TBProAudio CS5501 v2.1.4 WiN ͨµÀÌõ²å¼þ
CS-5501 ÊÇÒ»¸öͨµÀÌõ²å¼þ£¬´øÓÐË«¾ùºâÆ÷¡¢ÃÅÏÞ/À©Õ¹Æ÷¡¢deesser ѹËõÆ÷¡¢ÏÞÖÆÆ÷ºÍ±¥ºÍ¡¢Áé»îµÄÄ£¿é·Óɺ͹ý²ÉÑù¡£CS-5501 ÊǷdz£³É¹¦µÄ CS-3301 µÄ¼Ì³ÐÕß¡£Ëü±£³ÖÁË CS-3301 µÄÁ÷³©ÉùÒô£¬²¢ÔÚËùÓиú×ٺͻìÒôÇé¿öÏÂÌṩÁ˸ü´óµÄÁé»îÐÔ¡£
ÌØÐÔ
2x 7 Ƶ¶Î¾ùºâÆ÷
2x ÔëÉùÃÅ/À©Õ¹Æ÷
2x ѹËõÆ÷£¬VCA/FET/OPTP Éè¼Æ
2x ÐÞÕûÆ÷
2x ÏÞÖÆÆ÷
±¥ºÍ
ÈÈÔëÉù£¬ÓÃÓÚÄ£ÄâÉùÒô·ÂÕæ
EQ ÈÝÏÞÄ£Äâ
HQ ¹ý²ÉÑù
ÐźŹý³å±£»¤ ¿É
Á´½ÓµÄÊäÈë/Êä³öÍÆ×Ó£¬°üÀ¨·´Ïà
Ä£¿é²ÎÊýÁ´½Ó
À©Õ¹¼ÆÁ¿¡¢ÊäÈë/Êä³ö/ÔöÒæ½µµÍ¡¢·åÖµ¡¢RMS¡¢EBU ºÍ VU
¸ÐÖªÏì¶ÈÆ¥Å䣨ÓÉ AB-LM Lite Ìṩ֧³Ö£©
Ä£¿é·ÓÉ
¹ã·ºµÄ²àÁ´Ö§³ÖÐí¶àЧ¹ûÄ£¿é
Ðí¶àÊæÊʹ¦ÄÜ£¬Èç¶À×àºÍÐÅºÅ¼à¿Ø
Ô¤Éè¹ÜÀí
²ÎÊýrandomizer
¿ÉÑ¡ÑÕÉ«Ö÷Ìâ
´óÇÒÒ×ÓÚʹÓà GUI
Ãâ·Ñ GUI Ëõ·Å
64 λÄÚ²¿´¦Àí
·Ç³£¸ßЧµÄ CPU ʹÓÃÉè¼Æ
¸ü¸ÄÈÕÖ¾£º
2.1.4£º
¨C FIX£ºFET ²¹³¥±È£¨ÄÚ²¿¸º±È£©
2.1.3£º
¨C УºÇ¿ÖƵ¥ÉùµÀģʽ£¬½ö×óÉùµÀ´¦Àí
ָʾ£º
ʹÓò¹¶¡Îļþ°²×°ºÍÌæ»» dll/vst3£¬Ê¹Óðüº¬µÄÃÜÔ¿¼¤»î
CS-5501 is a channel strip plugin with double EQ, gate/expander, deesser compressor, limiter and saturation, flexible module routing and oversampling. CS-5501 is the sucessor of the very sucessfull CS-3301. It keeps the smooth sound of CS-3301 and provides much more flexibility in all tracking and mixing situations.
Features
2x 7 band EQ
2x noise gate/expander
2x compressor, VCA/FET/OPTP design
2x dresser
2x limiter
saturation
thermal noise for analogue sound emulation
EQ tolerance simulation
HQ over sampling
signal overshot protection
link-able input/output fader including phase inversion
module parameter link
extended metering, input/output/gain reduction, Peak, RMS, EBU and VU
perceptual loudness matching (powered by AB-LM Lite)
module routing
extensive side-chain support for many effect modules
many comfort functions like soloing and signal monitoring
preset management
parameter randomizer
selectable color theme
large and easy to use GUI
free GUI scaling
64-bit internal processing
very efficient CPU usage design
Changelog:
2.1.4:
¨C FIX: FET comp ratio (internal negative ratio)
2.1.3:
¨C NEW: force mono mode, only left channel processing
Instructions:
install & replace dll/vst3 with patched files, activate with included key
https://audioz.uproxy.co/software/win/197840-download_tbproaudio-cs5501-v214-win.html
