¼ÒôÅïĸ´øºóÆÚÒôÀÖÖÆ×÷·½°¸
¼ÒôÅï
²É¹ºÄÚÈÝÊÇ·ñ½ø¿ÚÊýÁ¿¼ÆÁ¿µ¥Î»¼¼Êõ²ÎÊýÒªÇóÆ·ÅÆÐͺÅ
ÒôƵ½Ó¿Ú·ñ1̨ »°·ÅÊýÁ¿£º4·/65dB
Êý×Ö½Ó¿Ú£ºADAT&S/PDIF
¶ú»ú½Ó¿Ú£º2¸ö/125dB¶¯Ì¬
Êä³öµçƽ£º¿ÉÑ¡+12/+24dB
¶ú·ÅÍÆÁ¦£º150mW@300¦¸£¨+19dB£©
ÏßÐÔÊä³ö£º8·/127dB¶¯Ì¬
UADºËÐÄÊý£º6ºË
Ä£ÄâÊäÈ룺8·/123dB
¼àÌýÊä³ö£ºTRS/129dB
»°·Å½Ï´óÔöÒæ£º65dB
¹©µç·½Ê½£ºÍâÖù¦ÄÜ
Çý¶¯Èí¼þ£ºUA Console
¼æÈÝϵͳ£ºMac OS / Windows
»°·Å¹¦ÄÜ£ºUnison/¶Ô½²»°Í²/·´Ïà/µÍÇÐ/PAD
ÐéÄâͨµÀ£º8x8ÐéÄâÄÚ¼ͨµÀ¡¢4×éCue×Ó»ìÒôͨµÀ
Êý¾Ý½Ó¿Ú£ºË«À×µç3£¨Ö§³Ö¶ą̀Apollo X´®Áª£©
¼àÌý¿ØÖÆ£º¶Ô½²¡¢7.1¡¢×ÜÏß¿ØÖÆ
Apollo x8
DAW¿ØÖÆÌ¨·ñ1̨8 ¸ö´¥¸Ðµç¶¯Í¨µÀµÄÍÆ×Ó
1 ¸ö´¥¸Ðµç¶¯Ö÷ͨµÀµÄÍÆ×Ó
12 ¶Î LEDÏÔʾͨµÀµÄÒôÁ¿µçƽֵ £¬Å䱸ÓÃÓÚͨµÀ£¨µ¥ÉùµÀ£©ºÍÖ÷ͨµÀ£¨Á¢ÌåÉù£©µÄÒôÁ¿µçƽֵ ( ÔÚÇãбµÄ¶¥²¿ÏÔʾ£¬±ãÓÚ¹Û²ì)
8 ¸öË«ÖØ¹¦ÄܱàÂëÆ÷ÐýÅ¥£¨°´Ï»òÐýת£©
11 ¶Î¶àÖÖÑÕÉ« LED ָʾÐýťλÖÃÖÜΧµÄ±àÂëÆ÷
´óÐÍË«±³¹âLCDÏÔʾÆÁÏÔʾÿ¸öͨµÀµÄͨµÀÃû³Æ£¨ÏÂLCD£©ºÍ²»Í¬µÄ¿ØÖƲÎÊý£¨ÉÏLCD£©
10 ¶Î LED ÏÔʾʱ¼äÏîÄ¿µÄÔÚ SMPTE »ò BBT Ö®¼ä .
¿ìËÙ¹öÂֿɽøÐÐËÑË÷¿ØÖÆ
ÿÌõͨµÀ´øµÆµÄ°´Å¥¿É¿ØÖÆÆôÓÃÂ¼ÖÆ¡¢¶À×à¡¢¾²Òô¡¢Ñ¡Ôñ
6 ¸ö´øµÆ°´¼ü£¬°üÀ¨²¥·Å£¬Í£Ö¹£¬Â¼ÖÆ£¬»Ø·Å£¬¿ì½øºÍÑ­»·
´øµÆµÄ¡°Zoom¡±¼üÓÐ4 ¸öµÄ·½Ïò°´Å¥
9 ¸ö´øµÆµÄ¿É·ÖÅä MIDI¹¦Äܰ´Å¥£¨È¡¾öÓÚ DAW£©
ÄÜÀ©Õ¹ 3 ̨ QconPro XS £¬¹²Í¬Ê±¿ØÖÆ32 ¸öͨµÀ
ÓµÓÐ 3 ¸ö USB À©Õ¹¶Ë¿Ú
ICON Qcon Pro X
ÈËÉù»°Í²·ñ1Ö§Èý¸öÖ¸ÏòÐÔ£ºÈ«Ïò£¬ÐÄÐÍ£¬8×ÖÐÍ
¡£´¦Àí¸ß´ï127dBµÄÉùѹ²»»á±äµ÷
¿É¿ª¹ØµÄµÍƵ¹öÇÐ
¿É¿ª¹ØµÄ10dBË¥¼õ×°ÖÃ
¿ÉÏû³ýÔÚ½ü¾àÀëÄÚ½²»°Ê±Ëù²úÉúµÄµÍƵÔëÒô
¿ÉÓëÈκβúÆ·æÇÃÀ£¬²¢ÄÜÖ§³Ö¸÷ÖÖ²»Í¬Ìõ¼þϵļÒô
ÉùÒô¹¤×÷Ô­Àí:ѹÁ¦Ìݶȴ«¸ÐÆ÷
Ö¸ÏòÐÔ;È«ÏòÐÔ£¬ÐÄÐÍ£¬8×ÖÐÍ
ƵÏ죺20Hz-20KHz
ÁéÃô¶È (1KHz-1KOHM):20/28/22mVPa
Êä³ö×迹£º200ohms
¸ºÔØ×迹£º1000ohms
ÁéÃô¶È (CCIR486-3):26/23/25dB-A
ÁéÃô¶È (DIN/EC 651):15/12/14dB-A
S/Nt (CCIR 486-3) :68/71/69dB
S/NEt (DIN/IEC 651) :79/82/80dB
·åÖµÉùѹ¼¶£¨THDСÓÚ0.5%£© £º117dB(ÐÄÐÍ)
·åÖµÉùѹ¼¶£¨THD СÓÚ0.5%,Ԥ˥¼õ£©£º127dB
½Ï´óÊä³öµçÀÖ£º390Mv
Âó¿Ë·ç´«¸ÐÆ÷ (DIN/EC651)¶¯Ì¬·¶Î§ £º105dB
Neumann U87AI
ÈËÉù»°Í²·ñ1Ö§Âó¿Ë·çÀàÐÍ£º´óÕñĤµçÈÝÂó¿Ë·ç
¹¤×÷Ô­Àí£ºÑ¹Á¦ÌÝʽ»»ÄÜ×°ÖÃ
Ö¸ÏòÐÍ£ºÈ«Ö¸Ïò¡¢ÐÄÐÍÖ¸Ïò¡¢8×ÖÐÍÖ¸Ïò
ƵÏ췶Χ£º15-33kHz
ÁéÃô¶È£¨1kHz- 1KOHM£©£º20/28/22mVPa
Êä³ö×迹£º150Å·
ÁéÃô¶È£º26/23/25dB-A
Éùѹ¼¶£º128dB
Ë«ÒôÉ«Çл»¼¼Êõ£ºV-Tube£¨·ÂÕæµç·½¨Ä££©
ÐéÄâµç×ӹܼ¼Êõ£ºµç·½¨Ä£µç×Ó¹ÜÊ§Õæ
×î´óÊä³öµçѹ£º392mV
bblaudio T2G
ÀÖÆ÷»°Í²·ñ4֧ƵÂÊÏìÓ¦  20-20KHZ
Ö¸ÏòÐÔ  ÐÄÐÍ
ÁéÃô¶È   6mV/Pa(-44db)+/-3db at 1khz
×î´óÉùѹ¼¶  >75db
¶¯Ì¬·¶Î§    12db
Êä³ö×迹  200¦¸
¹¤×÷µçѹ   12-48V»ÃÏóµçÔ´
½Ó¿ÚÀàÐÍ   XLRÈýÕ뿨ũ
³ß´ç        ³¤140mm  Ö±¾¶ 19mm
ÖØÁ¿         150g
Authority CM1
˫ͨµÀ»°·Å·ñ1̨ÊäÈë×迹£ºÂó¿Ë·ç 2k Ohm£¬ÏßÐÔ 22k Ohm£¬¸ß×迹£¨Hi-Z£©2M Ohm
Êä³ö×迹£º600 Ohm
×î´óÔöÒæ£º75dB£¬Âó¿Ë·ç·¶Î§´Ó 20 ÖÁ 75dB£¬ÏßÐÔ£¨LINE£©·¶Î§´Ó 0 ÖÁ 40dB£¬¸ß×迹£¨Hi-Z£©·¶Î§´Ó 0 ÖÁ 40dB
×î´óÊä³ö£º+27dBu
ÐÅÔë±È£º´óÓÚ92dB@LINE£¬Ã¿Í¨µÀÔÊÐí´æÔÚÎó²î£¬µ«ÊÇÓÅÓÚ92dB¾ùÊôÓÚÉè¼Æ·¶Î§¡£Âó¿Ë·ç£ºµçÈÝÂó¿Ë·ç
ÀÖÆ÷£ºµç¼ªËû£¬µçbass£¬ºÏ³ÉÆ÷
ÒôƵ½Ó¿Ú£ºÏßÐÔ£¨LINE£©ÊäÈë¡¢Êä³ö
bblaudio M2
ѹËõÆ÷·ñ1̨ͨµÀÊý£ºÁ¢ÌåÉù
ÄÚ²¿²àÁ´Â˲¨ÆµÂÊ·¶Î§£º55Hz¡«340Hz@18dB/oct¡£
ÊäÈëµçƽ¿ØÖÆ£º-¡Þ¡«0dB¡£
ѹËõÆ÷¹Õµã£ºHard Knee/Soft KneeÇ°Ãæ°å¿ª¹ØÑ¡Ôñ¡£
ÃÅÏÞ·¶Î§£º+20dBV¡«-40dBV¡£
ѹËõ±È£º1:1 ¡« ¡Þ¡£
Æô¶¯Ê±¼ä£º£¨fast£©0.1ms¡«165ms£¨Slow£©¡£
ÊÍ·Åʱ¼ä£º£¨fast£©5ms¡«2s£¨Slow£©¡£
Êä³öÔöÒæ£º0 ÖÁ +20dB¡£ÆµÂÊÏìÓ¦£º 20Hz ~ 22kHz (¡À0.5dB, @ 1kHz)
ÊäÈë×迹£ºÏßÐÔ 20k Ohm
Êä³ö×迹£º600 Ohm
×î´óÊä³ö£º+27dBu
bblaudio C2
ĸ´øÏÞ·ùÆ÷·ñ1̨ͨµÀÊý£ºÁ¢ÌåÉù¡£
¾ùºâÆ÷Ƶ¶Î£ºÈýƵ¶ÎºÍ¸ß¡¢µÍƵÂ˲¨Æ÷¡£
ƵÂÊÏìÓ¦£º20Hz¡«60kHz(¡À0.5dB)£¬@1kHz¡£
±¾µ×Ô룺£¼-70dBu @0dB Out Gain¡£
ÊäÈë×迹£º20K Ohms¡£
Êä³ö×迹£º600 Ohms¡£
×î´óÊä³öµçƽ£º+27dBu¡£
µÍÇУº10 ¡«75Hz @ 12dB/oct¡£
¸ßÇУº4.7k ¡« 60kHz @ 12dB/oct ¡£
µÍƵLF£ºÔöÒæ·¶Î§£º¡À6dB£¬É¨Æµ·¶Î§£º50Hz¡«400Hz£»Q=0.707£»¸é¼Üʽ¡£
ÖÐÆµMF£ºÔöÒæ·¶Î§£º¡À6dB£¬É¨Æµ·¶Î§£º65Hz to 1.7kHz/650Hz¡«17kHz @x10±¶Æµ³Ì¿ª¹Ø£»Q£ºHi=0.75£¬low=0.35£»²ÎÁ¿Ê½¡£
¸ßƵMF£ºÔöÒæ·¶Î§£º¡À6dB£»É¨Æµ·¶Î§£º1.5kHz¡«30kHz + Air£»Q=0.707£»¸é¼Üʽ¡£
×ÜµçÆ½¿ØÖÆ£º-¡Þ¡«0dB¡£
µçƽ±í£ºÁ¢ÌåÉùLEDÊä³öµçƽָʾµÆ¡£
bblaudio Limiter
8ͨµÀ»°·Å·ñ1̨ƵÂÊÏìÓ¦£º20Hz-20kHz + 0.5 / -1.5dB
¶¯Ì¬·¶Î§£º109 dB£¨A¼ÓȨ£©
THD + N£º<0.001£¥
ÔëÉùEIN£º-127 dBu
×î´óÊäÈëµçƽ£¨ÎÞ´ò»÷µæ£©£º+8 dBu
×î´óÊäÈëµçƽ£¨´ø´ò»÷µæ£©£º+16 dBu
ÔöÒæ·¶Î§£º50 dB
ÊäÈë×迹£º3k¦¸
Ö§³ÖµÄ²ÉÑùÂÊ£º44.1 kHz£¬48 kHz£¬88.2 kHz£¬96 kHz£¬176.4 kHz£¬192 kHz
Ïß·ÊäÈ룺
THD + N£º<0.002£¥
×î´óÊäÈëµçƽ£º+22 dBu
ÔöÒæ·¶Î§£º50 dB
ÊäÈë×迹£º49k¦¸
Focusrite Scarlett OctoPre 8
Ч¹ûÆ÷·ñ1̨UAD-2 Satellite  OCTO 8ºËÐÄЧ¹ûÆ÷´¦ÀíÆ÷   °üº¬²å¼þ
UA 610-B Tube Preamp and EQ Fairchild® 670 (Legacy)  Teletronix® LA-2A Classic Leveling Amplifier (Legacy)  1176SE/LN® Classic Limiting Amplifiers (Legacy)Pultec® Pro Equalizers (Legacy) Precision Mix Rack Collection  UA Precision Enhancer Hz RealVerb Pro
UA Apollo 8 QUAD
Ö÷¼àÌýÒôÏä·ñ2Ö»×î´óÉùѹ¼¶
104 dBƵÂÊÏìÓ¦·¶Î§
47 Hz - 25 kHz (-6 dB)ƵÂÊÏìÓ¦¾«×¼¶È
¡À 2 dB
£¨54 Hz - 20 kHz)µ¥Ôª³ß´ç
µÍƵ 5 ´ç
¸ßƵ 3/4 ´ç¹¦·Å¹¦ÂÊ
µÍƵ 50 W
¸ßƵ 50 WÒôƵ½Ó¿ÚÀàÐÍ
1 x XLR Ä£ÄâÊäÈë
Genelec/ÕæÁ¦ 8330A
¶Ô±È¼àÌýÒôÏä·ñ2Ö»¸ßÒôµ¥Ôª£ºU-ART¸ßÒôµ¥Ôª
µÍÒôµ¥Ôª£º¾Û±ûÏ©8´çµÍÒôµ¥ÔªºÍºóÖÃʽµ¼Ïò¿×
ÄÚÖù¦·Å£º2¸öDÀ๦·Å
¹¦·Å¹¦ÂÊ£º70Íß(µÍÒôµ¥Ôª)£¬20Íß(¸ßÒôµ¥Ôª)
ÊäÈëÁéÃô¶È£º¿ÉÇл»µÄ+4 dBu/ -10 dBV
ƵÂÊÏìÓ¦·¶Î§£º33 Hz -25 kHz
ÿ¶ÔÒôÏäÔÚ1Ã×´¦²âµÃµÄ·åÖµÉùѹ¼¶£º¡Ý118 dB
·ÖƵµã£º2.6 kHz
¿ØÖÆÃæ°å£º±³²¿
¿ØÖÆÑ¡Ïµçƽ¡¢ÊäÈ뿪¹Ø¡¢+/-2dB¸ßƵºÍµÍƵ¸é¼Ü¾ùºâ
Ä£ÄâÊäÈ룺1¸öXLR¡¢1¸öRCA
¶î¶¨¹¦ÂÊ£º150 W
ÖØÁ¿£º9.8¹«½ï(21.6°õ)
³ß´ç£¨¸ßx¿íx³¤£©£º40cm x 25cm x 33.5cm
ÊäÈëµçѹ·¶Î§£º100-240V
ADAM T8V
¼àÌý¿ØÖÆÆ÷·ñ1̨ƵÂÊ·¶Î§ £º10 Hz - 100 kHz (+/- 3 dB)
ÊäÈë×迹ͨ¹ýSub-Dƽºâ£º50 kOhm/ͨ¹ýRCA²»Æ½ºâ£º>10 kOhm
Êä³ö×迹ͨ¹ýRCA²»Æ½ºâ£º<600 Ohm
×Üг²¨Ê§Õæ¼ÓÔëÉù£º0.006 %
ÔëÉù£¨A¼ÓȨ£©£º>80 dBu
¿¹¹ýÔØÐÔ£º+22 dBu
¶¯Ì¬·¶Î§£º110 dB ¹²Ä£ÒÖÖÆ±È£º>70 dBu
Ïàλ£º-20¡ã@20 kHz
Crosstalk L-R£º>-70 dB@1 kHz/0 dBu
³ß´ç£º³¤¡Á¿í¡Á¸ß(mm)£º272 x 220 x 91
ÖØÁ¿£º2.3¹«½ï
SPL MTC 2381
¼Òôʦ¼àÌý¶ú»ú·ñ2ֻƵÂÊÏìÓ¦18Hz-25kHz
Çý¶¯µ¥Ôª£º´ó³ß´ç50mmÇý¶¯
¶î¶¨¹¦ÂÊ£º15mW
×î´ó¹¦ÂÊ£º30mW
Éùѹ¼¶£º113dB IEC-318@1mW, 1kHz
×迹£º16ohm +/-2.4 (15%)
ÖØÁ¿£º0.55kg
ÐлõAvantone Pro MP1 MP-1
¸èÊÖ¼àÌý¶ú»ú·ñ8Ö»Åå´÷·½Ê½£ºÍ·´÷ʽ²åÍ·/½Ó¿Ú£º3.5mmµ¥ÔªÖ±¾¶£º40mmƵÂÊ·¶Î§£º15-22000Hz×迹£º47Å·Ä·ÁéÃô¶È£º96dBICON  HP200
¶ú»ú·ÖÅäÆ÷·ñ1̨¶à¹¦ÄÜרҵ¶ú»ú·Å´óÆ÷£¬ÊʺÏÎę̀¼°Â¼ÒôÊÒʹÓÃ
6¸öÍêÈ«¶ÀÁ¢µÄÁ¢ÌåÉù´ó¹¦ÂÊ·ÅÇø¶Î
2¸öÁ¢ÌåÉùÖ÷ÊäÈë¶Ë£¬Ìṩ2¸ö¶ÀÁ¢»ìÒô¹¦ÄÜ£¬
6¸ö¶ÀÁ¢µÄÖ±½ÓÊäÈë¶Ë£¬Ìṩ¶àÖÁ6¸öÁ¢ÌåÉù»ìÒô¹¦ÄÜ
±¾»ú¿ÉÈ·±£¸÷ÖÖ¶ú»úµÄÒôÖÊ´ïµ½×î¼Ñ£¬ÉõÖÁÔÚÒôÁ¿×î´óʱҲ²»ÀýÍâ
ÿ¸öͨµÀ¾ùÉèÓÐOUTPUT LEVEL(Êä³öµçƽ)ÐýÅ¥¼°6¸öÊä³öָʾµÆ
ÿͨµÀÅäÓе¥ÉùµÀ¿ª¹Ø£¬Ê¹ÓÃÁé»î·½±ã
ÿ¸öͨµÀÉèÓÐǰ1¸ö¼°ºó2¸öµÄ1/4¡±TRS¶ú»ú½Ó¿Ú
ÿ¸öͨµÀµÄÖ±½ÓÊäÈ루DIRECT  INPUT£©½Ó¿Ú¿ÉÓÃÓÚÖ±½ÓÁ¬½ÓÈκÎÒôÔ´
ƽºâʽÖ÷Êä³ö¶Ë¿É´®Áª¶à¸ö¶ú»ú·Å´óÆ÷
»·ÐαäѹÆ÷¿ÉÈ·±£ÔëÒô¼°´ÅÐÔ¸ÉÈżõµ½×îµÍ
Behringer HA6000
·ÀÅçÕÖ·ñ2¸ö¶ì¾±Ö±¾¶£º8mm
• ¶ì¾±³¤¶È£º330 mm
• ²ÄÁÏ£º¸Ö
• ÐýÈëʽÉÏ£º¹Ü¾¶´ï30 mm
• ¹ýÂËÍøÖ±¾¶£º200mm
• ÌØµã£ºË«ÄáÁúÆÁ£¬ËÜÁÏ¿ò¼Ü£¬´óÖ±¾¶¶Ü¹¹
• ÑÕÉ«£ººÚ
• ÖØÁ¿£º0.32ǧ¿Ë
GOTTOMIX PF-06
ÈËÉù»°Í²Ö§¼Ü·ñ2¸ö¸ß¶È  1340-2210mm
½Å¼Ü»ú¹¹  3¸ö¿ÉËø¶¨½ÅÂÖ
ÂÝÎÆ½Ó¿Ú   3/8"ºÍ5/8"
ÑÕÉ«    ºÚÉ«
²ÄÁÏ     ¸ÖÖÆ
ÉìËõ¶¯±Û   ÅäÖØ3KG
ÖØÁ¿   17.42¹«½ï
´øÂÖ×ÓÎę̀ÑݳöÂó¿Ë·çÈý½Ç¼Ü»°Í²½Å¼Ü
ÀÖÆ÷»°Í²Ö§¼Ü·ñ4¸öѹÖýµ××ù
²ÄÖÊ£º¸ÖÍȲ¿½á¹¹£º´ø¿ÉÕÛµþÍȵĵ××ù
ÂÝÎÆ½ÓÍ·£º3 / 8"
¸ß¶Èµ÷½Ú£ºÀëºÏÆ÷
¸Ë×éºÏ£ºÁ½¼þʽÕÛµþÉè¼Æ
¶¯±Û£ºÒ»ÌåʽµÄÉè¼Æ
¶¯±Û¹Ì¶¨£ºµûÐÎÂÝĸ£»
¶¯±Û³¤¶È£º805mmºÁÃ×
¸ß¶È:900-1600mm,
ÖØÁ¿: 2.19 kg,
¸ß¶È:1010/1720 mm,
ÉìËõ¸Ë³¤¶È : 805mm.
ÒøÓã
ÒôÏäÖ§¼Ü·ñ1¶ÔÒôÏäÐü¸¡Ö§¼Ü ÓÐЧÒÖÖÆÒôÏäºÍ×ÀÃæ²úÉúµÄ¹²Õñ
·ÀÖ¸ÎÆÑÆ¹â Ä«ºÚÉ«
ÖØÁ¿  900g
³ß´ç  16¡Á10¡Á20
¶¨ÖÆ
¶ú·ÖÖ§¼Ü·ñ1¸ö±ê×¼1U¶ú·Ö½Ó¿Ú£¬ÍÐÅÌ¿ÉÉÏÏÂ×óÓÒÈÎÒâµ÷½Ú ÌØÖÆ¶ú·Ö¹Ò¼Ü  ¸ßÆ·Öʿɹ̶¨ÍòÏòÂÖµ××ù
¸ß¶È   790-1060mm
ÖØÁ¿  6.0KG
²ÄÖÊ  ¸Ö²Ä+ËÜÁÏ
ÒôÍõ
Æ×¼Ü·ñ3¸öÖ§¸Ë¼ÓÖØ¡¢¸ßµÍ¿Éµ÷½Ú¡¢Íϰå¼Ó´ó ¿ÉÕÛµþÀ֯׼ÜÒøÓã
¼ÒôÅ﹤×÷̨·ñ1¸ö±ê×¼19Ó¢´ç»ú¼Ü¸ù¾ÝÈËÌ幤³ÌѧÉè¼Æ ²ÉÓÃÓÅÖÊÀäÔþ¸Ö°å ¸ßÃܶȰåÌù ±íÃæ¾­µäÅçËÜ  Á㲿¼þÏÖ³¡×é×° ¼Ó¹¤Ó²»¯ £¬ÄÍѹ¿¹Ë¤£¬È«Êý¿Ø»úе¼Ó¹¤¹¤ÒÕ£¬¼æÈÝËùÓбê×¼»ú¼ÜÉ豸£¬¾ßÓб³²¿É¢ÈÈ¿× ±ßÔµÔ²ÈóµÈÌØµã¶¨ÖÆ
¼ÒôÅïÏ߲ķñ1ÌײÉÓÃ¸ßÆ·ÖÊÎÞÑõÍ­ÒôƵÏ߲썰üº¬¸÷ÀàÒôƵ½Ó²å¼þ£©¶¨ÖÆ
Õý°æÂ¼ÒôÈí¼þ·ñ1Ì×ÀûÓÃÇø¶ÎÔöÒæ¼ÓËٱ༭ºÍ»ìÒô£¬ÇáËɵ÷Õû¼°Æ¥ÅäÔöÒæµçƽ¡¢½øÐÐÔ¤»ì¡£
ÔÚÒ»¸ö¹¤³ÌÖÐʹÓöàÖÖÒôƵ¸ñʽ£¬°üÀ¨½»´í¸ñʽ£¬¶øÎÞÐèÎļþ¸´ÖÆ¡£
¡¡ÔÚ32λ¸¡µã¸ñʽÖУ¬ÒÔ¸ü´ó¶¯Ì¬ÓàÁ¿Â¼ÖƺÍÒÔ¸ü¸ß½âÎö¶ÈµÄÉùÒô½øÐÐĸ´ø´¦Àí¡£
¡¡Í¨¹ýÔöÇ¿µÄ´ÅÅÌ´¦Àí³ÌÐò£¬ÔÚ½ÏÂýµÄÓ²ÅÌÇý¶¯Æ÷ÉÏ»ñµÃ¾ø¼ÑµÄÏìÓ¦¡£
¡¡ÒÔµÍÑÓ³ÙÄ£Ê½Â¼ÖÆ£¬µ±Ê¹ÓõÚÈý·½ÒôƵ½Ó¿Úʱ£¬¿ÉÖ±½Ó½øÐмàÌý¡£
¡¡¡¡Í¨¹ýAvid ͨµÀÌõ²å¼þ£¬»ñµÃ System 5 µ÷Òǫ̂µÄ EQ ºÍ¶¯Ì¬´¦ÀíµÄÒôÖÊ¡£
ʹÓà EUCON ¿ØÖÆÆ÷ʱ£¬¼´ÓµÓг¬¹ý 500 ¸ö¸½¼ÓµÄ Pro Tools ÃüÁî¡£
¡¡ÔËÓà AudioSuite ÁîÄú¹¤×÷¸üÇáËÉ£¬¿É¶ÔäÖȾµÄƬ¶Î½øÐз´Ïò²Ù×÷£¬´¦Àí¼°¸ü¶à
ʹÓÃÑÓÕ¹µÄ24Сʱʱ¼äÏߣ¬ÎªÁ¬ÐøÐÔ°æ±¾´´½¨³¬³¤µÄ¸ñʽÏîÄ¿¡£
ÀûÓÃʵʱµ­±äÀ´´ò¿ªº¬ÓдóÁ¿µ­±äµÄ¹¤³Ì£¬ÒÔʵÏÖ¸ü¼ÑÏìÓ¦¡£
¡¡½«»ìÒôÖ±½Óµ¼³öÖÁ SoundCloud£¬ÓëÊÀ½ç¹²Ïí²¢ÍÆ¹ãÄúµÄÒôÀÖ¡£
Avid Pro Tools  ´ø¹·
MIDI±àÇú¿ØÖÆÆ÷ ·ñ1̨¼üÅÌ ÇÙ¼üÊý 88
ÀàÐÍ NW-GH£¨ÌìÈ»ÊµÄ¾ÖØ´¸£©¼üÅÌ£ººÏ³ÉºÚ̴ľºÍ·ÂÏóÑÀ¼üÃæ
ÒôÉ«
ÒôÔ´È¡Ñù ÒôÔ´È¡Ñù¼¼Êõ AWM2
·¢ÉùÊý ·¢ÉùÊý(×î¶à) 128
ÄÚ½¨ ÒôÉ«Êý 57£¨¸ÖÇÙ£º10 / µç×Ó¸ÖÇÙ£º14 / Sub£º33£©
Ч¹û
ÀàÐÍ ÑÓ³Ù 2 ÖÖÀàÐÍ£¨Ä£Ä⣬Êý×Ö£©
²ÐÏì 1 ÖÖÀàÐÍ£¨Hall£©
Ö÷¾ùºâÆ÷ 3 ÖÖÆµÂÊ£¨¿ÉɨƵÖÐÆµ£©
²åÈëЧ¹û ¸ÖÇÙ£º2 ÖÖϵͳ£¨1£ºÖÆÒôÆ÷¹²Ãù/ 2£ºÑ¹Ëõ¡¢ÆÆÒô¡¢Ê§Õæ¡¢ºÍÉù£¬E. ¸ÖÇÙ£º3 ÖÖϵͳ£¨1£ºÊ§Õæ/ 2£º×Ô¶¯ÉùÏñ¡¢²üÒô¡¢ÒôƵЧ¹ûÆ÷¡¢´¥¿ØÍÜÍÜÒô¡¢Ì¤°åÍÞÍÞÒô¡¢Ñ¹Ëõ/ 3£ººÍÉù 1¡¢ºÍÉù 2¡¢Ïâ±ß¡¢ÒÆÏàÆ÷ 1¡¢ÒÆÏàÆ÷ 2¡¢ÒÆÏàÆ÷ 3£©£¬Sub£º1 ÖÖϵͳ£¨ºÍÉù/Ïâ±ß¡¢ÐýתÀ®°È¡¢²üÒô¡¢ÆÆÒô£©
ÑÅÂí¹þ CP88
ÆÀÂÛÁÐ±í£¨1£©
¸Ðл·ÖÏíÁË¡£¡£¡£²»ÈÝÒ×
2021-11-24 16:05:20 »Ø¸´
