& y$ M$ _! C9 CCockos REAPER 6.62 (x86 x64) RePack (& Portable) by xetrin4 B( L+ |. z3 t7 A6 e1 T
, ?3 v- {" i; L# Y$ j5 w. s: n ! ~1 F6 F# \* j3 q
Interface language: Russian, English and others
0 s. Q. z! u, U6 M$ J3 \! w7 s1 Q: m9 u2 w: u' M5 d
0 ~+ ^, d6 u1 g1 \- Q
System requirements:
& d: @# J: i; H' {$ t' f• Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11 (32-bit & 64-bit)
/ k" S% d: ~$ E! H( ^( c
/ {% g6 ~8 h1 ADescription:
. }% J7 \ l7 p# L& n7 B' c% C3 YCockos Reaper is one of the most advanced programs for creating music, both in the studio and at home. . The main feature of the program is that it has pattern, keyboard and audio editing. You can specify an unlimited number of audio or midi tracks, not counting how many VST virtual instruments can be added.
1 p- u) l+ `2 q& j, X, Z4 d- N
2 [$ T6 L* i) d( f1 x# D+ qAdditional Information:
1 b( v C |# y* A& V1 R8 A4 AReaper takes up less space on your hard drive and does not load the processor, like programs from the FL Studio, Cubase, Reason or Sonar series. You can work with this program even on low-power computers with sound cards that do not support Full duplex operating modes. Although, if the soundcard supports this mode, you will get unlimited opportunities to create your compositions with professional sound even in formats such as 5 + 1, and with additional plug-ins, even 7 + 1.
3 c( F1 y* A2 M- ~A huge plus of the program is that it supports VST / VST3, not counting the support for DirectX plugins. You can use both the built-in editing tools for audio or midi tracks, as well as third-party plugins. The program also supports the ReWire virtual instrument connection system. Thanks to the harmonious interface, you can always see what you are editing at the moment. A virtual multi-channel console is always in front of your eyes - with its help you can instantly perform operations with changing the volume, editing effects both on a single track and on the Master track.
9 t2 j& f1 @! \1 R* ?* i+ N
" A% n, E) T+ t6 G/ F5 OProgram features:
9 o! k& l: D1 ]8 w+ M6 d• Full support for VST, VSTi, DX and DXi plugins required for operation. AU plugin is only supported on Mac OS.
* B3 @& C* |6 W) E• Custom format plugins that are written in javascript.
( e1 Q( P: \- _5 A/ B• Program versions for 64-bit platforms. At the same time, it stores a platform for launching on 32-bit platforms.- _8 ]) l* U) C- q& ]3 ^7 U8 v
• Full support for the ASIO 2.0 protocol and compatibility with all multi-channel devices.( [- V' f W* \1 p
• Support for MIDI devices.. i2 z# |# S; N
• Setting up all aspects of working with the application, including hot keys, behavior in situations and other actions.
9 o' y2 h- O5 p! X) |
* M" n& p3 C5 S* CRePack features:* t6 B. M/ E2 H6 t" O
1. A tablet from ADMIN@CRACK + ARMOR (x32) and TEAM R2R (x64) is sewn in.
: }5 e2 A* P3 r, x1 u( N* Y2. Program language: Russian (by Nikitich , xetrin), English, German (by MrData).
$ J) d# R4 u; X8 J8 l5 G+ \3. Nothing is cut.% i" E {. p; l
4. Added themes Instrument 2 and Instrument 2 Dark (by Kusakanaka).) o5 H6 U. V) B0 \
5. The presence of a portable version from the developer.
; i1 ], I2 |" H; Q1 j6. Installer language: Russian and English.
( `+ ?6 X- v& o/ ]5 A/ H. U7. Picking up settings files (reaper.ini, reaper-fxtags.ini, reaper-midihw.ini, reaper-mouse.ini, reaper-vstplugins.ini, reaper-vstplugins64.ini, REAPER-wndpos.ini), if it is next to the installer (works with both standard install and portable install).- }4 |0 x1 ]: D: A$ x
8. Backup settings files (reaper.ini, reaper-fxtags.ini, reaper-midihw.ini, reaper-mouse.ini, reaper-vstplugins.ini, reaper-vstplugins64.ini, REAPER-wndpos.ini) when uninstalling the program.) \3 ~" g. {4 t/ s7 y* e3 S
9. Automatic and manual selection of OS bit depth.
D3 Y$ c' f, @9 E: h$ w- [- u10. Repack based on is 6.0.5 mod (by Leserg).2 E* d& I1 r6 ^2 N' w
3 B. u' N+ X' L4 t# P
Quiet mode startup keys4 p; H6 A% [' m" D; s6 e, A
Very silent installation: /VERYSILENT0 X0 P5 n1 ^6 `
Do not create shortcut(s) in the start menu: /NSSB7 y R6 D; S7 E F$ _7 t& q
Do not create shortcut(s) on the desktop: /NSD
9 k/ b! d! k3 ?- }Installation language: /LANG=(ENG,RUS,GER)6 ^2 Y( ]" W& `% B, b" x P
Standard installation : /INSTALLER
% v7 X: V {% qUnpacking the portable version: /PORTABLE
) C0 z# a0 [ }. z5 NProgram update: /UPDATE
/ M) j3 E+ D0 A. n0 X: jBit depth: /X32 and/X64
. J! C; O( i5 B) |1 hExport settings to desktop: /BS
3 g& C4 p8 t$ B. X8 ?& |Delete program settings: /DS
' z, D3 ~6 W0 w! c7 l
9 F2 `, S, n/ J$ IExample5 N& ~: M) l6 N, Q6 `3 `3 i
Install, N4 @6 `' V) `5 x* @
REAPER_v*_RePack_by_xetrin.exe /INSTALLER /X64 /LANG=RUS /PSTSM /PSTTB /VERYSILENT2 p# T% n0 L; C( V* o9 k% N$ h. q
Uninstall8 l3 a' _0 u3 G, J- m7 s6 K5 B
for /f "skip=2 tokens=2*" %%a in ('Reg Query "HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Cockos REAPER_is1" /v UninstallString 2^> nul') do start "" /wait %%b /BS /DS /VERYSILENT+ S1 R1 ^- H% l2 {4 |3 \7 Z
- B# J, ~+ k# ^2 [0 |
What's new:' N$ t2 U3 D8 ~( f
Version 6.62
( k1 `4 P1 G1 v" ?3 ~Released July 1, 2022- Y! _0 J i2 f: {! f0 U# t
7 F# P1 L' ]( |5 S
More detailed changelog and version history
+ v! d8 ^# u# w( m9 x! P0 qCode:
% N* f# O8 H+ k& Mhttps://www.reaper.fm/whatsnew.txt
3 c' g2 r5 C8 x# `) f! L" `; w" [" B+ U
TcAlVnV.gif( j2 f0 J [+ l' S5 O/ \8 W
Code:
, f$ G( h% B) q7 m2 i% Z* M. j' Khttps://nitro.download/view/C1D703F07050EA8/Cockos_REAPER_6.62_x86_x64_RePack__Portable_by_xetrin.rar2 J$ e7 f2 k6 f
Code:
. k% b6 N/ R I; ^ X' [https://rapidgator.net/file/1fcccc7b3ef899a7e38b147aea658fb7/Cockos_REAPER_6.62_x86_x64_RePack__Portable_by_xetrin.rar
+ I% o5 _9 o* U; o6 Q, MCode:2 m9 |0 F$ ~5 \% W/ W+ X( i# t7 u! l
https://uploadgig.com/file/download/F4d309a2E12f5786/Cockos_REAPER_6.62_x86_x64_RePack__Portable_by_xetrin.rar |
