Soniccouture Moonkits v1.1.0 KONTAKT ¼Ü×Ó¹ÄÒôÔ´
Moonkits£ºÌ½Ë÷¼Ü×Ó¹ÄÈáºÍÒ»ÃæµÄÈÎÎñ¡£
Ë¢×Ó£¬µ«²»½öÊÊÓÃÓÚ¾ôÊ¿ÀÖ¡£»¹Óаô¡¢Ä¾é³¡¢²è°ô£ºÈκοÉÒÔ»ººÍ¹¥»÷²¢ÈÃÎÆÀí·¢³öÉùÒôµÄ¶«Î÷¡£
Moonkits ÌØÒâÔÚµÍËÙÏÂÂ¼ÖÆÁ˶îÍâµÄϸ½Ú£¬ÒòΪ²¢·ÇÿÊ×ÇúÄ¿¶¼ÊÇÒ¡¹öÀÖ¡£Äã²»ÐèÒªÓÃÁ¦·ÛËéÌ×¼þ¡£
Ö»ÊǺܰôµÄ´¥¸Ð¡£
Ì×¼þ + °¼²ÛÔ¤ÀÀ
Moonkits ¾ßÓÐ 80 ¸ö»ìºÏÔ¤ÉèÌ×¼þ£¬ËæÊ±¿ÉÓá£
ÿ¸öÌ×¼þ¶¼ÓÐ×Ô¼ºµÄÂɶ¯£¬ÉèÖúò¢×¼±¸ºÃ×÷Ϊ MIDI ÍÏ·Å¡£
Ö±½Ó²åÈ룬»òÌøÈëеķ½Ïò¡£
´ËÊÓÆµµ¼ÀÀչʾÁ˶àÖÖÔ¤ÉèÌ×¼þ¡£
KONTAKT ²¥·ÅÆ÷ (6.2) ¼æÈÝ
ÕâÊÇ Kontakt Player ÀÖÆ÷¡£ÕâÒâζ×ÅÄúÎÞÐèÓµÓÐÍêÕû°æµÄ NI Kontakt ¼´¿ÉʹÓÃËü¡£Ëü½«×÷Ϊ²å¼þÀÖÆ÷ÔÚÈκΠVST/AU/RTAS/AAX/WASAPI¡¢¼æÈݵÄÖ÷»ú³ÌÐò»ò DAW ÖÐÔËÐУ¬ÀýÈ磺Cubase¡¢Logic¡¢Ableton Live¡¢DP¡¢Reaper¡¢Pro-Tools¡£ÎÞÐè¶îÍ⹺Âò¡£
ϵͳҪÇó£º
Windows 7 »ò¸ü¸ß°æ±¾£¨×îÐ嵀 Service Pack£¬32/64 룩£¬Intel Core Duo »ò AMD AthlonTM 64 X2£¬4 GB RAM£¨ÍƼö 6 GB RAM£©
Mac£ºOS X 10.12 »ò¸ü¸ß°æ±¾£¬Intel Core 2 Duo£¬5 GB RAM
ÐÂ 1.1.0 ¨C 2021-08-27
ÐÂÔö¹¦ÄÜ
¨C ·¿¼äÂó¿Ë·çµÆÑ¡Ïî
¨C ¹¤¾ßÌáʾ
ÒÑÐÞ¸´µÄÎÊÌâ
¨C ±ÀÀ£Ñ¡Ïî²Ëµ¥
¨C ÔÚ Beat Shift ºÍ Euclid ÖÐÐÞ¸´ÁËÒ¡°Ú¼ÆËã
¨C Beatshifter 100% µÄ¼¸Âʲ»ÔÙ¿ÉÄÜΪ 0
ÐèÒª KONTAKT 6 »ò KONTAKT 6 PLAYER 6.2 »ò¸ü¸ß°æ±¾
Moonkits: a mission to explore the softer side of the drumkit.
Brushes, but not only for Jazz. Also rods, mallets, tea sticks: anything that mellows the attack and allows the texture to sing out.
Moonkits was intentionally recorded with extra detail at low velocites, because not every track is rock¡¯n¡¯roll. You don¡¯t need to smash the kit hard.
Just great touch and feel.
KITS + GROOVES PREVIEW
Moonkits features 80 preset kits mixed and ready to go.
Each kit has its own groove, set up and ready to drag and drop as MIDI.
Slot it straight in, or jump off into new directions.
This video tour shows off the wide selection of preset kits.
KONTAKT PLAYER (6.2) COMPATIBLE
This is a Kontakt Player instrument. This means that you do not need to own the full version of NI Kontakt to use it. It will run as a plug-in instrument in any VST/AU/RTAS/AAX/WASAPI,compatible host program or DAW eg: Cubase, Logic, Ableton Live, DP, Reaper, Pro-Tools. No extra purchase necessary.
System Requirements:
Windows 7 or higher (latest Service Pack, 32/64 Bit), Intel Core Duo or AMD AthlonTM 64 X2, 4 GB RAM (6 GB RAM recommended)
Mac: OS X 10.12 or higher, Intel Core 2 Duo, 5 GB RAM
NEW 1.1.0 ¨C 2021-08-27
ADDED Feature
¨C Room Mic Lign Option
¨C Tool Tips
FIXED Issues
¨C Crash options menu
¨C Swing calculations fixed in Beat Shift and Euclid
¨C Beatshifter chance of 0 no longer possible at 100%
Requires KONTAKT 6 or KONTAKT 6 PLAYER version 6.2 or later
https://www.2download.net/2021/10/soniccouture-moonkits-110-kontakt-full.html |
