Initial Audio Slice v1.1.6 Incl Keygen WiN/OSX-R2R LoopÇÐÆ¬Æ÷
Sector ²¨±íºÏ³ÉÆ÷²å¼þµÄ¿ª·¢ÉÌÓÖÍÆ³öÁËвå¼þ¡£Õâ´Î²»ÊÇÐÂºÏ³ÉÆ÷£¬¶øÊÇÒ»¸ö¹¤¾ß£¬Äã¿ÉÒÔÓÃËüÀ´´¦Àí¡¢ÇÐÆ¬ºÍ×éÖ¯²ÉÑù¡£
Slice ÊÇÒ»¿îÐ嵀 Loop ÇÐÆ¬Æ÷¡¢²ÉÑùÆ÷²å¼þ£¬ÊÊÓÃÓÚ macOS ºÍ Windows¡£
Initial Audio Slice
Slice ÊÇÒ»¿î²ÉÑù»Ø·Å¡¢loop ÇÐÆ¬¼æ½ÚÅÄÖÆ×÷²å¼þ¡£²ÉÑù¿ÉÒÔÇáËÉͨ¹ýÍÏ·ÅÔڸòå¼þÖмÓÔØ¡£ÔÚÕâÀÄã¿ÉÒÔÇÐÆ¬¡¢Ñ­»·¡¢·´Ïò¡¢±ä»»Òô¸ß»òÕß½øÐÐʱ¼äÉìËõ¡£²ÉÑù¿ÉÒÔͨ¹ý DAW »òʹÓÃÄÚÖõÄÒôÐòÆ÷/¸ÖÇÙ¾íÖá½øÐд¥·¢¡£ËùÒÔÄã¿ÉÒÔÖ±½ÓÔÚÆäÖд´½¨ÒôÐò¡£
¸Ã¿ª·¢ÉÌ»¹ÄÚÖÃÁËÒ»¸ö¸ß¼¶¹ÄÒôÐòÆ÷¡¢±´Ë¹ÒôÐòÆ÷ºÍ²¥·ÅÁбí±à¼­Æ÷¡£´ËÍ⣬Äã¿ÉÒÔÓà 4 ¸öЧ¹û»ú¼ÜÀ´ÍêÉÆÉùÒô£¬Ã¿¸ö¶¼´øÓÐ 11 ¸öÄÚÖÃЧ¹û¡£Slice ´øÓг¬¹ý 300 ¸öÃâ°æË°Ô­³§²ÉÑù£¬°üÀ¨Ò»Ð©³õʼµÄ½ÚÅÄºÍ¹Ä Pattern¡£
·Ç³£·½±ãµÄÊÇ£¬Äã¿ÉÒÔÔÚ²å¼þÖд´½¨×Ô¼ºµÄ¿â¡¢¹Ä Pattern£¬ÒÔ¼°½ÚÅÄ£¬²¢½øÐÐÏúÊÛ¡£Slice »á½«ÄãʹÓõÄËùÓвÉÑùºÍ¹ÄÉù±£´æµ½ÏîÄ¿ÎļþÖУ¬Óû§²»±Ø´¦ÀíÎļþºÍÎļþ¼Ð£¬Ö»Ðèͨ¹ýÍϷžͿÉÒÔ¼ÓÔØÐÂÄÚÈÝ¡£
ÊÔÌýÊÓÆµ
Initial Slice is a loop slicer and beat making plugin. Load audio loops via drag and drop to slice, loop, reverse, pitch shift or even time stretch them. Initial Slice also comes with multiple built in piano rolls so you can create sequences right in the box. On top of this we have an advanced drum sequencer, bass sequencer, playlist editor, 4 effect racks (each with 11 built in effects) and lots of top quality content.
Producers from all across the globe came together to built a massive library of over 300 melodic trap, hiphop, drill and rnb loops, drum patterns and beat starters.
Over 300 royalty free factory samples including beatstarters and drum patterns.
Main Editor which lets you slice, timestretch, pitchshift, loop, reverse and gate your samples.
3 effect racks and 1 master rack
Built in Slice sequencer allowing you to program slice patterns
Built in advanced Drum Sequencer
Built in Bass Sequencer / Sample Player
Built in Playlist allowing you to create quick arrangements
Built in Sample Library allowing you to access your drum kits and sample packs in the box
home page
https://initialaudio.com/product/slice-loop-slicer-plugin/
