Óü¼ÊõʵÁ¦Ëµ»°£¬×î¸ßTHX DOMINUSÈÏÖ¤: ÃÀ¹úPERLISTEN D12S³¬µÍÒô
Ò»¼Ò2020Äê²ÅÕýʽÎÊÊУ¬È´Ôڶ̶̲»µ½¶þÄêʱ¼ä¾Í·çÃÒHigh EndÒôÏìÊг¡£¬ÃÀ¹úPerlisten¿É˵ÊÇÕæÕýµÄºÚÂí¡£È»¶øPerlistenµÄ³É¹¦¾ø·ÇÖ»ÊÇÐÒÔË£¬¶øÊÇÇ¿´óµÄÑз¢ÍŶӶàÄêµÄŬÁ¦³É¹û£¬PerlistenÔçÔÚ2016Äê¾Í³ÉÁ¢£¬µ«³ÉÁ¢µÄǰ3Äê¶¼ÔÚ½øÐÐÑз¢£¬ÓëÆäËûHigh EndÖÆÔìÉ̵ĺÏ×÷£¬²¢È·¶¨ÒÔ´ïµ½THX×î¸ß±ê×¼ÎªÆ·ÅÆºËÐĶ¨Î»£¬2020Ä꣬PerlistenÔÚÀ®°È³É¹¦È¡µÃÊÀ½çÉϵÚÒ»¸öTHX Dominus(ÉϵÛÖ®Éù)µÚ4¼¶×î¸ßÈÏÖ¤ºó£¬ÕýʽÏòÊг¡ÏúÊÛ¡£THX Dominus´ú±í¸ÃÀ®°È¿ÉÒÔÂú×㳬¹ý55ƺÒÔÉϵĿռ䣬¶øÇÒÊ§ÕæÂʷdz£µÍ¡£
Perlisten D12s²úƷͼ
D12sΪPerlisten³¬µÍÒô²úÆ·ÖÐÌå»ý×îСÕߣ¬ÆäÒÀȻӵÓÐTHX DominusÖ®ÈÏÖ¤£¬¿É±ð±»ÆäÌå»ýËùÃÉÆ­£¬D12sÄÚÓÐ1.5kWµÄÇ¿´óÀ©´ó»ú£¬³ÐÏ®×Ô¼ÒÆì½¢Ðͺŵļ¼Êõ£¬ÃܱÕʽµÄÉè¼Æ¡¢µÍQÖµ¡¢Æ½ÎȵĹö½µÆµÂÊÏìÓ¦£¬ÈÃD12sÓµÓÐ¸ßÆ·ÖʵÄÉùÒô£¬²¢Ò×ÓÚÈÚºÏÓÚÊÓÌý¿Õ¼äÖ®ÖС£
D12sËùÓеŦÄÜÓë±£»¤¾ùÓÉרÊôÉè¼Æ£¬48-bit DSP¼°32-bit ARM M4 Cortex´¦ÀíÆ÷À´¿ØÖÆ£¬ÔÚ΢ÃëÖ®¼ä¾ÍÄÜ·´Ó¦Íê³É£¬·Ç³£Ç¿´ó¡£300mm(Ô¼12¡å)¸´ºÏʽ̼ÏËάÕñĤµ¥ÌåΪPerlisten×Ô¼ÒÉè¼Æ£¬Ê¹Óöà¸öÂÁºÏ½ð¶ÌȦ£¬Ç¿´óµÄ´ÅÌúϵͳ¡¢¶à²ãŵÃÀʿֽ(NOMEX)Ö©Öë¿ò¼Ü¡¢¼«ÇáÖ®ÂÁÉùȦµÈµÈ¡£×Ô¼ÒרÀûÖ®·ÇÏßÐÔÄ£Ðͼ¼Êõ¿ÉÄ£ÄâËùÓÐÔª¼þÒÔ×î¼Ñ»¯µ¥Ìå±íÏÖ£¬²¢Ê¹ÓÃKlippelÀײâÉäÁ¿¡£ËùÓеÄDϵÁУ¬°üÀ¨D12s£¬¾ùÅäÓÐ2.4¡å LCD²ÊÉ«´¥¿ØÓ©Ä»£¬²¢ÓÐרÊôAPP¿ÉÒÔ½øÐÐÉ趨¡£
Perlisten D12s²úÆ·¹æ¸ñͼ
Perlisten D12s³¬µÍÒô
THX DominusÈÏÖ¤
À©´ó»ú: 1.5kW rms short term
Ó©Ä»: 2.4¡å LCD²ÊÉ«´¥¿Ø
רÊôAPP: iOS/ Android
´¦ÀíÆ÷: 32-bit ARM Cortex M4, double precision floating point math
DSP: Ti DSP 48-bit data paths
µ¥Ìå: 300mm£¬Ì¼ÏËάÕñĤ(+/-30mm linear excursion)
ЧÂÊ: 92dB / 150mV / 1.0m
ƵÂÊÏìÓ¦:THX EQ: 20-289Hz (-6dB) / 16-330Hz (-10dB)
Boost (Large Room) EQ: 16-289Hz (-6dB) / 14-330Hz (-10dB)
Cut (Small Room) EQ: 25-289Hz (-6dB) / 19-330Hz (-10dB)
ÊäÈë: 2 x Balanced XLR, 2 x Unbalanced RCA
Êä³ö: 2 x Balanced XLR unbuffered, 2 x Unbalanced RCA unbuffered
Parametric EQ: 10-Band PEQ with 3 user presets
µÍͨÂ˲¨: Bypass, 30-160Hz, slope 6,12,18,24dB/oct
Ïàλ: Variable 0-270¡ã
¼«ÐÔ: Normal / inverted
³ß´ç: 448 x 420 x 450mm
ÖØÁ¿: 41.0 kg
