Jon V Audio Fircomp 2 vst3 Mac update May 16 2021 [MacOSX WIN] ·åֵѹËõÆ÷/ÏÞ...
Jon V Audio Fircomp 2 vst3 Mac update May 16 2021 [MacOSX WIN] ·åֵѹËõÆ÷/ÏÞÖÆÆ÷
³¬¸É¾»µÄ·åֵѹËõÆ÷/ÏÞÖÆÆ÷£¬¾ßÓÐÇ¿¾¢µÄÆðÒô¡¢ÒôÀÖÊͷźͿÉÑ¡µÄǰհƽ»¬£¬ÊÊÓÃÓÚ¹ìµÀ»ò×ÜÏß¡£Áã/µÍÑÓ³ÙºÍµÍ CPU¡£
¡ö ¿ìËÙ»òÏàͬÑù±¾µÄÆô¶¯Ê±¼ä£¬¼´Ê¹ÔÚÁãÑÓ³ÙģʽÏÂÒ²²»»áÌýÆðÀ´¡°
ßÇßÕ¡±Éù¡ö ÉõÖÁ±È Fircomp 1 ¸ü¸É¾»¡£Á½Õß¿ÉÒÔ²¢ÅÅʹÓÃ
¡ö ´´ÐµÄÊý×Ö°üÂç¼ì²âÔÊÐí±ÈµäÐ͵ķåֵѹËõÆ÷µÍµÃ¶àµÄÊ§Õæ£¬Ã»Óйý³å»òÖͺó
¡ö ¿ÉÑ¡µÄǰհ FIR ÔöÒæÆ½»¬£¬ÒÔ»ñµÃ¸üÇåÎúµÄÉùÒô
¡ö ¿ÉËÜÐÎÊͷŽ׶Σ¬¾ßÓÐÒôÀÖÐÔ¡¢¸ß¶ÈÒÀÀµÓÚÀúÊ·µÄÐÐΪ¡£±ÜÃâ´®ÁªÊ¹Óöą̀ѹËõ»ú£¡
¡ö ²àÁ´ Hipass Â˲¨Æ÷ºÍÍⲿ²àÁ´ÄÜÁ¦
¡ö ´øÓÐÁ¢ÌåÉùÁ´½ÓºÍƽºâµÄ¼òµ¥Á¢ÌåÉùÑ¡Ïî
¡ö ÖÐ/²à´¦Àíģʽ
¡ö ¸ÐÖªÏì¶È¼ÆÁ¿£¬¾ßÓмòµ¥µÄ²¹³¥ÔöÒæºÍƽºâ²¶×½
¡ö ¿ÉÇл»µÄ´¹Ö±»òˮƽÔöÒæË¥¼õ¼ÆÁ¿£¬¾ßÓпɵ÷·¶Î§
¡ö ¿ìËÙ¼ÓÔØÔ¤É裬Ͱ±È½Ïϵͳ
¡ö ʹÓÿɵ÷Õû´óСµÄ GUI£¬¿É×Ô¶¨ÒåÑÕÉ«ºÍ±³¾°Í¼Æ¬£¡
¡ö µÍCPU£¬È«64λDSP´úÂ룬³ä·ÖÀûÓÃSSEÖ¸Áî¡£ºÁ²»ÓÌÔ¥µØ²åÈëÿÊ×ÇúÄ¿£¡
¡ö ¹Ø±ÕǰհµÄÁãÑÓ³Ù¡£ÆôÓÃǰհ£¬²¹³¥ÑÓ³ÙΪ 1.5 ºÁÃë
¡ö ÒôƵÐÅºÅµÄÆµÂÊÏìӦûÓÐÏàÒÆ»ò±ä»¯
¸ü¸ÄÈÕÖ¾£º
½ñÌì·¢²¼ÁË fircomp 2 µÄÒ»¸öС¸üУ¬ÓÐһЩСµÄ¸Ä½ø£¬ÒÔ¼°Ò»¸öеġ°ñîºÏ·åÖµ¡±Ä£Ê½£¬ÕâÊDZê׼ģʽµÄÇá΢±ä»¯
Ultra clean peak compressor/limiter with punchy attack, musical release, and optional lookahead smoothing, for tracks or busses. Zero/low latency and low CPU.
¡ö Fast or same-sample attack times that never sound ¡°clicky¡±, even in zero latency mode
¡ö Even cleaner than Fircomp 1. Both can be used side-by-side
¡ö Innovative digital envelope detection allows for much lower distortion than typical peak compressors, without overshoot or lag
¡ö Optional lookahead FIR gain smoothing for an even cleaner sound
¡ö Shape-able release stage with musical, highly history-dependent behaviour. Avoids use of multiple compressors in series!
¡ö Sidechain hipass filter and external sidechain ability
¡ö Easy stereo options with stereo link and balance
¡ö Mid / side processing mode
¡ö Perceived loudness metering, with easy makeup gain and balance snapping
¡ö Switchable vertical or horizontal gain reduction metering, with adjustable range
¡ö Quick loading of presets, bucket comparison system
¡ö Make it yours, with a resizable GUI, customizable colours and background image!
¡ö Low CPU, fully 64-bit DSP code, making full use of SSE instructions. Insert on every track without a second thought!
¡ö Zero latency with lookahead off. With lookahead on, compensated latency of 1.5ms
¡ö No phase shift or change in frequency response of the audio signal
Change log:
Released a small update to fircomp 2 today, with some minor improvements, and a new ¡°coupled peak¡± mode which is a slight variation of the standard mode
https://looptorrent.net/jon-v-audio-fircomp-2-vst3-x64/
