Solid State Logic ¨C SSL Native Plugins v6.5.30 VST Free Download
Year / Release Date: 12.2020
Version: 6.5.30
Developer: Solid State Logic
Developer site: https://www.solidstatelogic.com/products/plug-ins
Format: VST, VST3, AAX
Bit depth: 64bit
Tabletka: cured | R2R
System requirements: VST, AAX Host
Description: SSL Native Plugins v6.5.30 provide fidelity, advanced feature set, and legendary tonal characteristics of SSL audio products in an accessible plugin form. Latest Native V6.5 Release from Solid State Logic Introduces New Plugin ¡°X-EQ 2¡±
Accessing the full range of SSL Native plugins is the best way to take advantage of all the SSL tools.
Key features:
24-band fully parametric high quality digital EQ, featuring unique SSL anti-cramping algorithms
DSP Optimisation makes X-EQ 2 super efficient and CPU light
A total of 17 different filter types: 5 different cut filters, 9 bell shapes, shelving filters, a parallel mode, and custom filters
Extensive control options including draggable EQ graph nodes, mouse wheel adjustment and numerical data entry
Extremely low noise and low non-linear distortion filter algorithms resulting in the residual THD+N significantly lower than 24-bit quantisation noise
Mid/Side and Left/Right spatial processing options
Individual band solo and bypass
Real-time FFT analysis display
Inclusion of Phase & Step response graphs to show the effect of EQ processing
SSL Native Plugins v6.5.30 provide the precision, advanced feature set and legendary tonal characteristics of SSL audio products in affordable plug-in form. The latest Native V6.5 release from Solid State Logic introduces the new ¡®X-EQ 2¡¯ plug-in and provides all users authorisation of SSL Native licenses onto a computer instead of a physical iLok dongle.
The SSL Native ¡®Complete Bundle¡¯ includes: X-EQ2, ChannelStrip, (Updated) Bus Compressor, FlexVerb, Drumstrip, VocalStrip, X-Saturator, X-Comp, X-ValveComp and X-Phase,  and is available on monthly subscription from $14.99/mo via Gobbler. If you would prefer to own them outright, SSL Native Plugins 6.5.30 as can be purchased individually or as the ¡®Complete Bundle¡¯ from the SSL Web Store.
https://audioplugins.net/ssl-native-plugins-v6-5-30/
