Apple.Logic.Pro.X.v10.7.6.macOS
& f4 E5 ~# D) c# `0 ?- w1 K$ D% k0 | + @) L" k: B: @% H
Logic Pro X is the most advanced version of Logic ever. Sophisticated tools for professional songwriting, editing, and mixing are built around a modern interface that¡¯s designed to get creative results quickly and also deliver more power whenever it¡¯s needed.! {( m% B- `9 Q( c! k
Powerful Interface1 X1 }# g2 M$ d7 A# |) e
• Consolidate and control multiple tracks or create rich, layered instruments with Track Stacks& |7 {3 _- U" V3 L& v+ Q, g
• Smart Controls allow you to manipulate multiple plug-ins and parameters with a single move( l% [* y6 k. g7 f
• Support for the Touch Bar on MacBook Pro provides convenient controls for creating, editing and navigating your songs+ A: _+ |7 E6 p
• Autosave keeps your work safe and sound
- ^$ i# F/ L) v+ Z8 GProfessional Music Production
$ N L }+ {# L+ V& R; V• Record and edit MIDI or audio using a comprehensive set of editors and tools$ _4 Z$ Q( i2 H' E
• Keep takes organized with take folders and build comps quickly with Quick Swipe Comping, @. u, u$ H! A) w8 J$ H6 u
• Track Alternatives let you create and switch between different playlists of regions and edits on a track0 f" f) I" h1 b
• Render any combination of effect plug-ins to a selection of audio using Selection-based Processing
9 d' S! K2 X3 \( E9 G9 r4 \9 ?5 F! A• Fix out-of-tune vocals and change the melodies of recorded audio with Flex Pitch
! V! I( }' j/ P5 h4 l* O• Manipulate the timing and tempo of any recording with ease using Flex Time, l% C i& b. s6 i( J, I$ Z- ?
• Comprehensive mix and plug-in parameter automation can be part of a region or track
/ S! D+ A. R" ~$ v6 x( ~. } j• Create and mix music from anywhere in the room using Logic Remote on iPad or iPhone
; D/ d* R( z4 N* V0 U! s! R8 o• Produce simple lead sheets or orchestral scores with built-in Score editor+ z/ T" a0 _% k% Y# A
Drum Production5 y# j; Y3 K# |1 j9 J
• Create authentic acoustic, electronic, or hip hop drum tracks using Drummer, a virtual session player and beat producer2 p9 |- j) y7 a6 M/ V
• Choose among 28 distinct drummers that can take your direction and perform millions of unique grooves+ |5 P) g6 e$ V7 p
• Build your own acoustic drum kits with Drum Kit Designer using a collection of deeply sampled drums
# Q. ^6 m" L2 C g! {4 l4 K" o• Customize the sound of your electronic beats using Drum Machine Designer
( v v: g3 \5 W; @1 v tKeyboards and Synths
2 h/ E d' n9 P. [9 k7 f, \• Get inspired by collection of synths that provide analog, wavetable, FM, additive, granular, spectral, and modeling synthesis
3 O# Q. [( u- {# O. b3 i @• Quickly find sounds or create unique new ones with Alchemy, the ultimate sample manipulation synthesizer
7 l; [' S; a, C; T6 t! U( y6 F# L2 ~• Play or create a wide variety of rich sampled instruments with the EXS24 Sampler
5 [; U P/ x& ?• Instantly turn a simple chord into a rich performance with the Arpeggiator0 P5 ?3 N0 `# F' Z
• Transform simple ideas into elaborate performances using nine MIDI plug-ins8 w7 g1 {4 C& }4 }8 e4 `1 S
• Play faithful models of classic organs, keyboards, and vintage synths4 s% U5 v7 _- g! X- _' G
Guitar and Bass Gear6 |6 d; V6 `& K( Y# Q4 W ]' I2 S1 X) N# k
• Build your own guitar or bass rig with Amp Designer using vintage and modern amps, cabinets, and mics W. |7 O" O1 S- Y4 E, h# ~6 I4 I
• Design a custom Pedalboard from a collection of delay, distortion, and modulation stompboxes4 ?7 G0 q! f( \4 A8 o: V$ o# J
• Access the Tuner with just a click to quickly get in tune0 d. P( _5 n9 u8 i9 `$ f! ?7 K Y
Creative and Production Effects. }7 M9 s9 [" U% ~% {
• Play your sounds through realistic acoustic spaces using Space Designer convolution reverb$ Q1 y0 _, q& `; f0 I0 U+ r L
• Use a range of multi-tap, vintage tape, and stereo delays
j& B0 l( Y, h0 [( l1 h( ]- K• Add movement to your tracks with a variety of modulation effects
0 F. U/ v! ] }3 ?2 lSound Library' Y' M; r! G2 E6 L; g1 ^
• Over 2800 instrument and effect Patches
6 t) U! N) O; {- W6 L' n8 t# {• 1000 meticulously sampled instruments
- H$ o0 S% c5 P) `• More than 7000 Apple Loops in wide range of genres
/ c' ~5 g$ r: v+ p6 @Compatibility
0 `2 J$ N7 L- T) ~! \% {. h% i9 C• Expand your instrument and effects library with third-party Audio Units-compatible plug-ins
e1 K) {+ @. M3 F; E7 H• Share to GarageBand option allows you to remotely add new tracks to your Logic project from your iPhone or iPad via iCloud/ x2 c/ ]* i$ y9 W2 l$ P
• Import and export XML to support Final Cut Pro X workflows
, ]9 g9 W% ^5 q# g* G• Export and share your songs directly to SoundCloud% C. A- l# j, a- q" U) k) D
• Open projects from Logic 5 or later
- ^4 y" a! n; B( l \0 A2 o! e4 K5 i" O
Compatibility: macOS 12.3 or later
7 l- I# N w& h; J* y, Y& khttps://www.apple.com/logic-pro/. l# [1 t0 Z) v- C4 G, F6 H: C
