Initial Audio BoostX ¶¯Ì¬ºÍÖÇÄܵı¥ºÍ/¹ýÔØ²å¼þ
Boost X ÊÇÒ»¸ö¶¯Ì¬ºÍÖÇÄܵı¥ºÍ/¹ýÔØ²å¼þ¡£ÓÃÓÚͨ¹ýÌí¼Ó¶îÍâµÄг²¨Ê¹ÈκÎÉùÒô¸üÎÂů¡£
Ðí¶àÆäËû Saturation/Overdrive ²å¼þʹÓþ²Ì¬£¨ÎÞ״̬£©Ëã·¨£¬¸ÃËã·¨²»»á¸ù¾Ýͨ¹ýµÄÒôƵ¶ø¸Ä±ä¡£ÕâЩЧ¹ûÒÀÀµÓÚÔöÒæÌáÉý£¬µ±ÒôƵ´ïµ½Ä³¸öãÐֵʱ£¬¾Í»áÓ¦Óñ¥ºÍ¶È¡£ËüÃÇҪô´ò¿ªÒªÃ´¹Ø±Õ£¬±¥ºÍ¶ÈÔںܴó³Ì¶ÈÉÏÈ¡¾öÓÚ´«ÈëËüÃǵÄÒôƵµÄÏì¶È¡£
Boost X ²»Í¬£¬Ëü¶ÔÊäÈëÒôƵ×ö³ö·´Ó¦£¬²¢ÔÚµ±Ç°Ïì¶ÈÏÂÓ¦ÓÃÍêÃÀµÄ±¥ºÍ¶È¡£ÕâÒâζ׿´Ê¹Êǰ²¾²µÄÉùÒôÒ²¿ÉÒÔ±»¹ý¶ÈÇý¶¯£¬¶ø²»»áÔö¼ÓÏì¶È¡£ Boost-X »¹¿ÉÒÔ²¹³¥¸ÐÖªÏì¶È£¬½øÒ»²½½µµÍÏì¶È£¬ÕâÑùÄú¾Í¿ÉÒÔÔÚ²»ÆÆ»µ»ìÒôƽºâµÄÇé¿öÏÂΪÉùÒôÌí¼Ó·á¸»µÄг²¨¡£
ΪÄúµÄÉùÒôÌṩ·á¸»µÄÉî¶ÈºÍÎÂů£¬ÔÚÄúµÄ»ìÒôÖкܺõØÈÚÈëÆäÖУ¬ÒÔÕæÕýµÄÄ£ÄâÎÂůºÍ¸Ð¾õ½«ÄúµÄÈËÉùºÍÀÖÆ÷´øÈëÉú»î¡£Ê¹Óà Boost X ¨C ¶¯Ì¬±¥ºÍ¶ÈÀ´»ñµÃËü¡£
ÌáÉý X ¹¦ÄÜ
¶¯Ì¬±¥ºÍ¡ª¡ª¶¯Ì¬ÏìÓ¦ÊäÈëÐźŵÄ״̬±¥ºÍ¡£
16 ±¶¹ý²ÉÑù ¨C ×î´ó³Ì¶ÈµØÒÖÖÆ»ìµþºÍ×î¸ßÖÊÁ¿µÄÉùÒô¡£
7 ±¥ºÍ¶ÈÀàÐÍ¡£
´óÒôÁ¿ÐýÅ¥£¬¿É½øÐо«Ï¸¿ØÖÆ¡£
¸ßÇå¿Éµ÷Õû´óСµÄ GUI¡£
ƽ̨£ºWiN64 ¨C VST/VST3
Boost X is a dynamic and smart Saturation/Overdrive plugin. Used to make any sound warmer by adding extra harmonics.
Many other Saturation/Overdrive plugins use a static (stateless) algorithm that doesn¡¯t change depending on the audio passed through. These effects rely on a gain boost, when the audio hits a certain threshold then Saturation is applied. They are either on or off and the amount of saturation is heavily dependent on the loudness of the audio passed into them.
Boost X is different, it reacts to the input audio and applies the perfect amount of saturation at the current loudness. This means even quiet sounds can be overdriven without any gain in loudness. Boost-X also compensates for perceived loudness, bringing the loudness down even further so you get nice rich harmonics added to your sound, without destroying the balance of your mix.
Gives your sounds a rich depth and warmth that sits well in your mix, bringing your vocals and instruments to life with a true analog warmth and feel. Get it with Boost X ¨C Dynamic Saturation.
Boost X Features
Dynamic saturation ¨C Stateful saturation which dynamically responds to the input signal.
16 times Oversampling ¨C For maximum aliasing repression and highest quality sound.
7 Saturation types.
Large amount knob for fine control.
High definition resizable GUI.
Platform: WiN64 ¨C VST/VST3
