¿£¬¶ÔÓ¦°àÅÆÉ豸²»Í¬µÄ°²×°·½Ê½¡£
¡ø8.°àÅÆ½ÚÄ¿²ÉÓÃÄ£¿é»¯ÏÔʾ·½Ê½¡£Óû§¿É¸ù¾ÝÐèÒª£¬×Ô¶¨ÒåÌí¼Ó¹¦ÄÜÄ£¿é½øÐÐÏÔʾ¡£Ö§³ÖÌí¼Ó°à¼¶ÐÅÏ¢¡¢¿Î±í¡¢°à¼¶ÈÙÓþ¡¢ÖµÈÕÉú¡¢µ¹¼ÆÊ±¡¢ÐÂÎÅ¡¢Ïà²á¡¢ÊÓÆµ¡¢¿¼ÇÚ¼°µÚÈý·½¶Ô½ÓÓ¦ÓõÄÏÔʾ¡£¸÷ÏÔʾģ¿é¿ÉÉèÖò»Í¬ÏÔʾ´óС£»Ö§³Ö·¢²¼ÁÙʱ»î¶¯£ºÄÚÖöàÌ׻ģ°å¼°¶àÖÖÔ¤ÖÃÖ÷ÌâÑÕÉ«¡£Ö§³Ö²åÈëÎÄ×Ö¡¢Í¼Æ¬¡¢Í¼ÐΡ¢Í³¼ÆÍ¼±í¡¢±í¸ñ¡¢³£Óù«Ê½µÈÔªËØ¡£²¢¿É¶Ô²ã¼¶¹ØÏµ¡¢¶ÔÆë·½Ê½¡¢ÏÔʾλÖýøÐÐ×Ô¶¨ÒåÉèÖá£Ö§³Ö×Ô¶¨ÒåÏÔʾʱ¼ä£»Ö§³Öµ¹¼ÆÊ±¹¦ÄÜ£¬¿É×Ô¶¨ÒåʼþÃû³Æ¡¢½ØÖ¹Ê±¼ä£¬Ê¼þµ¹¼ÆÊ±ÔÚ°àÅÆÊµÊ±ÏÔʾ¡£Í¬Ò»½ÚÄ¿×î¶àÖ§³Ö²åÈë¡Ý12¸öµ¹¼ÆÊ±Ä£¿é£»ºÚ°åÌùÖ§³ÖÊÖÊÆÍÏ×§ÈÎÒâλÖã¬×ö×§ÖÁ×ó²à»òÓÒ²àºó¿É×Ô¶¯ÊÕËõ£¬²»ÕÚµ²£¬Ôٴεã»÷¿ÉÕ¹¿ªºÚ°åÌù£¬Ò²¿ÉÒþ²Øµ½¹¤¾ßÀ¸£¬ºÚ°åÌùÖ§³Ö¡Ý18ÖÖÆ¤·ôÑÕÉ«£¬¿É×Ô¶¨Ò寤·ôÑÕÉ«£¬Ö§³Ö͸Ã÷ÖµÉ趨¡££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
9.Ö§³ÖÉ豸ËùÔڵصÄÌìÆøÏÔʾ¡£Ö§³Ö¶ÔÐÅÏ¢·¢²¼½øÐÐÉóºËȨÏÞ¹ÜÀí£¬Óû§½øÐÐÐÅÏ¢·¢²¼Ê±£¬ÐèÉóºËºó²Å¿ÉÔÚÉ豸ÉÏչʾ¡£°àÅÆ¿ÉÁ¬½Ó´óÆÁÉ豸£¬ÔÚ°àÅÆ¼´¿É–Ë¿´½ÌÊÒÄÚµÄÉÏ¿Î»Ãæ£¬°àÖ÷ÈÎÔÚÈËÁ³Ê¶±ðºó£¬ÊµÏÖµç×Ó¿ÉÊÓ»¯Ñ²¿Î¡£
Æß¡¢É豸¹ÜÀí
¡ø10.Ö§³Ö²é¿´É豸ÐÅÏ¢£¬¿É²é¿´°àÅÆËùÔڵص㡢°à¼¶ÐÅÏ¢¡£ÍøÂçIP¼°¹Ì¼þ°æ±¾¡£Ö§³Ö°´Õյص㡢°à¼¶ºÍ°àÅÆÃû³Æ»òip½øÐÐËÑË÷£»Ö§³Ö²é¿´Ñ§Ð£ÄÚËùÓаàÅÆÊ¹ÓÃ״̬£¬ÔÚÏß°àÅÆ¿ÉÒÔÏÔʾʵʱÆÁÄ»½ØÍ¼£¬¿É½øÐÐÖØÆô¡¢´ý»ú¡¢ÉèÖÃÒôÁ¿¡¢ÉèÖùÜÀíÃÜÂë¡¢¹Ø»úµÈ²Ù×÷¡£¿Éµ¥Ò»»òÅúÁ¿ÉèÖã»ÏµÍ³Ö§³ÖÉ趨°àÅÆ¶¨Ê±¿ª¹Ø»ú¹ÜÀí²ßÂÔ£¬Ö§³Ö¶Ô°àÅÆÉèÖöà×é×Ô¶¯¿ª¹Ø»úʱ¼ä£¬¿ÉʵÏÖ°àÅÆÃ¿ÌìÖ´Ðв»Í¬µÄ¿ª¹Ø»úʱ¼ä²ßÂÔ£»Ö§³Ö¶¨Ê±¿ª¹Ø»úÌØÊâ¼Æ»®£¬Õë¶ÔÖÜÄ©ÁÙʱµ÷¿ÎºÍ½Ú¼ÙÈÕÇé¿ö£¬Ö§³ÖÔÚ°àÅÆ¿ª»úÇÒÁªÍø×´Ì¬ÏÂÉèÖÃÁÙʱ¿ª¹Ø»ú¼Æ»®À´Âú×ãѧУÁÙʱ¿ª¹Ø»úÐèÇó¡££¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ©
11.´ý»ú°àÅÆÖ§³ÖÍøÂ绽Ðѹ¦ÄÜ£¬ÀëÏß°àÅÆÖ§³ÖµØµã¼°°à¼¶Ãû³ÆÏÔʾ£¬±ãÓÚÀÏʦѲ²é¡£ÔÚÉ豸¹ÜÀíÖÐɾ³ýÖÕ¶Ë£¬ÖÕ¶Ë»á×Ô¶¯»Ö¸´µ½³ö³§ÉèÖ㬱ãÓÚ¸ü»»°à¼¶»òÖØÐ°󶨡£
Ê®¡¢Òƶ¯Ð¡³ÌÐò
¡ø12.Ö§³Ö¿ØÖÆ£¬¿ìËÙʵÏÖ¼´Ê±¿ª¹Ø»ú¡¢ÖØÆô¡¢ÒôÁ¿ÉèÖõȲÙ×÷£»ÐÅÏ¢ÉóºË¡£¿ÉÔÚС³ÌÐòÖÐÉóºË°àÅÆ½ÚÄ¿¡¢Í¨Öª¡¢Í¼Æ¬¡¢ÊÓÆµµÈÐÅÏ¢¡£Ñ¡Ôñͨ¹ý»òÍ˻ء£Ö§³ÖÅúÁ¿ÉóºË¹¦ÄÜ£»Ö§³Ö²é¿´²âμǼ¡£²é¿´×ÜÌå²âÎÂÊý¾ÝÒÔ¼°ÌåÎÂÒì³£ÈËÔ±Ã÷ϸ¡£Ö§³ÖÈÕÆÚÑ¡Ôñ£»Ö§³Ö²é¿´¿¼ÇڼǼ¡£²é¿´×ÜÌ忼ÇÚͳ¼Æ¡¢²é¿´È±ÇÚ¡¢³Ùµ½ÈËÔ±Ã÷ϸ¡£Ö§³ÖÈÕÆÚÑ¡Ôñ£»¿Éͨ¹ýС³ÌÐòʵʱ·¢²¼°à¼¶ÏûÏ¢¡£¿É×Ô¶¨Òå·¢²¼Ê±¼ä¼°ÏÔʾÉ豸£»¿Éͨ¹ýС³ÌÐòʵʱ¸üа༶Ïà²á¼°ÊÓÆµ×ÊÔ´¡£¿ÉÊÖ»úÅÄÕÕÉÏ´«»òÏà²áѡȡͼƬ£¬·¢²¼µ½Ö¸¶¨É豸£»£¨Ìṩ¹ú¼Ò¹ãµç×ֵܾļì²â±¨¸æ»òÆäËû¾ßÓÐCMAÈÏÖ¤±êÖ¾µÄ¼ì²â±¨¸æ²¢µç×Óǩգ© |
| ϵͳ¼¯³É | 1.°üÀ¨¸÷ÀàÓÅÖÊÏ߲ġ¢¸¨²Ä£»É豸λÖúÏÀí£¬Ç¿Èõµç²¼ÏßÕûÆëÃÀ¹Û£¬Ïß·,½Ó·ì¹æÕû¡¢Î޷죻°´Ñ§Ð£ÒªÇó¶ÔËùÉæÈí¼þ½øÐÐÈ«Ãæ°²×°ºÍµ÷ÊÔ£¬ÏµÍ³¸÷²¿£¨Èí¡¢Ó²¼þ£©È«Ãæ¼æÈÝ£¬ÔËÐÐ˳³©¡£ |
| Ì컨Éùѧģ¿é | 1.²ÉÓÃÈýÖØ»ºÕð½éÖʽṹ¡¢¸ßÃܶÈÎüÉùÃÞ¡£
2.¼õÕð½á¹¹£º¶ÆÐ¿Çá¸ÖÁú¹Çµõ¶¥£¬¼ÓÇ¿ÐÍÇá¸ÖÁú¹Ç£¬ÈýÖØ»ºÕð½éÖʽṹ£¬Ìî³ä²ÄÁÏΪ¡Ý46KG/m3µÄÀëÐIJ£Á§ÏËάÎüÉùÃÞ£»
3.ÎüÉù½á¹¹£ºÄ¾Áú¹ÇÖ§¼ÜÍø£¬Ë¢¡Ý3±é·À»ðÍ¿ÁÏ£¬Ìî³ä²ÄÁÏΪ¡Ý46KG/m3µÄÀëÐIJ£Á§ÏËάÎüÉùÃÞ£¬±£»¤²ãΪÎ޷IJ¼Æ½ÆÌ£»
4.ÎüÉùÔìÐÍÎüÒôÌ壺»ù²ÄΪÏðľ£¬ÊÎÃæÎª»·±£Ä¾À¯ÓÍ¡£ |
| Ç½ÃæÉùѧģ¿é | 1.ȫƵÎüÉùºÍÀ©É¢£¬²ÉÓÃÏðľºÍ»·±£Ä¾À¯ÓÍ£»
2.½á¹¹²ã£º¶ÆÐ¿Çá¸ÖÁú¹Ç£¬U75¼ÓÇ¿ÐÍ£¬Ìî³ä¡Ý46KG/m3µÄÀëÐIJ£Á§ÏËάÎüÉùÃÞ£»
3.ÎüÉù²ã£ºÄ¾Áú¹ÇÖ§¼ÜÍø£¬Ìî³ä¡Ý46KG/m3µÄÀëÐIJ£Á§ÏËάÎüÉùÃÞ£»
4.À©É¢Ì壺Ïðľ£»
5.µÍƵÏÝÚ壺50Hz-125Hz¡£ |
| µØÃæÉùѧģ¿é | 1.µØÃæ¼õÕð²ã½á¹¹Éè¼Æ£¬ÓÐЧ¼õÉÙ´«µ¼ÔëÒô£»
2.ʯËÜÄ¾ÎÆµØ°åºÍʵľÌß½ÅÏߣ¬Ê¯ËÜÄ¾ÎÆµØ°å:ºñ¶È¡Ý4mm£¬¿ÉÑ¡ÑÕÉ«¿îʽ£»
3.¸ôÒôÕ±µþ±ßÆÌÉè¼°¼õÕðµæÆÌÉè¡£ |
| ¸ôÉù´°Éùѧģ¿é | 1.²ÉÓÃÈý²ã¸¡·¨²£Á§£¬¸Ö»¯ºñ¶È¡Ý12mm£¬ÓÐЧ¸ôÀë¼ÒôÊҺͿØÖÆÊÒÖ®¼äµÄÔëÒô£¬È·±£Â¼Òô»·¾³µÄ´¿¾»ºÍ°²¾²£»
2.ʹÓÃÄÍÓõĸֻ¯²£Á§£¬È·±£´°»§µÄ°²È«ÐÔºÍÄÍÓÃÐÔ¡£ |
| ¸ôÒôÃż°Éùѧģ¿é¸½¼þ | 1.¸ôÒôÃÅµÄ¿ÕÆøÉù¸ôÉùµ¥ÖµÆÀ¼ÛÁ¿+ƵÆ×ÐÞÕýÁ¿£¨¼ÆÈ¨¸ôÉùÁ¿+·ÛºìÔëÉùƵÆ×ÐÞÕýÁ¿£©¡Ý40dB£»
2.Óöà²ã²»Í¬ÌØÖʲÄÖÊ£¨½ðÊô¡¢×èÄᡢʵľ£©¸´ºÏ¶ø³ÉµÄ·À»ð¸ôÒôÃÅ£»
3.LEDÕÕÃ÷£ºLEDͲµÆºÍÉ䵯£¬ÊÙÃü¡Ý11000Сʱ£¬¹âͨÁ¿Î¬³ÖÂÊ¡Ý85%£¬ÏÔɫָÊý´ïµ½¡Ý85£»Ç½²åÃæ°å£¬¿ª¹ØÃæ°å¡£ |
