| ÒôƵ¹¤×÷Õ¾ | Treain | | 1¡¢ ΪרҵÒôƵÉè¼Æ£¬¾¹ý¹ú¼Ò¹ãµç²úÆ·¼ì²âÖÐÐÄÈÏÖ¤
2¡¢ ¼æÈÝ Avid£¬Steinberg£¬Cakewalk£¬Merging Pyramix£¬Magix£¬Sonic Studio,Adobe£¬AutodeskµÈ
3¡¢ ´îÅä¡°1200¡±ÏµÁлúÏä Intel Xeon Processor E5-2603v4 ÁùºË1.7G
4¡¢ ÄÚ´æ16GB DDR4 2400Mhz ¸ßËÙÓ²ÅÌ1TB SSD SATA 6Gbps¹Ì̬ÅÌ
5¡¢ 7200 rpm/DVD¿Ì¼»ú/AMD R5 230 2GB 64bit GDDR3ÏÔ¿¨ Ë«ÏÔ DVI+VGA 2560x1600 4xUSB2.0, 6xUSB3.0,1xUSB3.1 Type c 1xFirewire 400 1xFirewire 800
6¡¢ 1x ǧÕ×Íø¿¨,Ä£×éµçÔ´520W
7¡¢ QuietCool ¾²ÒôÉè¼Æ
8¡¢ Treain Care ¼¼ÊõÖ§³Ö
9¡¢ Windows 7/10 Professional 64Bit µ÷ÖÆ°æ | ̨ | 2 |
| ÏÔʾÆ÷ | | | 1¡¢ ³ß´ç: 23.8Ó¢´ç
2¡¢ ´¹Ö±¿ÉÊӽǶÈ: 178¡ã
3¡¢ µã¾à: 0.275mm
4¡¢ ½Ó¿ÚÀàÐÍ: HDMI VGA
5¡¢ ƽ¾ùÁÁ¶È: 250cd/m^2
6¡¢ ·Ö±æÂÊ: 1920x1080
7¡¢ ˮƽ¿ÉÊӽǶÈ: 178¡ã
8¡¢ ÆÁÄ»±ÈÀý: 16:9
9¡¢ ¶Ô±È¶È: 1000:1
10¡¢ ÆÁÄ»ÀàÐÍ: LED | ̨ | 2 |
| ÒôƵ½Ó¿Ú | RME | Fireface 802 | 1¡¢ 30ÊäÈë/30Êä³öͨµÀ
2¡¢ 12 x Ä£ÄâÊäÈë/Êä³ö
3¡¢ 4 x »°Í²/ÀÖÆ÷ǰÖ÷Ŵó
4¡¢ 1 x AES/EBUÊäÈë/Êä³ö
5¡¢ 2 x ADATÊäÈë/Êä³ö£¨»ò1 x ADATÊäÈë/Êä³ö + 1 x SPDIFÊäÈë/Êä³ö ¹âÏË£©
6¡¢ 1 x ×ÖʱÖÓÊäÈë/Êä³ö
7¡¢ 1 x MIDIÊäÈë/Êä³ö
8¡¢ »ðÏß»òUSB²Ù×÷
9¡¢ TotalMix FX
10¡¢ ¿ÉÑ¡×éºÏ£º¸ß¼¶Ô¶³Ì¿ØÖÆÆ÷ | ̨ | 1 |
| Êý×Ö¿ØÖÆÌ¨ | Mackie/RunningMan | MCU Pro | 1¡¢ 100mm ´¥¸ÐÁéÃôµÄAlpsµç¶¯ÍÆ×Ó£»
2¡¢ ÿͨµÀMute¡¢Solo¡¢Pan¡¢Send Level¼°Rec. Arm¹¦Äܼü£»
3¡¢ V-Pot ¿ØÖÆÈí¼þ¡¢²å¼þЧ¹ûÆ÷ºÍÐéÄâÀÖÆ÷É豸£»
4¡¢ È«Ì×µçÆ½±íÇÅ£¬¼°¹ìÃû³ÆºÍ²ÎÊýÏÔʾ£»
5¡¢ 50 ¶à¸ö°´Å¥¸üºÃµØ¶ÔÈí¼þ²ÎÊý½øÐпØÖÆ£»
6¡¢ ´Å´ø´«ËÍ¿ØÖÆ£»
7¡¢ ÍêÕûµÄÑÝʾ±íÄÜÏÔʾ³öÒô¹ìÃû³ÆºÍ²ÎÊý£»
8¡¢ ÉÏ¡¢Ï¡¢×ó¡¢ÓҺͷŴóµÄÖ¸Õë°´Å¥£»
9¡¢ ´øÓÐ USB MIDI ½Ó¿ÚÄÜÖ±½ÓºÍ Mac »òÕß PC ϵͳÏàÁ¬½Ó£¬»¹ÄÜÔÙÁ¬½Ó¶îÍâ 3 ¸ö MIDI É豸£»
10¡¢ ͨ¹ý Mackie Control Extender Pro ½øÐÐÀ©Õ¹£»
11¡¢ USB ½Ó¿ÚÁ¬½ÓµçÄÔ£»
12¡¢ ÄÚÖÃ 3x3 MIDI ½Ó¿Ú¡£
13¡¢ 16·DAW¿ØÖƽçÃæÀ©Õ¹Æ÷
14¡¢ 100mm´¥¸ÐʽPenny&Gilesµç¶¯ÍÆ×Ó
15¡¢ ͨ¹ý¶à¹¦ÄÜV-Pot£¬¿ìËÙ¿ØÖÆÉùÏñ¡¢Ð§¹ûµçƽµÈ
16¡¢ MackieרÃŵÄͨѶÐÒ飬֧³ÖDAWÈí¼þ
17¡¢ ͨµÀ¾²Òô¡¢Ñ¡Ìý¡¢ÉùÏñ¡¢Êä³öµçƽ&¼Òô¹¦ÄÜ
18¡¢ È«²¿Éù¹ìÃû³ÆºÍ²ÎÊýÏÔʾ
19¡¢ ʵÏÖÓëMCU ProÖ®¼äµÄÀ©Õ¹£¬×éºÏ³É¸ü¼ÓÇ¿´óµÄ¼Òôµ÷Òǫ̂½çÃæ | ̨ | 1 |
| MIDI¼üÅÌ | Nektar | LX61+ USB | 1¡¢ 61 ¼üÁ¦¶È¸ÐÓ¦ºÏ³ÉÆ÷´¥¸Ð¼üÅÌ
2¡¢ 4 Á¦¶ÈÇúÏß + 3 ÐÞÕý£¬ÍäÒôºÍµ÷ÖÆÂÖ£¬°Ë¶ÈÇл»°´Å¥£¬ÒƵ÷°´Å¥¿ØÖÆ£¬ 8 ÐýÅ¥£¬9 30mm ÍÆ×Ó£¬9 ¿É·ÖÅä°´Å¥£¬6 רÓÃ×ß´ø°´Å¥£¬ 5 Ô¤ÉèλÖô洢¿ØÖÆÉèÖÃ
3¡¢ Ò³Ãæ°´Å¥£¨½öÓÃÓÚ Nektar DAW Integration£©
4¡¢ Õë¶Ô¶àÊý DAW µÄ Nektar DAW Integration
5¡¢ ¹Äµæ
6¡¢ 8 Á¦¶È¸ÐÓ¦¹Äµæ
7¡¢ ÿ¸ö¹Äµæ´ø 4 É« LED ±³¹â£ºÂÌÉ«£¬»ÆÉ«£¬³ÈÉ«£¬ºìÉ«
8¡¢ 4 Á¦¶ÈÇúÏßÍâ¼Ó 3 ÐÞÕý
9¡¢ Note-learn
10¡¢ ¹Äµæ¿É·ÖÅäÒô·ûºÍ MIDI CC ÐÅÏ¢
11¡¢ ¼ÓÔØ»ò´æ´¢ÈÎÒâ 4 ¹ÄµæÓ³Éä
12¡¢ ¼ô¼ºÍ³¡¾° LED °´Å¥
13¡¢ ½Ó¿Ú
14¡¢ 1/4¡± TS ̤°å¿ª¹ØÊäÈ루MIDI ¿É·ÖÅ䣩
15¡¢ ±³Ãæ°å USB ¶Ë¿Ú£¬ÓÉ USB ×ÜÏß¹©µç
16¡¢ ͨ¹ýÆ»¹ûÉãÏñÍ·Á¬½ÓÅä¼þ£¨²»Ìṩ£©Á¬½Óµ½ iPad | ̨ | 1 |
| ¼ÒôÈí¼þ | Avid | Pro Tools | 1¡¢ ÀûÓÃÇø¶ÎÔöÒæ¼ÓËٱ༺ͻìÒô£¬ÇáËɵ÷Õû¼°Æ¥ÅäÔöÒæµçƽ¡¢½øÐÐÔ¤»ì
2¡¢ ÔÚÒ»¸ö¹¤³ÌÖÐʹÓöàÖÖÒôƵ¸ñʽ£¬°üÀ¨½»ÌæÊ¹Ó㬶øÎÞÐèÎļþ¸´ÖÆ
3¡¢ ÔÚ32λ¸¡µã¸ñʽÖУ¬ÒÔ¸ü´ó¶¯Ì¬ÓàÁ¿Â¼ÖƺÍÒÔ¸ü¸ß½âÎö¶ÈµÄÉùÒô½øÐÐĸ´ø´¦Àí
4¡¢ ͨ¹ýÔöÇ¿µÄ´ÅÅÌ´¦Àí³ÌÐò£¬ÔÚ½ÏÂýµÄÓ²ÅÌÇý¶¯Æ÷ÉÏ»ñµÃ¾ø¼ÑµÄÏìÓ¦
5¡¢ ÒÔµÍÑÓ³ÙÄ£Ê½Â¼ÖÆ£¬µ±Ê¹ÓõÚÈý·½ÒôƵ½Ó¿Úʱ£¬¿ÉÖ±½Ó½øÐмàÌý
6¡¢ ͨ¹ý ͨµÀÌõ²å¼þ£¬»ñµÃ System 5 µ÷Òǫ̂µÄ EQ ºÍ¶¯Ì¬´¦ÀíµÄÒôÖÊ
7¡¢ ʹÓà EUCON ¿ØÖÆÆ÷ʱ£¬¼´ÓµÓг¬¹ý 500 ¸ö¸½¼ÓµÄ Pro Tools ÃüÁî
8¡¢ ÔËÓà AudioSuite ÁîÄú¹¤×÷¸üÇáËÉ£¬¿É¶ÔäÖȾµÄƬ¶Î½øÐз´Ïò²Ù×÷£¬´¦Àí¼°¸ü¶à
9¡¢ ʹÓÃÑÓÕ¹µÄ24Сʱʱ¼äÏߣ¬ÎªÁ¬ÐøÐÔ°æ±¾´´½¨³¬³¤µÄ¸ñʽÏîÄ¿
10¡¢ ÀûÓÃʵʱµ±äÀ´´ò¿ªº¬ÓдóÁ¿µ±äµÄ¹¤³Ì£¬ÒÔʵÏÖ¸ü¼ÑÏìÓ¦
11¡¢ ½«»ìÒôÖ±½Óµ¼³öÖÁ SoundCloud£¬ÓëÊÀ½ç¹²Ïí²¢ÍÆ¹ãÄúµÄÒôÀÖ | Ì× | 1 |
| ¼Òô»°Í² | | | 1¡¢Ö¸Ïò£ºÐÄÐÍ
2¡¢ÆµÂÊÏìÓ¦£º20Hz-20kHz
3¡¢ÁéÃô¶È£º10 mV/Pa; -40 dB re. 1 V/Pa
4¡¢Êä³ö×迹£º¡Ü200¦¸
5¡¢×îС¸ºÔØ×迹£º¡Ý2000¦¸
6¡¢¶¯Ì¬·¶Î§£º117dB
7¡¢Éùѹ¼¶£º153dB THD 10% | Ö» | 2 |
| ¾µä¶àÖ¸Ïò¼Òô»°Í² | Cavatina | T535 | 1¡¢ 1.2Ó¢´çTϵÁи߾«¶È¼«Í·
2¡¢ Âó¿Ë·çÀàÐÍ: µç×ӹܵçÈÝÂó¿Ë·ç
3¡¢ µç×Ó¹ÜÀàÐÍ£ºVD-6072
4¡¢ µçÔ´: VD-535µçÔ´
5¡¢ Ö¸ÏòÐÔ£º Ô²ÐÍ¡¢ÐÄÐÍ¡¢8×ÖÐ͵ȾÅÖÖÖ¸ÏòÐÔ
6¡¢ ƵÂÊ·¶Î§£º17-24Khz
7¡¢ ÁéÃô¶È£º28mV/Pa
8¡¢ µÈЧÔëÒô¼¶£º18dB( A¼ÆÈ¨IEC651)
9¡¢ ×î´óÉùѹ¼¶£¨0.5% THD @ 1000Hz£©£º148dB
10¡¢ ½ÓÍ·:XLR3F | Ö» | 1 |
| ˫ͨµÀ»°Í²·Å´óÆ÷ | Valseana | P2-T | 1¡¢ VUµçƽ±í
2¡¢ µÍÔëÉù¡¢µÍÊ§Õæ´¿AÀàµç·Éè¼Æ
3¡¢ ³¬¿íƵÂÊÏìÓ¦
4¡¢ ƵÂÊÏìÓ¦£º1Hz¡«125KHz
5¡¢ ¶¯Ì¬·¶Î§£º>120dB(A-Weighted)
6¡¢ CMRR:>95dB
7¡¢ THD:<0.005%(typical)
8¡¢ ×î´ó»°Í²ÊäÈëµçƽ£º+20dBu
9¡¢ ×î´óÏß·ÊäÈëµçƽ£º+17dBu
10¡¢ »°Í²ÊäÈë×迹£º 350¦¸/1250¦¸
11¡¢ Êä³ö×迹£º 80¦¸
12¡¢ ×î´óÊä³öµçƽ£º+20dB
13¡¢ Êä³ö×迹£º<47Ohms
14¡¢ ×î´óÔöÒæ£º75dB
15¡¢ µÈЧÊäÈë¶ËÔëÉù£º£125dBu
16¡¢ Ïû²¨Ö¸Ê¾µçƽ£º +27dBu
17¡¢ µÍÇÐÑ¡Ôñ£º10-200Hz
18¡¢ ¸ºÔØ×迹£º ¡Ý1000Å·Ä·
19¡¢ ×î´óÉùѹ¼¶£º 124dB SPL(0Db SPLµÈÓÚ2*10-5 Pa)
20¡¢ µÈЧÔëÉù¼¶£º £¼21dB-A | ̨ | 3 |
| µ¥Í¨µÀ»°Í²Ç°Ö÷ŴóÆ÷ | Valseana | MA4041 | 1¡¢ »°Í²ÊäÈë×迹£º 350¦¸/1250¦¸
2¡¢ Ïß·ÊäÈë×迹£º 12K¦¸
3¡¢ DIÊäÈë×迹£º 1M¦¸
4¡¢ Êä³ö×迹£º 75¦¸
5¡¢ ƵÂÊÏìÓ¦£º 8Hz¡«20KHz
6¡¢ DIƵÏ죺 120Hz¡«20KHz
7¡¢ µÈЧÊäÈë¶ËÔëÉù£º »°Í²¡Ü£126dBu
8¡¢ Ïß·¡Ü£110dB
9¡¢ DI¡Ü£105dB
10¡¢ Ïû²¨Ö¸Ê¾µçƽ£º +27dBu
11¡¢ ¸ºÔØ×迹£º ¡Ý1000Å·Ä·
12¡¢ ×î´óÉùѹ¼¶£º 124dB SPL(0Db SPLµÈÓÚ2*10-5 Pa)
13¡¢ µÈЧÔëÉù¼¶£º £¼21dB-A | ̨ | 1 |
| СÕñĤÀÖÆ÷¼Òô»°Í²Ì××° | | | 1¡¢ ÀàÐÍ£ºµ¥Ä¤Æ¬Ä£¿é»¯FETµçÈÝ»°Í²
2¡¢ Ö¸ÏòÐÔ£ºÐÄÐÍ£¬È«·½Î»£¬³¬ÐÄÐÍ
3¡¢ ƵÂÊÏìÓ¦£º20Hz-20000Hz
4¡¢ ÁéÃô¶È£º12mV/Pa.ÆäÖÐ1pa=94dB SPL
5¡¢ Êä³ö×迹£º<200Å·Ä·
6¡¢ ¸ºÔØ×迹£º>1200Å·Ä·
7¡¢ ×î´óÉùѹ¼¶£º150dBÉùѹ¼¶Óë-10dBË¥¼õ
8¡¢ ÔëÉù£º16dBÉùѹ¼¶£¨A¼ÓȨ/IEC268-15£©
9¡¢ S/NÐÅÔë±È£º78·Ö±´
10¡¢ PadË¥¼õ£º-10dB»ò-20dB
11¡¢ µÍÇУº6·Ö±´/±¶Æµ³Ì£¬ÔÚ75Hz»ò150Hz
12¡¢ µçÔ´ÒªÇó£º48+/-4V
13¡¢ ÏûºÄµçÁ÷£º<2ºÁ°²
14¡¢ Á¬½ÓÆ÷£º¶Æ½ð3ÕëXLR
15¡¢ µç·£ºFETÇý¶¯£¬ÀëɢƽºâÊä³ö | ¶Ô | 1 |
| ¼àÌýÒôÏä | Valseana | CR8 | 1¡¢ ƵÂÊÏìÓ¦£º36Hz¡ª50kHz£¨¡À3dB£©
2¡¢ µÍƵÏì¶ÈË¥¼õ£º-3dB@60Hz
3¡¢ ¸ßƵÏì¶ÈË¥¼õ£º-3dB@22KHz
4¡¢ Éùѹ¼¶£º100dB SPL@1m£¨@1 meter,+5dBu into Balanced Input)
5¡¢ ×î´óÉùѹ¼¶£º118dB SPL@1m£¨Per Pair£©
6¡¢ µÍÒôµ¥Ôª£º1¸ö/£¨8in£©203mm
7¡¢ ¸ßÒôµ¥Ôª£º1¸ö/£¨1in£©25mm
8¡¢ µÍÒôµ¥Ôª¹¦ÂÊ£º100watts 4ohm (·åÖµ200watts£©
9¡¢ ¸ßÒôµ¥Ôª¹¦ÂÊ£º50watts 4ohm£¨·åÖµ100watts£©
10¡¢ ѹ°ÚÂÊ£º£¾15V/¦Ìs
11¡¢ г²¨Ê§Õ棨THD,SMPTEIMD,DIM100):£¼0.035£¥
12¡¢ ¸ßƵÀàÐÍ£ºMonlithic IC,Class AB with DMOS power stage
13¡¢ µÍƵÀàÐÍ£ºDiscrete bipolar Class AB
14¡¢ ÀàÐÍ£º24dB/±¶Æµ³Ì
15¡¢ ·ÖƵµã£º3kHz
16¡¢ ÁéÃô¶È£º+4dBU at 300Hz for full output
17¡¢ ÊäÈë×迹£º20k¦¸£¨Æ½ºâ£©/10k¦¸£¨·Çƽºâ£©
18¡¢ ¸ßƵ²¿·ÖEQ:+2dB/+4dB@100Hz£¬shelving
19¡¢ µÍƵ²¿·ÖEQ:+2dB@5kHz£¬shelving | ¶Ô | 1 |
| ¼àÌý¶ú»ú | AKG | K271 MKII | 1¡¢ ¶ú»úÀàÐÍ£º·â±Õʽ
2¡¢ ÒôƵƵÏ췶Χ£º16 - 28000 Hz
3¡¢ ¶ú»úÁéÃô¶È£º104 dB SPL/V
4¡¢ ×î´óÊäÈ빦ÂÊ£º200 mW
5¡¢ ±ê³Æ×迹£º55 Ohms
6¡¢ ¿É·ÖÀëÏßÀ£ºÊÇ
7¡¢ ÏßÀ³¤¶È£º3 m
8¡¢ ¿É¸ü»»¶úµæ£ºÊÇ
9¡¢ ÀàÐÍ£ºÂݸËʽ¶þºÏÒ»²å¿×£¨1/4¡°ºÍ1/8¡±£© | ¸ö | 2 |
| ¸èÊÖ¼àÌý¶ú»ú | AKG | K72 | 1¡¢ ¶ú»úÀàÐÍ£º·â±Õʽ
2¡¢ ×î´óÊäÈ빦ÂÊ£º200 mW
3¡¢ ÒôƵƵÏ췶Χ£º16 - 22000 Hz
4¡¢ ¶ú»úÁéÃô¶È£º113 dB SPL/V
5¡¢ ±ê³Æ×迹£º32 Ohms
6¡¢ ÏßÀ³¤¶È£º3 m
7¡¢ ÀàÐÍ£ºÂݸËʽ¶þºÏÒ»²å¿×£¨1/4¡°ºÍ1/8¡±£©
8¡¢ ÐԱ𣺹«
9¡¢ ½ÓÍ·£º3-TRS | ¸ö | 8 |
| ¶ú»ú·ÖÅä·Å´óÆ÷ | | | | ̨ | 2 |
