iZotope Neutron Advanced 3.8.1 WIN »ìÒôЧ¹ûÆ÷
À´×Ô Ozone ºÍ RX µÄÖÆÔìÉÌ£¬Neutron 3 ½«°ÑÄúµÄ»ìºÏÎï´øÈë 21 ÊÀ¼Í¡£Æ¾½è¸üºÃµÄÐÔÄÜ¡¢ÐµĽ»»¥Ê½¿ÉÊÓ»¯ºÍ»ìÒôÖúÊÖ£¨¿ÉÔÚÕû¸ö»á»°ÖÐ×Ô¶¯ÉèÖü¶±ð£©£¬¹¤×÷ËٶȱÈÒÔÍùÈκÎʱºò¶¼¿ì¡£
Íê³ÉÄúµÄÇúÄ¿£¬¿ªÊ¼ÄúµÄ»ìÒô
ȫРNeutron 3£¬»ìÒôÖúÊÖÑо¿ÄúµÄ¸èÇú²¢ÔÚ¼¸ÃëÖÓÄÚÌṩÇúÄ¿¼¶±ð½¨Òé¡£²é¿´°üº¬ iZotope IPC ²å¼þµÄÍêÕûÇúÄ¿ÁÐ±í£¬ÎªÄúµÄ»ìÒôÑ¡ÔñÒ»¸ö Focus ÔªËØ£¬È»ºóÈà Mix Assistant ñöÌýÄúµÄ¸èÇú£¬´Ó¶øÔÚ±ÈÒÔÍù¸ü¶ÌµÄʱ¼äÄÚΪÄúµÄ»ìÒôÕÒµ½×î¼ÑÆðµã¡£
µñ¿ÌÄãµÄÉùÒô
Ç¿´óµÄРSculptor Ч¹ûʹÓà iZotope ¹âÆ×ÕûÐμ¼ÊõΪÄúµÄÇúÄ¿×ÅÉ«¡£Ê¹Óà All-Purpose ËÜÔìÌí¼Ó·áÂú¶È¡¢ÈóÉ«ºÍ³å»÷Á¦£¬»òʹÓÃËæ¸½µÄÀÖÆ÷ÅäÖÃÎļþÀ´ÔöÇ¿ÇúÄ¿µÄ×ÔÈ»Òôµ÷¡ª¡ª»ò»ìºÏºÍÆ¥ÅäÀÖÆ÷ÅäÖÃÎļþÒÔ»ñµÃÒâÏë²»µ½µÄ´´ÔìÐÔЧ¹û¡£
еĽ»»¥Ê½ÊÓ¾õЧ¹û
¿Éµ÷Õû´óС£¬ÃÀ¹Û£¬¶øÇÒËÙ¶ÈÃ÷ÏÔ¸ü¿ì¡£ÉîÈëÑо¿¿ÉÔöÇ¿ÄúµÄ»ìÒôÌåÑéµÄ·ÖÎö¹¤¾ß£¬²¢Í¨¹ýΪÈËÀà¶ø·Ç»úÆ÷ÖÆ×÷µÄ²å¼þ¿Ø¼þ»ñµÃ½á¹û¡£
ÔÚÕû¸ö»á»°ÖнøÐн»Á÷
ʹÓÃËæ¸½µÄ Visual Mixer ²å¼þµ÷Õû»á»°ÖÐÈκΠNeutron »ò Relay µÄÔöÒæ¡¢ÉùÏñºÍ¿í¶È¡£ÔÚ Neutron 3 Advanced ÖУ¬Äú¿ÉÒÔʹÓà Mix Assistant °´Å¥¸ü¿ìµØµ½´ïÒ»¸öºÃµÄÆðµã¡£
ƽ̨£º£¨Win64£»AAX¡¢VST3¡¢VST£©
From the makers of Ozone and RX, Neutron 3 will bring your mixes into the 21st century. Work faster than ever with better performance, new interactive visualizations, and Mix Assistant, which automatically sets levels across your session.
Finish your tracks, start your mix
Brand new to Neutron 3, Mix Assistant studies your song and provides track level suggestions in seconds. View a complete list of your tracks containing iZotope IPC plug-ins, select a Focus element for your mix, then let Mix Assistant listen to your song to achieve an optimal starting point for your mix in less time than ever before.
Sculpt your sound
The powerful new Sculptor effect uses iZotope spectral shaping tech to color the your tracks. Add fullness, polish, and punch with All-Purpose shaping, or use the included instrument profiles to enhance the natural tone of your tracks¡ªor mix and match instrument profiles for unexpected, creative effects.
New interactive visuals
Resizeable, beautiful, and significantly faster. Dive into analysis tools that enhance your mixing experience and get results with plug-in controls made for humans, not machines.
Communicate across your session
Use the included Visual Mixer plug-in to adjust the gain, pan, and width of any Neutron or Relay in your session. In Neutron 3 Advanced, you can use the Mix Assistant button and get to a great starting point even faster.
Platform: (Win64; AAX, VST3, VST)
Homepage
https://www.izotope.com/
