Output Movement v1.0.3 MacOSX ½Ú×àFX²å¼þ
MovementÊÇÒ»¸öÁîÈËÐ˷ܵÄFX²å¼þ£¬¿ÉΪÈκÎÊäÈëʵʱÌí¼ÓÇ¿´óµÄ½Ú×à¡£ רΪ¹¤×÷ÊÒ»òÎę̀´òÔ죬ʹÓÃÒýÇæÎªÈκιìµÀ»òÏÖ³¡±íÑÝ×¢ÈëÉúÃü¡£ 4¸ö½Ú×àÒýÇæÊ¹ÓòàÁ´£¬OutputרÓеÄFluxģʽ£¬LFO£¬Step SequencerºÍMacros½øÐÐÁËÎÞ·ì»ìºÏ£¬ÒÔÌṩ¸É¾»µÄÌåÑé¡£
ʹÓÃXYºêµæ¼´Ê±µ÷ÕûÉùÒô£¬¸Ãºêµæ¿ÉÒ»´Î¿ØÖƶà´ï152¸ö²ÎÊý¡£ Ä£Ä⽨ģµÄfxÓÅ»¯µ÷ÖÆ¡£ ͨ¹ý»ìÏìÔö¼Ó½Ú×à¸Ð£¬²¢Ñ¹Ëõ£¬±ÃËÍ£¬¹ýÂËÆ÷ºÍEQµÄ´ò¿ªºÍ¹Ø±Õ£¬ÑÓ³Ù±äÐÎÒÔ¼°µç×Ó¹ÜÊ§ÕæµÄ¼ÓÈȺÍÀäÈ´¡£ ½«ÈÎÒâÊý×ÖÍϷŵ½76¸öÐýÅ¥ÖеÄÈκÎÒ»¸öÉÏ£¬¾ù¿ÉÇáËɽøÐе÷ÖÆ¡£ ´ÓÂ˲¨Æ÷½ØÖ¹µÄ±ê×¼ÕýÏÒ²¨µ½Ê§Õæ½ôËõµÄ32²½ÈýÖØÒô£¬ÔÙµ½¹ÄÑ»·µ÷ÖÆÒôÁ¿¡£
Output Movement
Output
V 1.1.0.4
MacOS
Instructions: Attached.
Movement is an exciting FX plugin that adds powerful RHYTHMS to any input in real-time. Built equally for the studio or stage, use the engine to breathe life into any track or live performance.
MOVEMENT is an extremely powerful and innovative tool crafted to be simple, intuitive and easy to use. Dial in a rhythm from one of 300+ presets or build from scratch using Flux, Sidechain, LFO or Step Sequencer rhythm modulation, then use the XY pad to tweak up to 152 parameters in real time. Perform live with it, automate it in your DAW or just find the perfect blend of the original input and the rhythms.
¡°MOVEMENT is not only powerful but also incredibly musical,¡± says Output Founder Gregg Lehrman. ¡°Whether you¡¯re slowly bringing in and out subtle motion or adding insane movement, you¡¯ll find that each and every rhythm combination is first and foremost musical.¡±
MOVEMENT Features:
+ 300+ Presets for instant playability.
+ Input any sound, instrument or track.
+ Modulate any parameter with any rhythm in real time.
+ Sidechain, LFO, Step Sequencer rhythm modulation.
+ Output¡¯s proprietary Flux and Randomizer.
+ Advanced sidechain modulation ¨C modulate any parameter.
+ Analog filters, EQ, delay, distortion, compression and reverb effects.
+ XY pad for performance.
+ Built for live performance and for the studio.
+ Simple design and ease of use.
https://crackedvst.com/audio-plugins/output-movement-mac/ |
