Echo Sound Works Sub Zero 808 v1.5 WAV KONTAKT 808¹Ä»ú
ÓÃÓÚ Kontakt µÄ 808 ºÍ³¬µÍÒô¿â ÕÒµ½ÍêÃÀµÄ 808 ¿ÉÄܺÜÀ§ÄÑ£¬µ«ÏÖÔÚ²»ÊÇÁË¡£ÎÒÃÇÖÆ×÷ Sub Zero 808 ÊÇÒòΪÎÒÃÇ×÷ÎªÖÆ×÷ÈË£¬ÏëÒªÒ»ÖÖ¸üºÃ¡¢¸ü¿ìµÄ·½Ê½À´·ÅÖÃÎÒÃÇµÄ 808¡£
ÎÒÃÇ×ܹ²ÎªÕâ¸ö¿âÖÆ×÷ÁË 200 ¶à¸öÔ¤É裬µ«Ö»±£ÁôÁË×îºÃµÄ¡£ÎÒÃÇÈÓµôÁËÈκÎûÓгɹ¦µÄ¶«Î÷¡£
ÄúÐèÒªµÄËùÓпؼþ¶¼ÔÚÒ»¸ö¼òµ¥µÄ½çÃæÖÐ
¨C Sub Zero 808 ×°ÓÐ 150 ¸ö¿ÉÁ¢¼´Ê¹ÓõÄÔ¤Éè
¨C Sub Zero 808 ÊÊÓÃÓÚÈκÎÀàÐ͵ÄÒôÀÖ ¨C Hip Hop¡¢Trap¡¢RnB¡¢EDM¡¢Pop
¨C Sub Zero 808 µÄÉè¼ÆÒ×ÓÚʹÓà ¨C Òò´ËÄú¿ÉÒÔרעÓÚÖÆ×÷ÒôÀÖ
3ÖÖÀàÐ͵ÄÔ¤Éè
¨C 808s£ºÕâЩÊÇÄúÔÚÏñ Sub Zero 808 ÕâÑùµÄ¿âÖÐËùÆÚÍûµÄ¾µä¡¢ÖØ»÷¡¢½ÚÅ͍Òå 808
¨C No Kicks£ºÃ¿¸ö 808 ¶¼ÓÐÒ»¸öËæ¸½µÄ¡°No Kick¡±°æ±¾£¬·Ç³£ÊʺÏÄúµÄÇúÄ¿ÒѾÓÐÄúϲ»¶µÄ
µ×¹Ä ¨C Clean Subs£ºÓÐʱÄúÖ»ÐèÒªÒ»¸ö¼òµ¥¶øÍêÕûµÄµÍÒôÅÚ£¬Õâ¾ÍÊÇÎÒÃÇÖÆ×÷ÕâЩµÄÔÒò¡£Êʺ϶àÖÖÀàÐ굀 EDM
ÿÄê¶¼»áÌí¼ÓеÄÔ¤Éè
808 ÊǶÀÒ»ÎÞ¶þµÄ¡£ËüÃǵı仯ºÍÑݱä±ÈÎÒÃÇÄÜÏëµ½µÄÈÎºÎÆäËûÉùÒô¶¼Òª´ó¡£Ê±ÉÐ808ÔÚ2020Äê×öµÄÏñʲôÿ¸öÈ˶¼¿ÊÍûÔÚ2017ÄêʹÓÃûÓÐÈκÎÉùÒô£¬Õâ¾ÍÊÇΪʲôÎÒÃÇÿÄê¶¼Ôö¼ÓеÄÔ¤Ö÷ÖÁã808¡£
µ÷ÕûºÃ²¢×¼±¸¿ªÊ¼
ÿ¸öÔ¤Éè¶¼ÒѾ¹ýµ÷Õû£¬¿ÉÒÔΪÄúµÄµÍÒôÏß×öºÃ×¼±¸¡£
Èç¹ûÄãÐèÒª£¬ÎÞ¾¡µÄά³Ö
ÎÒÃÇÈÃÄú¿ÉÒÔËæÐÄËùÓûµØÊ¹ÓÃÕâЩ 808¡£
Èç¹ûÄúÐèÒª£¬¼¸ºõÿ¸ö²¹¶¡¶¼»áÎÞÐÝÖ¹µØÎ¬³ÖÏÂÈ¥¡£Ö»Ðèµ÷¸ßÑÓÒôÐýÅ¥²¢°´×¡¸ÃÒô·û¼´¿É¡£
ÓÉ 2,518 ÐдúÂëÌṩ֧³Ö
Sub Zero 808 ΪÄúÍê³É·±ÖصŤ×÷£¬Òò´ËÄú¿ÉÒÔרעÓÚ×Ô¼º×îÉó¤µÄÊÂÇ飬¼´ÖÆ×÷ÒôÀÖ¡£
×¢Ò⣺ÐèÒªÍêÕû°æ KONTAKT 5.7.3 ¼°¸ü¸ß°æ±¾£¡
808 & Sub Bass library for Kontakt
Finding the perfect 808 can be hard, but not anymore. We made Sub Zero 808 because we as producers, wanted a better, faster way of laying down our 808¡¯s.
We made over 200 presets in total for this library, but only kept the best of the best. We threw away any that didn¡¯t make the cut.
Perfect Low End Starts Here
All of the control you need in one simple interface
¨C Sub Zero 808 is loaded with 150 Presets that are immediately useable
¨C Sub Zero 808 will work for Any Genre of Music ¨C Hip Hop, Trap, RnB, EDM, Pop
¨C Sub Zero 808 was designed to be Easy To Use ¨C So you can focus on making music
3 types of presets
¨C 808s: These are your classic, heavy hitting, beat defining 808¡¯s you¡¯d come to expect in a library like Sub Zero 808
¨C No Kicks: Each 808 has an accompanying ¡°No Kick¡± version which is perfect for when your track already has a kick that you like
¨C Clean Subs: Sometimes you just need a simple, yet full sounding sub bass and that¡¯s why we made these. Perfect for multiple genres of EDM
New presets added every year. For free
808¡¯s are unique. They change and evolve more than any other sound we can think of. Trendy 808¡¯s in 2020 don¡¯t sound anything like what everyone was aspiring to use in 2017.
That¡¯s why we add new presets to Sub Zero 808 each year for free.
Tuned and ready to go
Each preset has been tuned and is ready for your bassline.
Endless sustains if you need them
We give you the freedom to work with these 808s how you want.
Almost every patch will sustain endlessly if you need it to. Just turn up the sustain knob and hold that note down.
Powered by 2,518 lines of code
Sub Zero 808 does the heavy lifting for you so you can focus on what you do best, make music.
https://www.androvinsoft.com/202 ... b-zero-808-v15.html
NOTE: REQUIRES THE FULL VERSION KONTAKT 5.7.3 AND HIGHER! |
