Build your own ensembles with 29 individual instruments and 13 different mutes. Whether you prefer a more centered sound for concert works or a wide sound for film scoring, 58 positions allow you to create any layout you desire. Infinite Brass comes with 3 standard spaces: the warm Mozarteum, the bombastic Bersa Hall, and the dry Studio. The ambiance is generated in real-time through convolution using bespoke impulse responses unique to each position and room, so the ambiance is always 100% reflecting the performance. Phase-aligned samples result in no perceived cross-fades between the layers; the response is smooth, musical, and sounds like the real thing.
Infinite Brass boasts some of the widest brass instrument ranges on the market and a consistent dynamic range from ppp to fff for all instruments. All instruments have playable vibrato, flutter, and growl, even all three at the same time.
REQ: Aaron Venture Infinite Brass 1.6 KONTAKT screenshot
FULL ARSENAL
From symphonic to big band, you¡¯re all set. You get access to 29 instruments¡ªfrom the soaring sounds of a piccolo trumpet, down to the ground-shaking contrabass tuba and the raspy cimbassi. Create any configuration you want. Combine different mutes in a line for endless color options.
What's new in INFINITE BRASS 1.6?
Another big update for Infinite Brass. No new instruments this time, but you'll find quality-of-life improvements, new workflow compatibility features, sound improvements, new mics, legato improvements, and more.
https://www.kvraudio.com/product/infinite-brass-by-aaron-venture |
