Zero-G Impromptu Electric Guitars KONTAKT µçÓ°¼ªËû
Ò»¸öÁîÈËÄÑÒÔÖÃÐŵŤ¾ß£¬ÓÃÓÚ´´½¨ÃÀÀöµÄ²»¶Ï·¢Õ¹µÄµçÓ°¼ªËû
Zero-G ¼´Ð˵缪ËûÊÇÒ»ÖÖµçÓ° Kontakt 6 ÀÖÆ÷£¬¾ßÓÐ 21 ¸öÒôÉ«ºÍ³¬¹ý 8GB µÄÑù±¾¡£ IEG ÖÂÁ¦ÓÚ´´½¨¸´ÔӵĻùÓÚ¼ªËûµÄ¡¢²»¶Ï·¢Õ¹µÄÒô¾°¡£
Èý°Ñ³öÉ«µÄ¼ªËû£¨°üÀ¨Ò»°Ñµç×ÓÄÐÖÐÒô£©ÒÔ 48kHz/24bit µÄƵÂʽøÐÐÁ˷dz£ÏêϸµÄ²ÉÑù£¬Ê¹ÓõçÈݺʹø×´Âó¿Ë·ç£¬²¢Í¨¹ý´óÁ¿¼ªËṳ̂°å½øÐÐÁË´¦Àí¡£
IEG µÄºËÐÄÊǼ´ÐËÒýÇæ£»Ò»¸öÀûÓü´Ð˵ġ¢Î´Í¬²½µÄƬ¶ÎÑ»·Óë¿ÅÁ£ºÏ³ÉÆ÷Ïà½áºÏµÄϵͳ¡£
ÎÒÃÇÔÚÈý¸ö²»Í¬µÄÇ¿¶È²ãÖÐÂ¼ÖÆÁ˼´Ð˱íÑÝ£¬Äú¿ÉÒÔʹÓÃĬÈÏÓ³Éäµ½µ÷ÖÆÂÖµÄÖÐÑëÐýÅ¥ÔÚËüÃÇÖ®¼ä½øÐеÈëµ³ö¡£
ÔÚµ÷ÖÆÂÖÍêÈ«°´ÏµÄÇé¿öÏÂÑÝ×àÒ»¸öÒô·û½«ÔÚ¸ÃÒô¸ßÉÏ´¥·¢Ï¡ÊèµÄ¼´ÐËÑ»·£»¿ªÊ¼Òƶ¯mod-
¹öÂÖÖð½¥µÈëµ³öµ½Öеȣ¬×îºóµ½Ãܼ¯²ã¡£
³ýÁËÇ¿¶ÈÖ®Í⣬»¹ÒÔ²»Í¬µÄ·½Ê½¶ÔÕâЩ²ã½øÐвÉÑù£ºÏ¡Êè²ãÊÇÓÃÊÖÖ¸µ¯×༪Ëû¼Ç¼µÄ£¬Öмä²ãÊÇÓÃÈáÈí¹â»¬µÄľ²¦Æ¬¼Ç¼µÄ£¬¶øÃܼ¯²ãÊÇÓúñºñµÄ²¦Æ¬¼Ç¼µÄ¡£ £¬Ó²ËÜÁÏÌô¡£
ÄÐÖÐÒô¸½¼Ó
Baritone Extras Îļþ¼Ð°üº¬Í¨¹ýһϵÁмªËṳ̂°å´¦ÀíÄÐÖÐÒôµç¼ªËû»ñµÃµÄÈýÖÖÀÖÆ÷¡£¶ÔÓÚÕâЩÀÖÆ÷£¬¿ÉÒÔʹÓà SFX ²¿·Ö¡£ÕâЩЧ¹û¿ÉÒÔÔÚãÅËøÄ£Ê½ÏÂʹÓúìÉ«¼ü´¥·¢¡£
µæ
Pads Îļþ¼Ð°üº¬ÎåÖÖרÃÅÓÃÓÚ´´½¨»ùÓÚ¼ªËûµÄÒô¾°µÄÀÖÆ÷¡£°üº¬Ò»¸ö¶àÐÎ×´µÄ LFO À´´´ÔìÉùÒôµÄÔ˶¯ºÍ±ä»¯£¬ÆäÇ¿¶È¿ÉÒÔͨ¹ý MOTION ÐýÅ¥¿ØÖÆ£¬
Ïò×ó»òÏòÓÒת¶¯ÐýÅ¥½«ÏàÓ¦µÄÐÎ×´Ìí¼Óµ½ LFO ·ù¶Èµ÷ÖÆ£¬´Ó¶ø´´½¨¸´ÔÓµÄÐÎ×´¡£
¾ØÐβ¨ÐξßÓÐÂö³å¿í¶È (PW) ¿ØÖÆ¡£ LFO ÓëÖ÷»úͬ²½£¬ÆäƵÂÊ¿ÉÒԸıä (FREQ)¡£
ÁãÖØÁ¦¼´Ð˵缪Ëû KONTAKT ÆÁÄ»½ØÍ¼EXTRA INSTRUMENTS
¨C Îļþ¼Ð Reverse Sync °üº¬ 4 ¸öºÍ 8 ¸öС½Ú£¬ËÙ¶Èͬ²½µÄ·´ÏòÑù±¾£¬¿ÉÓÃ×÷ÒôÀÖÖеÄÉÏÉýÆ÷ºÍ¹ý¶É¡£
¨C Îļþ¼Ð Strat Extras °üº¬µ¥¸ö Harmonics ²¦Æ¬ºÍÒ»¸ö Strat Plucks Multi-Pick ÀÖÆ÷¡£ Multi-Pick ÒôÉ«¶ÔÁ¦¶ÈÃô¸Ð£¬ÒÔ²»Í¬Á¦¶ÈÇû÷ÇÙ¼ü»á´¥·¢ÒÔ²»Í¬·½Ê½µ¯×àµÄ²ÉÑù¡£
¨C Telechords Îļþ¼Ð°üº¬Ðí¶àʹÓà Telecaster Thinline Â¼ÖÆµÄºÍÏÒ Patch¡£Ë«ÒôºÍÏÒÊǽö°üº¬¸ùÒôºÍСÈý¶È»ò´óÈý¶ÈµÄÑù±¾£¬Ïà¸ôÒ»¸ö°Ë¶È£¬Õâ¶ÔÓÚ»·¾³ÒôÀÖÀ´ËµÊÇÒ»ÖÖÌØ±ðÓÐÓõÄÉùÒô¡£´óºÍÏÒÓ³ÉäÔÚ×ÏÉ«¼üÉÏ£¬Ð¡ºÍÏÒÓ³ÉäÔÚÂÌÉ«¼üÉÏ¡£ÇáÇáÇû÷ÇÙ¼ü»á²úÉú¹ö¶¯µÄºÍÏÒ¡£
ÖØÒªÌáʾ£º±¾²úÆ·ÐèÒªÍêÕû°æµÄ Kontakt 6.5.2 »ò¸ü¸ß°æ±¾£¡
³ýÁËÔÚÑÝʾģʽÏ£¬ËüÔÚÃâ·Ñ Kontakt ²¥·ÅÆ÷Öв»Æð×÷Óá£
An incredible tool for creating beautiful evolving cinematic guitars
Zero-G Impromptu Electric Guitars is a cinematic Kontakt 6 instrument featuring 21 patches and over 8GB of samples. IEG is dedicated to the creation of complex guitar-based, ever-evolving soundscapes.
Three exceptional guitars (including an electric Baritone) were sampled in great detail at 48kHz/24bit, using condenser and ribbon microphones and processed through a large number of guitar pedals.
The centrepiece of IEG is the Impromptu Engine; a system that utilises loops of improvised, un-synced snippets combined with a granular synthesizer.
We recorded improvised performances in three different intensity layers that you are able to crossfade between using the central knob which is mapped to the mod-wheel by default.
Playing a note with the mod-wheel completely down will trigger a sparse improvised loop on that pitch; start moving the mod-
wheel up to gradually crossfade to the medium and finally, to the dense layer.
Other than the intensity, the layers were also sampled playing the instrument in different ways: the sparse layer was recorded playing the guitar with fingers, the medium layer was recorded using a soft, smooth, wooden pick while the dense layer was recorded using a thick, hard plastic pick.
BARITONE EXTRAS
The Baritone Extras folder contains three instruments obtained processing the baritone electric guitar through a series of guitar pedals. For these instruments, an SFX section is available. These effects can be triggered using the red keys in latch mode.
PADS
The Pads folder contains five instruments dedicated to creating guitar-based soundscapes. A multi-shape LFO is included to create movement and variation in the sound, its intensity can be controlled by the MOTION knob,
Turning the knobs left or right adds the corresponding shape to the LFO amplitude modulation, thus creating complex shapes.
The rectangle waveform has pulse width (PW) control. The LFO is synchronised to the host and its frequency can be changed (FREQ).
EXTRA INSTRUMENTS
¨C The folder Reverse Sync contains 4 and 8 bars, tempo-synced reversed samples that can be used as risers and transitions in your music.
¨C The folder Strat Extras contains single Harmonics plucks and a Strat Plucks Multi-Pick instrument. The Multi-Pick patch is velocity-sensitive and hitting the key with different velocities will trigger samples plucked in different ways.
¨C The folder Telechords contains a number of chordal patches recorded using a Telecaster Thinline. The two-note chords are samples containing only the root note and the minor or major third, one octave apart, which is an especially useful voicing for ambient music. Major chords are mapped on the purple keys, minor chords are mapped on the green keys. Hitting the key softly will produce a rolled chord.
IMPORTANT: This product requires the FULL version of Kontakt 6.5.2 or higher!
It will not work in the FREE Kontakt Player, except in DEMO Mode.
https://aaxtorrent.net/2020/12/zero-g-impromptu-textural-percussions-kontakt/ |
