发表于 2022-7-1
|阅读模式
Piezo makes it a snap to record audio on your Mac. In seconds, you'll be recording audio from any application or from audio inputs like microphones. Piezo requires almost no configuration, and it's a blast to use! Simple and inexpensive - that's a winning combination.
What's New:
版本 1.7.9: ACE 11.8.2 中的改进 - 音频捕获引擎 (ACE) 已更新至 11.8.2,为更可靠的音频捕获做了许多改进。这包括解决使用内置麦克风时 FaceTime 音量问题的解决方法,以及处理执行不善的改进
- 音频单元。当设备提供错误信息时,音频设备采样时钟的跟踪现在也能更好地工作。许多常见音频流中的 CPU 使用率已降低,跨设备的时钟同步已得到改进,并且持久设备跟踪已得到改进。
- StarLeaf VoIP 捕获支持
- 现在支持 StarLeaf Mac 应用程序作为 VoIP 音频源,可以轻松录制对话的两半。
- 对肯定较低的采样率进行上采样有时会产生音频伪影的问题已得到解决。
- 当 Piezo 的完整版解锁后,“许可证”窗口现在巧妙地显示应用程序的版本号。
- 对新用户第五次发布时显示的邮件列表注册窗口以及“发布
- 新版本首次发布时显示的“备注”窗口,您现在可能正在查看!
- 软件更新检查现在仅在欢迎窗口关闭后进行。
Improvements in ACE 11.8.2
The Audio Capture Engine (ACE) has been updated to 11.8.2, with many improvements for even more reliable audio capture. This includes a workaround for issues with FaceTime volume when using the built-in microphone, as well as an improvement in dealing with poorly implemented
Audio Units. Tracking of audio devices sample clocks also now works better when the device is providing erroneous information. CPU usage has been reduced in many common audio flows, clock synchronization across devices has been improved, and persistent device tracking has been improved.
StarLeaf VoIP Capture Support
The StarLeaf Mac app is now supported as a VoIP audio source, making it easy to record both halves of a conversation.
An issue where upsampling of certainly low sample rates could sometimes produce audio artifacts has been resolved.
When the full version of Piezo has been unlocked, the “License” window now subtly shows the application's version number.
Fussy typography improvements have been made to the mailing list sign-up window shown at the fifth launch for new users, as well as the “Release
Notes” window shown at the first launch of a new version, which you might be looking at right now!
Software Update checks now occur only after the Welcome Window has been closed.
https://insmac.org/macosx/1076-piezo.html
