| ÐòºÅ | É豸Ãû³Æ | Æ·ÅÆÐͺŠ| Ö÷Òª¼¼Êõ²ÎÊý¼°ËµÃ÷ | ÊýÁ¿ | µ¥Î» |
| 1 | ´óÕñĤ»°Í²£¨1£© | Neumann U87AI | ÒªÇó»°Í²Éùѧ¹¤×÷ÔÀí£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷
ÒªÇó¾ß±¸3ÖÖÖ¸ÏòÐÔʰÒô£ºÐÄÐÍÖ¸Ïò¡¢È«Ö¸Ïò¡¢8×ÖÖ¸Ïò£»µÍƵÏìӦƵÂÊ£º¡Ü20Hz ¸ßƵÏìӦƵÂÊ£º¡Ý20000H
½Ï´óÊä³öµçѹ²»Ð¡ÓÚ390Mv
¾ß±¸¹©µçµçѹ(P48£¬IEC 61938)£º48V ¡À 4V
µçÁ÷Ô´ÏûºÄ²»´óÓÚ(P48£¬IEC 61938)£º0.8 mA
ÁéÃô¶È£¨CCIR486-3£©£º²»Ð¡ÓÚ26/23/25dB (È«Ïò/ÐÄÐÍ/8)
³ß´ç²»Ð¡ÓÚ56mm(Ö±¾¶) x 200mm(³¤¶È)
ÒªÇóµ¥Ì壺µçÈÝʽ
·åÖµÉùѹ¼¶²»Ð¡ÓÚ£¨THDСÓÚ0..5%£©117db£¨ÐÄÐÍ£©
¶î¶¨×迹²»Ð¡ÓÚ200 ohms
¸ºÔØ×迹²»Ð¡ÓÚ1 kohms
¾ß±¸Æ¥Åä½Ó¿Ú£ºXLR 3Ffu'tou
ÒªÇóÖØÁ¿ÔÚ500g-510gÖ®¼ä | 2 | Ö§ |
| 2 | ´óÕñĤ»°Í²£¨2£© | Shure KSM44A | ÒªÇó¾ß±¸3ÖÖÖ¸ÏòʰÒô£ºÈ«Ö¸Ïòʰ¡¢Ë«Ö¸Ïò¡¢ÐÄÐÍÖ¸Ïò£»µÍƵÏìӦƵÂÊ£º¡Ü20Hz £¬¸ßƵÏìӦƵÂÊ£º¡Ý20000Hz
ÒªÇó»°Í²´«¸ÐÆ÷ÀàÐÍ£ºµçÈÝ
¾ß±¸Ë¥¼õÆ÷¿ª¹Ø£º-15 dB
ÁéÃô¶È£¨dBV/Pa£©£ºÐÄÐÍÖ¸Ïò²»Ð¡ÓÚ£¨-31 dBV/Pa£©¡¢È«Ö¸Ïò²»Ð¡ÓÚ£¨-37 dBV/Pa£©¡¢ ˫ָÏò²»Ð¡ÓÚ£¨-36 dBV/Pa£©£»ÁéÃô¶È£¨mV/Pa£©£ºÐÄÐÍÖ¸Ïò²»Ð¡ÓÚ£¨29,8 mV/Pa£©¡¢È«Ö¸Ïò²»Ð¡ÓÚ£¨14,8 mV/Pa£©¡¢ ˫ָÏò²»Ð¡ÓÚ£¨16,8 mV/Pa£©
Êä³ö×迹£º²»Ð¡ÓÚ50¦¸
Éùѹ£ºÐÄÐÍÖ¸Ïò²»Ð¡ÓÚ£¨Pad off£º134 dB¡¢Pad on£º150 dB£©¡¢È«Ö¸Ïò²»Ð¡ÓÚ£¨Pad off£º140 dB¡¢Pad on£º152 dB£©¡¢Ë«Ö¸Ïò²»Ð¡ÓÚ£¨Pad off£º139 dB¡¢Pad on£º151 dB£©
µÈЧ×ÔÔ룺ÐÄÐÍÖ¸Ïò²»´óÓÚ4 dB£¨A£©¡¢È«Ö¸Ïò²»´óÓÚ6 dB£¨A£©¡¢Ë«Ö¸Ïò²»´óÓÚ7,5 dB£¨A£©£»»ÃÏóµçÔ´ÔÚ11 ¨C 52 V DCÖ®¼ä | 4 | Ö§ |
| 3 | СÕñĤ»°Í² | Neumann KM184 | ÒªÇó»°Í²Éùѧ¹¤×÷ÔÀí£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷
ÒªÇó¾ß±¸Ö¸ÏòÐÔ£ºÐÄÐÍ£»µÍƵÏìӦƵÂÊ£º¡Ü20 Hz£¬ ¸ßƵÏìӦƵÂÊ£º¡Ý20000Hz
ÁéÃô¶È£º²»Ð¡ÓÚ15mV/Pa
Êä³ö×迹£º²»Ð¡ÓÚ50ohms
¸ºÔØ×迹£º²»Ð¡ÓÚ1000ohms
ÁéÃô¶È²»Ð¡ÓÚ£¨CCIR 468-3£©£º25dB
ÁéÃô¶È²»Ð¡ÓÚ£¨DIN/IEC 651£©£º16dB-A
ÐÅÔë±È²»Ð¡ÓÚ£¨CCIR 468-3£©£º69dB
ÐÅÔë±È²»Ð¡ÓÚ£¨DIN/IEC 651£©£º78dB
·åÖµÉùѹ¼¶²»Ð¡ÓÚ£¨THDµÈÓÚ0.5%£©£º138dB
½Ï´óÊä³öµçѹ£º10dBu
Âó¿Ë·ç´«¸ÐÆ÷¶¯Ì¬·¶Î§²»Ð¡ÓÚ£º122dB
¾ß±¸¹©Ó¦µçѹ£º48+4VµçÁ÷£º2.3mA
ÒªÇó³ß´çÔÚ22mm x 107mmÖ®¼ä£¬ÖØÁ¿£º80g-90gÖ®¼ä Ð踽ËÍ»°Í²¼Ð | 8 | Ö§ |
| 4 | »°Í²³ÉÆ·Ïߣ¨10Ã׳¤¶È£© | ¶¨ÖÆ | ÒªÇó´ø¿¨Å©¹«Ä¸µÄ³ÉÆ·Ïß ³¤¶È¡Ý10Ã×
Ï߲IJÎÊý£º
µ¼ÌåÊý²»ÉÙÓÚ4¸ù
±ê×¼Ïß¾¶²»´óÓÚ6mm
µ¼Ìå½ØÃæ»ý²»Ð¡ÓÚ0.20mm/24AWG
µ¼ÌåÍ˿ֱ¾¶²»Ð¡ÓÚ0.08mm
ÏßоֱÁ÷µç×費СÓÚ9.8Å·Ä·/100m
µ¼ÌåÍË¿ÊýÁ¿²»ÉÙÓÚ40¸ù
ÍÍøÃܶȲ»Ð¡ÓÚ94%
¿¨Å©Í·²ÎÊý£º
ÒªÇó¾ß±¸¶ÆÄøÍâ¿Ç ¶ÆÒø´¥µã ´¥µã¼äµçÈÝ ¡Ü 4 pF
´¥µãµç×è ²»´óÓÚ 3 m¦¸
¾øÔµÇ¿¶È²»Ð¡ÓÚ1,5 kVdc
¾øÔµµç×費СÓÚ10 G¦¸ (³õʼ)
µ¥¸ö´¥µã¶î¶¨µçÁ÷²»Ð¡ÓÚ 16 A
¶î¶¨µçѹ ²»´óÓÚ 50 V | 16 | Ìõ |
| 5 | ÒôƵ¿¨Å©ÐźÅÏߣ¨3Ã׳¤¶È£© | ¶¨ÖÆ | ÒªÇó¿¨Å©¹«Ä¸µÄ³ÉÆ·Ïß ³¤¶È¡Ý3Ã×
Ï߲IJÎÊý£º
µ¼ÌåÊý²»ÉÙÓÚ4¸ù
±ê×¼Ïß¾¶²»´óÓÚ6mm
ÍÍøÃܶȲ»Ð¡ÓÚ94%
¿¨Å©Í·²ÎÊý£º
ÒªÇó¾ßÓжÆÄøÍâ¿Ç ¶ÆÒø´¥µã ´¥µã¼äµçÈÝ ¡Ü 4 pF
| 6 | »°Í²Ö§¼Ü | ¶¨ÖÆ | ÒªÇóÖ§¼Ü»ù×ù²ÄÖÊ£º½ðÊô²ÄÁÏ ¸ß¶È·¶Î§94-164cm Ö®¼ä
ºá¸Ë³¤¶È²»Ð¡ÓÚ£º81cm ÑÕÉ«ºÚÉ« ¾»Öز»Ð¡ÓÚ£º2.5KG ÒªÇó³ÐÖØ£º5.0KGÒÔÉÏ | 12 | Ö» |
| 7 | ÒôƵTRS´óÈýоÐźÅÏß | ¶¨ÖÆ | ÒªÇóTRS´óÈýоµÄ³ÉÆ·Ïß ³¤¶È¡Ý3Ã×
Ï߲IJÎÊý£ºµ¼ÌåÊý²»ÉÙÓÚ4¸ù£»±ê×¼Ïß¾¶²»´óÓÚ6mm £»
µ¼Ìå½ØÃæ»ý²»Ð¡ÓÚ0.20mm/24AWG£»µ¼ÌåÍ˿ֱ¾¶²»Ð¡ÓÚ0.08mm £»ÏßоֱÁ÷µç×費СÓÚ9.8Å·Ä·/100m £»µ¼ÌåÍË¿ÊýÁ¿²»ÉÙÓÚ40¸ù £»ÍÍøÃܶȲ»Ð¡ÓÚ94%
TRS´óÈýо²ÎÊýÒªÇó£º
¾øÔµÇ¿¶È ²»Ð¡ÓÚ1 kVdc
¾øÔµµç×è ²»Ð¡ÓÚ 2 G¦¸ (³õʼ)
¶î¶¨µçѹ ²»´óÓÚ50 V
µçÀÂÍâ¾¶ÒªÇóÔÚ4 - 7 mmÖ®¼ä
βÌײÄÁÏÒªÇ󣺾ÛËõÈ© (POM) + PU
´¥µãµç¶ÆÒªÇó£º2 ¦Ìm Ni (Su)
´¥µãÒªÇ󣺻ÆÍ (CuZn39Pb3)
ÄÚо²ÄÁÏÒªÇ󣺾Ûõ£°· (PA 6.6 30 % GR)
·ûºÏ±ê×¼ IEC 60603-11 / EIA RS-453
¿Éº¸ÐÔ ·ûºÏ IEC 68-2-20 | 16 | Ìõ |
| 8 | »°Í²·Å´óÆ÷ | Rupert Neve 5211 | ÒªÇó¾ß±¸2·»°Í²Ç°¼¶·Å´óÆ÷
¾ß±¸AÀà·Å´óµç· ¾ßÓж¨ÖƱäѹÆ÷ ¾ß±¸¿Éµ÷½ÚµÄSILKг²¨±¥ºÍµç· ¾ß±¸20HZ-250HZ¿ÉɨƵµÍÇÐ
1 kHzʱµÄ×î´óÊäÈëµçƽ²»Ð¡ÓÚ£º +26 dBu
ÔëÉù£ºÏß·Êä³ö£¨µ¥Î»ÔöÒæ£©²»Ð¡ÓÚ£º-104 dBV£¬-101.9 dBu
-6 dB Ïß·Êä³ö£¨µ¥Î»ÔöÒæ£©²»Ð¡ÓÚ£º-109 dBV£¬-107 dBu
Ïß·Êä³ö£¨+ 30 dB ÔöÒæ£©²»Ð¡ÓÚ£º-98 dBV£¬-96 dBu
Ïß·Êä³ö£¨+66 dB ÔöÒæ£©£º²»Ð¡ÓÚ-66 dBV£¬-64 dBu
µÈЧÊäÈëÔëÉù£º²»Ð¡ÓÚ -128 dBV, -126 dBu
×î´óÊä³ö£º1 kHz ʱ²»Ð¡ÓÚ+26.5 dBuÏûºÄ¹¦ÂÊ£º35W£¨½Ï´ó£© | 4 | ̨ |
| 9 | 8·»°·Å | Focusrite Clarett OctoPre | ÒªÇó¾ß±¸8·»°Í²ÊäÈë »ÃÏóµçÔ´ ¾ß±¸ADAT¹âÏ˽ӿÚ
ÒªÇó¾ß±¸Ö§³ÖµÄ²ÉÑùÂÊ44.1 kHz£¬48 kHz£¬88.2 kHz£¬96 kHz£¬176.4 kHz£¬192 kHzÂó¿Ë·çÊäÈë
ƵÂÊÏìÓ¦²»ÁÓÓÚ 20 Hz-35 kHz¡À0.1 dB
¶¯Ì¬·¶Î§£¨ÎÞ²åÈ룩²»Ð¡ÓÚ 117 dB£¨A¼ÓȨ£©
¶¯Ì¬·¶Î§£¨´ø²åÈ룩²»Ð¡ÓÚ 115 dB£¨A¼ÓȨ£©
×Üг²¨Ê§Õæ²»´óÓÚTHD + N 0.001£¥
ÔëÉù²»¸ßÓÚEIN ¨C128 dBu£¨A¼ÓȨ£©
×î´óÊäÈëµçƽ²»Ð¡ÓÚ +16·Ö±´¡À0.5·Ö±´ | 1 | ̨ |
| 10 | ¡ùµ÷Òǫ̂ | Solid State Logic AWS916 | ÒªÇó¾ß±¸4 ¸öSuperAnalogueTM ԒͲ / Ïß / Hi-Z / 48V / HPF ºÍ¼«ÐÔ¿ª¹Ø£»4¸ö SuperAnalogueTM ¾ß±¸Ë«¡¢µ¥ÉùµÀÇл»µÄÁ¢ÌåÉùÏß·µçƽÊäÈë
ÒªÇó¾ß±¸ÄÚÖà 16 ͨµÀ 96 Khz / 24 λ USB ½Ó¿Ú
¾ß±¸´ø¸ß¼¶Â·ÓÉ£»¾ß±¸´øÓС°×Ô¶¯¡±°æ±¾µÄ G-Comp ×ÜÏßѹËõÆ÷µÄ»ù±¾°æ±¾
ÿ¸öͨµÀÉ쵀 ²»ÉÙÓÚ3 ¶Î SSL LF/MF/HF EQ
¾ß±¸¾µä SSL ͨµÀ¶¯Ì¬´¦Àí
¾ß±¸ÌýԒͲѹËõÆ÷
¾ß±¸´øÓÐÔ´¾ØÕóµÄË«¶ÀÁ¢¶ú»úÊä³ö
¾ß±¸100 ºÁÃ׿ØÖÆÌ¨¼¶ÍÆ×Ó | 1 | ̨ |
| 11 | Èí¼þ¿ØÖÆÆ÷ | Solid State Logic UF8 | ÒªÇó¾ß±¸²»ÉÙÓÚ8¸öÂí´ïÍÆ×ÓÒôƵ¹¤×÷Õ¾¿ØÖÆÆ÷
¾ß±¸¸ßÆ·ÖÊ 100 ºÁÃ×´¥Ãþ¸ÐÓ¦ÍÆ×Ó£¬¸ß·Ö±æÂʲÊÉ«ÏÔʾÆÁÈ«½ðÊôÍâ¿Ç£¬ÊÎÓÐÀË¿Ñô¼«Ñõ»¯¶¥°å¡£
¾ß±¸8¸öÎÞÏÞÐýת±àÂëÆ÷×Ô¶¨Ò幤×÷Á÷³Ì£¬
ÒªÇóÿ¸öÉ豸 ¾ß±¸ 43 ¸ö¿É·ÖÅä¼ü£» 5 ×é 8 ¸öÓû§¼ü + 3 ¸ö¿ì½Ý¼ü
¾ß±¸ÖÇÄܶàÓÃ;CHANNELͨµÀ±àÂëÆ÷
¾ß±¸Êó±ê¹ö¶¯Ä£Ä⹦ÄÜ£¬¿É¿ØÖƽ«Êó±êÐüÍ£ÔÚÉÏÃæµÄÈκβå¼þ²ÎÊý
¾ß±¸¸ßËÙ USB Á¬½Ó¡£
¾ß±¸¿É´®Áª4̨ͬÑù»úÆ÷¡£ | 2 | ̨ |
| 12 | ¼àÌý¿ØÖÆÆ÷ | SPL MTC 2381 MKII | ÒªÇó¾ß±¸Ä£ÄâÊäÈëºÍÊä³ö£»XLRºÍTRS²å¿×£¨Æ½ºâ£©£¬RCA
×î´óÊäÈëÔöÒæ£º¡Ý22.5dBu
¹²Ä£ÒÖÖÆ²»Ð¡ÓÚ£º80dBu
ÊäÈë×迹²»Ð¡ÓÚ£º20kÅ·Ä·
Êä³ö×迹²»Ð¡ÓÚ£º75Å·Ä·
ƵÂÊ·¶Î§²»ÁÓÓÚ£º10Hz-150khz
THD +N (10 Hz ‒ 22 kHz, 0 dBu)£º0.0027%
ÔëÉù²»´óÓÚ£º-94.3dBu
¶¯Ì¬·¶Î§²»Ð¡ÓÚ116.3dB
¾ß±¸´ø»·ÐαäѹÆ÷µÄÄÚ²¿ÏßÐÔµçÔ´
Ä£ÄâÒôƵµÄ¹¤×÷µçѹ²»´óÓÚ£º+/-18v
¼ÌµçÆ÷ºÍLEDµÄ¹¤×÷µçѹ²»´óÓÚ£º+12v | 1 | ̨ |
| 13 | Éù¿¨ | Steinberg AXR4U | ÒªÇóºÍ¹¤×÷Õ¾Èí¼þ¾ßÓÐÁ¼ºÃµÄ¼æÈÝÐÔ
¾ß±¸Á¬½ÓÀàÐÍ£ºUSB3
¾ß±¸´øÓÐRND SilkµÄAXR Hybrid PreǰÖû°·Å
¾ß±¸¶¶¶¯¼¼Êõ£ºSSPLL¾ß±¸°åÔØDSP£ºDSPX
Íâ¹Û²»´óÓÚ£º19Ó¢´ç»ú¼Üµ¥Ôª£¬1 HU
¾ß±¸½ðÊôÍâ¿Ç ¾ß±¸ÍâÖÃ24V AC ÊÊÅäÆ÷
½Ï´ó²ÉÑùÂʲ»Ð¡ÓÚ382kHz¶¯Ì¬·¶Î§ÊäÈë²»´óÓÚ120dB
³ß´ç£¨¿íx¸ßxÉ²»´óÓÚ£º480 x45x378 mm
ÖØÁ¿²»´óÓÚ£º4600g
Êýģת»»¾ß±¸ AD/DA£º32bit
ÊäÈë×ÜÊý²»ÉÙÓÚ£º28£¬¶ÀÁ¢Êä³ö×ÜÊý²»ÉÙÓÚ£º24 £¬Êä³ö×ÜÊý²»ÉÙÓÚ£º24 | 1 | ̨ |
| 14 | Êý×ÖÒôƵ¹¤×÷Õ¾ | Steinberg Cubase Pro | ÒªÇó±ê×¼µÄÊý×ÖÒôƵ¹¤×÷Õ¾Õý°æÈí¼þ£¬ÖÐÎIJÙ×÷½çÃæ¡£¿ÉÒÔ¼æÈÝ֮ǰ°æ±¾µÄCUBASE¹¤³ÌÎļþ
ÒªÇó¾ß±¸64λÒôƵÒýÇæ£¬ÆµÂÊÏìÓ¦³¬¹ý192kºÕ×È
¾ß±¸²»ÏÞÊýÁ¿µÄÒôƵÓëmidiÀÖÆ÷¹ìµÀ£¬
¾ß±¸²»ÏÞÊýÁ¿µÄvst²å¼þ²åÈ빦ÄÜ£¬¶à´ï256ÌõµÄVCA¹ìµÀ£¬³¬¹ý3000ÖÖÀÖÆ÷ÒôÉ«£¬×Ô´ø³¬¹ý80ÖÖ¸÷ʽÒôƵ²å¼þ°üº¬eq£¬Ñ¹ËõµÈ£¬
¾ß±¸Ö§³Ö³¬¹ý256¸öÎïÀíÊäÈëÓëÊä³ö£¬×Ô´øÒô¸ß£¬½Ú×àÐÞÕýµÈ¹¦ÄÜ¡£ | 1 | Ì× |
| 14.1 | ²å¼þÌ××° | Waves Mercury | ÒªÇó¾ß±¸³¬¹ý250¸öÖ÷Á÷²å¼þ£¬°üº¬¸÷Àà·ç¸ñѹËõ£¬¾ùºâ£¬»ìÏ죬ÑÓʱ£¬ºÏ³ª£¬Òô¸ßÐÞÕý£¬½µÔ룬ĸ´øµ÷ÕûµÈµÈ²å¼þ¡£²¢Ìṩ¼¼ÊõÖ§³Ö¡£ | 1 | Ì× |
| 15 | ¼àÊÓÆ÷ | EIZO CG247X | ÒªÇó¼àÊÓÆ÷ÀàÐÍ£ºIPS ±³µÆ ¹ãÉ«Óò LED
ÒªÇó³ß´ç²»Ð¡ÓÚ 24.1" / 61.1cm
ÒªÇóÎïÀí·Ö±æÂʲ»Ð¡ÓÚ1920 x 1200 £¨³¤¿í±È16:10)
ÒªÇóÏÔʾ³ß´ç²»Ð¡ÓÚ£¨Ë®Æ½ x´¹Ö±£© 518.4 x 324.0 mm
µã¾à²»´óÓÚ 0.270 x 0.270 mm
ÏñËØÃܶȲ»Ð¡ÓÚ 94ppi
¾ß±¸»Ò½×É«µ÷ DisplayPort, HDMI:1024É«µ÷£¨Ñ¡×Ô65281É«£©
¾ß±¸DVI:256 É«£¨Ñ¡×Ô65281É«£©
¾ß±¸ÏÔʾɫ²Ê DisplayPort, HDMI:10.7 ÒÚÑ¡×Ô 278ÍòÒÚ
DVI:1677ÍòÑ¡×Ô 278ÍòÒÚ
¿ÉÊÓ½Ç¶È ²»Ð¡ÓÚ£¨Ë®Æ½/´¹Ö±,±ê×¼£© 178¡ã¡¢178¡ã
ÁÁ¶È £¨±ê×¼£©²»Ð¡ÓÚ 350 cd/m2
¶Ô±È¶È £¨±ê×¼£©²»Ð¡ÓÚ 1000:1
ÏìӦʱ¼ä £¨±ê×¼£© ²»´óÓÚ15 ms £¨»ÒÖÁ»Ò£©
¾ß±¸¿íÉ«Óò £¨±ê×¼£© Adobe RGB£º99%
¾ß±¸Ô¤Éèģʽ É«²Êģʽ£¨Custom¡¢Adobe RGB¡¢sRGB¡¢Calibration£©
¾»ÖØ ²»µÍÓÚ7.8 kg / 17.2 °õ
¾»ÖØ (ÎÞµ××ù)²»µÍÓÚ 5.0 kg / 11.0 °õ
¸ß¶Èµ÷½Ú·¶Î§ ²»µÍÓÚ155 mm
Çãб²»µÍÓÚ ÏòÉÏ35¡ã¡¢ÏòÏ 5¡ã
Ðýת²»µÍÓÚ 344¡ã
ÖÐÐÄÐýת²»µÍÓÚ 90¡ã
¾ßÓÐÈÏÖ¤¼°±ê×¼ CB, CE, TUV/GS, cTUVus, FCC-B, CAN ICES-3 (B), VCCI-B, TUV/Ergonomics, RCM, RoHS, WEEE, EAC, China RoHS, CCC | 2 | ̨ |
| 16 | µçÄÔÖ÷»ú | ¶¨ÖÆ | ¾ß±¸i7 12700 CPU Ö÷°å¾ß±¸Ö§³ÖÀ×µç3ÒÔÉÏ½Ó¿Ú ÏÔ¿¨Ö§³ÖË«ÏÔʾÆ÷Êä³ö¡¢DPÊä³ö2¸öÒÔÉÏ ÏÔ´æÀàÐÍ£ºGDDR6¼°ÒÔÉÏ8GÏÔ´æ¼°ÒÔÉÏ ¹Ì̬ӲÅÌ2T¼°ÒÔÉÏ µçÔ´500W¼°ÒÔÉÏ Äڴ棺DDR5 16G˫ͨµÀ£¨2¸ù£©¼°ÒÔÉÏ | 1 | ̨ |
| 17 | ¶ú»ú·ÖÅäÆ÷ | Sonifex RB-HD6 | ÒªÇó¾ß±¸6·Á¢ÌåÉù¶ú»ú·ÖÅä·Å´óÆ÷
ÒªÇóÊäÈë×迹:¡Ý20k¦¸Æ½ºâ,¡Ý10k¦¸·Çƽºâ
¾ß±¸¿ÉÒÔÇý¶¯×迹Ϊ32¦¸ µ½600¦¸µÄ¶ú»ú£¬,¶øÇÒ¶¼Äܱ£³Ö150mWµÄÊä³ö
¾ß±¸µ¥¶ÀÒôÁ¿¿ØÖÆ:-60dB µ½+18dBÔöÒæ
×î´óÊäÈëµçƽ²»Ð¡ÓÚ:+28dBu
Ö÷ÒôÁ¿¿ØÖƲ»Ð¡ÓÚ:¡À10dBÔöÒæ | 3 | ̨ |
| 18 | ¼àÌýÒôÏì | QUESTED S7R | ÒªÇóƵÂÊÏìÓ¦²»ÁÓÓÚ68Hz-20kHz ¡À 2dB £»58Hz - 6dB
µÍƵÊä³ö¹¦ÂÊ£º²»Ð¡ÓÚÁ¬Ðø120W £»¸ßƵÊä³ö¹¦ÂÊ:²»Ð¡ÓÚÁ¬Ðø70W
×迹£º²»Ð¡ÓÚ10K ohm µç×ÓÆ½ºâ£¬¾ß±¸RFÂ˲¨Æ÷
×î´óÉùѹ¼¶£º²»Ð¡ÓÚ105dB³ÖÐø·ÛºìÐÅÔê@1m Leq 1·ÖÖÓ
ÁéÃô¶È£º²»Ð¡ÓÚ96dBÉùѹ@1Ã×
×Üг²¨Ê§Õæ¶È£º²»´óÓÚ0.03%,ÔÚ 20Hz-20KHz.ÒÔϵÍÓÚÏ÷²¨1dbµÄˮƽÉϲ»´óÓÚ0.005%@1kh
¸ßÒôµ¥Ôª£º¾ß±¸ÈíÇò¶¥¸ßÒô²»Ð¡ÓÚ1 x 28 mm (1 ⅛ Ó¢´ç)
µÍÒôµ¥Ôª£º²»Ð¡ÓÚ1x165mm (6.5Ó¢´ç)
³ß´ç£¨¸ß¡Á¿í¡ÁÉ²»´óÓÚ
244 (w) x 347 (h) x 302 (d) mm 9.6¡±(w) x 13.6¡±(h) x 11.9¡±(d)
ÖØÁ¿²»µÍÓÚ
11.7kg / 22.5 °õ | 2 | Ö» |
| 19 | ¼àÌýÒôÏì | QUESTED SB10R + SBC250 | µÍÒô¼àÌýÒôÏäÒªÇóƵÂÊÏìÓ¦²»ÁÓÓÚ
29Hz-200Hz ¡À 2dB & 25Hz-200Hz ¡À 6dB
×迹²»¸ßÓÚ10K ohm µç×ÓÆ½ºâ
×î´óÉùѹ²»µÍÓÚ116dB³ÖÐø ·ÛºìÐÅÔê@1m Leq 1·ÖÖÓµ¥¸öÒôÏäÒ»°ë¿Õ¼ä
½ÓÏß·½Ê½£º²»ÉÙÓÚ2¶ÔXLR£¬1/4Ó¢´ç²å¿××éºÏ½ÓÍ·
µçÔ´ÒªÇó£º
µçѹ£º¾ß±¸ÓÐÄÚÖòåÍ·ÉèÖãº±ê³Æ115V/230V@50-60Hz 230V
É趨ֵ£º ×îµÍ160V£¬ÏÞÖÆÊä³ö¹¦ÂÊ£º×î´ó255V 115VÉ趨ֵ£º×îµÍ80V£¬ÏÞÖÆÊä³ö¹¦ÂÊ£º×î´ó127V
½ÓÏ߾߱¸Òý½Å1½ÓµØÏß Òý½Å2½ÓÕý¼« Òý½Å3½Ó¸º¼« 1¶Ô½ÓÏßÖù
µÍÒôµ¥Ôª²»Ð¡ÓÚ1 x 250mm£¨10Ó¢´ç£©
³ß´ç²»Ð¡ÓÚ£¨¸ß¡Á¿í¡ÁÉ
600 (w) x 332 (h) x 300 (d) mm 23.6¡±(w) x 13¡±(h) x 11.8¡±(d)
ÖØÁ¿²»µÍÓÚ19.8 kg / 43.5lb
¹¦·Å²ÎÊýÒªÇó£º
ºã¶¨¹¦Âʲ»µÍÓÚ250W RMS
Ê§Õæ¶È£º²»´óÓÚ 0.03%, µÍÓÚÏ÷²¨µÄ1dBµçƽ£¬ 20Hz-120Hz. typ 0.005% @ 20W RMS 100 Hz
ÐÅÔë±È²»µÍÓÚ -100dB
¹©Ó¦ÉÌÐèÌṩÏàÓ¦Æ·ÅÆÊÚȨÊé | 1 | Ì× |
| 20 | ¼àÌý¶ú»ú | Sony MDR-7506 | ÒªÇó¼àÌý¶ú»úÀàÐÍ:Í·´÷ʽ
¾ß±¸´ÅÌúÀàÐÍ£ºîÏ
µ¥ÔªÖ±¾¶²»Ð¡ÓÚ40.0 mm
ÁéÃô¶È²»µÍÓÚ106 dB/W/m
×迹²»Ð¡ÓÚ63 Ohms at 1khz
ƵÂÊÏìÓ¦²»ÁÓÓÚ10-20000Hz
¾ß±¸¹¦ÂÊÈÝÁ¿1,000mW
¾ß±¸ÎÞÑõͽºÏÏߺÍ3.5ת6.3mm½ÓÍ·
ÏßÀ³¤¶È²»ÉÙÓÚ3m¾ß±¸¿ÉÀÉìµç»°Ê½µ¯»ÉÏß
ÖØÁ¿²»¸ßÓÚ230g | 16 | Ì× |
| 21 | ¶¨ÖÆÒô¿ØÌ¨ | ¶¨ÖÆ | Òô¿ØÌ¨´óС²»Ð¡ÓÚ£¨³¤2.2m£¬¿í1m £¬¸ß0.75m£©£¬¾ß±¸ 16¸öÒÔÉÏ»ú¼Üλ¡¢1¸öMIDi(61¼üÅÌ)³éÌë ¡£
ÒÔÄܰ²×°Éϱ¾´Î²É¹ºÉ豸Ϊ׼ | 1 | ̨ |
| 22 | ¶Ô½²Ö§¼Ü | ¶¨ÖÆ | ÒªÇó¿É°²×°¼ÐÓÚ×ÀÃæ£¬¿É°²×°¶¯È¦»°Í²¡£ | 1 | ̨ |
| 23 | ÒôƵÐźÅÏß | ¶¨ÖÆ | Ï߲IJÎÊý£ºµ¼ÌåÊý²»ÉÙÓÚ4¸ù£»±ê×¼Ïß¾¶²»´óÓÚ6mm £»µ¼Ìå½ØÃæ»ý²»Ð¡ÓÚ0.20mm/24AWG£»µ¼ÌåÍ˿ֱ¾¶²»Ð¡ÓÚ0.08mm £»ÏßоֱÁ÷µç×費СÓÚ9.8Å·Ä·/100m £»µ¼ÌåÍË¿ÊýÁ¿²»ÉÙÓÚ40¸ù £»ÍÍøÃܶȲ»Ð¡ÓÚ94% | 100 | Ã× |
| 24 | ÒÆ¶¯¹Ì̬ӲÅÌ | Î÷ÊýWD | ¹Ì̬ӲÅÌÈÝÁ¿SSD 2TB¼°ÒÔÉÏ | 1 | ̨ |
| 25 | µçԴʱÐòÆ÷ | FURMAN PS-8R E III | ×î´óÊä³öµçÁ÷²»Ð¡ÓÚ£º 10A
¹¤×÷µçѹ·¶Î§²»ÁÓÓÚ£º 220 ¨C 240 VAC@50 ¨C 60 Hz£¨ÈȶÏ·Æ÷£©
¾ß±¸¹ýѹ¹Ø¶Ï£º ¼«¸ßµçѹ¹Ø¶Ï£¬275¡À5VAC
¾ß±¸¼â·å±£»¤Ä£Ê½£º »ðÏß¶ÔÁãÏߣ¬ÁãµØÏßй¶
¾ß±¸¼â·åǶλµçѹ£º 376 VAC·åÖµ@6000V/3000 A
ÏìӦʱ¼ä²»Ð¡ÓÚ£º 1ÄÉÃë
×î´óÀËÓ¿µçÁ÷²»Ð¡ÓÚ£º 6500A
ÔëÉùË¥¼õ£º¾ßÓÐÏßÐÔÂ˲¨Ïû³ý¼¼Êõ£¬ÔëÉùË¥¼õ²»µÍÓÚ£º10 dB @ 10 kHz, 40 dB @ 100 kHz, 50 dB @ 500 kHz
³ß´ç²»´óÓÚ£º 44.33mm ¸ß x 482.6mm ¿í x 165.1mm Éî
ÖØÁ¿²»´óÓÚ£º 3.03kg
¹¦ºÄ²»´óÓÚ£º 10W£¨ÎÞ¸ºÔØ£©
¾ß±¸°²È«ÈÏÖ¤£º TUV | 1 | ̨ |
| 26 | »°Í²³ÉÆ·Ïߣ¨10Ã׳¤¶È£© | | ´ø¿¨Å©¹«Ä¸µÄ³ÉÆ·Ïß ³¤¶È¡Ý10Ã×£»
Ï߲IJÎÊý£º
µ¼ÌåÊý²»ÉÙÓÚ4¸ù
±ê×¼Ïß¾¶²»´óÓÚ6mm
ÍÍøÃܶȲ»Ð¡ÓÚ94%
¿¨Å©Í·²ÎÊý£º
¶î¶¨µçѹ ²»´óÓÚ 50 V | 10 | Ìõ |
| 27 | ÅÄÉãרҵµÆ¾ß | | ¾ß±¸Ë«É«Î¡¾3200K-5600K¡¿ÅäÓÐµÆ¼Ü | 3 | Ö» |
