| ÏîÄ¿ | É豸Ãû³Æ | ¼¼Êõ²ÎÊý | Æ·ÅÆÐͺŠ| µ¥Î» | ÊýÁ¿ |
| 1 | ÒôƵµçÄÔ¹¤×÷Õ¾ | ×ÀÃæÊ½ÒôƵһÌå»ú
²ÉÓö¨ÖƵÄÒôƵÖ÷°å
Pro DAW ÒôƵһÌå»ú,64¹ì@48kHzÒôƵ¼»ì¡¢128¹ìMIDI£¬64¸ö Native²å¼þ¡¢64¹ì¸¨Öú£¬²ÉÑùÂÊ 44.1/48/96/192khz
ÄÚÖÃ2½ø2³öÒôƵ½Ó¿Ú£¬ASIO2.0/WDM/MME Çý¶¯£¬
3.7GHz Ë«ºËËÄÏß³Ì Intel Core i3 ´¦ÀíÆ÷
×ÜÏ߸ߴï8GT/s DMI3£¬Èý¼¶»º´æ3MB
8G 2133 DDR4 Äڴ棬¿ÉÀ©Õ¹ÖÁ32G
1TB 7200rpm Barracude Ó²ÅÌ
ͼÐδ¦ÀíÆ÷ Intel HD Graphics 530£¬1GB£¬HDMI/DVI
×ÀÃæÊ½ÒøÂÁСºÐ×Ó£¬ÇáÇÉÍâ¹ÛÉè¼Æ 24x24x10cm
Windows 10 64bit Treainµ÷ÖÆÏµÍ³
רҵAudio/MIDIÍâÉè½Ó¿Ú£º1x USB 3.1/2x USB 3.0/1x USB 2.0£»1x Intel Gigabit NIC
ÑéÖ¤Èí¼þ£ºEarmaster¡¢Pro Tools¡¢Cubase¡¢Sibelius¡¢Samplitude¡¢Ableton Live¡¢Max/DSP¡¢Sonar¡¢Reason¡¢Reaper¡¢Kontakt¡¢Engine¡¢Waves
Ԥװ²ÉÑùÓëÒôÉ«£º
Native Instruments ÒôÉ«¿â: Kontakt 5.3²ÉÑùÆ÷£¬LibraryÒôÉ«±í:°üº¬Galaxy Steinway 5.1 Surround ¸ÖÇÙ£¬Acoustic Legend HD¼ªËû£¬Studio Drummer¹Ä£¬ALICIA's Keysµç¸ÖÇÙ£¬Kontakt FactoryLibrary×ÛºÏÒôÔ´£¬Lass Strings ¹ÜÏÒÀÖµÈ
ÖйúÃñÀÖÒôÉ«¿â£º ´µ×à:µÑ×Ó£¬¶´óºù«˿£¬ßï…È£¬ÀÏÒ: ¶þºú£¬¾©ºú£¬ÂíÍ·ÇÙ£¬µ¯²¦: ¹ÅÇÙ£¬¹ÅóÝ£¬ÅýÅã¬ÈýÏÒ£¬´ò»÷: ÑïÇÙ£¬ÃñÀÖ´ò»÷×é
Êó±ê¼üÅÌÌ××°. | | ̨ | 1 |
| 2 | ÏÔʾÆ÷ | ÆÁÄ»³ß´ç:27Ó¢´ç
×î¼Ñ·Ö±æÂÊ:2560x1440
ÆÁÄ»±ÈÀý:16:9£¨¿íÆÁ£©
¸ßÇå±ê×¼:2K
Ãæ°åÀàÐÍ:IPS-ADS
±³¹âÀàÐÍ:LED±³¹â
¶¯Ì¬¶Ô±È¶È:2000Íò:1
¾²Ì¬¶Ô±È¶È:1000:1
»Ò½×ÏìӦʱ¼ä:5ms | | ̨ | 2 |
| 3 | Êý×ÖÒôƵ½Ó¿Ú | 20 ½ø£¬24 ³ö×ÀÃæ½Ó¿Ú
4 x Class-A Audient ¿ØÌ¨»°·Å 60 dB ÔöÒæ
ͬÀàÁìÏÈ AD/DA ת»»Æ÷
2 x Õë¶ÔÊý×ÖÀ©Õ¹µÄ ADAT ÊäÈëºÍÊä³ö
2 x ·ÖÀë JFET ÀÖÆ÷ÊäÈë
2 x Íêȫƽºâ²åÈë
2 x ¶ÀÁ¢Á¢ÌåÉù¶ú»úÊä³ö
Ö÷´ÎÒôÏäÊä³ö
ScrollControl
3 x Óû§¶¨Ò幦Äܰ´¼ü
רÓöԽ²¡¢ÈõÒôºÍÐÞ¼ô¿ØÖÆ
µÍÑÓ³Ù DSP µ÷Òǫ̂
×ÖʱÖÓÊä³ö
USB 2.0 ¼æÈÝ
24-bit/96kHz
È«½ðÊôÍâ¿Ç | Audient ID44 | ̨ | 1 |
| 4 | ´óÕñĤµçÈÝ»°Í² | 1¡¢ÕñĤ:6¦Ìmºñ¡¢¶Æ½ð
2¡¢ÆµÂÊÏìÓ¦:20Hz - 20kHz
3¡¢Ö¸ÏòÐÍ:ÐÄÐÍ¡¢8×ÖÐͺÍȫָÏò
4¡¢×迹:200¦¸
5¡¢ÁéÃô¶È:15mV/Pa
6¡¢Ë¥¼õÑ¡Ôñ¿ª¹Ø:0 dB, -10 dB
7¡¢¸ßͨÂ˲¨Ñ¡Ôñ:6 dB/oct, 150 Hz
8¡¢µÈЧÔëÉù:20dB(A-weighted IEC 651)
9¡¢ÐÅÔê±È:74dB (Ref. 1Pa A-weighted)
10¡¢×î´óÉùѹ(0.5%THD):130dB
11¡¢»ÃÏóµçÔ´:48V (¡À4V)
12¡¢°üº¬µç×ӹܻ°Í²Ò»Ö»£¬µç×ӹܷŴóµçÔ´ºÐÒ»¸ö£¬5ÕëÂó¿Ë·ç»°Í²ÏßÒ»Ìõ£¬µçÔ´ÏßÒ»Ìõ£¬·ÀÕð¼ÜÒ»Ì×¼°ÂÁÏä¡£ | GAPROJECTS TC1 Tube | Ö§ | 2 |
| 5 | ˫ͨµÀ»°Í²·Å´óÆ÷ | ¿É±äÊäÈë×迹ÓÃÓÚÁé»î»°Í²ÒôÉ«µ÷Õû(150 Å·Ä·µ½2400Å·Ä·)
Ñ¡Ôñ¼«°åµçѹ
´óVUµçƽ±í
·ÖÁ¢µÄAÀàÊäÈ뻰ͲǰÖ÷ŴóÆ÷C
µÍÔöÒæÉèÖÃʱ·Ç³£µÍµÄÔëÉù
·Ç³£µÍµÄ×Üг²¨Ê§Õæ(THD)
ºÜ¿íµÄƵÂÊÏìÓ¦
×°ÓÚÇ°Ãæ°åµÄÀÖÆ÷ÊäÈë²å×ù
Ö§³ÖÖмäλÖÃ/²àÅÔ»°Í²¼¼Êõ Ö§³ÖMSÖÆÊ½Â¼Òôģʽ
ÔÚ +4dbm/-10dbvÊä³ö²Ù×÷
Ñ¡ÔñÁ¢ÌåÉù/Êä³ö¿ØÖƶÀÁ¢²Ù×÷s
×Ô¶¯ÀÖÆ÷ÊäÈëÑ¡Ôñ
ƵÂÊÏìÓ¦15Hz to 48 kHz (+0, -1dB) @Õý³£µçѹ
15Hz to 120 kHz (+0, -1dB) @¸ßµçѹ
¶¯Ì¬·¶Î§: >110dB ("A"¼ÆÈ¨)
¹²Ä£ÒÖÖÆ±È: >90dB
×Üг²¨Ê§Õæ: <0.005% (±ê×¼)
µÈÖµÊäÈëÔëÉù-129dBu (XLR, "A"¼ÆÈ¨)
×î´óÊäÈëµçƽ: +19dBu (cannon)
×î´óÀÖÆ÷ÊäÈë: +17dBu
ÊäÈë×迹: 150-3000Å·Ä·µ÷Õû (XLR)>800K Å·Ä· (ÀÖÆ÷)
×î´óÊä³öµçƽ: +27dBu (XLR)
Êä³ö×迹: < 47 Å·Ä·(XLR)
×î´óÔöÒæ: 75dB
µçƽ±í¿Ì¶È: 0 VU = +4dBu output (+4dBģʽ) 0 VU = -10dBVÊä³ö (-10dB ģʽ)
¸ßͨÂ˲¨Æ÷: single pole, 10-200 Hz adjustable
µçÔ´ÐèÇó: 125 VAC / 220VAC ³ö¿Ú²úÆ·°´³ö¹ú¼ÒÅäÖÃ
Ìå»ý: (¸ßx¿íxÉî Ó¢´ç)´óÓÚµÈÓÚ3.50 x 19.0 x 8.75
Ìå»ý: (¸ßx¿íxÉî ÀåÃ×)´óÓÚµÈÓÚ 88 x 482x 222
ÖØÁ¿: (°õ/¹«½ï)´óÓÚµÈÓÚ10.5 / 4.7 | ART Pro MPA-II | ̨ | 1 |
| 6 | ¼àÌýÒôÏä | ÀàÐÍ£ºË«Ïò½ü³¡µÄ¹¤×÷ÊҲο¼ÓÐÔ´¼àÌýÒôÏä
¡ï¸ßÒôÇý¶¯£º3´çRibbon Tweeter´øÊ½¸ßÒôµ¥Ôª
µÍÒôÇý¶¯£º6Ó¢´ç(203ºÁÃ×)voicecoil¿·òÀ¶ûÍä×¶×èÄáÏ𽺻·ÈÆ,´Åshieldedt
·ÖƵÏìÓ¦£º2.7khz
ƵÂÊ·¶Î§£º45hz-22khz
¹¦ÂÊ£º ¸ßÒô50W£¬µÍÒô60W
ÐÅÔë±È£º> 100db TypicalA-weighted
½»²æÆµÂÊ£º2.6KHZ
ÊäÈëÁ¬½ÓÆ÷£º1 x XLRƽºâÊäÈëÁ¬½ÓÆ÷/ 1 x TRSƽºâ²»Æ½ºâÊäÈë
¼«ÐÔ£ºÏòÍâ»ý¼«ÐźÅ+ÊäÈë²úÉúµÍÆµ×¶Î»ÒÆ
ÊäÈë×迹£º20 K¦¸Æ½ºâ,10 K¦¸Æ½ºâ
ָʾÆ÷£ºµçÔ´¿ª/¹ØºóÃæ°åָʾÆ÷
¹¦ÂÊÒªÇó£ºFactory-programmed 115 V ~ 50/60 Hz,230 V ~ 50/60 Hz,or100V50/60 Hz
²ÄÖÊ£ºVinyl-laminated high-acoustic-efficiency MDF
¡ïµçÔ´£ºÖ¸Ê¾µÆLEDÏÔʾ
³ß´ç£º´óÓÚµÈÓÚ(W x D H)£º250mmx300mm x 410 mm
ÖØÁ¿£º(²»º¬°ü×°)£º´óÓÚµÈÓÚ11.0¹«½ï | Redsound TC-80 | Ö» | 2 |
| 7 | µç¸ÖÇÙ | ¼üÅÌ ¼üÊý 88
ÀàÐÍ GHS¼üÅÌ£¨½¥²ãʽ´¸¸Ð±ê×¼¼üÅÌ£©£¬Ä¥É°ºÚ¼ü
´¥ÃþÁéÃô¶È Ó²/ÖÐ/Èí/¹Ì¶¨
Ãæ°å ÓïÑÔ ÖÐÎÄ
ÒôÉ«
ÒôÔ´ ¸ÖÇÙÒôÉ« ´¿ÒôCFÉùÒôÒýÇæ
¸´Òô ¸´ÒôÊý£¨×î´ó£© 192
Ô¤Öà ÒôÉ«ÊýÁ¿ 24
Ч¹û
ÀàÐÍ »ìÏì ÓУ¨4ÖÖÀàÐÍ£©
ÖÇÄÜÉùѧ¿ØÖÆ£¨IAC£© ÓÐ
ÖÆÒô¹²Ãù ÓÐ
ÉùÒôÔöÇ¿ ÓÐ
¹¦ÄÜ Ë«ÒôÉ«/µþ¼ÓÒôÉ« ÓÐ
·Ö¸îÒôÉ« ÓÐ
Ë«¸ÖÇÙģʽ ÓÐ
ÀÖÇú
Ô¤Öà ԤÖÃÀÖÇúÊýÁ¿ 21Ê×ʾ·¶ÀÖÇúºÍ50Ê׸ÖÇÙÇú
¼Òô ÀÖÇúÊýÁ¿ 1
¹ìµÀÊýÁ¿ 2
Êý¾ÝÈÝÁ¿ ÿÊ×ÀÖÇú100 KB£¨Ô¼11,000¸öÒô·û£©
¼æÈÝÊý¾Ý¸ñʽ »Ø·Å SMF£¨¸ñʽ0£¬¸ñʽ1£©
¼Òô SMF£¨¸ñʽ0£©
¹¦ÄÜ
×ÜÌå¿ØÖÆ ½ÚÅÄÆ÷ ÓÐ
½Ú×෶Χ 5 - 280
ÒÆµ÷ -6µ½0,0µ½+6
Òôµ÷΢µ÷ 414.8-440.0-446.8Hz
°é×àÐÍ 20£¨°üº¬¹ÄºÍ±´Ë¹2¸öÉù²¿£©
´æ´¢ºÍÁ¬½Ó
Á¬½Ó DC IN DC IN 12 V
Í·´÷¶ú»ú ±ê×¼Á¢ÌåÉù²å¿Úx2
ÑÓÒô̤°å ÓУ¨ËæÇÙ¸½ËÍ£©
Èý̤°åµ¥ÔªLP ÐèÁíÍ⹺Âò
MIDIרÓÃ½Ó¿Ú ÎÞ£¨¿Éͨ¹ýUSBµ½Ö÷»ú½Ó¿Ú´«ÊäMIDI£©
¸¨ÖúÒôƵÊä³ö [L / L + R] [R]
USBµ½Ö÷»ú ÓÐ
¹¦·ÅºÍÑïÉùÆ÷
¹¦·Å´óÓÚµÈÓÚ 7 W x 2
ÑïÉùÆ÷ ´óÓÚµÈÓÚ12 cm x 2 + 4 cm x 2 | ÑÅÂí¹þP-125 | Ì× | 1 |
| 8 | ¼ÒôÈí¼þ | • ȫеÄVariAudio 3
• ÈËÉùÒô¸ßÐÞÕý¹¦ÄÜÉý¼¶
• µ÷Òǫ̂¿ìÕÕ¹¦ÄÜ
• ¿ìËٶԹ칦ÄÜ
• ÐÂͨµÀÌõ
• Ö§³Ö32bitÉî¶ÈµÄ¶¯Ì¬
• Ôö¼ÓÁ˶Ô64bitÉî¶ÈµÄ¸¡µãÔËËãÄÜÁ¦
• еIJàÁ´¹¦ÄÜ
• еÄÓû§½çÃæ
• 5 GB¸ßÆ·ÖʵÄÉùÒôºÍÑ»·• AAFÖ§¼Ü
• 20¸öеÄÂö³åÏìÓ¦
• ÑÓʱ¼àÊÓÆ÷
• Ö§³Ö¸ß·Ö±æÂÊÏÔʾÆ÷£¬ÊÓÍøÄ¤ÆÁÄ»
• ýÌå»ú¼ÜЧӦ
• MPEÖ§³Ö
• ¸Ä½øµÄͼƬ±à¼
• ÐéÄâÏÖʵ
• ARAÔØÌå | YAMAHA steinberg Cubase | Ì× | 1 |
| 9 | ÖÇÄܱàÇúÈí¼þ | Óг¬¹ý 80 ¸öÁîÈ˼¤¶¯µÄй¦ÄܺÍÔöÇ¿£¡Ö÷ÆÁĻͼÐÎÓû§½çÃæÒÔ¼°ÖØÐÂÉè¼Æ£¬´øÓкܶàÐèÇóµÄ¸Ä½ø£¬°üÀ¨Ò»¸öÐµģ¬¸üСµÄ¸²¸ÇÇø£¬¿ÉÅäÖù¤¾ßÀ¸µÈ¡£ÕæÊµÒô¹ì±ÈÒÔǰ¸üºÃ£¬´øÓиĽøµÄÀÉìºÍת»»Æ·ÖÊ£¨Elastique 3£©£¬¸üºÃµÄÀÖ¾ä¹ý¶É£¬»¹ÓÐ×ÔÈ»µÄ±àÅÅ¡£ÎÒÃÇÔö¼ÓÁËÓÉ Brent Mason Õ¦i12 ¸öµ÷ÑÝ×àµÄеĽÐ×ö 12 ¶¨µ÷¼ªËûÕæÊµÒô¹ì¡°Woodshedding¡±£¬¾ßÓÐ¸ßÆ·ÖÊ£¨¾«È·£©µÄ¼ÇÆ×£¬·Ç³£ÊʺÏÓÚÑо¿ºÍѧϰ¡£ÓɺܶàÕæÊµ¹ÄÔöÇ¿°üÀ¨°ë/Ë«/Èý±¶ËÙ¶È£¬Ò»¸ö¹ÄÒô¹ì¶à¸ö¹Ä/´ò»÷ÀÖ/Loop µÈ¡£ÓÐÒ»¸ö¾ßÓг¬¹ý 8000 Á÷ÐиèÇúÔªÊý¾ÝÐÅÏ¢µÄרÓõĸ赥ä¯ÀÀÆ÷¡£Óû§Òô¹ìÔöÇ¿°üÀ¨°ë/Ë«/ÈýËÙ£¬ÐÝÖ¹£¬3/4 »ª¶û×ÈÖ§³ÖµÈ¡£ÎÒÃÇÌí¼ÓÁËÒ»¸öÐ嵀 VST ºÏ³ÉÆ÷£¨sforzando SFZ ºÏ³ÉÆ÷£©ÓëÁ÷ÐÐµÄ .SFZ ÒôÉ«¸ñʽµÄÖ§³Ö£¬»¹ÓÐ PG Music ¸ßÆ·ÖÊÉùÒô | Band-in-a-Box | Ì× | 1 |
| 10 | ´òÆ×Èí¼þ | Èí¼þÖ§³Ö¼òÆ×¡¢ÎåÏ߯ס¢¹ÄÆ×¡¢¹¤³ßÆ×¡¢Âà¹Ä¾¡¢ÅýÅÃÆ×¡¢ÃñÀÖÏ·ÇúÆ×¡£Ö§³Ö»ìºÏÅŰ桢×Ô¶¯ÅäÆ÷¡¢£Í£É£Ä£ÉÒôÀÖÖÆ×÷£¬²¢ÄܼÓÔØVSTIÒôÔ´¡£×¨Òµ¼¶¼òÆ×ÓëÎåÏ߯׻ìÅÅ»¥»»ÒýÇæ£¬¿ÉʤÈγö°æ¼¶×¨ÒµÇúÆ×¡£ÓµÓÐÔÚÖйúÊ״δﵽ֧³Ö¸ÖÇÙÊ®¼¶¸´ÔÓÇúÆ×µÄ¹¦Á¦¡£ | Avid Sibelius | Ì× | 1 |
| 11 | ¶ú»ú·ÖÅäÆ÷ | 1¡¢°ËͨµÀ´ó¹¦Âʶú»ú·ÖÅä·Å´óÆ÷16¸ö¶ú»úÊä³ö¼àÌý
2¡¢ºóÃæ°å¾ßÓÐXLR¶àÖÖÊäÈë¶Ë¿Ú£¬ÊÊÓ¦²»Í¬µÄÉ豸ÊäÈë
3¡¢Ã¿¸ö½Ó¿Ú´ïµ½1500MWÊä³ö
4¡¢Á¢ÌåÉù/µ¥ÉùµÀ¿ª¹Ø¿ÉÒÔ»ìºÏÁ½×éµ¥ÉùµÀÐźÅ
5¡¢±ê×¼19Ó¢´ç1U»ú¼Üʽ´¿ÂÁ»úÉíÉè¼Æ£¬ÓÐЧɢÈÈ
6¡¢Ã¿Í¨µÀ×î´óÊä³ö¹¦ÂÊ£º+21 dBm£¨¸ºÔØ×迹100¦¸£©
7¡¢ÐÅÔë±È > 90 dBu£¨Î´¼ÓȨ22Hz-22KHz£©
8¡¢THD < 0.1£¥
9¡¢ÆµÂÊÏìÓ¦ 20Hz - 30 kHz
10¡¢½»Á÷µçÔ´ 115 / 230V〜50Hz-60Hz£¨30W£©
11¡¢³ß´ç ´óÓÚµÈÓÚ483.0¡Á44.5¡Á170.0mm WxHxD | Redsound HA-820 | ̨ | 1 |
| 12 | ¼àÌý¶ú»ú | ¹¤×÷ÔÀí£ºÈ«·â±Õʽ
Åå´÷·½Ê½£ºÍ·´÷°ü¶úʽ
»»ÄÜ·½Ê½£º¶¯È¦Ê½
À®°ÈÖ±¾¶£º¡é53mm
×迹£º60Å·
ÁéÃô¶È£º93dB¡À3dB
ƵÂÊÏìÓ¦£º10Hz-30kHz
ÉÏÏÞ¹¦ÂÊ£º600mW
¶î¶¨¹¦ÂÊ£º300mW
Ïß³¤3M+1M
²åÍ·:¡é3.5mm+¡é6.3mm | ISK MDH9000 | ¸± | 8 |
| 13 | ¼Òôʦ¼àÌý¶ú»ú | 1.ÀàÐÍ£º·â±Õ¶¯È¦Ê½Â¼ÒôÅï¼àÌý¶ú»ú£»
2.Çý¶¯µ¥Ôª£º50ºÁÃ×îÏÌúÅð´ÅÌú£»
3.ƵÂÊÏìÓ¦£º10Hz-32kHz£»
4.ÁéÃô¶È£º98dB (+/-3dB 1mW @ 1kHz)£»
5.×迹£º32¦¸(+/- 15% @1000Hz)£»
6.×î´óÊäÈ빦ÂÊ£º1500mW£»
7.Ê§Õæ¶È£º<5% (@1kHz)£»
8.Á¬½Ó²åÍ·£º3.5ºÁÃ×(1/8Ó¢´ç)TRS/Jack£»
9.ÏßÀ³¤¶È£º3Ã×10Ó¢´ç£» | GAPREMIER HD-680 | ¸± | 1 |
| 14 | µçÔ´¾»»¯±£»¤Æ÷ | 1¡¢2´ç²ÊɫҺ¾§ÖÇÄÜÏÔʾ´°£¬¿ÉʵʱÏÔʾµ±Ç°µçѹ£¬ÈÕÆÚʱ¼ä£¬Í¨µÀ¿ª¹Ø×´Ì¬
2¡¢8·¿ª¹ØÍ¨µÀÊä³ö£¬Ã¿Â·ÑÓʱ¿ªÆôºÍ¹Ø±Õʱ¼ä¿É×ÔÓÉÉèÖ㨷¶Î§0~999Ã룬µ¥Î»ÎªÃ룩
3¡¢Ã¿Í¨µÀ¿ÉÒÔ¶ÀÁ¢¿ª¹Ø»òͬʱȫ²¿¿ª¹Ø
4¡¢Ö§³ÖÃæ°åLockËø¶¨¹¦ÄÜ£¬·ÀÖ¹Îó²Ù×÷
5¡¢ÄÚÖÃʱÖÓоƬ£¬¿É¸ù¾ÝÈÕÆÚʱ¼ä¶¨Ê±ÉèÖÃ×Ô¶¯¿ª¹Ø»ú
6¡¢Ö§³Ö¶ą̀É豸¼¶ÁªË³Ðò¿ØÖÆ£¬¼¶Áª×´Ì¬¿É×Ô¶¯¼ì²â¼°ÉèÖÃ
7¡¢ÅäÖÃRS232½Ó¿Ú£¬Ö§³ÖÍⲿÖÐÑë¿ØÖÆÉ豸¿ØÖÆ
8¡¢Ã¿Ì¨É豸×Ô´øÉ豸±àÂëID¼ì²âºÍÉèÖ㬿ÉʵÏÖÔ¶³Ì¼¯ÖпØÖÆ
9¡¢10×éÉ豸¿ª¹Ø³¡¾°Êý¾Ý±£´æ/µ÷Ó㬳¡¾°¹ÜÀíÓ¦Óüòµ¥±ã½Ý
10¡¢Ç·Ñ¹¡¢³¬Ñ¹¼ì²â¼°±¨¾¯
11¡¢ÄÚÖõçÔ´Â˲¨ÏµÍ³£¬¾»»¯µçÁ÷Éù
12¡¢µ¥Â·¶î¶¨Êä³öµçÁ÷ 13A£¬¶î¶¨×ÜÊä³öµçÁ÷30A | Redsound PRO-3500 | ̨ | 1 |
| 15 | »°Í²¼Ü | ²ÄÖÊ£º¸ßÇ¿¶È¸Ö¹Ü
¸ß¶È£º1000-1760mm
ºá¸Ë³¤¶È£º530-910mm
µ××ù£º½ðÊô | | ¸ö | 2 |
| 16 | ¼ÒôÅï²Ù×÷̨ | ²ÉÓÃ¸ßÆ·ÖÊʵľ²ÄÁÏÖÆ×ö¶ø³É, £¬¼ò½àÁ÷³©µÄÏßÌõ£¬ÓÅÑŵıÈÀý£¬Í»ÆÆ³±Á÷ÏÞÖÆ,öÁÓÀ¶Ëׯ¡£¶¥²ã¿ÉÒÔͬʱ·ÅÖÃ2¸ö24Ó¢´çÏÔʾÆ÷ÒÔ¼°2¸öÒôÏä¡£Á½±ß·Ö±ðÓÐ4UµÄ»ú¼Ü,¿É°²×°19Ó¢´çµÄ¼ÒôÉ豸¡£½ðÊô¼Ü×Ӽӹ̵Ä×ÀÉí£¬³ÐÖØÄÜÁ¦´ïµ½400½ï£¬ÎȹÌÀο¿²»Ò¡»Î£¬×¿Ô½Æ·ÖÊÈ·±£×À×ÓʹÓÃ8Äê²»±äÐΡ£ | | Ì× | 1 |
| 17 | ·ÀÅçÕÖ | ¸ßЧ˫²ãÕÖĤ
¸ßЧ˫²ãÕÖĤ
¿Éµ÷Õû»°Í²¼Ð£¬¸÷ÖÖÀàÐÍ»°Í²ÊÊÓÃ
¶ì¾±Éè¼Æ¿É¾«È·¶¨Î»
¼Ó´ó³ß´ç | | °Ñ | 2 |
| 18 | ¶ú»ú·ÖÅäÆ÷Ö§¼Ü | »î¶¯¶ú»ú·Å´óÆ÷Ö§¼Ü£¬¿É·Å±ê×¼£±£¹Ó¢´çÉ豸£¬Ç°ºó¿ÉÒÔ¶àÖֽṹ×éºÏ£¬ÃŰ壬ä°å¾ù¿ÉÄÚÖÃÍмܣ¬Íаå.°²×°·½±ã¿ì½Ý£¬ÍâÐÎÃÀ¹Û´ó·½£¬·½±ã¸÷ÖÖ±ê×¼ÒôÊÓÆµÉ豸µÄ°²×°µÈ¡£Ò²¿É¸ù¾ÝÄúµÄ½¨Òé½øÐÐϵÁÐÉè¼Æ Éú²ú¹¤ÒÕ£º²ÉÓùúÄÚÏȽøÊý¿ØÉ豸£¬¾¼ôÇУ¬³åѹ£¬ÕÛÍ䣬º¸½ÓµÈ¼Ó¹¤¹ý³Ì£¬×îºó¾²µçÅçËÜ£®¼Ó¹¤²ÄÁÏ£ºÈ«²¿²ÉÓÃÓÅÖÊÀäÔþ£Á£³¸Ö°å£»Ö÷¿ò¼ÜȫΪ 2.0mm ÓÅÖÊÀäÔþ¸Ö°å£¬ÆäËü×°ÊμþΪ 1.2 mm ÓÅÖÊÀäÔþ¸Ö°å.ľ֯²¿·Ö£ºÓÅÖʸßÃܶȰå²Ä | | ¸ö | 1 |
| 19 | Æ×¼Ü | ¹ÜÏÒÀÖÖаåÆÕ¼Ü | | ¸ö | 2 |
| 20 | Ïß²Ä | ±¾ÏµÍ³×¨ÓÃÏß²Ä | | Åú | 1 |
