BBE Sound Sonic Sweet 4.3.0 WiN Ч¹ûÆ÷
BBE Sonic Sweet¡°ÓÅ»¯¡±ÊǶÔԭʼ¡°Sonic Sweet¡±²å¼þ°üÖаüº¬µÄ²å¼þµÄÍêÈ«ÖØÐ´¡£Ö¼ÔÚÈÃÄúµÄ»ìÒô¸üÇåÎú¡¢¸üÏìÁÁ£¬¾ÍÏñËüµÄǰÉíÒ»Ñù£¬ËüΪ¸ÃϵÁÐÌí¼ÓÁËÒ»¸öеĵÚËĸö²å¼þ£¬¼´ Mach 3 Bass¡£À¦°ó°üµÄºËÐÄÈÔÈ»ÊÇ BBE ÖøÃûµÄ Sonic Maximiser Ó²¼þϵÁеÄÈí¼þ°æ±¾£¬ÕâÊÇ¶ÔÆäרÓд¦Àí¼¼ÊõµÄÄ£Ä⣬ΪÉùÒôÔöÇ¿É趨ÁË»ù×¼¡£×Ô 80 Äê´úÊ×´ÎÍÆ³ö BBE Sound רҵÒôƵ´¦ÀíÆ÷ÒÔÀ´£¬ÊÀ½çÖªÃûÒôÀÖ¼Ò¾ÍÒ»Ö±¼á³ÖʹÓà BBE Sound רҵÒôƵ´¦ÀíÆ÷¡£
BBE µÄ Sonic Sweet ¡°Optimised¡± ½«Ôö¼Ó¶¥¶ËµÄÇåÎú¶ÈºÍµ×²¿µÄÖ¬·¾£¬¾ÍÏñËûÃÇÖøÃûµÄÓ²¼þ´¦ÀíÆ÷ûÓдó¶àÊýÆäËûÉùÒôÔöÇ¿Æ÷³£¼ûµÄ¡°Ë»Ë»Éù¡±»òÊý×Ö¡°Ë»Ë»Éù¡±Ò»Ñù¡£Õâ¸öеġ°ÓÅ»¯¡±°æ±¾´øÀ´µÄ¸Ä½øÀ©Õ¹µ½Ò»¸öеÄÓÅ»¯ GUI ºÍ¸Ä½øµÄ¿ØÖÆÀ´Î¢µ÷ÄãµÄÉùÒô¡£
D82 ÊÇ×îÐ嵀 Sonic Maximizer Ó¦ÓóÌÐò£¬ËüÊÇÒ»¸öÒ×ÓÚʹÓõIJå¼þ£¬¿É»Ö¸´ÉùÒôͼÏñµÄ×ÔÈ»ÇåÎú¶ÈºÍÉî¶È¡£
¿ØÖÆ£º
Lo Contour ¨C µ÷½ÚÏàλ²¹³¥Á¿
µÍƵ
¹ý³Ì ¨C µ÷½ÚÏàλ²¹³¥¸ßµÄÁ¿
ƵÂÊÊä³ö
µçƽ ¨C ½«Êä³öµçƽ´Ó -12dB µ÷Õûµ½ +12dB
H82 г²¨×î´ó»¯Æ÷ÊÇÒ»ÖÖ¶àÆµ¶ÎÔöÇ¿Æ÷£¬¿ÉÉú³Éг²¨ÒÔÔöǿƵÂÊ£¬´ÓµÍ¶Ë³å»÷µ½¸ß¶Ë˻˻Éù¡£
¿ØÖÆ£º
Lo Tune ¨C Ñ¡ÔñµÍƵ·¶Î§ÒÔÔöǿг²¨
Lo Mix ¨C µ÷Õûг²¨ÔöÇ¿µÄ¼¶±ð
Hi Tune ¨C Ñ¡Ôñ¸ßƵ·¶Î§ÒÔÔöǿг²¨
Hi Mix ¨C µ÷Õûг²¨ÔöÇ¿µÄ¼¶±ð
Êä³öµçƽ ¨C ½«Êä³öµçƽ´Ó -12dB µ÷Õûµ½ 0dB
L82 Loudness Maximizer ÊÇÒ»ÖÖÓÐЧ¡¢Ò×ÓÚʹÓõÄĸ´ø/¶¯Ì¬ÏÞÖÆÆ÷£¬¿ÉÒÔʹÒô¹ì±äºñ£¬ÒÔ»ñµÃÓÅÃÀ¡¢×¨ÒµµÄ¸Ð¾õ¡£
¿ØÖÆ£º
ÁéÃô¶È ¨C ´Ó 0dB µ½ -30dB µ÷ÕûÊäÈëÁéÃô¶Èˮƽ
ÊÍ·Å ¨C ´Ó 0-100 ºÁÃëµ÷ÕûÊÍ·Åʱ¼ä
ƽ̨£ºWiN64 ¨C VST/VST3/AAX
The BBE Sonic Sweet ¡°Optimised¡± is a complete rewrite of the plug-ins included in the original ¡°Sonic Sweet¡± plug-ins bundle. Designed to make your mixes clearer and louder like its forerunner, it adds a new fourth plug-in to the collection, the Mach 3 Bass. At the heart of the bundle there is still the software version of BBE¡¯s famous Sonic Maximiser hardware range, which is an emulation of their exclusive processing technologies that has set the benchmark for sound enhancement. World-renowned musicians have insisted upon using BBE Sound professional audio processors since they were first introduced in the ¡¯80s.
BBE¡¯s Sonic Sweet ¡°Optimised¡± will add clarity to the top end and fatness to the bottom, just like their famous hardware processors do without the ¡°fizz¡± or digital ¡°sizzle¡± common to most other sonic enhancers. The refinements brought by this new ¡°Optimised¡± version extends to a new optimised GUI and improved controls for fine-tuning your sound.
The D82 is the latest Sonic Maximizer application in a easy-to-use plug-in that restores natural clarity and depth to the sound image.
Controls:
Lo Contour ¨C regulates the amount of phase-compensated
low frequencies
Process ¨C regulates the amount of phase-compensated high
frequencies Output
Level ¨C adjusts output level from -12dB to +12dB
The H82 Harmonic Maximizer is a Multi-band enhancer that generates harmonics for adding emphasis to frequencies, from low-end punch to top-end sizzle.
Controls:
Lo Tune ¨C selects range of low frequencies for harmonic enhancement
Lo Mix ¨C adjusts level of harmonic enhancement
Hi Tune ¨C selects range of high frequencies for harmonic enhancement
Hi Mix ¨C adjusts level of harmonic enhancement
Output Level ¨C adjust output level from -12dB to 0dB
The L82 Loudness Maximizer is an effective, easy-to-use Mastering/Dynamics Limiter that fattens up tracks for a polished, professional feel.
Controls:
Sensitivity ¨C adjusts input sensitivity level from 0dB to -30dB
Release ¨C adjusts release time from 0-100ms
Output Level ¨C adjusts output level from -12dB to 0dB
Platform: WiN64 ¨C VST/VST3/AAX
https://filecr.com/windows/bbe-sound-sonic-sweet/?id=177822817992
