Iam Lamprey Achromic for Kontakt and NEAT Player ½ðÊôÓ²ºË½Ú×༪Ëû
Achromic ÊÇÒ»¸ö¼ªËû¿â£¬×¨×¢ÓÚÓÃÓÚ½ðÊô»òÓ²ºËÖÆ×÷µÄ¼¤½ø½Ú×༪Ëû¡£ËüרÃÅÕë¶Ô¼ªËû¿âÖг£¼ûµÄ¹Ø¼üÎÊÌ⣬ÀýÈçÈõ²¦Æ¬¹¥»÷ºÍ¹ýÓÚ¸´ÔÓµÄÑÝ×àÒýÇæ¡£
Achromic ÊÇÄúÖ»ÐèÒªËÙ¶È¿ìÇÒÒôÖʳöÉ«µÄ½Ú×༪ËûµÄ½â¾ö·½°¸¡£
¿É×÷Ϊ NEAT Player µÄ¶ÀÁ¢¿â»ò×÷Ϊ Kontakt ¿âʹÓá£
Çë×¢Ò⣺Achromic Êä³ö DI Ðźš£Äú½«ÐèÒªÒ»¸ö¼ªËû·Å´óÆ÷²å¼þ£¨»òʹÓà Kontakt µÄÄÚÖòå¼þ£©¡£×Ô 2020 Äê 1 Ô 15 ÈÕÆð£¬ÎÒ½«²»ÔÙÏòÌø¹ý´ËÒªÇóµÄÈËÍ˿
·ÇÖØ¸´Ñ»·£º
²¥·ÅÒýÇæÊ¹Ó÷ÇÖØ¸´Ëã·¨ÒÔÑ»··½Ê½ÔÚÈÎÒ»²à²ð·Ö 2 ¸öÑù±¾¡£Õâ»á²úÉú±ÆÕæµÄÉùÒô²¢Ïû³ý¡°»úǹ¡±Ð§¹û¡£
No Weak Picking£º
³ýÁ˳£¹æ²ÉÑùÖ®Í⣬ÎÒ»¹Â¼ÖÆÁ˵¥¶ÀµÄÎÞµ÷²¦Æ¬¹¥»÷£¬ÒÔµþ¼ÓÔÚÔʼÒô·ûÖ®ÉÏ¡£×Ô¶¨ÒåÓû§½çÃæÔÊÐíÍêÈ«¿ØÖÆÕâЩ¸½¼ÓÑù±¾µÄÒôÁ¿£¬ÒÔ±ãÔÚÄúÐèÒª»ý¼«ÌôÑ¡ÒÔÏû³ýÑÏÖØµÄ·Å´óÆ÷Ê§ÕæÊ±¡£Õâ¸öÏàͬµÄÐýÅ¥»¹¿ØÖÆÍ¨¹ýºó¶ËµÄ˲̬ÕûÐÎÆ÷Ч¹ûÓ¦ÓÃµÄÆðÒô¼¶±ð£¬´Ó¶ø²úÉú¸ü¶àµÄÌôÐÆÐÔ¡£Ã»Óиü¶àµÄÈõ²ÉÕª£¡
¼òµ¥Ð´·¨£º
ûÓа´¼ü¿ª¹Ø¡£ÊÖÕÆ¾²ÒôʹÓõÍËÙ£¬ÑÓÒôʹÓøßËÙ¡£¶îÍâµÄ¹Ø½ÚÓ³Éäµ½²ÊÉ« FX ¼ü£¨Èç Pick Scrapes »ò Dead Notes£©¡£Achromic ´ÓÍ·¿ªÊ¼Éè¼Æ£¬ÒÔ¾¡¿ÉÄÜ¿ìµØÊéд¡£
Fret Noise ºÍ Release Samples£º
¶îÍâµÄÔëÒôÑù±¾±»µ¥¶À¼Ç¼£¬²¢ÓÐËæ»ú»ú»áÔÚÊÍ·Åʱ´¥·¢¡£ÕâЩÉùÒôµÄÒôÁ¿ºÍË¥¼õ¿ÉÒÔͨ¹ý½çÃæÉ쵀 Fret Noise Knob ½øÐпØÖÆ¡£
Force Downpick£º
¶ÔÓÚÐèÒªÓÃÁ¦ÃÍ»÷µÄ¼´ÐËÑÝ×࣬Force Downpick ¿ª¹Ø¿ÉÒÔʹÉϳå³Ì·¢Òô¾²Òô¡£Õâ¿ÉÒÔʹÓÃÈκΠDAW µÄÄÚÖÃ×Ô¶¯»¯½øÐÐ×Ô¶¯»¯¡£
ÍäÒô¼üºÍ FX ¼ü£º
ʹÓÃÈκΠMIDI ¿ØÖÆÆ÷ÍäÇúÒô¸ß£¬»òʹÓà DAW ×Ô¶¯»¯¡£Achromic »¹°üÀ¨¶îÍâµÄ FX ¼ü£¬Èç Pinch Harmonics¡¢Pick Scrapes ºÍ Dead Notes¡£
½öÖ±½ÓÐźţº
Achromic Êä³öÔʼÐźŠ(DI)£¬ÄúÐèÒªÌṩ×Ô¼ºµÄÔöú·Å´óÆ÷»òÄ£Ä⣬²ÅÄÜÕæÕýÖÆ×÷³öÊôÓÚÄú×Ô¼ºµÄÉùÒô¡£
ÌØµã£º
ÕæÕýµÄÁ¢ÌåÉù£¬·ÇÖØ¸´Ñ»·Ëã·¨¡£
¾ßÓÐÇ¿ÖÆÏòϼðÑ¡ÉèÖõı¸ÓüðÑ¡ÒýÇæ¡£
µ¥¶À¼Ç¼ Pick Attack Ñù±¾ºÍ Transient Control¡£
±ÆÕæµÄ Fret ºÍ Release ´¥·¢Ñù±¾¡£
F1-D6 ·¶Î§
×¨ÒµÖÆ×÷ºÍ´¦ÀíµÄÑù±¾
¸½¼Ó FX ¼ü£¬Èç Scrapes¡¢Dead Notes ºÍ Quick Slides¡£
×Ô¶¯»¯½Ó¿Ú¡£
Êä³öÒ»¸ö¸É¾»µÄ DI ÐźŽøÐзŴó¡£
Kontakt 5.8 »ò¸ü¸ß°æ±¾£¨ÐèÒªÍêÕû°æ±¾£©¡£
ʲôÊÇ NEAT PLAYER£º
×Ô´Ó¿ªÉèÉ̵êÒÔÀ´£¬ÓкܶàÈËÎÊÎÒ¹ØÓÚÎÒµÄÀÖÆ÷µÄ¶ÀÁ¢ VST °æ±¾¡£ÎÒÍêÈ«Àí½â²¢Í¬ÇéÄãÃÇÕâЩ¸ºµ£²»Æð»ò¸ù±¾²»ÏëʹÓà Kontakt µÄÈË£¬¶øÇÒÎÒµ±È»ÎÞ·¨Ö§¸¶¿ª·¢Õß·ÑÓÃÀ´ÔÚ Free Kontakt Player Éϰ²×°ÎҵĿ⡣
Òò´ËÎÒ¸øÄãÎҵĽâ¾ö·½°¸£ºNEAT Player£¡
NEAT£¨ÉõÖÁûÓÐÊʵ±µÄ±êÌ⣩²¥·ÅÆ÷Ŀǰ´¦ÓÚ Windows VST2 ºÍ VST3 ¸ñʽµÄ²âÊÔ°æÖУ¬Mac °æ±¾ÉÔºóÍÆ³ö¡£
×¢Ò⣺°üº¬´Ë¿âµÄ NEAT Player ºÍ hr1 Îļþ¡£
Achromic is a guitar library focused on aggressive rhythm guitars for metal or hardcore productions.
It specifically targets key issues often found in guitar libraries such as weak pick-attack and overly-complicated playing engines.
Achromic is the answer for when you just need rhythm guitars fast and sounding great.
Available as a standalone library for the NEAT Player, or as a Kontakt Library.
PLEASE NOTE: Achromic outputs a DI signal. You will need a guitar amp plugin (or use Kontakt¡¯s in-built one). As of 15/01/2020 I will no longer be refunding people that skip over this requirement.
Non-Repeating Round Robin:
The playback engine uses a non-repeating algorithm to split 2 samples either side in a round-robin fashion. This results in a realistic sound and removes the ¡°machine-gun¡± effect.
No Weak Picking:
In addition to regular sampling, I went in and recorded individual atonal pick attacks to layer on top of the original notes. The custom user-interface allows complete control over the volume of these additional samples for when you need aggressive picking to cut through heavy amp distortion. This same knob also controls the level of Attack applied through a Transient Shaper effect on the backend, resulting in even more pick aggression. No more weak picking!
Simple Writing:
No keyswitches. Use low-velocity for palm mutes and high velocity for sustains. Additional articulations are mapped to the coloured FX keys (like Pick Scrapes or Dead Notes). Achromic is designed from the ground-up to be as fast as possible for writing purposes.
Fret Noise and Release Samples:
Additional noise samples were individually recorded and have a random chance to trigger on release. The volume and decay of these sounds can be controlled with the Fret Noise Knob on the interface.
Force Downpick:
For riffs that need to slam extra hard, the Force Downpick switch mutes the up-stroke articulations. This can be automated using any DAW¡¯s inbuilt automation.
Pitch-Bend and FX Keys:
Bend the pitch with any MIDI controller, or use DAW automation. Achromic also includes additional FX keys like Pinch Harmonics, Pick Scrapes and Dead Notes.
Direct Signal Only:
Achromic outputs a raw signal (DI), you¡¯ll need to provide your own sweet-sounding amps or simulations to really make the sound your own.
FEATURES:
True Stereo, Non-Repeating Round Robin Algorithm.
Alternate Picking engine with Force Downpick setting.
Seperately recorded Pick Attack samples and Transient Control.
Realistic Fret and Release trigger samples.
F1-D6 Range
Professionally produced and processed samples
Additional FX keys like Scrapes, Dead Notes and Quick Slides.
Automatable Interface.
Outputs a clean DI Signal for reamping.
Kontakt 5.8 or later (FULL VERSION REQUIRED).
What is NEAT PLAYER:
Since launching the store, I¡¯ve had numerous people ask me about a standalone VST version of my instruments. I completely understand and sympathize with those of you who cannot afford, or simply don¡¯t wish to use Kontakt, and I certainly can¡¯t afford to pay the developer fees to get my libraries on the Free Kontakt Player.
Therefore I give you my solution: the NEAT Player!
NEAT (Not Even Appropriately Titled) Player is currently in beta for Windows VST2 and VST3 formats, with Mac versions coming later.
NOTE: NEAT Player and hr1 file for this library are included. |
