Blue Cat Audio Blue Cats Connector 1.0.0 WINͨÓÃÉùÒôÁ¬½Ó²å¼þ
ÄãÓÐûÓÐÏë¹ý¿Ë·þÄã×îϲ»¶µÄ DAW µÄÏÞÖÆ£¬²¢ÔÚÈκνÓÊܲå¼þµÄµØ·½Ö®¼ä»æÖÆÐéÄâÒôƵºÍ MIDI µçÀ£¿ÄúÊÇ·ñÔø¾ÒòΪÎÞ·¨Ê¹Óòå¼þ´´½¨·´À¡Ñ»·¶ø¸Ðµ½¾ÚÉ¥£¿½«²»Í¬¼ÆËã»úÉϵĶà¸öÓ¦ÓóÌÐòÁ¬½ÓÔÚÒ»ÆðÔõôÑù£¿
µÈ´ý½áÊøÁË£¡ Blue Cat µÄÁ¬½ÓÆ÷¿ÉÈÃÄúÍê³ÉËùÓÐÕâЩ£¬ÉõÖÁ¸ü¶à£¡Ëü¿ÉÒÔÔÚÈκνÓÊܲå¼þµÄλÖÃÖ®¼äʵʱ´«ÊäÒôƵºÍ MIDI Êý¾Ý£ºÒ»¸ö»ò¶à¸öÓ¦ÓóÌÐò£¬ÔÚһ̨»ò¶ą̀Á¬½Óµ½ÍøÂçµÄ»úÆ÷ÉÏ¡£
½èÖú¾«È·µÄ»º³å¿ØÖÆ£¬Äú¿ÉÒÔʵÏÖ¾¡¿ÉÄܵ͵ÄÑÓ³Ù£ºÔÚµ¥¸öÓ¦ÓóÌÐòÖÐʹÓÃʱ£¬¿ÉÒÔµÍÖÁ 0 ¸öÑù±¾¡£
ÆäÄÚÖõÄÖØ²ÉÑùºÍÆ¯ÒÆ²¹³¥Ëã·¨ÈÃÄú¿ÉÒÔÔÚ¾ßÓв»Í¬²ÉÑùÂʺͷÇͬ²½Ö÷ʱÖÓµÄλÖÃÖ®¼ä´´½¨ÎÞ·ìÁ¬½Ó£ºËüÖ»Êǹ¤×÷£¡
Ö÷ÒªÌØµã
VST¡¢VST3¡¢AAX »òÒôƵµ¥Ôª¸ñʽµÄͨÓÃÁ¬½Ó²å¼þ¡£
ÔÚ DAW Öд´½¨×Ô¼ºµÄÒôƵ/MIDI ·ÓÉ£¨ÔÊÐí·´À¡Ñ»·£©¡£
ÔÚ¶ą̀¼ÆËã»úÉϵÄÈκÎÒôƵÈí¼þÖ®¼ä´´½¨Á¬½Ó¡£
×îСÑÓ³Ù£¬ÍêÈ«¿ØÖÆ»º³å¡£
Ö§³Öµ¥¸öÁ¬½ÓÉϵĶà¸ö²ÉÑùÂÊ£¨ÄÚÖÃÖØ²ÉÑù£©¡£
ÄÚÖÃÆ¯ÒƲ¹³¥¡£
ʹÓõ¥¸öʵÀý·¢ËͺͽÓÊÕ»ØÒôƵ/MIDI¡£
Blue Cat ÒôƵ±ê×¼
ÊÊÓÃÓÚ Mac ºÍ Windows µÄ´ó¶àÊý²å¼þ¸ñʽ¡£
ÍêÕûµÄ MIDI ¿ØÖƺÍ×Ô¶¯»¯Ö§³Ö£¬MIDI ѧϰ¡£
¿ÕÏÐʱûÓÐ CPU ¸ºÔØ£º´¦ÀíÔÚÊäÈë¾²Òô£¨×î¼Ñ CPU ʹÓÃÂÊ£©Ê±¹Ø±Õ¡£
¾ßÓÐ͸Ã÷¶ÈºÍËõ·Å¹¦ÄܵĿɶ¨ÖÆÓû§½çÃæ¡£
Smooth Bypass£ºÎÞÔëÒô²å¼þ¼¤»î/Í£Óá£
³·ÏúÖØ×ö¡£
È«¹¦Äܼ¯³ÉÔ¤Éè¹ÜÀíÆ÷¡£
ÔÚʵÀýÖ®¼ä¸´ÖÆ/Õ³Ìù²å¼þµÄ״̬¡£
Ö§³ÖÈκβÉÑùÂÊ¡£
Have you ever dreamt to overcome the limitations of your favorite DAW and draw virtual audio and MIDI cables between any places that accept plug-ins? Have you ever been frustrated not to be able to create feedback loops with plug-ins? What about connecting multiple applications together, on different computers?
The wait is over! Blue Cat¡¯s Connector lets you do all of this, and more! It can stream audio and MIDI data in real time, between any locations that accepts plug-ins: one or several applications, on one or several machines connected to a network.
With precise buffering control, you can achieve the lowest possible latencies: down to 0 samples, when used in a single application.
Its built-in resampling and drift compensation algorithms let you create seamless connections between locations with different sample rates and unsynchronized master clocks: it just works!
Main Features
Universal connection plug-in available in VST, VST3, AAX or Audio Unit format.
Create your own audio/MIDI routings inside your DAW (feedback loops allowed).
Create connections between any audio software on multiple computers.
Minimal latency, with full control over buffering.
Supports multiple sampling rates on a single connection (built-in resampling).
Built-in drift compensation.
Send and receive back audio/MIDI with a single instance.
Blue Cat Audio Standards
Available in most plug-in formats for Mac and Windows.
Full MIDI control and automation support, MIDI Learn.
No CPU load on idle: processing shuts down when fed with silence (optimal CPU usage).
Customizable user interface with transparency & zoom.
Smooth Bypass: noiseless plug-in activation / deactivation.
Undo/Redo.
Full featured integrated presets manager.
Copy/paste the state of the plug-in between instances.
Any sample rate supported.
Whats New
Updates: official site does not provide any info about changes in this version.
Homepage
https://www.bluecataudio.com/Products/Product_Connector/ |
