Spectrasonics Trilian v1.6.3d (x64)
Trilian® ÊÇ Spectrasonics ±´Ë¾µÄÕûÌå½â¾ö·½°¸ Trilian ÊÇ Spectrasonics ÂÅ»ñÊâÈÙµÄ Trilogy ±´Ë¾ÀÖÆ÷µÄ¼Ì³ÐÕߣ¬¿ÉÌṩ¸üÉîÈëµÄÒôÀÖ±í´ï¿ØÖƺ͸ü´óµÄÉùÒôËÜÔìÁé»îÐÔ¡£Trilian µÄ 34GB ¿âµÄ´óСÊÇ Trilogy µÄ 10 ±¶£¬²¢Å䱸ÁËÓë Trilogy Ò»Ñù´óСµÄËùÓÐеÄÔ­Éù¡¢µçºÍºÏ³É±´Ë¾£¬²¢Å䱸ÁËËùÓÐеÄÔ­Éù¡¢µçºÍºÏ³É±´Ë¾¡£
¸ß·Ö±æÂʽçÃæ
Trilian Ö§³ÖÐÂÖØÐÂÉè¼ÆµÄ¸ß·Ö±æÂʽçÃæ£¬²¢Ö§³Ö HiDPI ÏÔʾÆ÷¡£ÏÖ´ú»¯µÄ GUI ÏÖÔÚ¸üÒ×ÓÚʹÓÃÇҿɵ÷Õû´óСÒÔÊæÊʵØÈÚÈëÄúµÄ¹¤×÷¿Õ¼ä¡£
×Ô¶¨Òå¿Ø¼þ
Ϊÿ¸ö Patch ³ÊÏÖµÄ×Ô¶¨Òå¿Ø¼þʹÄú¿ÉÒÔ³¬Ô½Ô­Ê¼ÉùÒô¡£Ö±¹ÛµÄ½çÃæ°üÀ¨ÓÐÓõÄÑÝ×à¿ØÖÆºÍרΪÿ¸ö Patch ÖÆ×÷µÄ¸ßÖÊÁ¿´´ÒâЧ¹û´¦Àí¡£Êýǧ¸ö°üº¬µÄ Patch չʾÁË·Ç·²µÄ¶à¹¦ÄÜÐÔºÍÄÜÁ¦£¬¿ÉÒÔΪÄúµÄÒôÀÖÏÔ×Ŷ¨ÖÆÕâЩ¹ÄÎèÈËÐĵÄÉùÒô¡£
¶Ô¶ÀÌØµÄϸ΢֮´¦½øÐÐÁËÉî¶È²ÉÑù£¬°üÀ¨Á¬×àºÍ»¬Òô·¢Òô¡¢»úеÔëÒôºÍÊÍ·Å·ºÒô£¬½«ÕâЩÉùÒôµÄÕæÊµÐÔÌáÉýµ½Ò»¸öȫеÄˮƽ¡£Trilian ÁîÈ˾ªÌ¾µÄ Acoustic Bass ÊÇ Spectrasonics ·¢²¼µÄ×îÏêϸµÄÀÖÆ÷Ö®Ò»£¬ÓµÓÐ 4 ¸öÒôƵͨµÀºÍ³¬¹ý 21,000 ¸ö²ÉÑùÀ´´´½¨Õâ¸öµ¥Ò»ÀÖÆ÷£¡ËùÓÐÕâЩ¶¼ÎªÕæÕý¹ÄÎèÈËÐĵıíÑÝÔöÌíÁËÕæÊµ¸Ð¡£
Greatly Enhanced Arpeggiator
• New Pattern and Play Modes
• New Presets Library
• New Step Modifiers
• New Chord Voicings
• New Pitch Slides
• New Step Dividers
• Capture MIDI Files!
Omnisphere Integration
As a bonus for Omnisphere users, Trilian integrates fully as a satellite instrument within the Omnisphere® interface, allowing the exploration of endless new sonic possibilities and combinations.
Trilian Creative Library
Trilian now also includes an incredible library of over 200 unique patches specially designed for users who also have Omnisphere 2. The richly detailed bass sounds of Trilian have been dramatically transformed using Omnisphere's deep synthesis capabilities. An extremely special collection of sounds for modern music producers.
3 FX Units
• Vintage Compressor
• Modern Compressor
• Gate Expander
• Vintage 2-Band EQ
• Vintage 3-Band EQ
• Graphic 7-Band EQ
• Graphic 12-Band EQ
• Parametric 2-Band EQ
• Parametric 3-Band EQ
• Formant Filter
• Power Filter
• Valve Radio
• Flame Distortion
• Smoke Amp
• Ultra Chorus
• Retro-Phaser
• Pro-Phaser
• EZ-Phaser
• Retro-Flanger
• Flanger
• Chorus Echo
• BPM Delay
• BPM Delay X2
• BPM Delay X3
• Radio Delay
• Retroplex
• Pro-Verb
• EZ-Verb
• Spring Reverb
• Imager
• Tube Limiter
• Tape Slammer
• Wah-Wah
Standalone with Recording
Flow Capture™ is a special recording function built into the Trilian standalone app - which grabs spontaneous musical moments in audio, MIDI and .trilian sound format simultaneously.
How to install on Windows
- Install Trilian
- Replace Trilian.dll to VST FOLDER
- Replace & Trilian.vst3 to VST3 FOLDER
For Application
- To get STANDALONE workin'
Go to
C:\ProgramData\Spectrasonics\plug-ins\64bit
- Replace Trilian.dll and Trilian.vst3
For Pro Tools Users
- To get AAX workin'
Go to
Done.
Whats new in this version
Trilian Software 1.6.3d
• Flow Capture: New Standalone feature allows you to grab spontaneous musical moments as audio, MIDI and sound formats simultaneously
• Fixes an issue in Logic 10.7.4 where loading an AU preset file did not update the AU preset name at the top of Logic's plugin window
• Fixes a bug where sending the plugin Pitch Bend sequences that contain a wide range could cause audible stepping at large Host buffer sizes
System Requirements
• Microsoft Windows 7 or higher
• VST 2.4 or higher, AAX capable host software
• 64-bit host
Code:
https://nitroflare.com/view/D2C898A5BD1E6C6/Spectrasonics_-_Trilian_v1.6.3d.rarhttps://rapidgator.net/file/84c9f57fe82a3472a1c5cbb188837e63/Spectrasonics_-_Trilian_v1.6.3d.rar.html
