public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.my_audio_record);
stateView = (TextView) this.findViewById(R.id.view_state);
stateView.setText("×¼±¸¿ªÊ¼");
btnStart = (Button) this.findViewById(R.id.btn_start);
btnStop = (Button) this.findViewById(R.id.btn_stop);
btnPlay = (Button) this.findViewById(R.id.btn_play);
btnFinish = (Button) this.findViewById(R.id.btn_finish);
btnFinish.setText("Í£Ö¹²¥·Å");
btnStop.setEnabled(false);
btnPlay.setEnabled(false);
btnFinish.setEnabled(false);
// ÔÚÕâÀïÎÒÃÇ´´½¨Ò»¸öÎļþ£¬ÓÃÓÚ±£´æÂ¼ÖÆÄÚÈÝ
File fpath = new File(Environment.getExternalStorageDirectory()
.getAbsolutePath() + "/data/files/");
fpath.mkdirs();// ´´½¨Îļþ¼Ð
try {
// ´´½¨ÁÙʱÎļþ,×¢ÒâÕâÀïµÄ¸ñʽΪ.pcm
audioFile = File.createTempFile("recording", ".pcm", fpath);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
public void onClick(View v) {
int id = v.getId();
switch (id) {
case R.id.btn_start:
// ¿ªÊ¼Â¼ÖÆ
// ÕâÀïÆô¶¯Â¼ÖÆÈÎÎñ
recorder = new RecordTask();
recorder.execute();
break;
case R.id.btn_stop:
// Í£Ö¹Â¼ÖÆ
this.isRecording = false;
// ¸üÐÂ״̬
// ÔÚÂ¼ÖÆÍê³ÉʱÉèÖã¬ÔÚRecordTaskµÄonPostExecuteÖÐÍê³É
break;
case R.id.btn_play:
player = new PlayTask();
player.execute();
break;
case R.id.btn_finish:
// Íê³É²¥·Å
this.isPlaying = false;
break;
class RecordTask extends AsyncTask {
@Override
protected Void doInBackground(Void... arg0) {
isRecording = true;
try {
// ¿ªÍ¨Êä³öÁ÷µ½Ö¸¶¨µÄÎļþ
DataOutputStream dos = new DataOutputStream(
new BufferedOutputStream(
new FileOutputStream(audioFile)));
// ¸ù¾Ý¶¨ÒåºÃµÄ¼¸¸öÅäÖã¬À´»ñÈ¡ºÏÊʵĻº³å´óС
int bufferSize = AudioRecord.getMinBufferSize(frequence,
channelConfig, audioEncoding);
// ʵÀý»¯AudioRecord
AudioRecord record = new AudioRecord(
MediaRecorder.AudioSource.MIC, frequence,
channelConfig, audioEncoding, bufferSize);
// ¶¨Ò建³å
short[] buffer = new short[bufferSize];
// ¿ªÊ¼Â¼ÖÆ
record.startRecording();
int r = 0; // ´æ´¢Â¼Öƽø¶È
// ¶¨ÒåÑ»·£¬¸ù¾ÝisRecordingµÄÖµÀ´ÅжÏÊÇ·ñ¼ÌÐøÂ¼ÖÆ
while (isRecording) {
// ´ÓbufferSizeÖжÁÈ¡×Ö½Ú£¬·µ»Ø¶ÁÈ¡µÄshort¸öÊý
// ÕâÀïÀÏÊdzöÏÖbuffer overflow£¬²»ÖªµÀÊÇʲôÔÒò£¬ÊÔÁ˺ü¸¸öÖµ£¬¶¼Ã»Óã¬TODO£º´ý½â¾ö
int bufferReadResult = record
.read(buffer, 0, buffer.length);
// Ñ»·½«bufferÖеÄÒôƵÊý¾ÝдÈëµ½OutputStreamÖÐ
for (int i = 0; i < bufferReadResult; i++) {
dos.writeShort(buffer[i]);
publishProgress(new Integer(r)); // ÏòUIÏ̱߳¨¸æµ±Ç°½ø¶È
r++; // ×ÔÔö½ø¶ÈÖµ
// Â¼ÖÆ½áÊø
record.stop();
Log.v("The DOS available:", "::" + audioFile.length());
dos.close();
} catch (Exception e) {
// TODO: handle exception
return null;
// µ±ÔÚÉÏÃæ·½·¨Öе÷ÓÃpublishProgressʱ£¬¸Ã·½·¨´¥·¢,¸Ã·½·¨ÔÚUIÏß³ÌÖб»Ö´ÐÐ
protected void onProgressUpdate(Integer... progress) {
stateView.setText(progress[0].toString());
protected void onPostExecute(Void result) {
btnStart.setEnabled(true);
btnPlay.setEnabled(true);
protected void onPreExecute() {
// stateView.setText("ÕýÔÚÂ¼ÖÆ");
btnStart.setEnabled(false);
btnStop.setEnabled(true);
class PlayTask extends AsyncTask {
@Override
isPlaying = true;
int bufferSize = AudioTrack.getMinBufferSize(frequence,
short[] buffer = new short[bufferSize / 4];
try {
// ¶¨ÒåÊäÈëÁ÷£¬½«ÒôƵдÈëµ½AudioTrackÀàÖУ¬ÊµÏÖ²¥·Å
DataInputStream dis = new DataInputStream(
new BufferedInputStream(new FileInputStream(audioFile)));
// ʵÀýAudioTrack
AudioTrack track = new AudioTrack(AudioManager.STREAM_MUSIC,
frequence, channelConfig, audioEncoding, bufferSize,
AudioTrack.MODE_STREAM);
// ¿ªÊ¼²¥·Å
track.play();
// ÓÉÓÚAudioTrack²¥·ÅµÄÊÇÁ÷£¬ËùÒÔ£¬ÎÒÃÇÐèÒªÒ»±ß²¥·ÅÒ»±ß¶ÁÈ¡
while (isPlaying && dis.available() > 0) {
int i = 0;
while (dis.available() > 0 && i < buffer.length) {
buffer[i] = dis.readShort();
i++;
// È»ºó½«Êý¾ÝдÈëµ½AudioTrackÖÐ
track.write(buffer, 0, buffer.length);
// ²¥·Å½áÊø
track.stop();
dis.close();
return null;
// stateView.setText("ÕýÔÚ²¥·Å");
btnFinish.setEnabled(true);
¶þ¡¢MediaRecorder ʵÏÖÂ¼ÖÆÒôƵ£º
package com.hb56.MyAndroidUtil;
import java.io.File;
import java.io.IOException;
import android.app.Activity;
import android.content.ContentValues;
import android.content.Intent;
import android.media.MediaPlayer;
import android.media.MediaRecorder;
import android.net.Uri;
import android.os.Bundle;
import android.os.Environment;
import android.provider.MediaStore;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
* Õâ¸öÊÇÀûÓÃMediaRecorderÀàÀ´ÊµÏÖ×Ô¼ºµÄÒôÆµÂ¼ÖÆ³ÌÐò
* ΪÁË¿ÉÒÔÂ¼ÖÆÒôƵÎÒÃÇÐèÒªRECORD_AUDIOȨÏÞ
* ΪÁË¿ÉÒÔдÈëSDCard£¬ÎÒÃÇÐèÒªWRITE_EXTERNAL_STORAGEȨÏÞ
* ÀûÓÃMediaRecorderÀàʵÏÖ×Ô¼ºµÄÒôÆµÂ¼ÖÆ³ÌÐò
*com.hb56.MyAndroidUtil.MediaRecorderActivity
* @author Admin-zhangyx
* create at 2014-11-16 ÏÂÎç2:13:38
public class MediaRecorderActivity {
private TextView stateView;
private Button btnStart,btnStop,btnPlay,btnFinish;
private MediaRecorder recorder;
private MediaPlayer player;
private File audioFile;
private Uri fileUri;
public void onCreate(Bundle savedInstanceState){
stateView = (TextView)this.findViewById(R.id.view_state);
btnStart = (Button)this.findViewById(R.id.btn_start);
btnStop = (Button)this.findViewById(R.id.btn_stop);
btnPlay = (Button)this.findViewById(R.id.btn_play);
btnFinish = (Button)this.findViewById(R.id.btn_finish);
public void onClick(View v){
int id = v.getId();
switch(id){
//¿ªÊ¼Â¼ÖÆ
//ÎÒÃÇÐèҪʵÀý»¯Ò»¸öMediaRecorder¶ÔÏó£¬È»ºó½øÐÐÏàÓ¦µÄÉèÖÃ
recorder = new MediaRecorder();
//Ö¸¶¨AudioSource ΪMIC(Microphone audio source ),ÕâÊÇ×ÓõÄ
recorder.setAudioSource(MediaRecorder.AudioSource.MIC);
//Ö¸¶¨OutputFormat,ÎÒÃÇÑ¡Ôñ3gp¸ñʽ
//ÆäËû¸ñʽ£¬MPEG-4:Õ⽫ָ¶¨Â¼ÖƵÄÎļþΪmpeg-4¸ñʽ£¬¿ÉÒÔ±£»¤AudioºÍVideo
//RAW_AMR:Â¼ÖÆÔʼÎļþ£¬ÕâÖ»Ö§³ÖÒôÆµÂ¼ÖÆ£¬Í¬Ê±ÒªÇóÒôƵ±àÂëΪAMR_NB
//THREE_GPP:Â¼ÖÆºóÎļþÊÇÒ»¸ö3gpÎļþ£¬Ö§³ÖÒôƵºÍÊÓÆµÂ¼ÖÆ
recorder.setOutputFormat(MediaRecorder.OutputFormat.THREE_GPP);
//Ö¸¶¨Audio±àÂ뷽ʽ£¬Ä¿Ç°Ö»ÓÐAMR_NB¸ñʽ
recorder.setAudioEncoder(MediaRecorder.AudioEncoder.AMR_NB);
//½ÓÏÂÀ´ÎÒÃÇÐèÒªÖ¸¶¨Â¼ÖƺóÎļþµÄ´æ´¢Â·¾¶
File fpath = new File(Environment.getExternalStorageDirectory().getAbsolutePath()+"/data/files/");
fpath.mkdirs();//´´½¨Îļþ¼Ð
try {
//´´½¨ÁÙʱÎļþ
audioFile = File.createTempFile("recording", ".3gp", fpath);
recorder.setOutputFile(audioFile.getAbsolutePath());
//ÏÂÃæ¾Í¿ªÊ¼Â¼ÖÆÁË
try {
recorder.prepare();
} catch (IllegalStateException e) {
recorder.start();
break;
case R.id.btn_stop:
recorder.stop();
recorder.release();
//È»ºóÎÒÃÇ¿ÉÒÔ½«ÎÒÃǵÄÂ¼ÖÆÎļþ´æ´¢µ½MediaStoreÖÐ
ContentValues values = new ContentValues();
values.put(MediaStore.Audio.Media.TITLE, "this is my first record-audio");
values.put(MediaStore.Audio.Media.DATE_ADDED, System.currentTimeMillis());
values.put(MediaStore.Audio.Media.DATA, audioFile.getAbsolutePath());
fileUri = this.getContentResolver().insert(MediaStore.Audio.Media.EXTERNAL_CONTENT_URI, values);
//Â¼ÖÆ½áÊøºó£¬ÎÒÃÇʵÀý»¯Ò»¸öMediaPlayer¶ÔÏó£¬È»ºó×¼±¸²¥·Å
player = new MediaPlayer();
player.setOnCompletionListener(new MediaPlayer.OnCompletionListener() {
@Override
public void onCompletion(MediaPlayer arg0) {
//¸üÐÂ״̬
stateView.setText("×¼±¸Â¼ÖÆ");
//×¼±¸²¥·Å
try {
player.setDataSource(audioFile.getAbsolutePath());
player.prepare();
} catch (IllegalArgumentException e) {
//¸üÐÂ״̬
stateView.setText("×¼±¸²¥·Å");
break;
case R.id.btn_play:
//²¥·Å¼Òô
//×¢Ò⣬ÎÒÃÇÔÚ¼Òô½áÊøµÄʱºò£¬ÒѾʵÀý»¯ÁËMediaPlayer£¬×öºÃÁ˲¥·ÅµÄ×¼±¸
player.start();
//¸üÐÂ״̬
//ÔÚ²¥·Å½áÊøµÄʱºòÒ²Òª¸üÐÂ״̬
break;
//Íê³ÉÂ¼ÖÆ£¬·µ»ØÂ¼ÖƵÄÒôƵµÄUri
Intent intent = new Intent();
intent.setData(fileUri);
this.setResult(RESULT_OK, intent);
this.finish();
break;
