µçÈÝ»°Í²
3 }- Y a9 J/ m2 g& N) V4 v/ b
TM-80) y7 I2 A7 D: c A/ I
& N5 K* e; @3 ], \; j( P
' `6 O; l& w% W. l! C0 X- t9 g z
" k# @9 n; `+ G3 j7 L& |
TM-80ÊÇרΪ¼Òͥ¼Òô¶øÉè¼ÆºÍ¶¨¼ÛµÄ´óÕñĤµçÈÝ»°Í²¡£ËüµÄÌØµãÊÇÒ»¸ö18ºÁÃ×´¿ÂÁÕñĤµÄÐÄÐÎÖ¸ÏòʰÒôÆ÷£¬·Ç³£ÊʺÏÂ¼ÖÆÈËÉùºÍÉùѧÀÖÆ÷¡£»°Í²ÄÚ²¿µç·ͨ¹ý¾«ÃܵÄÉè¼Æ´ïµ½ÍêÃÀµÄʰÒôЧ¹û£¬ÔÚ¼õÉÙÔëÒôºÍÊ§ÕæµÄͬʱÓÖÄܱ£³Ö·á¸»¡¢±¥ÂúµÄÒôÖÊ¡£; z/ T4 I8 I( J! O3 o
( |% b3 H# V$ K8 r! X# _* Z3 Y
+ ?* X1 X f( F, m; L5 [ B5 G9 N& U
" R" P" J6 ^/ }* M# ~: \2 N
TM-80ÓÐ×Å20Hz-20kHz¿í¹ãµÄƵÂÊÏìÓ¦ºÍ¸ß´ï136dB SPL×î´óÉùѹ¼¶£¬Äã¿ÉÒÔ·ÅÐĴ󵨵ØÓ뼪Ëû·Å´óÆ÷¡¢¹ÄºÍÆäËûÏìÁÁµÄÀÖÆ÷Ò»ÆðʹÓá£
1 l3 X" [) H% e
# a8 e, x# k" `8 I l7 b1 O$ b# y( e; j& b1 z* r
/ k. P) R2 {& Q: L' `' E
TM-80¸½Ë͵ÄÐü¹Òʽ·ÀÕð¼ÜÄܼõÉÙ¼Òô¹ý³ÌÖеÄ¡¡ÉùºÍÔëÒô¡£6 N0 L% n9 E! m( ^7 Q1 n m9 I
) }" H1 S, N7 t S$ z
/ J- j' I5 k/ U6 D
2 s R) ]" `& R3 p7 e+ |: j/ C" w
" T1 A2 e* V2 H% \5 HÌØµãºÍ¹æ¸ñ£º
$ a7 l* Z, u- V; z
. {" L; B. b$ [% z8 |, S18ºÁÃ×´¿ÂÁÕñĤ
* G. |0 |8 _ f4 M/ T2 |
; A. y7 \. v+ c8 r²ÉÓþ«È·Éè¼ÆµÄµç×Óµç·- h2 I/ A, T0 E: u2 w% V6 k ]
1 w x j0 K! [; W4 e
Íâ¿Ç²ÉÓÃѹÖýп²ÄÁÏ" Y' k l! e* G% d W6 x
: O$ ~6 H( D' E; y% d5 d# b7 }
´«ÉùÆ÷ÀàÐÍ£ºµçÈÝ' W5 [ O3 [7 R
2 T& W6 E9 R: n! x6 U- c
Ö¸ÏòÐÔ£ºÐÄÐÍ8 S& u6 @1 l1 \7 w+ x
# p: K% M# @8 U5 M6 @. P
»ÃÏóµçÔ´£º9-48V- T/ v& b# O% }8 U3 i9 W1 ^
. \( W1 t- ?" z- D4 IƵÂÊÏìÓ¦£º20Hz-20kHz: U( T( j @9 ]( _8 p! H) f- U
( R+ o# B9 d2 c( C1 |% I: J2 PÁéÃô¶È£º-38dB ¡À2dB (0dB=1V/Pa @1kHz)1 w; E1 ?) X9 H% W6 R& R
. e& B' o* W/ x# B1 G. `0 \6 F
Êä³ö×迹£º200¦¸ ¡À30% (1kHz)0 l5 w5 O* l) f- }6 K" V4 [
/ B" d& s2 n2 X5 l& o" ^
×î´óSPL£º136dB£¨1% THD @1kHz£©
+ S" c; P6 T: c" c* V' z$ m5 x2 |5 t, b* [% z' l! x
ÐÅÔë±È£º77dB
" @3 t8 q! S5 D6 o4 F
/ B `8 o d* y³ß´ç(¿í¡Á¸ß¡ÁÉî)£º48mm¡Á165mm¡Á48mm+ ]8 `. ~7 r' r1 }2 E# Y3 x9 m B/ Z
. T9 x: d* T3 Q" {ÖØÁ¿£º300g3 _, D, T* a. U) m
! E! V) m/ w. J) R
* s! T& t" l! ?# ? Z# D. U
4 g3 W* Z5 |$ E- T3 o: T; h1 K7 T0 W
: K" i" _% D* s8 f1 T& V! U
, b, u$ d9 y$ N# E
" `/ C4 N' b0 @( N) K
TM-200SG
$ H- G9 u! V( {7 \" t7 G2 M
9 a2 o( P3 j6 f0 r- E9 o& [, D! k* J
* a6 T p7 u# j
9 r% _) S9 |6 u' N2 }
) c& q- Y2 x1 r4 u, e' G1 h/ }. T( K
; a/ k# B5 O8 E2 e& `* X1 M* L, S* a& O! x
TM-200SGÊÇÒ»¿îÒ×ÓÚ²Ù×÷µÄ¶Ìǹ»°Í²£¬¾ßÓи߶ȶ¨ÏòµÄǿָÏòÐÔ£¬·Ç³£ÊÊÓÃÓÚµçÓ°ÅÄÉã¡¢ÊÓÆµ²©¿Í»òÐÂÎű¨µÀ¡£ËüÅ䱸µÄ»°Í²¼Ð£¬¿ÉÒÔ°²×°ÔÚÈκδøÓÐÈÈÑ¥µÄÏà»úÉÏ£¬³¬ÐÄÐÎģʽÄÜÔÚ»°Í²Ö¸ÏòµÄ·½ÏòÉϲ¶×½ÉùÒô£¬Óë´Ëͬʱ×î´ó³Ì¶È¾Ü¾ø»·¾³ÔëÒôºÍ»ìÏ죺Ëü»áÔÚÄãµÄÏà»úǰʰȡÅÄÉã¶ÔÏóµÄÉùÒô£¬¼õÉÙÀ´×Ô½»Í¨¡¢³åÀË¡¢»ØÉùºÍÆäËû¸ÉÈŵÄÔëÒô£¬ÓÐÖúÓÚ¸ÄÉÆÊ¹ÓÃDSLRµ¥·´»òÆäËûÏà»ú´´½¨µÄÈκÎÊÓÆµÂ¼ÖƵÄÉùÒô¡£, ^/ [/ h/ p, Y$ p8 |' h
- c- d& @; ~& n+ |3 B& m1 D
$ H: z% h6 q7 @. t' `
' W( v! @( S" K3 w
TM-200SG¸½ËÍÁ˺£Ãà·À·çÕÖÒÔ½µµÍ·çÔëÉù£¬Í¬Ê±»¹ÄÚÖÃÁ˵ÍÇÐÂ˲¨Æ÷£¬¿É½øÒ»²½½µµÍ·çÉùºÍ»·¾³ÔëÒô£¬ÖØÁ¿Çá¡¢Ìå»ýСȴÄÜʵÏÖ¸ßÒôƵÖÊÁ¿£¬ÊÇÉãÏñʦÔÚÏÖ³¡Â¼ÖÆÒôƵµÄºÃ´îµµ¡£: r7 V3 S2 z$ Q
M! y* c `' z X' p( J, k
* Z- }- O' Z6 M3 ?' n4 cÌØµãºÍ¹æ¸ñ£º
u2 R9 x4 u- a9 v4 F: o. B0 q* M5 E, H
½ô´ÕÇá±ãµÄÉè¼Æ£¬Ò×ÓÚ²Ù×÷
# C& u; s; F- @% M" _/ x- S. H7 p5 @. T: T
³¬ÐÄÐÎÖ¸ÏòÐÔÈ·±£ÔÚ»§ÍâʹÓû·¾³ÏÂʰÒôµÄ¸ßÖÊÁ¿
; K3 s3 Q! ~# x, G5 ~4 a3 X' {* H. V4 A
ʹÓñê×¼³ß´çµÄÈÈÑ¥×ù°²×°µ½Ïà»ú8 C7 A. \4 w- R3 p/ F. j6 e
, y0 {* [; E: p´«ÉùÆ÷ÀàÐÍ£ººó¼¶Ê½×¤ÌåµçÈÝ»°Í²6 m4 d& O8 d, d+ s ^6 O
9 P' r5 ]4 H+ Z8 G1 F( U, l5 UÖ¸ÏòÐÔ£º³¬ÐÄÐÍ; ]4 `3 V- H- _" P1 n8 j
* y) c, y! Q$ z0 X& Q1 S3 S
»ÃÏóµçÔ´£º48V
' w" X1 _& A# p; p* R7 O1 s( U. W0 r1 B( X
ƵÂÊÏìÓ¦£º30Hz-20kHz3 Q: U, l: k# Y0 g: |
~: `: |/ P% C) x9 ^% vµÍÇÐÂ˲¨Æ÷£º160Hz,-3dB
" D; T a; k9 ]6 Q
1 N4 i4 j! @ x% Y$ e% JÁéÃô¶È£º¨C40dB ¡À3dB (0dB=1V/Pa @1kHz)' W" _- F: D& Y- q# q
2 S% t; N, {8 [6 J, U' @Êä³ö×迹£º200¦¸ ¡À30% (1kHz)5 b; t8 r6 l- c' i3 L! U4 u0 t9 X; i
3 W( N, ^5 h2 E: v) a×î´óSPL£º132dB£¨1% THD @1kHz£©- f# c7 H" [. l
3 U/ [7 c" |9 ~* `+ ^
ÐÅÔë±È£º74dB
0 O2 g$ ~* s' X0 q5 k9 v) {
8 z5 j6 y7 D' Z8 h1 i0 l, l³ß´ç(L¡ÁØ)£º153mm¡Á23mm3 Q' q9 O1 k, l
( j% l. {" m, l) I9 u1 Y4 ]1 Z4 Y0 ?ÖØÁ¿£º53g
; R/ ^4 G8 G+ X; O( B) |3 [: X6 m: O$ U4 [2 }3 I$ {( \
5 m7 O, |. {0 m9 A
( E, o: c8 D$ [. r, ?4 F$ }
4 y7 Q) @; [6 a/ n7 U7 Y( I" Q/ BTM-95GN
. t2 c( d$ {+ g! ]; n2 I4 P$ X+ k U g4 ^/ a8 r7 @7 _
6 I2 g* Y" a7 q* Y8 n6 g( }2 e& S7 @( Z
TM-95GNÊÇÒ»¿î¶ì¾±»°Í²£¬ÊÊÓÃÓÚ¸öÈ˹㲥¡¢»áÒé»òÆäËûÓïÒôÓ¦Óá£* Y" K B7 t# Y) ~
q: M! T \8 w0 t$ P
! c5 v0 G; n$ ^3 d
7 r, P: {1 n2 i6 o4 v
( g% A# b6 Q! s3 G- p, a# I ZTM-95GN»°Í²Ê¹ÓÃÁËÇáÐÍÕñĤµÄפ¼«ÌåµçÈÝ»°Í²µ¥Ôª£¬Äܹ»ÒÔ¸ßÆ·ÖʵÄÒôÖʽøÐÐʰÒô£¬²¢ÇÒÖ»ÄÜʰȡÀ´×ÔÆäÃæÏò·½ÏòµÄÉùÒô£¬¾Ý´ËÄã¿ÉÒÔÇáËɲ¶×½Ö÷³ÖÈ˵ÄÉùÒô£¬¶ø²»»á´øÈë±³¾°¸ÉÈÅÔëÒô¡£% W; Y6 p( X7 _
* s& V5 A7 s. B5 m
2 D* a9 X3 Z& ]
8 m8 s& o; t7 y1 F! W0 Q0 Z! RTM-95GN¶ì¾±»°Í²¸Ë³¤¶ÈԼΪ460mm£¬¶øÇÒÅ䱸ÁËÒ»¸öºñʵÎȶ¨µÄ½ðÊôµ××ù£¬ÕâÑù¿ÉÒÔµ¥ÊÖÇáËɰڶ¯µ½ÈÎÒâ½Ç¶È£¬²¢ÅäÖÃÓе¥¶ÀµÄON/OFF¿ª¹Ø£¬Äܷܺ½±ãµÄ´ò¿ªºÍ¹Ø±Õ»°Í²£¬ÔÚÎÞÈË˵»°Ê±¹Ø±Õ»°Í²¼´¿É·ÀÖ¹Â¼ÖÆÈκβ»±ØÒªµÄÔëÒô£»ÁíÍ⻹ÅäÖÃÁËÓзÀ·çÕÖÒÔ±ÜÃⱬÒô
0 A9 O" s, P3 A& W
% `! T2 R9 N6 S9 H- q
: ^( v, V, q: C( q$ B
0 i8 ?! f7 E- P; t; q9 R: X! M1 g' S5 ]) @
! Z) { e' D- Z- v+ a4 I' G' }9 |9 K& R
ÌØµãºÍ¹æ¸ñ£º
4 F* `/ O7 R& T! U9 f- W
% p3 P: `! s: H5 O3 x+ J0 O: |´«ÉùÆ÷ÀàÐÍ£ººó¼¶Ê½×¤¼«ÌåµçÈÝ»°Í²
( C- p) K _# U$ y7 Q0 y& I
8 S c9 V" B1 Y- `6 v5 XÖ¸ÏòÐÔ£ºµ¥Ö¸ÏòÐÔ. l8 z" b- ]! q3 g) p' _9 |
- C. B! B6 P' Y" R! S»ÃÏóµçÔ´£º48V
; B. U7 S" b$ H* |2 A$ y/ ` a3 l% F
8 W. a5 [9 K- qƵÂÊÏìÓ¦£º50Hz-16kHz. y( ^1 B2 `7 p# g) g4 m/ A. @. t2 c
1 k& g' n+ V* y
ÁéÃô¶È£º-39dB ¡À3dB (0dB=1V/Pa @1kHz)9 ^: q0 Q* e1 R0 \" \& n4 D
7 f* K2 @& A2 G! `/ {, S+ Y9 H8 K
Êä³ö×迹£º250¦¸ ¡À30%
5 X! ]% H/ W' @" l v. G) M+ n, \( R
Q9 i+ \& v6 q; D l" p- v³ß´ç(¿í¡Á¸ß¡ÁÉî)£º133mm¡Á458mm¡Á140mm& t; ~0 Y6 _ K" p
/ z& p+ @& u/ DÖØÁ¿£º970g |
