FeelYourSound Sundog 3.8.0 WIN±àÇú¸¨Öú¹¤¾ß
Èí¼þ
Ò»ÀÍÓÀÒݵذÚÍÑ×÷¼ÒµÄÕϰ­¡£ÇáËɳ¢ÊÔеÄÒô½×¡¢ºÍÉùºÍÐýÂÉ¡£Ê¹Óà Sundog Çá¶øÒ×¾ÙµØÑÝ×àºÍÏҺͻùÒô¡£ÔÚ¼¸ÃëÖÓÄÚ´ÓÆ½¾²¡¢Á÷³©¡¢·ÅËɵķç¸ñת±äΪ³äÂú»îÁ¦µÄÀÖ¹ÛÇúµ÷¡£´ðÓ¦µÄ¡£
ÈÃд¸è±äµÃÍ´¿àµÄËļþÊÂ
ÿÊ׸趼ÐèÒªÁ¼ºÃµÄºÍÉù»ù´¡¡£Ò»µ©ÄãÓÐÁ˺ÍÏÒ£¬ÉèÖÃÒ»¸ö±´Ë¹Ïß²¢Ìí¼ÓһЩºÜºÃµÄ±³¾°ÐýÂÉ£¬Äã¿Ï¶¨ÖªµÀËüÊÇ·ñ»áºÜ°ô ¨C »òÕßÖ»ÊÇ meeeh¡£
µ«ÕâÀïÓÐÒ»¸öÎÊÌâ¡­¡­
ÕÒµ½ÄÇÊ׸èºËÐľÍÏñÍÚ½ð×ÓÒ»Ñù¡£ÕâÊǺܶ๤×÷£¬¶øÇÒ¾­³£ÊDz»±ØÒªµÄÖØ¸´ºÍ·³ÈË¡£ÏÂÃæµÄÄÚÈÝÄãÊDz»ÊǺÜÊìϤ£¿
• ÄúÒѾ­ÎªÒ»Ê׸èÇú×¼±¸ºÃÁËËùÓÐÀÖÆ÷£¬µ«ÕÒ²»µ½ºÃµÄºÍÏÒ½øÐС£
• Äú±àдÁËËùÓеĺÍÏҺͱ³¾°ÐýÂÉ£¬µ«ÏÖÔÚÏë³¢ÊÔ¾ßÓÐÏàͬÐýÂÉģʽµÄ²»Í¬ºÍÏÒ¡£
• Äú×ÜÊÇÍ˻ص½ÄúÒѾ­ÖªµÀµÄÏàͬµ÷ºÍÒô½×¡£
• ÄúÈ·ÇеØÖªµÀÐýÂÉ/ÅÃÒô/±´Ë¾ÏßÓ¦¸ÃÈçºÎ¹¹½¨£¬²¢ÇÒ»áÒòΪÖð¸öÒô·ûµØÊäÈëÒÔÆ¥ÅäºÍÏÒ¶ø·³ÄÕ¡£
Èç¹ûÄú¿ÉÒÔÌø¹ý×è°­Äú½øÐиü¶àʵÑéµÄ¶«Î÷£¬ÄDz»ÊǺܺÃÂð£¿ÎÒÈ·ÐÅÕâ¶ÔÎÒÀ´ËµÊÇÕýÈ·µÄ¡£Õâ¾ÍÊÇΪʲôÎÒ×øÏÂÀ´±àдһ¸ö¿ÉÒÔ°ïÖúÎÒ¼õÉÙĦ²ÁµÄÈí¼þ¡ª¡ªËüÒÔ±ÈÎÒÏëÏóµÄ¸ü¶àµÄ·½Ê½´Ù½øÁËÎҵĸèÇú´´×÷¡£
Soo.. Sundog ÈçºÎΪÄúÌṩ°ïÖú£¿
Sundog Ö¼ÔÚÓëËùÓÐÖ÷ÒªµÄ DAW ÅäºÏʹÓá£ËùÓÐÒô·ûÊä³ö¶¼Í¨¹ý MIDI ½øÐС£Ö»ÒªÄúÔÚ Sundog ºÍÄúµÄ DAW Ö®¼äÉèÖÃÒ»ÌõÐéÄâ MIDI µçÀ£¬Äú¾Í¿ÉÒÔ¿ªÊ¼Ê¹ÓÃÁË¡£
µ«¼´Ê¹Ã»ÓÐÐéÄâ MIDI µçÀ£¬ÄúÒ²¿ÉÒÔ´´½¨ÐµĸèÇúºÍÀ־䣬ÒòΪ Sundog °üº¬×Ô¼ºµÄ¹¤³§ÒôÉ«¼¯£¬°üº¬ 100 ¶àÖÖÀÖÆ÷¡£Ëü¿ÉÒÔ½« MIDI ÎļþÖ±½Óµ¼³öµ½ÆäËû³ÌÐò¡£
ÄúÒª×öµÄµÚÒ»¼þÊÂÊÇÑ¡ÔñÒô½×ºÍ»ùÒô¡£ÀýÈ磬Èç¹ûÄúÏë´´×÷Ò»Ê׿ìÀֵĸèÇú£¬ÇëÒÔ C ´óµ÷ΪÀý£¬Èç¹ûÄúÏëдһÊ×±¯É˵ÄÃñÒ¥£¬ÇëÒÔ E Сµ÷ΪÀý¡£Ö»ÐèÑ¡ÔñÒ»¸öÒô½×²¢µ¯×àһЩÒô·û¡£Äã»áºÜ¿ì¸Ð¾õµ½³ÓµÄÇéÐ÷¡£
ÔÚµÚ¶þ²½ÖУ¬ÄúÇл»µ½ÌØÊâµÄºÍÏÒÊÓͼ¡£ÄúÖ»Ðèµ¥»÷°´Å¥¼´¿ÉÊÕÌýºÍÏÒ ¨C ËüÃǶ¼ÊʺÏÄúÑ¡ÔñµÄÒô½×£¡
Ò»µ©ÄãÕÒµ½ÁËһЩ²»´íµÄºÍÏÒ£¬Äã¾Í¿ÉÒÔ´´½¨Ò»¸öºÍÏÒ½øÐС£Õ⽫ÊÇÄú¸èÇúµÄºÍÉù»ù´¡¡£
»Øµ½Ö÷ÊÓͼ£¬ÕæÕýµÄħ·¨¿ªÊ¼ÁË¡£Äú¿ÉÒÔʹÓÃÊó±ê¡¢MIDI ¼üÅÌ»ò¼ÆËã»ú¼üÅÌÀ´´´½¨ÐµÄÐýÂÉ¡£ÄúµÄËùÓÐÊäÈë¶¼¿ÉÒÔÓ³Éäµ½Òô½×Òô·û ¨C ·Ç³£ÊʺÏDZÔÚ¿Í»§£¡ ¨C »òµ±Ç°ºÍÏÒÒô·û¡£
ÕâÑù£¬ÄúµÄÐýÂɽ«Ê¼ÖÕÌýÆðÀ´ºÜºÍг£¡ÏÖÔÚ£¬Èç¹ûÄú·µ»ØºÍÏÒÊÓͼ²¢¸ü¸ÄһЩºÍÏÒ£¬ÄúµÄËùÓÐÐýÂɶ¼»áÁ¢¼´¸üС£
Get rid of writer¡¯s block once and for all. Experiment with new scales, harmonies, and melodies easily. Use Sundog to play around with chords and basenotes like a breeze. Go from calm, smooth, chill out styles to energetic upbeat tunes in a matter of seconds. Promised.
Four things that can make songwriting painful
Every song needs a good harmonic base. Once you have the chords going, set up a bassline and added some nice background melodies you surely know whether it¡¯s going to be great ¨C or just meeeh.
But here¡¯s the catch¡­
Finding that song core is like digging for gold. It¡¯s a lot of work and oftentimes needlessly repetitive and annoying. Does the following sound familiar to you?
• You have all the instruments ready for a song, but cannot find good chord progressions.
• You wrote all the chords and background melodies, but now want to try different chords with the same melodic patterns.
• You always fall back to the same keys and scales that you already know.
• You know exactly how a melody / arpeggio / bassline should be structured and are annoyed by entering it note by note to match the chords.
Wouldn¡¯t it be great if you could skip the stuff that holds you back to experiment more? I know for sure that this was true for me. This is why I sat down to write a software that could help me reduce the friction ¨C and that boosted my songwriting in more ways than I thought was possible.
Soo.. how can Sundog assist you?
Sundog is designed to work with all major DAWs. All note output happens via MIDI. As long as you set up a virtual MIDI cable between Sundog and your DAW you are ready to go.
But even without a virtual MIDI cable you can create new songs and phrases, as Sundog contains an own factory soundset with over 100 instruments. And it can export MIDI files directly to other programs.
The first thing you do is choosing a scale and a basenote. Take C Major for example if you want to compose a happy song, or E Minor if you write a sad ballad. Just choose a scale and play some notes. You will quickly get a feeling for the mood of the scale.
In a second step you switch over to a special chords view. You can listen to chords by just clicking buttons ¨C and they will all fit your chosen scale!
Once you have found some nice chords you can create a chord progression. This will be the harmonic base of your song.
Back in the main view the real magic starts. You can use your mouse, your MIDI keyboard, or your computer keyboard to create new melodies. All your input can either be mapped to scale notes ¨C great for leads! ¨C or to the current chord notes.
This way your melodies will always sound harmonic! Now if you go back to the chords view and change some chords all your melodies will get updated at once.
What¡¯s New:
official site does not provide any info about changes in this version.
