Ayaic Ceilings Of Sound PRO v0.5.3 WIN EQЧ¹ûÆ÷
Ceilings Of Sound PRO ²ÉÓÃÕæÕý¶ÀÌØµÄ·½·¨À´¾ùºâÉùÒô£¬²¢ÇÒÊǵÚÒ»¸ö½«ÔëÉùƵÆ×ºÏ²¢Îª¾ùºâ¡°ÐýÅ¥¡±µÄ¾ùºâÆ÷¡£15 ¸öÓû§¿É¶¨ÒåµÄÌ컨°åƵ¶Î£¬Ã¿¸öƵ¶Î°üº¬ 49 ¸öÔëÉùбÂÊ£¬¿ÉÈÃÄú´´½¨Éù²¨Ì컨°åÐÎ×´£¬Çý¶¯ 50/31 Ƶ¶ÎÏßÐÔͼÐξùºâÆ÷µÄÉèÖ᣾ùºâÆ÷ÒÔ 0 ÑÓ³Ù¡¢µÍ CPU ¸ºÔØÔËÐУ¬µ«ÈÔ¾ßÓи߾«¶È£¬¼´Ê¹ÔÚÕæÕýÖØÒªµÄµÍƵÏÂÒ²ÊÇÈç´Ë¡£¡°Ê¹ÆµÆ×·ûºÏÌ컨°å¡±¹¦ÄÜÖ»Ðèµ¥»÷һϰ´Å¥£¬¼´¿ÉʹÄúµÄ EQ ·ûºÏÌ컨°åÐÎ×´¡£49 ¸öÌ컨°åµ¼¹ì¿É°ïÖúÄúƽºâÌ컨°åÐÎ×´£¬ÒÔ±ÈÒÔÍù¸ü¿ì¸üºÃµØÆ½ºâ¡£ÕâÒâζ×ÅÎÞÂÛÄúʹÓõÄÊÇÎÒÃÇÊý°ÙÖÖÔ¤ÉèÖеÄÒ»ÖÖ£¬Äú×Ô¼º´´½¨µÄÔ¤ÉèÖ®Ò»»òÔÚ»ìÒô/ĸ´øÖÆ×÷¹ý³ÌÖмòµ¥µØ²Ù×ÝԭʼÒôƵµÄÌ컨°åÐÎ×´£¬ÍêÃÀ¾ùºâÖ»Ðè¡°µã»÷¡±¼´¿É¡£ÎÒÃÇÈ·ÐÅ£¬Ò»µ©Äú¿ªÊ¼Ê¹Óà Ceilings Of Sound PRO£¬Äú¾Í»áºÜ¿ì·¢ÏÖΪʲôËü±»³ÆÎª Hyper-EQ¡£
Ceilings Of Sound PRO takes a truly unique approach to equalizing sound and is the first equalizer to incorporate the spectrum of noise as equalization ¡°knobs¡±. 15 user-definable ceiling bands containing 49 noise-slopes each allow you to create sonic-ceiling shapes that drive the settings of a 50/31-band Linear Graphic Equalizer. The EQs operate at 0 latency, low CPU load yet are hi-precision, even at the low frequencies where it really matters. A ¡°conform spectrum to ceiling¡± feature conforms your EQ to your ceiling shape with a click of a button. 49 ceiling guides help you balance your ceiling shapes to equalize faster and better than ever. This means whether you¡¯re working with one of our hundreds of presets, one of your own created presets or simply manipulating the ceiling shape of your raw audio during mix-down/mastering, perfect equalization is a ¡°click¡± away. We are certain that once you beginning using Ceilings Of Sound PRO you¡¯ll quickly discover why it¡¯s called a Hyper-EQ.
https://bondibeachau.com/ayaic-ceilings-of-sound-pro-v0-5-3-win/
