ÈýÎé΢ É䯵¿ª¹ØWiFi GSR1370S ¼æÈÝÌæ´úSKY/RTC/KCT/Qorvo
Cynthia-AI
2024-9-18 13:43:30
оƬ
# g# s) H" p) `; x* Q4 q2 G
( P7 ^; H5 j; G7 FGSR1370S: CMOS SOI SPDT Switch 0.01 ¨C 7.2 GHz+ \$ T4 S  `4 H* O
0 R& K/ }% y& c! `2 G: \$ `9 s0 VApplications" H  N+ R% l! K$ w9 Z. Y8 g5 B  P
, A! S. _: q  j# _$ \) O
*WLAN 802.11a/b/g/n/ac/ax networks / N9 h! V( w' K* A- d
2 r2 z% x4 S  X0 {, X+ _+ ]4 r) u
* ISM band radios 3 f% U# }1 K" y, ?: L
. V* |" W9 X) Q+ h. `* Low power T/R systems8 F# X+ \0 h6 `; u+ g3 T
1 N4 \: ~7 G1 z& m2 B
Features 4 H8 k# ^: {! ^4 v' M( \' }
0 m2 X  g  E9 u7 ^; E3 }6 y7 S*P0.1dB +32dBm typical @ +3.3V# ^" v! O8 o# O9 k! B# f
4 z+ e  U% P5 f8 t4 V2 G/ [
*Low insertion loss (0.50dB @ 2.5GHz, 0.58dB @ 5.8GHz)
; @! Z) [  x/ z) q5 K+ f0 [
- ]& A( ^5 q2 \' `: [* High isolation (25dB @ 2.5GHz) & A6 Z" V& [# k  w0 l; G
3 I: O6 I+ I; e3 V6 }
* Low delay, switch time: 75~125nS ) {' C4 a3 j) i
8 R0 Z' U* p5 J1 `% d' C
* 1.5mm ¡Á 1.5mm QFN Package (MSL3, 260¡ãC per JEDEC-J-STD-020)4 r  g& V% O$ E
6 l# R* z3 b6 d$ ~5 b. T( UDescription
7 {. V/ t( P& i& }/ G7 @
5 s6 w5 n2 c+ g# E5 B, s# r0 m8 uUsing advanced switching technologies, the GSR1370S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.5 mm ¡Á 1.5 mm package. The GSR1370S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz required high power at low control voltage.
& M1 q! f! s( ^" E5 C1 b/ z" C5 z
+ v% I% y# Y7 U  T( |& y
; z, k* p$ V% W/ W- d7 ~* `
