UL ¨C The House of Sound The Bass v2.0 KONTAKT±´Ë¹ÒôÔ´
ÒôÔ´
ÏñÂüÍÓÁÖÒ»ÑùµÄÎÄÉ­±´Ë¹µÄ¸ÅÄî·Ç³£¼òµ¥¡£
Äú¿ÉÒÔʹÓüü¿ª¹ØÔÚ¿ÕÏÒ£¨0 Æ·£©ºÍ 22 Æ·Ö®¼äµÄÈκÎÏÒÉÏÑÝ×àÈκÎÒô·û¡£
ÎÒÖÆ×÷ÁËÕâ¸ö kontakt ÀÖÆ÷£¬ÕâÑùÎҾͿÉÒÔµ¯×àÎÒÏëÒªµÄÈκÎÒô·û£¬ÕâÑùÎҾͿÉÒÔµ¯×౴˾£¬²¢ÓµÓÐÓ뱴˾ÏàͬµÄºÍÏÒ¼ä¾àÒÔ¼°ÓëÏÒÀÖÏàͬµÄÒôµ÷¡£ÓµÓÐÕýÈ·µÄÒôµ÷·Ç³£ÖØÒª£¬ÕâÑùËü²ÅÄÜÌýÆðÀ´ÕýÈ·¡£
UL ¨C The House of Sound The Bass v2.0 KONTAKT screenshot ÔÚÎÄÉ­±´Ë¾ÖУ¬Äú¿ÉÒÔʼÖÕÔÚÕýÈ·µÄÏÒÉÏÑ¡ÔñÕýÈ·µÄÒô·û£¬»òÕßÈç¹ûÄúϲ»¶ÄÇÖÖÉùÒô£¬Ò²¿ÉÒÔÑ¡Ôñ¿ÕÏÒ¡£Äã¿ÉÒÔ¾ö¶¨Ê²Ã´ÊÇÊʺÏÄãµÄ£¬ÕâÊÇÄãµÄÑ¡Ôñ¡£
µ±Äúµ¯×àÅÃÒôÒô·ûʱ£¬Äú¿ÉÒÔÇå³þµØÌýµ½ TONE OF THE STRING¡£
±¾Ò³ÊÓÆµÖнâÊÍÁËÈçºÎʹÓÃÎÄÉ­±´Ë¾¡£
Äú¿ÉÒÔÔÚÏÂÃæÊÕÌýÎÄÉ­±´Ë¾µÄʾÀý¡£µÚ 3 Ê×ÇúÄ¿ÖÐÓиü¶àµÄ°´¼ü¿ª¹ØÒô·û¡£
ÄãµÃµ½Ê²Ã´£º
¨C ÓÐÒ»¸öÔ¿³×¿ª¹Ø£º
+ 8 ¸öÑ­»·³¤Òô·û
+ 4 ¸öÑ­»·¾²ÒôÒô·û¡£ £¨´ÓÆ·¸ñ 1 ¿ªÊ¼£©
+ 4 ÂÖÑ­»·´ò¶ú¹â
+ 2 ÂÖÑ­»·´¸ÉÏ
+ 2 ÂÖÑ­»·Èü
+ 2 ÂÖÑ­»· ½ ÉÏ»¬ÖÁÑÝ×àµÄÒô·û£¨´ÓÆ·¸ñ 2 ¿ªÊ¼£©
+ 2 ÂÖÑ­»· 1 ÏòÉÏ»¬¶¯µ½²¥·ÅµÄÒô·û£¨´ÓÆ·¸ñ 3 ¿ªÊ¼£©
+ 2 ÂÖÑ­»· ½ ÏòÏ»¬¶¯µ½ÑÝ×àµÄÒô·û£¨´ÓÆ·¸ñ 1 ¿ªÊ¼£©
+ 2 ÂÖÑ­»· 1 ÏòÏ»¬¶¯µ½²¥·ÅµÄÒô·û£¨´ÓÆ·¸ñ 1 ¿ªÊ¼£©
ËùÓÐÀÖÆ÷¶¼ÐèÒª kontakt full 6.5.3 ¼°ÒÔÉÏ£¡
The concept of the venson bass like the mandolin is very simple.
You can play any note on any string between the open string (0 fret) and the 22nd fret using key switches.
I made this kontakt instrument so I can have the ability to play any note that I want, that way I can play the bass and have the same spacing of the chords that the bass has and the same tone that the strings has. It¡¯s very important to have the right TONE OF THE STRING so it will sound the right.
In the venson bass you can select always the right note on the right string or you can select the open strings if you like that sound. you can decide what is right to you it¡¯s your choice.
You can hear the TONE OF THE STRING clearly when you play arpeggio notes.
How to use the venson bass is explained in the video in this page.
You can listen for examples for the venson bass here below. Track number 3 has more key switch notes in it.
What you get:
¨C There is a key switch for:
+ 8 round robin long notes
+ 4 round robin mute notes. (starting from fret 1)
+ 4 round robin slap
+ 2 round robin hammer on
+ 2 round robin pull off
+ 2 round robin ½ up slide to the note played (starting from fret 2)
+ 2 round robin 1 up slide to the note played (starting from fret 3)
+ 2 round robin ½ down slide to the note played (starting from fret 1)
+ 2 round robin 1 down slide to the note played (starting from fret 1)
All instrument has a requirement for kontakt full 6.5.3 and above!
home page
https://www.ul-thehouseofsound.com/product/venson-bass/
