Initial Audio IA-LA1 Compressor ÖÇÄÜѹËõЧ¹ûÆ÷
ÎÒÃÇµÄ IA-LA1 ѹËõ²å¼þ±»Éè¼ÆÎª³¬¼¶ÏìÓ¦¡£Ëü´øÓÐÒ»¸ö͸Ã÷µÄËã·¨£¬²»»áÒýÈëÊ§Õæ»òαÏñ¡£µ«Èç¹ûÐèÒª×ÅÉ«£¬ÎÒÃÇÓÐ THD ¿ØÖÆ£¬ËüÒýÈëÁËκ͵Ķ¯Ì¬Ê§Õ棬Ôö¼ÓÁ˶îÍâµÄÎÂůºÍÉî¶È¡£
IA-LA1 ´øÓо«È·µÄµçƽ±íºÍÔöÒæË¥¼õ±í£¬¿ÉÒÔÇå³þµØ¿´µ½ÕýÔÚÓ¦ÓõÄѹËõ¡£Ê¹ÓÃÎÒÃÇµÄ IA-LA1 ѹËõÆ÷²å¼þÔÚ¸ü¶ÌµÄʱ¼äÄÚ»ñµÃÍêÃÀµÄѹËõ¡£
ÇáËÉѹËõ
IA-LA1 ÊÇÒ»¸ö¼òµ¥Ò×ÓÃµÄ Compressor ²å¼þ¡£ãÐÖµºÍ²¹³¥ÔöÒæÊÇÁ½¸öÖ÷Òª¿Ø¼þ¡£ãÐÖµ±íʾѹËõ½«¿ªÊ¼Ó°ÏìÒôƵµÄ¼¶±ð¡£³¬¹ýãÐÖµµÄÈκÎÄÚÈݶ¼»á±»Ñ¹Ëõ£¬Õâ»á½µµÍÒôƵµÄ¶¯Ì¬·¶Î§¡£ãÐÖµÔÚÊäÈë±íÉÏÏÔʾΪ³ÈÉ«Ïߣ¬µ±ÒôƵµçƽ³¬¹ý´ËÏßʱ£¬½«¿ªÊ¼½øÐÐѹËõ¡£ÏÖÔÚʹÓÃÃÖ²¹ÔöÒæÀ´²¹³¥Ïì¶ÈµÄÈκÎËðʧ¡£¾ÍÊÇÕâÑù£¡Ã¿´ÎÖ»ÐèʹÓÃÕâÁ½¸ö¿Ø¼þ¼´¿É»ñµÃÍêÃÀµÄѹËõ¡£ÎÞÐèÏñÐí¶àÆäËûѹËõÆ÷ÄÇÑùÉèÖÃÆô¶¯»òÊÍ·Å¡£
IA-LA1 ѹËõÆ÷²å¼þ¹¦ÄÜ
×Ô¶¯Ñ¹Ëõ¡ª¡ªÎÞÐèÉèÖÃÆô¶¯ºÍÊÍ·Åʱ¼ä¡£
THD ¨C ×Üг²¨Ê§Õ棬Ôö¼Ó¶îÍâµÄÎÂůºÍÉî¶È¡£
Ô¤Éè¹ÜÀíÆ÷ ¨C ±£´æºÍ¼ÓÔØ×Ô¶¨ÒåÔ¤Éè¡£
ÊäÈëÔöÒæ¡ª¡ªÔÚ½øÈëѹËõ֮ǰ½«ÒôÆµÍÆµÃ¸ü´ó¡£
ÃÖ²¹ÔöÒæ ¨C Ôö¼ÓÒÔ²¹³¥Ñ¹ËõÔì³ÉµÄÈκÎÏì¶ÈËðʧ¡£
¸ßÇå¿Éµ÷Õû´óСµÄ GUI¡£
Our IA-LA1 compressor plugin is designed to be super responsive. It comes with a transparent algorithm that introduces no distortion or artefacts. But if colouration is required we have the THD control, which introduces a gentle dynamic distortion adding extra warmth and depth.
IA-LA1 comes with accurate level meters and a gain reduction meter giving a clear visual of the compression being applied. Get perfect compression in less time with our IA-LA1 compressor plugin.
Easy Compression
IA-LA1 is a simple to use Compressor plugin. Threshold and Make up gain are the two main controls. The threshold represents the level at which compression will start to affect the audio. Anything over the threshold is compressed, which reduces the dynamic range of the audio. The threshold is shown as an orange line on the input meter, compression will start to happen when the audio level goes above this line. Now use the Make up gain to compensate for any loss in loudness. That¡¯s it! Get perfect compression every time with just these two controls. No need to set an attack or release like on many other compressors.
IA-LA1 Compressor Plugin Features
Automatic compression ¨C no need to set attack and release times.
THD ¨C Total Harmonic Distortion, adds extra warm and depth.
Preset manager ¨C Save and load custom presets.
Input gain ¨C Push the audio louder before entering compression.
Make up gain ¨C Increase to compensate for any loss of loudness from the compression.
High definition resizable GUI.
