Adobe Media Encoder 2022 v22.3 macOS
Ingest, transcode, create proxies, and output any format you can imagine. This powerful media management tool allows you to work with media in a unified way across applications. Tight integration with Adobe Premiere Pro CC, After Effects CC, and other applications provides a seamless workflow.
Key Features:
¨C Support for 8K H.264 export
¨C Export XAVC QFHD Long GOP 4:2:2 formats
¨C Hardware-accelerated HEVC encoding on Windows 10 with 7th Generation (or later) Intel® Core™ processors and Intel Graphics enabled
¨C Improved RED camera format decoding
¨C Improved Sony RAW/X-OCN camera format decoding
¨C Hardware-accelerated H.264 encoding on Windows 10 with 6th Generation (or later) Intel® Core™ processors and Intel Graphics enabled
¨C Hardware-accelerated H.264 and HEVC encoding on Mac OS 10.13 systems with supported hardware
¨C Support for importing Canon C200 camera formats
¨C Support for importing Sony Venice camera formats
¨C RED camera Image Processing Pipeline [IPP2] support
¨C Destination Publishing support for new Twitter 280-character limit
¨C Channel selection when publishing to YouTube and Vimeo
¨C Playlist selection when publishing to YouTube
¨C Page selection when publishing to Facebook
¨C Add custom titles when publishing to YouTube, Facebook, or Vimeo
¨C Add custom video thumbnails when publishing to YouTube
¨C Notification for missing items in queue before encoding
¨C H.264 adaptive bitrate presets automatically choose best output bitrate based on source frame size and frame rate
¨C Animated GIF export on macOS and Windows
¨C Time Tuner effect improvements
¨C Newly optimized list of H.264 presets
¨C Format support for RF64 WAV Decode/Encode, decode for Sony X-OCN, and QuickTime DNx Smart Rendering
¨C Warning when importing non-native QuickTime sources
¨C Timecode modification for 720p 59.94 media
¨C Destination Publishing to Adobe Stock Contributor
¨C Adobe Team Projects support
¨C Support for Color Profiles from After Effects sources
¨C Automatically relinked assets when importing a sequence
¨C Option to maintain playback in Premiere Pro while rendering in Media Encoder
¨C Streamlined bit depth and alpha channel settings (QuickTime only)
¨C Export support for ambisonic audio (H.264 only)
¨C Support for Hybrid LOG Gamma (HLG)
¨C Support for HDR in HEVC (H.265) export Export support for Panasonic AVC-Long GOP Op1b |
