Zenhiser Epic Drum Rolls & Fills Wav
The key to anticipation, drive and euphoric rushes in your EDM tracks is the build up. It should take you a higher level of appreciation and turn clubbers into field of pulsating stompers. The uplifting drum intension, filter swept snares and rise of sfx makes this part of your track so important, the right drum roll, drum fill and sometimes upriser can turn a track from great to truly epic.
¡®Epic Drum Rolls & Fills¡¯ does exactly what it says, supplies an array of edm drum rolls and drum fills to epic proportions. Designed exclusively for EDM, House, Trance, Electro House, Progressive House and all the sub genres of dance this Zenhiser pack delivers exactly what you need in precession perfect quality. As with all Zenhiser packs we like to be a little ahead of the curve so to keep in tradition with our other drum rolls and drum fills packs we¡¯ve supplied everything by size for ease of use. Xtra Small Drum Rolls in 05. ¨C 1 bar long, Small Drum Rolls in 2 bars length, Medium in 4 bars and Large in 8 ¨C 16 bar long samples. This makes it so much easier for browsing Zenhiser drum rolls, you can choose the right roll for the right place within your track in seconds.
So if we created the ultimate drum rolls pack there would need to be something extra in the sample pack, the icing on the cake. Well we¡¯ve added it, 100 FX Shots & Percussion Hits to deliver the finishing sparkle to your professionally crafted kick ass drum fills! Now with ¡®Epic Drum Rolls & Fills¡¯ you¡¯ve got the edge over the competition, bpm labelled killer drum rolls, sized by folder with 100 incredible sound hits, what more could you possibly want!
