Reason Studios Reason v11.3.9 WIN
Reason 11 Ôö¼ÓÁËÒ»¸ö½Ð×öBeat Map Algorhythmic DrummerµÄ½Ú×àͼËã·¨¹Ä»ú£¬Í¬Ê±ÎªReason Rack Plugin¼ÓÈëÁË´ó¼ÒÆÚ´ýÒѾõÄMIDI OutÊä³öÉ豸¶øÇÒ¿ÉÒÔ¿ÉÒÔ´ÓÉ豸ÀïÖ±½ÓÍÏ×§Éú³ÉµÄÐýÂɵ½ÄãµÄDAWÈí¼þÀïʹÓá£
ÓÐÁËMIDI OutÊä³öÉ豸µÄReason Rack Plugin£¬¾Í¿ÉÒÔ½«ÔÚReason Rack PluginÀï´´½¨µÄÃÀÃîµÄºÍÉù¡¢½Ú×à¡¢ÐýÂÉÉõÖÁÊÇÉú³ÉµÄCVÐźÅÖ±½ÓÊä³ö¸øDAWÀ´Óã¬À´Çý¶¯DAWÀï¼ÓÔØµÄÆäËü²å¼þ¡£
¹Û¿´MIDI OutÊä³öÉ豸ÈçºÎ´îÅäDAWÈí¼þÍæ³ö¸÷ÖÖ»¨Ñù
ÊÔÌýÊÓÆµ
Reason 11Ö÷ÒªµÄÐÂÌØÐÔ£º
Ö»ÓÐReason Suite¿ÉÒÔ»ñµÃBeat Map Algorhythmic DrummerÕâ¸öеÄRack Extension£¬ÕâÊÇÒ»¸ö¿ÉÒÔ´´Ôì³ö´ò»÷ÀÖpatternµÄ²¥·ÅÆ÷£¬ÄÚÖÃÁ˸÷ÖÖ½Ú×à¡¢Ëã·¨£¬Ê¹Óüòµ¥µ«ÓÐ×ÅÇ¿´óµÄ¿ØÖÆÁ¦¡£Í¨³£¿ÉÒÔ¸úKong¡¢Rytmik»òUmpfÕâÖÖ¹ÄÀÖÆ÷´îÅäʹÓ㬵«Ò²¿ÉÒÔ´îÅäÐýÂÉÀÖÆ÷»ñµÃÆæÃîµÄ½á¹û
Reason Rack PluginÐÂÔöMIDI OutÉ豸£¬ÈÃÄã¿ÉÒÔ´ÓReason Rack PluginÀï·¢ËÍMIDIÒô·ûºÍMIDI CC¿ØÖÆÐÅÏ¢µ½ÄãµÄDAWÀ´Óã¬Ä㻹¿ÉÒÔ·¢ËÍ8¸öCVÐźųöÀ´½«ËüÃÇ·Ö±ð·¢Ë͸ø²»Í¬µÄMIDI CC¿ØÖÆÐÅÏ¢
¿ÉÒÔ½«Redrum¡¢Dr. Octo RexºÍMatrixÀïµÄÐýÂÉÐÅÏ¢ÍÏ×§µ½DAWÀïÉú³ÉMIDIÐÅÏ¢Ö±½ÓʹÓÃ
ÐÞ¸´bug
Reason 11×î´óµÄ¸Ä½øÄª¹ýÓÚReason Rack PluginÖÕÓÚ¿ÉÒÔÖ§³Ö×÷ΪAU²å¼þÔËÐÐÔÚmacOSϵͳϵÄÈκÎDAWÈí¼þÀïÁË£¬±ÈÈçLogic Pro¡£
ÁíÍâReason 11³ýÁËÐÞ¸´bugÒÔÍ⣬ҲÍêȫ֧³ÖmacOS CatalinaϵͳÁË¡£¸üÀ÷º¦µÄÊÇ£¬ÏÖÔÚÔÚReason Rack Plugin²å¼þÀïÒ²¿ÉÒÔÓÃTAB¼üÀ´Çл»»ú¼ÜÕý·´ÃæµÄÏÔʾÁË£¬¸úÔÚReasonÀïһģһÑùÁË£¡
Reason 11×î´óµÄ±ä»¯Äª¹ýÓÚ´ó¼Ò֮ǰ²Â²âµÄÄÇÑù£¬¾ÍÊÇReason½«×Ô¼ºµÄºËÐÄ»ú¼ÜºÍRack ExtensionÀ©Õ¹ÏµÍ³¶¼×ö³ÉÁËÒ»¸öVST 3²å¼þ£¬¿ÉÒÔÈÃÈκÎDAWÓû§ÏíÊܵ½ÔÚReasonÐéÄâ»ú¼Ü±³Ãæ½ÓÏߵĿì¸Ð¡£
Reason Rack Plugin£º
Reason½«×Ô¼ºµÄºËÐÄ»ú¼ÜºÍRack ExtensionÀ©Õ¹ÏµÍ³¶¼×ö³ÉÁËÒ»¸öVST 3²å¼þ£¬Õâ¸ö¾ÍÊÇReason Rack Plugin¡£Ëü¿ÉÒÔÈÃÈκÎDAWÓû§ÏíÊܵ½ÔÚReasonÐéÄâ»ú¼Ü±³Ãæ½ÓÏߵĿì¸Ð¡£
Reason 11°´ÕÕÍê±ÏÖ®ºó£¬Ä㽫¿´µ½Á½¸öвå¼þ£ºRason Rack PluginÐéÄâÀÖÆ÷ºÍReason Rack Plugin EffectsÐéÄâЧ¹ûÆ÷¡£´ò¿ªÖ®ºó½«ÊÇÒ»¸ö¿Õ°×µÄ»ú¼Ü£¬È»ºóÄã¿ÉÒÔËæÒâµÄ¿ªÊ¼ÍæÁË¡£
Õâ¸ö¿Õ»ú¼Ü¾ß±¸ÉèÖÃÊäÈë/Êä³öÒôƵͨµÀ¡¢MIDI¡¢ÅÔÁ´µÄ¹¦ÄÜ£¬Ò²ÓÐundoºÍredo£¬µ±È»Ò²±ØÐë¿ÉÒԷתµ½É豸±³ºóÀ´Á¬Ïß¡£
Reason Rack Plugin½«ÔÚ9ÔÂ25ÈÕËæReason 11Ò»Æðµ½À´£¬ReasonÈý¸ö°æ±¾µÄÓû§¶¼¿ÉʹÓá£Ä¿Ç°»¹Ã»Óе¥¶À·¢Ê۵ļƻ®£¬µ«ÎÒ¹À¼Æ²»¾ÃÖ®ºóÈðµäÈË»áÕâô×öµÄ¡£
Reason 11ÐÂÉ豸£º
³ýÁ˼¤¶¯ÈËÐĵÄReason Rack PluginÒÔÍ⣬Reason 11»¹ÐÂÔöÁËһЩĬÈϵÄлú¼ÜÉ豸£º
Sweeper Modulation Effect£¨ÉÏͼ£©£ºÒÆÏà¡¢Ïâ±ß¡¢Â˲¨µÈ¶¯Ì¬µ÷ÖÆÐ§¹û£¬ÉõÖÁÓÐ40¶ÎµÄÒÆÏࣨ´ó¶àÊýÒÆÏà¶¼ÊÇ2¶Î»ò4¶ÎµÄ£©
Quartet Chorus Ensemble£º´Ó¾µäµÄÄ£ÄâºÏ³ª£¬µ½¶ÀÌØµÄÉùÒôÁ£×ÓЧ¹û¶¼¿ÉÒÔ×öµ½
Master Bus Compressor£ºÄ¸´ø¼¶×ÜÏßѹËõÆ÷
Channel Dynamics£º¹¤×÷ÊÒ¼¶±ðµÄѹËõ¡¢À©Õ¹¡¢ÃÅÏÞ
Channel EQ£º´Ó¾µäÉ豸½¨Ä£µÄͨµÀÌõ¾ùºâ
Reason 11ÆäËü¸Ä½ø£º
Automation×Ô¶¯»¯ÇúÏß¿ÉÒÔÕæµÄ×öÇúÏßÁË
Á½¸öÖØµþµÄÒôÆµËØ²Ä½«¿É×ö×Ô¶¯½»²æµ»¯
ÿ¸öÒô¹ìµÄ×ÝÏòËõ·Å±ÈÀý¿ÉÒÔ²»Í¬ÁË
¿ÉÒÔ¾²Òôµ¥¶ÀµÄijһ¸öMIDIÒô·û
¿ÉÒÔÒ»´ÎÐÔ²åÈë¶à¸öÒ»×éµÄMIDIÒô·û
¿ÉÒÔͨ¹ý¸ÖÇÙ¾íÁ±´°ÏÔʾ³öÕýÔÚ²¥·ÅµÄ»òÑ¡ÖеÄÒô·û
The Reason Studios Reason 11 is the 2019 release of the ever popular Digital Audio Workstation from the former Propellerhead Software. This Audio Creation/Editing program has a powerful processing engine, a host of Instruments and Effects and is presented in 3x versions (Intro, Standard and Suite), making Reason 11 an excellent choice regardless of the user¡¯s needs.
Alongside the stand-alone DAW, Reason 11 can optionally be used as the Reason Rack Plug-In, a VST3 Plug-In format which allows for the use of Reason in other Digital Audio Workstations. This can make the transition to Reason a far more painless process for those familiar with different software.
Reason 11 is the industry standard edition of the lauded software. Included with the package is a generous compliment of Synthesizer sounds, sampled Instruments, Drum Kits, Loops and Effects which empower users to create professional Audio projects in a powerful Virtual Studio. Editing Audio and MIDI automation has received an update, speeding up workflow with a more intuitive response. The rock-solid Recording and Mixing options are retained from previous iterations, now augmented with a series of workflow improvements and new Devices.
Workflow Improvements
Curved Automation: Improved automation curves with ¡°smoother¡± movement and implementation.
Audio Clip Crossfades: Adjacent audio clips can now be seamlessly crossfaded with a simple mouse action.
Improved and Individual Vertical Zoom: Enjoy complete control over your view of waveforms on-screen.
Mute MIDI Notes: Easily mute/unmute individual MIDI notes to add variation to recordings and try things out without having to change position or delete the note itself.
New Pen Tool: Write multiple notes to your regions in real time. This is especially useful for drum programming.
Played/Selected Notes Now Shown in Key Edit.
Additional Workflow Improvements: Absolute snap function, drawing of automation points at the same volume, shortcut for MIDI notes shifting by one octave. |
